  2. Announcements
  • pepsonP
    pepsonP
    pepson
    Hi
    I start build MySensors Gateway on my Rpi3. I use radio RFM69HW and connected it as show on page to GPIO.
    https://www.mysensors.org/build/raspberry
    I build it by command:
    ./configure --my-transport=rfm69 --my-rfm69-frequency=868 --my-is-rfm69hw --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB1
    Then make. But in Domoticz when i run and add to hardware i have error:
    2017-12-27 17:05:09.419 MySensors: Using serial port: /dev/ttyUSB1
    2017-12-27 17:05:09.419 MySensors: Gateway Version: 2.2.0-rc.2
    2017-12-27 17:05:09.420 Error: Serial Port closed!... Error: End of file
    2017-12-27 17:05:10.419 MySensors: retrying in 30 seconds...
    2017-12-27 17:05:39.422 MySensors: Using serial port: /dev/ttyUSB1
    2017-12-27 17:05:39.422 Error: Serial Port closed!... Error: End of file
    2017-12-27 17:05:40.422 MySensors: retrying in 30 seconds...
    2017-12-27 17:06:09.425 MySensors: Using serial port: /dev/ttyUSB1
    2017-12-27 17:06:09.425 Error: Serial Port closed!... Error: End of file
    2017-12-27 17:06:10.425 MySensors: retrying in 30 seconds...
    2017-12-27 17:06:39.427 MySensors: Using serial port: /dev/ttyUSB1
    2017-12-27 17:06:39.428 Error: Serial Port closed!... Error: End of file
    2017-12-27 17:06:40.428 MySensors: retrying in 30 seconds...
    2017-12-27 17:07:09.430 MySensors: Using serial port: /dev/ttyUSB1
    2017-12-27 17:07:09.430 Error: Serial Port closed!... Error: End of file
    port ttyUSB1 is empty as i check.
    Please help me where is the problem...
    • pepsonP pepson
      Hi
      @pepson what output did you get when you tested the gateway?
      • pepsonP
        pepsonP
        pepson
        mysgw: Starting gateway...
        mysgw: Protocol version - 2.2.0-rc2
        mysgw: MCO:BGN:INIT GW,CP=RNNG---,VER=2.2.0-rc2
        mysgw: TSF:LRT:OK
        mysgw: TSM:INIT
        mysgw: TSF:WUR:MS=0
        mysgw: TSM:INIT:TSP OK
        mysgw: TSM:INIT:GW MODE
        mysgw: MCO:REG:NOT NEEDED
        mysgw: MCO:BGN:STP
        mysgw: MCO:BGN:INIT OK,TSP=1
        • pepsonP pepson
          mysgw: TSF:LRT:OK
          mysgw: TSM:INIT
          mysgw: TSF:WUR:MS=0
          mysgw: MCO:BGN:STP
          @pepson thanks. Nothing strange there. Anything i teresting in var/log/syslog after enabling debug output?
          • pepsonP
            pepsonP
            pepson
            Dec 27 21:11:48 domoticz systemd[1]: Stopping User Manager for UID 1000...
            Dec 27 21:11:48 domoticz systemd[715]: Stopped target Default.
            Dec 27 21:11:48 domoticz systemd[715]: Stopped target Basic System.
            Dec 27 21:11:48 domoticz systemd[715]: Stopped target Sockets.
            Dec 27 21:11:48 domoticz systemd[715]: Closed GnuPG cryptographic agent (access for web browsers).
            Dec 27 21:11:48 domoticz systemd[715]: Stopped target Paths.
            Dec 27 21:11:48 domoticz systemd[715]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
            Dec 27 21:11:48 domoticz systemd[715]: Closed GnuPG cryptographic agent and passphrase cache.
            Dec 27 21:11:48 domoticz systemd[715]: Stopped target Timers.
            Dec 27 21:11:48 domoticz systemd[715]: Closed GnuPG cryptographic agent (ssh-agent emulation).
            Dec 27 21:11:48 domoticz systemd[715]: Reached target Shutdown.
            Dec 27 21:11:48 domoticz systemd[715]: Starting Exit the Session...
            Dec 27 21:11:48 domoticz systemd[715]: Received SIGRTMIN+24 from PID 800 (kill).
            Dec 27 21:11:48 domoticz systemd[1]: Stopped User Manager for UID 1000.
            Dec 27 21:11:48 domoticz systemd[1]: Removed slice User Slice of pi.
            Dec 27 21:11:54 domoticz systemd[1]: Stopping Save/Restore Sound Card State...
            Dec 27 21:11:54 domoticz systemd[1]: Unmounting RPC Pipe File System...
            Dec 27 21:11:54 domoticz systemd[1]: Stopped target Graphical Interface.
            Dec 27 21:12:27 domoticz systemd-modules-load[125]: Inserted module 'i2c_dev'
            Dec 27 21:12:27 domoticz fake-hwclock[115]: Wed 27 Dec 20:12:25 UTC 2017
            Dec 27 21:12:27 domoticz systemd[1]: Mounted Configuration File System.
            Dec 27 21:12:27 domoticz systemd[1]: Started Apply Kernel Variables.
            Dec 27 21:12:27 domoticz systemd-fsck[127]: e2fsck 1.43.4 (31-Jan-2017)
            Dec 27 21:12:27 domoticz systemd[1]: Started Create Static Device Nodes in /dev.
            Dec 27 21:12:27 domoticz systemd[1]: Starting udev Kernel Device Manager...
            Dec 27 21:12:27 domoticz systemd-fsck[127]: rootfs: clean, 54121/474240 files, 431837/1933824 blocks
            Dec 27 21:12:27 domoticz systemd[1]: Started File System Check on Root Device.
            Dec 27 21:12:27 domoticz systemd[1]: Starting Remount Root and Kernel File Systems...
            Dec 27 21:12:27 domoticz systemd[1]: Started Remount Root and Kernel File Systems.
