  3. Repeater node crashes
16 Posts 3 Posters 4.8k Views 3 Watching
  • mimaretM mimaret
    @rejoe2 Thank you for your reply.
    I seemed to have read that for a repeater it was necessary to replace delay () by wait (). . .
    I will adapt my program according to your recommendations and keep you informed.
    @mimaret could you post the debug output from before and during the crash?
    What you're doing should work. The debug output usually gives useful info on why things don't work the way they are supposed to.
    Also, check the power problem flowchart on the page @rejoe2 linked earlier. PA_MAX puts very high stress on the power supply. My guess is that this is related to insufficient power stability.
    • mimaretM
      mimaretM
      mimaret
      @mfalkvidd Thank you for your reply.
      I do not think about power problem. The power supply can deliver 1A and I mounted a capacitor of 470 uF on the 3.3v and a 47 uF close to the radio module. I had doubts about hardware and I set up a second repeater.
      On the first repeater, radio module nrf24L01 + PA + LNA. On the second repeater, radio module nrf24L01 +. Same problem.
      When the repeater crashes, the interrupt is executed again. The led pin 13 that I do not manage is ON during normal operation and goes OFF when the repeater crashes.
      I noticed that by disabling the interrupt (// attachInterrupt (....), the repeater does not crash.
      I will look how to check the state of memory, stack, etc.
      I also include the debug output and I do not see anything particular.
      Home Assistant, Raspi MQTT Gateway , nodes MySensors
      • mimaretM
        mimaretM
        mimaret
        OOPS :
        19820560 TSF:MSG:SEND,111-111-0-0,s=2,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:0
        ------> Door
        ------> Door
        19825700 TSF:MSG:SEND,111-111-0-0,s=2,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:1
        ------> Door
        19826745 !TSF:MSG:SEND,111-111-0-0,s=2,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=NACK:0
        ------> Door
        19826745 TSF:MSG:SEND,111-111-0-0,s=2,c=1,t=16,pt=2,l=2,sg=0,ft=1,st=OK:0
        19826747 TSF:MSG:READ,255-255-255,s=255,c=7,t=255,pt=7,l=25,sg=1: 0
        19826755 !TSF:MSG:LEN,7!=32
        ------> readDHT
        20105310 TSF:MSG:SEND,111-111-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:42.4
        H: 42.40
        ------> read1Wire
        20105426
        ------> readDHT
        20405309 TSF:MSG:SEND,111-111-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:21.8
        T: 21.80
        20405323 TSF:MSG:SEND,111-111-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:42.1
        H: 42.10
        ------> read1Wire
        20405440
        20700045 TSF:SAN:OK
        ------> readDHT
        20705310 TSF:MSG:SEND,111-111-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:41.9
        H: 41.90
        ------> read1Wire
        20705427
        ------> Door
        20707352 !TSF:MSG:SEND,111-111-0-0,s=2,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=NACK:1
        ------> Door
        20707352 TSF:MSG:SEND,111-111-0-0,s=2,c=1,t=16,pt=2,l=2,sg=0,ft=1,st=OK:0
        ------> Door
        20723965 TSF:MSG:SEND,111-111-0-0,s=2,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:1
        ------> Door
        20725862 TSF:MSG:SEND,111-111-0-0,s=2,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:0
        ------> Door
        <------------------------------------CRASH-----------------
        ------> Door
        20729143 TSF:MSG:SEND,111-111-0-0,s=2,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:1
        ------> Door
        20730232 TSF:MSG:SEND,111-111-0-0,s=2,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:0
        ------> Door
        • mimaretM mimaret
          OOPS :
          ------> Door
          ------> Door
          ------> Door
          ------> Door
          ------> readDHT
          H: 42.40
          ------> read1Wire
          20105426
          ------> readDHT
          T: 21.80
          H: 42.10
          ------> read1Wire
          20405440
          20700045 TSF:SAN:OK
          ------> readDHT
          H: 41.90
          ------> read1Wire
          20705427
          ------> Door
          ------> Door
          ------> Door
          ------> Door
          ------> Door
          ------> Door
          ------> Door
          ------> Door
          @mimaret could you describe what you mean ny "crash"? I thought you meant that the node rebooted, but I see now that my assumption was wrong.
          • mimaretM
            mimaretM
            mimaret
            In fact, the node no longer executes the program and the only solution is to restart it with a reset or switch off the power supply.
            • mimaretM mimaret
              @mimaret strange. The (re)start should be visible in the debug output. Did you cut it out?
              • mimaretM
                mimaretM
                mimaret
                There is no restart. Only the interrupt executes when I open the door contact. The Loop () does not continue. I did not cut anything, I just added the crash line as soon as the program stopped.
                • mimaretM mimaret
                  @mimaret thanks for explaining.
                  I think the problem lies in calling send from within the interrupt handler. Interrupt handlers are supposed to execute very quickly. Usually they just set a flag that there is work to be done, and return.
                  From https://learn.adafruit.com/multi-tasking-the-arduino-part-2/interrupt-etiquette
                  Code in the ISR should not call anything that requires interrupts to be active (e.g. delay() or anything that uses the i2c bus). This will result in hanging your program.
                  From the debug output, send fails. That means the node must have tried to send, waited for acknowledgement until timeout, tried to send again and waited and so on until the max number of attempts is reached. That's way too much time to spend inside an interrupt handler. And the radio use
                  Try to only set a variable inside the interrupt handler, and perform the send from inside loop instead.
                  Also see https://arduino.stackexchange.com/questions/30968/how-do-interrupts-work-on-the-arduino-uno-and-similar-boards/30969
                  • mimaretM
                    mimaretM
                    mimaret
                    A big thank you for your contribution. I modified the program according to your proposals. Everything is working. I am attaching you the pieces of code relating to the door contact.
                    My problem is solved.
                      attachInterrupt(digitalPinToInterrupt(DOOR_PIN), DoorMoving, CHANGE);
                      DoorChange = 1;
                      LastDoor = 0;
                    void DoorMoving() {
                        DoorChange = 1;
                    void readDoor() {
                      if (DoorChange) {
                        boolean Door = (digitalRead(DOOR_PIN));
                        if (Door != LastDoor) {
                          send(msgDoor.set((Door) == HIGH ? 1 : 0));
                          LastDoor = Door;
                          DoorChange = 0;
                      readDoor();
                      if (currentMillis - previousMillis >= UPDATE_INTERVAL) {
                        readDHT();
                        read1Wire();
                    • mimaretM mimaret
                        DoorChange = 1;
                        LastDoor = 0;
                      void DoorMoving() {
                          DoorChange = 1;
                      void readDoor() {
                        if (DoorChange) {
                            LastDoor = Door;
                            DoorChange = 0;
                        readDoor();
                          readDHT();
                          read1Wire();
                      @mimaret great work! Thanks for posting your solution.