            Dec 27 21:12:27 domoticz systemd[1]: Starting Load/Save Random Seed...
            Dec 27 21:12:27 domoticz systemd[1]: Starting udev Coldplug all Devices...
            Dec 27 21:12:27 domoticz systemd[1]: Starting Flush Journal to Persistent Storage...
            Dec 27 21:12:27 domoticz systemd[1]: Started Flush Journal to Persistent Storage.
            Dec 27 21:12:27 domoticz systemd[1]: Started Load/Save Random Seed.
            Dec 27 21:12:27 domoticz systemd[1]: Started udev Kernel Device Manager.
            Dec 27 21:12:27 domoticz systemd[1]: Started Set the console keyboard layout.
            Dec 27 21:12:27 domoticz systemd[1]: Reached target Local File Systems (Pre).
            Dec 27 21:12:27 domoticz systemd[1]: Started udev Coldplug all Devices.
            Dec 27 21:12:27 domoticz systemd[1]: Starting Show Plymouth Boot Screen...
            Dec 27 21:12:27 domoticz systemd[1]: Received SIGRTMIN+20 from PID 190 (plymouthd).
            Dec 27 21:12:27 domoticz systemd[1]: Started Show Plymouth Boot Screen.
            Dec 27 21:12:27 domoticz systemd[1]: Found device /dev/disk/by-partuuid/e80766f2-01.
            Dec 27 21:12:27 domoticz systemd[1]: Starting File System Check on /dev/disk/by-partuuid/e80766f2-01...
            Dec 27 21:12:27 domoticz systemd[1]: Started Forward Password Requests to Plymouth Directory Watch.
            Dec 27 21:12:27 domoticz systemd[1]: Reached target Encrypted Volumes.
            Dec 27 21:12:27 domoticz systemd[1]: Reached target Paths.
            Dec 27 21:12:27 domoticz mtp-probe: checking bus 1, device 3: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1"
            Dec 27 21:12:27 domoticz mtp-probe: bus: 1, device: 3 was not an MTP device
            Dec 27 21:12:27 domoticz systemd[1]: Reached target Sound Card.
            Dec 27 21:12:27 domoticz systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
            Dec 27 21:12:27 domoticz systemd[1]: Starting Load/Save RF Kill Switch Status...
            Dec 27 21:12:27 domoticz systemd-fsck[227]: fsck.fat 4.1 (2017-01-24)
            Dec 27 21:12:27 domoticz systemd-fsck[227]: /dev/mmcblk0p1: 150 files, 42691/83705 clusters
            Dec 27 21:12:27 domoticz systemd[1]: Started File System Check on /dev/disk/by-partuuid/e80766f2-01.
            Dec 27 21:12:27 domoticz systemd[1]: Mounting /boot...
            Dec 27 21:12:27 domoticz systemd[1]: Started Load/Save RF Kill Switch Status.
            Dec 27 21:12:27 domoticz systemd[1]: Mounted /boot.
            Dec 27 21:12:27 domoticz systemd[1]: Reached target Local File Systems.
            Dec 27 21:12:27 domoticz systemd[1]: Starting Preprocess NFS configuration...
            Dec 27 21:12:27 domoticz systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
            Dec 27 21:12:27 domoticz systemd[1]: Starting Set console font and keymap...
            Dec 27 21:12:27 domoticz systemd[1]: Starting Raise network interfaces...
            Dec 27 21:12:27 domoticz systemd[1]: Starting Create Volatile Files and Directories...
            Dec 27 21:12:27 domoticz systemd[1]: Started Tell Plymouth To Write Out Runtime Data.
            Dec 27 21:12:27 domoticz systemd[1]: Started Preprocess NFS configuration.
            Dec 27 21:12:27 domoticz systemd[1]: Reached target NFS client services.
            Dec 27 21:12:27 domoticz systemd[1]: Reached target Remote File Systems (Pre).
            Dec 27 21:12:27 domoticz systemd[1]: Reached target Remote File Systems.
            Dec 27 21:12:27 domoticz systemd[1]: Started Set console font and keymap.
            Dec 27 21:12:27 domoticz systemd[1]: Started Create Volatile Files and Directories.
            Dec 27 21:12:27 domoticz systemd[1]: Starting Network Time Synchronization...
            Dec 27 21:12:27 domoticz systemd[1]: Starting Update UTMP about System Boot/Shutdown...
            Dec 27 21:12:27 domoticz systemd[1]: Started Update UTMP about System Boot/Shutdown.
            Dec 27 21:12:27 domoticz systemd[1]: Started Raise network interfaces.
            Dec 27 21:12:27 domoticz systemd[1]: Started Network Time Synchronization.
            Dec 27 21:12:27 domoticz systemd[1]: Reached target System Initialization.
            Dec 27 21:12:27 domoticz systemd[1]: Started Daily Cleanup of Temporary Directories.
            Dec 27 21:12:27 domoticz systemd[1]: Listening on D-Bus System Message Bus Socket.
            Dec 27 21:12:27 domoticz systemd[1]: Listening on triggerhappy.socket.
            Dec 27 21:12:27 domoticz systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
            Dec 27 21:12:27 domoticz systemd[1]: Reached target Sockets.
            Dec 27 21:12:27 domoticz systemd[1]: Reached target Basic System.
            Dec 27 21:12:27 domoticz systemd[1]: Starting LSB: Start OWFS at boot time...
            Dec 27 21:12:27 domoticz systemd[1]: Starting Login Service...
            Dec 27 21:12:27 domoticz systemd[1]: Starting Avahi mDNS/DNS-SD Stack...
            Dec 27 21:12:27 domoticz systemd[1]: Started Regular background program processing daemon.
            Dec 27 21:12:27 domoticz systemd[1]: Starting LSB: Autogenerate and use a swap file...
            Dec 27 21:12:27 domoticz systemd[1]: Starting LSB: Switch to ondemand cpu governor (unless shift key is pressed)...
            Dec 27 21:12:27 domoticz systemd[1]: Starting triggerhappy global hotkey daemon...
            Dec 27 21:12:27 domoticz systemd[1]: Started MySensors Gateway daemon.
            Dec 27 21:12:27 domoticz systemd[1]: Starting System Logging Service...
            Dec 27 21:12:27 domoticz systemd[1]: Starting Save/Restore Sound Card State...
            Dec 27 21:12:27 domoticz systemd[1]: Starting dhcpcd on all interfaces...
            Dec 27 21:12:27 domoticz systemd[1]: Started D-Bus System Message Bus.
            Dec 27 21:12:27 domoticz cron[328]: (CRON) INFO (pidfile fd = 3)
            Dec 27 21:12:27 domoticz cron[328]: (CRON) INFO (Running @reboot jobs)
            Dec 27 21:12:27 domoticz thd[331]: Found socket passed from systemd
            Dec 27 21:12:27 domoticz dhcpcd[339]: dev: loaded udev
            Dec 27 21:12:27 domoticz mysgw: Starting gateway...
            Dec 27 21:12:27 domoticz mysgw: Protocol version - 2.2.0-rc.2
            Dec 27 21:12:27 domoticz avahi-daemon[327]: Found user 'avahi' (UID 108) and group 'avahi' (GID 112).
            Dec 27 21:12:27 domoticz avahi-daemon[327]: Successfully dropped root privileges.
            Dec 27 21:12:27 domoticz avahi-daemon[327]: avahi-daemon 0.6.32 starting up.
            Dec 27 21:12:27 domoticz liblogging-stdlog:  [origin software="rsyslogd" swVersion="8.24.0" x-pid="334" x-info="http://www.rsyslog.com"] start
            Dec 27 21:12:27 domoticz kernel: [    0.000000] Booting Linux on physical CPU 0x0
            Dec 27 21:12:27 domoticz kernel: [    0.000000] Linux version 4.9.70-v7+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #1068 SMP Mon Dec 18 22:12:55 GMT 2017
            Dec 27 21:12:27 domoticz kernel: [    0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
            Dec 27 21:12:27 domoticz kernel: [    0.000000] CPU: div instructions available: patching division code
            Dec 27 21:12:27 domoticz kernel: [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
            Dec 27 21:12:27 domoticz kernel: [    0.000000] OF: fdt:Machine model: Raspberry Pi 3 Model B Rev 1.2
            Dec 27 21:12:27 domoticz kernel: [    0.000000] cma: Reserved 8 MiB at 0x3dc00000
            Dec 27 21:12:27 domoticz kernel: [    0.000000] Memory policy: Data cache writealloc
            Dec 27 21:12:27 domoticz kernel: [    0.000000] On node 0 totalpages: 255488
            Dec 27 21:12:27 domoticz kernel: [    0.000000] free_area_init_node: node 0, pgdat 80c6f400, node_mem_map bd336000
            Dec 27 21:12:27 domoticz kernel: [    0.000000]   Normal zone: 2246 pages used for memmap
            Dec 27 21:12:27 domoticz kernel: [    0.000000]   Normal zone: 0 pages reserved
            Dec 27 21:12:27 domoticz kernel: [    0.000000]   Normal zone: 255488 pages, LIFO batch:31
            Dec 27 21:12:27 domoticz kernel: [    0.000000] percpu: Embedded 14 pages/cpu @be5b0000 s25600 r8192 d23552 u57344
            Dec 27 21:12:27 domoticz kernel: [    0.000000] pcpu-alloc: s25600 r8192 d23552 u57344 alloc=14*4096
            Dec 27 21:12:27 domoticz kernel: [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
            Dec 27 21:12:27 domoticz kernel: [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 253242
            Dec 27 21:12:27 domoticz kernel: [    0.000000] Kernel command line: 8250.nr_uarts=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbdepth=16 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000  dwc_otg.lpm_enable=0 console=tty1 root=PARTUUID=e80766f2-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
            Dec 27 21:12:27 domoticz kernel: [    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
            Dec 27 21:12:27 domoticz kernel: [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
            Dec 27 21:12:27 domoticz kernel: [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
            Dec 27 21:12:27 domoticz kernel: [    0.000000] Memory: 991096K/1021952K available (7168K kernel code, 486K rwdata, 2012K rodata, 1024K init, 770K bss, 22664K reserved, 8192K cma-reserved)
            Dec 27 21:12:27 domoticz kernel: [    0.000000] Virtual kernel memory layout:
            Dec 27 21:12:27 domoticz kernel: [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
            Dec 27 21:12:27 domoticz kernel: [    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
            Dec 27 21:12:27 domoticz kernel: [    0.000000]     vmalloc : 0xbe800000 - 0xff800000   (1040 MB)
            Dec 27 21:12:27 domoticz kernel: [    0.000000]     lowmem  : 0x80000000 - 0xbe600000   ( 998 MB)
            Dec 27 21:12:27 domoticz kernel: [    0.000000]     modules : 0x7f000000 - 0x80000000   (  16 MB)
            Dec 27 21:12:27 domoticz kernel: [    0.000000]       .text : 0x80008000 - 0x80800000   (8160 kB)
            Dec 27 21:12:27 domoticz kernel: [    0.000000]       .init : 0x80b00000 - 0x80c00000   (1024 kB)
            Dec 27 21:12:27 domoticz kernel: [    0.000000]       .data : 0x80c00000 - 0x80c798bc   ( 487 kB)
            Dec 27 21:12:27 domoticz kernel: [    0.000000]        .bss : 0x80c7b000 - 0x80d3b9a4   ( 771 kB)
            Dec 27 21:12:27 domoticz kernel: [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
            Dec 27 21:12:27 domoticz kernel: [    0.000000] Hierarchical RCU implementation.
            Dec 27 21:12:27 domoticz kernel: [    0.000000] 	Build-time adjustment of leaf fanout to 32.
            Dec 27 21:12:27 domoticz kernel: [    0.000000] NR_IRQS:16 nr_irqs:16 16
            Dec 27 21:12:27 domoticz kernel: [    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
            Dec 27 21:12:27 domoticz kernel: [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
            Dec 27 21:12:27 domoticz kernel: [    0.000006] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
            Dec 27 21:12:27 domoticz kernel: [    0.000022] Switching to timer-based delay loop, resolution 52ns
            Dec 27 21:12:27 domoticz kernel: [    0.000304] Console: colour dummy device 80x30
            Dec 27 21:12:27 domoticz kernel: [    0.001203] console [tty1] enabled
            Dec 27 21:12:27 domoticz kernel: [    0.001250] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
            Dec 27 21:12:27 domoticz kernel: [    0.001318] pid_max: default: 32768 minimum: 301
            Dec 27 21:12:27 domoticz kernel: [    0.001653] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
            Dec 27 21:12:27 domoticz kernel: [    0.001696] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
            Dec 27 21:12:27 domoticz kernel: [    0.002734] Disabling memory control group subsystem
            Dec 27 21:12:27 domoticz kernel: [    0.002838] CPU: Testing write buffer coherency: ok
            Dec 27 21:12:27 domoticz kernel: [    0.002901] ftrace: allocating 22400 entries in 66 pages
            Dec 27 21:12:27 domoticz kernel: [    0.049380] CPU0: update cpu_capacity 1024
            Dec 27 21:12:27 domoticz kernel: [    0.049432] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
            Dec 27 21:12:27 domoticz kernel: [    0.049493] Setting up static identity map for 0x100000 - 0x100034
            Dec 27 21:12:27 domoticz kernel: [    0.051403] CPU1: update cpu_capacity 1024
            Dec 27 21:12:27 domoticz kernel: [    0.051410] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
            Dec 27 21:12:27 domoticz kernel: [    0.052106] CPU2: update cpu_capacity 1024
            Dec 27 21:12:27 domoticz kernel: [    0.052113] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
            Dec 27 21:12:27 domoticz kernel: [    0.052791] CPU3: update cpu_capacity 1024
            Dec 27 21:12:27 domoticz kernel: [    0.052798] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
            Dec 27 21:12:27 domoticz kernel: [    0.052887] Brought up 4 CPUs
            Dec 27 21:12:27 domoticz kernel: [    0.053059] SMP: Total of 4 processors activated (153.60 BogoMIPS).
            Dec 27 21:12:27 domoticz kernel: [    0.053089] CPU: All CPU(s) started in HYP mode.
            Dec 27 21:12:27 domoticz kernel: [    0.053115] CPU: Virtualization extensions available.
            Dec 27 21:12:27 domoticz kernel: [    0.053944] devtmpfs: initialized
            Dec 27 21:12:27 domoticz kernel: [    0.065214] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
            Dec 27 21:12:27 domoticz kernel: [    0.065538] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
            Dec 27 21:12:27 domoticz kernel: [    0.065601] futex hash table entries: 1024 (order: 4, 65536 bytes)
            Dec 27 21:12:27 domoticz kernel: [    0.066163] pinctrl core: initialized pinctrl subsystem
            Dec 27 21:12:27 domoticz kernel: [    0.067095] NET: Registered protocol family 16
            Dec 27 21:12:27 domoticz kernel: [    0.069334] DMA: preallocated 1024 KiB pool for atomic coherent allocations
            Dec 27 21:12:27 domoticz kernel: [    0.078209] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
            Dec 27 21:12:27 domoticz kernel: [    0.078258] hw-breakpoint: maximum watchpoint size is 8 bytes.
            Dec 27 21:12:27 domoticz kernel: [    0.078436] Serial: AMBA PL011 UART driver
            Dec 27 21:12:27 domoticz kernel: [    0.080361] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
            Dec 27 21:12:27 domoticz kernel: [    0.080925] uart-pl011 3f201000.serial: could not find pctldev for node /soc/gpio@7e200000/uart0_pins, deferring probe
            Dec 27 21:12:27 domoticz kernel: [    0.150223] bcm2835-dma 3f007000.dma: DMA legacy API manager at be80f000, dmachans=0x1
            Dec 27 21:12:27 domoticz kernel: [    0.152120] SCSI subsystem initialized
            Dec 27 21:12:27 domoticz kernel: [    0.152301] usbcore: registered new interface driver usbfs
            Dec 27 21:12:27 domoticz kernel: [    0.152411] usbcore: registered new interface driver hub
            Dec 27 21:12:27 domoticz kernel: [    0.152527] usbcore: registered new device driver usb
            Dec 27 21:12:27 domoticz kernel: [    0.159194] raspberrypi-firmware soc:firmware: Attached to firmware from 2017-12-01 16:17
            Dec 27 21:12:27 domoticz kernel: [    0.160594] clocksource: Switched to clocksource arch_sys_counter
            Dec 27 21:12:27 domoticz kernel: [    0.207210] VFS: Disk quotas dquot_6.6.0
            Dec 27 21:12:27 domoticz kernel: [    0.207324] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
            Dec 27 21:12:27 domoticz kernel: [    0.207555] FS-Cache: Loaded
            Dec 27 21:12:27 domoticz kernel: [    0.207822] CacheFiles: Loaded
            Dec 27 21:12:27 domoticz kernel: [    0.220056] NET: Registered protocol family 2
            Dec 27 21:12:27 domoticz kernel: [    0.220996] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
            Dec 27 21:12:27 domoticz kernel: [    0.221133] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
            Dec 27 21:12:27 domoticz kernel: [    0.221344] TCP: Hash tables configured (established 8192 bind 8192)
            Dec 27 21:12:27 domoticz kernel: [    0.221457] UDP hash table entries: 512 (order: 2, 16384 bytes)
            Dec 27 21:12:27 domoticz kernel: [    0.221525] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
            Dec 27 21:12:27 domoticz kernel: [    0.221756] NET: Registered protocol family 1
            Dec 27 21:12:27 domoticz kernel: [    0.222236] RPC: Registered named UNIX socket transport module.
            Dec 27 21:12:27 domoticz kernel: [    0.222269] RPC: Registered udp transport module.
            Dec 27 21:12:27 domoticz kernel: [    0.222297] RPC: Registered tcp transport module.
            Dec 27 21:12:27 domoticz kernel: [    0.222324] RPC: Registered tcp NFSv4.1 backchannel transport module.
            Dec 27 21:12:27 domoticz kernel: [    0.223276] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
            Dec 27 21:12:27 domoticz kernel: [    0.225612] workingset: timestamp_bits=14 max_order=18 bucket_order=4
            Dec 27 21:12:27 domoticz kernel: [    0.241781] FS-Cache: Netfs 'nfs' registered for caching
            Dec 27 21:12:27 domoticz kernel: [    0.242797] NFS: Registering the id_resolver key type
            Dec 27 21:12:27 domoticz kernel: [    0.242860] Key type id_resolver registered
            Dec 27 21:12:27 domoticz kernel: [    0.242888] Key type id_legacy registered
            Dec 27 21:12:27 domoticz kernel: [    0.245340] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
            Dec 27 21:12:27 domoticz kernel: [    0.245505] io scheduler noop registered
            Dec 27 21:12:27 domoticz kernel: [    0.245535] io scheduler deadline registered (default)
            Dec 27 21:12:27 domoticz kernel: [    0.245816] io scheduler cfq registered
            Dec 27 21:12:27 domoticz kernel: [    0.251562] BCM2708FB: allocated DMA memory fdd10000
            Dec 27 21:12:27 domoticz kernel: [    0.251615] BCM2708FB: allocated DMA channel 0 @ be80f000
            Dec 27 21:12:27 domoticz kernel: [    0.256725] Console: switching to colour frame buffer device 82x26
            Dec 27 21:12:27 domoticz kernel: [    0.261582] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
            Dec 27 21:12:27 domoticz kernel: [    0.264453] bcm2835-rng 3f104000.rng: hwrng registered
            Dec 27 21:12:27 domoticz kernel: [    0.265902] vc-mem: phys_addr:0x00000000 mem_base=0x3f000000 mem_size:0x3f600000(1014 MiB)
            Dec 27 21:12:27 domoticz kernel: [    0.269187] vc-sm: Videocore shared memory driver
            Dec 27 21:12:27 domoticz kernel: [    0.285964] brd: module loaded
            Dec 27 21:12:27 domoticz kernel: [    0.296350] loop: module loaded
            Dec 27 21:12:27 domoticz kernel: [    0.297737] Loading iSCSI transport class v2.0-870.
            Dec 27 21:12:27 domoticz kernel: [    0.299603] usbcore: registered new interface driver smsc95xx
            Dec 27 21:12:27 domoticz kernel: [    0.300990] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
            Dec 27 21:12:27 domoticz kernel: [    0.530382] Core Release: 2.80a
            Dec 27 21:12:27 domoticz kernel: [    0.531748] Setting default values for core params
            Dec 27 21:12:27 domoticz kernel: [    0.533143] Finished setting default values for core params
            Dec 27 21:12:27 domoticz kernel: [    0.734883] Using Buffer DMA mode
            Dec 27 21:12:27 domoticz kernel: [    0.736187] Periodic Transfer Interrupt Enhancement - disabled
            Dec 27 21:12:27 domoticz kernel: [    0.737532] Multiprocessor Interrupt Enhancement - disabled
            Dec 27 21:12:27 domoticz kernel: [    0.738902] OTG VER PARAM: 0, OTG VER FLAG: 0
            Dec 27 21:12:27 domoticz kernel: [    0.740281] Dedicated Tx FIFOs mode
            Dec 27 21:12:27 domoticz kernel: [    0.742000] WARN::dwc_otg_hcd_init:1032: FIQ DMA bounce buffers: virt = 0xbdd04000 dma = 0xfdd04000 len=9024
            Dec 27 21:12:27 domoticz kernel: [    0.744889] FIQ FSM acceleration enabled for :
            Dec 27 21:12:27 domoticz kernel: [    0.744889] Non-periodic Split Transactions
            Dec 27 21:12:27 domoticz kernel: [    0.744889] Periodic Split Transactions
            Dec 27 21:12:27 domoticz kernel: [    0.744889] High-Speed Isochronous Endpoints
            Dec 27 21:12:27 domoticz kernel: [    0.744889] Interrupt/Control Split Transaction hack enabled
            Dec 27 21:12:27 domoticz kernel: [    0.751657] dwc_otg: Microframe scheduler enabled
            Dec 27 21:12:27 domoticz kernel: [    0.751707] WARN::hcd_init_fiq:459: FIQ on core 1 at 0x80590aa0
            Dec 27 21:12:27 domoticz kernel: [    0.753058] WARN::hcd_init_fiq:460: FIQ ASM at 0x80590e10 length 36
            Dec 27 21:12:27 domoticz kernel: [    0.754417] WARN::hcd_init_fiq:486: MPHI regs_base at 0xbe87a000
            Dec 27 21:12:27 domoticz kernel: [    0.755813] dwc_otg 3f980000.usb: DWC OTG Controller
            Dec 27 21:12:27 domoticz kernel: [    0.757179] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
            Dec 27 21:12:27 domoticz kernel: [    0.758567] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
            Dec 27 21:12:27 domoticz kernel: [    0.759940] Init: Port Power? op_state=1
            Dec 27 21:12:27 domoticz kernel: [    0.761277] Init: Power Port (0)
            Dec 27 21:12:27 domoticz kernel: [    0.762752] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
            Dec 27 21:12:27 domoticz kernel: [    0.764101] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
            Dec 27 21:12:27 domoticz kernel: [    0.765440] usb usb1: Product: DWC OTG Controller
            Dec 27 21:12:27 domoticz kernel: [    0.766751] usb usb1: Manufacturer: Linux 4.9.70-v7+ dwc_otg_hcd
            Dec 27 21:12:27 domoticz kernel: [    0.768074] usb usb1: SerialNumber: 3f980000.usb
            Dec 27 21:12:27 domoticz kernel: [    0.770222] hub 1-0:1.0: USB hub found
            Dec 27 21:12:27 domoticz kernel: [    0.771542] hub 1-0:1.0: 1 port detected
            Dec 27 21:12:27 domoticz kernel: [    0.773419] dwc_otg: FIQ enabled
            Dec 27 21:12:27 domoticz kernel: [    0.773423] dwc_otg: NAK holdoff enabled
            Dec 27 21:12:27 domoticz kernel: [    0.773427] dwc_otg: FIQ split-transaction FSM enabled
            Dec 27 21:12:27 domoticz kernel: [    0.773440] Module dwc_common_port init
            Dec 27 21:12:27 domoticz kernel: [    0.773654] usbcore: registered new interface driver usb-storage
            Dec 27 21:12:27 domoticz kernel: [    0.775105] mousedev: PS/2 mouse device common for all mice
            Dec 27 21:12:27 domoticz kernel: [    0.777302] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
            Dec 27 21:12:27 domoticz kernel: [    0.778894] bcm2835-cpufreq: min=600000 max=1200000
            Dec 27 21:12:27 domoticz kernel: [    0.780631] sdhci: Secure Digital Host Controller Interface driver
            Dec 27 21:12:27 domoticz kernel: [    0.781980] sdhci: Copyright(c) Pierre Ossman
            Dec 27 21:12:27 domoticz kernel: [    0.783559] sdhost-bcm2835 3f202000.sdhost: could not get clk, deferring probe
            Dec 27 21:12:27 domoticz kernel: [    0.787123] mmc-bcm2835 3f300000.mmc: could not get clk, deferring probe
            Dec 27 21:12:27 domoticz kernel: [    0.788642] sdhci-pltfm: SDHCI platform and OF driver helper
            Dec 27 21:12:27 domoticz kernel: [    0.792679] ledtrig-cpu: registered to indicate activity on CPUs
            Dec 27 21:12:27 domoticz kernel: [    0.794296] hidraw: raw HID events driver (C) Jiri Kosina
            Dec 27 21:12:27 domoticz kernel: [    0.795907] usbcore: registered new interface driver usbhid
            Dec 27 21:12:27 domoticz kernel: [    0.797338] usbhid: USB HID core driver
            Dec 27 21:12:27 domoticz kernel: [    0.799562] vchiq: vchiq_init_state: slot_zero = 0xbdd80000, is_master = 0
            Dec 27 21:12:27 domoticz kernel: [    0.802307] [vc_sm_connected_init]: start
            Dec 27 21:12:27 domoticz kernel: [    0.805755] vc_vchi_sm_init: failed to open VCHI service (-1)
            Dec 27 21:12:27 domoticz kernel: [    0.805854] [vc_sm_connected_init]: failed to initialize shared memory service
            Dec 27 21:12:27 domoticz kernel: [    0.808797] [vc_sm_connected_init]: end - returning -1
            Dec 27 21:12:27 domoticz kernel: [    0.810708] Initializing XFRM netlink socket
            Dec 27 21:12:27 domoticz kernel: [    0.812256] NET: Registered protocol family 17
            Dec 27 21:12:27 domoticz kernel: [    0.813912] Key type dns_resolver registered
            Dec 27 21:12:27 domoticz kernel: [    0.815800] Registering SWP/SWPB emulation handler
            Dec 27 21:12:27 domoticz kernel: [    0.818025] registered taskstats version 1
            Dec 27 21:12:27 domoticz kernel: [    0.824815] uart-pl011 3f201000.serial: cts_event_workaround enabled
            Dec 27 21:12:27 domoticz kernel: [    0.826406] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
            Dec 27 21:12:27 domoticz kernel: [    0.831073] sdhost: log_buf @ bdd07000 (fdd07000)
            Dec 27 21:12:27 domoticz kernel: [    0.910624] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
            Dec 27 21:12:27 domoticz kernel: [    0.914335] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
            Dec 27 21:12:27 domoticz kernel: [    0.915839] mmc-bcm2835 3f300000.mmc: DMA channel allocated
            Dec 27 21:12:27 domoticz kernel: [    0.987418] mmc0: host does not support reading read-only switch, assuming write-enable
            Dec 27 21:12:27 domoticz kernel: [    0.990719] of_cfs_init
            Dec 27 21:12:27 domoticz kernel: [    0.990779] Indeed it is in host mode hprt0 = 00021501
            Dec 27 21:12:27 domoticz kernel: [    0.993836] of_cfs_init: OK
            Dec 27 21:12:27 domoticz kernel: [    0.995709] Waiting for root device PARTUUID=e80766f2-02...
            Dec 27 21:12:27 domoticz kernel: [    1.051010] mmc0: new high speed SDHC card at address 0001
            Dec 27 21:12:27 domoticz kernel: [    1.056145] mmcblk0: mmc0:0001 00000 14.9 GiB
            Dec 27 21:12:27 domoticz kernel: [    1.058962]  mmcblk0: p1 p2
            Dec 27 21:12:27 domoticz kernel: [    1.069058] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
            Dec 27 21:12:27 domoticz kernel: [    1.072012] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
            Dec 27 21:12:27 domoticz kernel: [    1.072437] random: fast init done
            Dec 27 21:12:27 domoticz kernel: [    1.076238] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
            Dec 27 21:12:27 domoticz kernel: [    1.080392] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
            Dec 27 21:12:27 domoticz kernel: [    1.121517] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
            Dec 27 21:12:27 domoticz kernel: [    1.124187] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
            Dec 27 21:12:27 domoticz kernel: [    1.133254] devtmpfs: mounted
            Dec 27 21:12:27 domoticz kernel: [    1.136413] Freeing unused kernel memory: 1024K
            Dec 27 21:12:27 domoticz kernel: [    1.173457] mmc1: new high speed SDIO card at address 0001
            Dec 27 21:12:27 domoticz kernel: [    1.190641] usb 1-1: new high-speed USB device number 2 using dwc_otg
            Dec 27 21:12:27 domoticz kernel: [    1.192168] Indeed it is in host mode hprt0 = 00001101
            Dec 27 21:12:27 domoticz kernel: [    1.420944] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
            Dec 27 21:12:27 domoticz kernel: [    1.422402] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
            Dec 27 21:12:27 domoticz kernel: [    1.424675] hub 1-1:1.0: USB hub found
            Dec 27 21:12:27 domoticz kernel: [    1.426166] hub 1-1:1.0: 5 ports detected
            Dec 27 21:12:27 domoticz kernel: [    1.694677] NET: Registered protocol family 10
            Dec 27 21:12:27 domoticz kernel: [    1.706057] ip_tables: (C) 2000-2006 Netfilter Core Team
            Dec 27 21:12:27 domoticz kernel: [    1.750624] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
            Dec 27 21:12:27 domoticz kernel: [    1.881013] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
            Dec 27 21:12:27 domoticz kernel: [    1.882603] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
            Dec 27 21:12:27 domoticz kernel: [    1.886946] smsc95xx v1.0.5
            Dec 27 21:12:27 domoticz kernel: [    1.984610] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:d4:81:2a
            Dec 27 21:12:27 domoticz kernel: [    2.353008] i2c /dev entries driver
            • pepsonP
              pepsonP
              pepson
              Dec 27 21:12:27 domoticz kernel: [    2.675918] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
              Dec 27 21:12:27 domoticz kernel: [    3.109172] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
              Dec 27 21:12:27 domoticz kernel: [    3.407342] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
              Dec 27 21:12:27 domoticz kernel: [    3.413382] usbcore: registered new interface driver brcmfmac
              Dec 27 21:12:27 domoticz kernel: [    3.601930] brcmfmac: Firmware version = wl0: Aug  7 2017 00:46:29 version 7.45.41.46 (r666254 CY) FWID 01-f8a78378
              Dec 27 21:12:27 domoticz kernel: [    3.602685] brcmfmac: brcmf_c_preinit_dcmds: CLM version = API: 12.2 Data: 7.11.15 Compiler: 1.24.2 ClmImport: 1.24.1 Creation: 2014-05-26 10:53:55 Inc Data: 9.10.41 Inc Compiler: 1.29.4 Inc ClmImport: 1.36.3 Creation: 2017-08-07 00:37:47
              Dec 27 21:12:27 domoticz avahi-daemon[327]: Successfully called chroot().
              Dec 27 21:12:27 domoticz avahi-daemon[327]: Successfully dropped remaining capabilities.
              Dec 27 21:12:27 domoticz avahi-daemon[327]: No service file found in /etc/avahi/services.
              Dec 27 21:12:27 domoticz systemd[1]: Started Avahi mDNS/DNS-SD Stack.
              Dec 27 21:12:27 domoticz systemd[1]: Reached target System Time Synchronized.
              Dec 27 21:12:27 domoticz avahi-daemon[327]: Network interface enumeration completed.
              Dec 27 21:12:27 domoticz avahi-daemon[327]: Server startup complete. Host name is domoticz.local. Local service cookie is 87145466.
              Dec 27 21:12:27 domoticz systemd[1]: apt-daily.timer: Adding 5h 31min 57.980339s random time.
              Dec 27 21:12:27 domoticz systemd[1]: Started Daily apt download activities.
              Dec 27 21:12:27 domoticz systemd[1]: apt-daily-upgrade.timer: Adding 2min 40.737204s random time.
              Dec 27 21:12:27 domoticz systemd[1]: Started Daily apt upgrade and clean activities.
              Dec 27 21:12:27 domoticz systemd[1]: Reached target Timers.
              Dec 27 21:12:27 domoticz systemd[1]: Started triggerhappy global hotkey daemon.
              Dec 27 21:12:27 domoticz systemd[1]: Started System Logging Service.
              Dec 27 21:12:27 domoticz systemd[1]: Started Save/Restore Sound Card State.
              Dec 27 21:12:27 domoticz dhcpcd[339]: wlan0: starting wpa_supplicant
              Dec 27 21:12:27 domoticz dhcpcd-run-hooks[374]: wlan0: starting wpa_supplicant
              Dec 27 21:12:27 domoticz systemd[1]: Started Login Service.
              Dec 27 21:12:27 domoticz dphys-swapfile[329]: Starting dphys-swapfile swapfile setup ...
              Dec 27 21:12:27 domoticz raspi-config[330]: Checking if shift key is held down:Error opening '/dev/input/event*': No such file or directory
              Dec 27 21:12:27 domoticz raspi-config[330]:  No. Switching to ondemand scaling governor.
              Dec 27 21:12:27 domoticz systemd[1]: Started LSB: Switch to ondemand cpu governor (unless shift key is pressed).
              Dec 27 21:12:27 domoticz OWFS[375]: DEFAULT: owlib.c:(208) Cannot open USB bus master
              Dec 27 21:12:27 domoticz OWFS[375]: DEFAULT: owlib.c:(52) No valid 1-wire buses found
              Dec 27 21:12:27 domoticz systemd[1]: start1wire.service: Control process exited, code=exited status=1
              Dec 27 21:12:27 domoticz systemd[1]: Failed to start LSB: Start OWFS at boot time.
              Dec 27 21:12:27 domoticz systemd[1]: start1wire.service: Unit entered failed state.
              Dec 27 21:12:27 domoticz systemd[1]: start1wire.service: Failed with result 'exit-code'.
              Dec 27 21:12:27 domoticz dphys-swapfile[329]: want /var/swap=100MByte, checking existing: keeping it
              Dec 27 21:12:27 domoticz kernel: [    4.979888] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
              Dec 27 21:12:27 domoticz kernel: [    4.979897] brcmfmac: power management disabled
              Dec 27 21:12:27 domoticz kernel: [    4.987898] Adding 102396k swap on /var/swap.  Priority:-1 extents:1 across:102396k SSFS
              Dec 27 21:12:27 domoticz dphys-swapfile[329]: done.
              Dec 27 21:12:27 domoticz systemd[1]: Started LSB: Autogenerate and use a swap file.
              Dec 27 21:12:27 domoticz dhcpcd[339]: eth0: waiting for carrier
              Dec 27 21:12:27 domoticz dhcpcd[339]: wlan0: waiting for carrier
              Dec 27 21:12:27 domoticz dhcpcd[339]: wlan0: carrier acquired
              Dec 27 21:12:27 domoticz kernel: [    5.321930] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
              Dec 27 21:12:27 domoticz kernel: [    5.322223] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
              Dec 27 21:12:27 domoticz dhcpcd[339]: DUID 00:01:00:01:21:b0:d9:d9:b8:27:eb:81:d4:7f
              Dec 27 21:12:27 domoticz dhcpcd[339]: wlan0: IAID eb:81:d4:7f
              Dec 27 21:12:27 domoticz dhcpcd[339]: wlan0: adding address fe80::6bd:3cc7:2b64:c842
              Dec 27 21:12:27 domoticz dhcpcd[339]: wlan0: carrier lost
              Dec 27 21:12:28 domoticz dhcpcd[339]: wlan0: deleting address fe80::6bd:3cc7:2b64:c842
              Dec 27 21:12:29 domoticz dhcpcd[339]: eth0: carrier acquired
              Dec 27 21:12:29 domoticz kernel: [    6.725223] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
              Dec 27 21:12:29 domoticz kernel: [    6.726375] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
              Dec 27 21:12:29 domoticz dhcpcd[339]: eth0: IAID eb:d4:81:2a
              Dec 27 21:12:29 domoticz dhcpcd[339]: eth0: adding address fe80::7a80:6e8f:27f0:4005
              Dec 27 21:12:29 domoticz dhcpcd[339]: eth0: probing address 192.168.13.5/24
              Dec 27 21:12:29 domoticz dhcpcd[339]: eth0: soliciting an IPv6 router
              Dec 27 21:12:30 domoticz avahi-daemon[327]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::7a80:6e8f:27f0:4005.
              Dec 27 21:12:30 domoticz avahi-daemon[327]: New relevant interface eth0.IPv6 for mDNS.
              Dec 27 21:12:30 domoticz avahi-daemon[327]: Registering new address record for fe80::7a80:6e8f:27f0:4005 on eth0.*.
              Dec 27 21:12:34 domoticz dhcpcd[339]: eth0: using static address 192.168.13.5/24
              Dec 27 21:12:34 domoticz dhcpcd[339]: eth0: adding route to 192.168.13.0/24
              Dec 27 21:12:34 domoticz dhcpcd[339]: eth0: adding default route via 192.168.13.1
              Dec 27 21:12:34 domoticz avahi-daemon[327]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.13.5.
              Dec 27 21:12:34 domoticz avahi-daemon[327]: New relevant interface eth0.IPv4 for mDNS.
              Dec 27 21:12:34 domoticz avahi-daemon[327]: Registering new address record for 192.168.13.5 on eth0.IPv4.
              Dec 27 21:12:34 domoticz dhcpcd[339]: forked to background, child pid 470
              Dec 27 21:12:34 domoticz systemd[1]: Started dhcpcd on all interfaces.
              Dec 27 21:12:34 domoticz systemd[1]: Reached target Network.
              Dec 27 21:12:34 domoticz systemd[1]: Reached target Network is Online.
              Dec 27 21:12:34 domoticz systemd[1]: Starting LSB: Home Automation System...
              Dec 27 21:12:34 domoticz systemd[1]: Starting /etc/rc.local Compatibility...
              Dec 27 21:12:34 domoticz systemd[1]: Starting Permit User Sessions...
              Dec 27 21:12:34 domoticz systemd[1]: Starting OpenBSD Secure Shell server...
              Dec 27 21:12:34 domoticz systemd[1]: Started /etc/rc.local Compatibility.
              Dec 27 21:12:34 domoticz systemd[1]: Started Permit User Sessions.
              Dec 27 21:12:34 domoticz systemd[1]: Starting Hold until boot process finishes up...
              Dec 27 21:12:34 domoticz systemd[1]: Starting Terminate Plymouth Boot Screen...
              Dec 27 21:12:34 domoticz systemd[1]: Received SIGRTMIN+21 from PID 190 (plymouthd).
              Dec 27 21:12:34 domoticz systemd[1]: Started Hold until boot process finishes up.
              Dec 27 21:12:34 domoticz systemd[1]: Started Terminate Plymouth Boot Screen.
              Dec 27 21:12:34 domoticz systemd[1]: Started Getty on tty1.
              Dec 27 21:12:34 domoticz systemd[1]: Reached target Login Prompts.
              Dec 27 21:12:34 domoticz systemd[1]: Started OpenBSD Secure Shell server.
              Dec 27 21:12:35 domoticz domoticz.sh[471]: 2017-12-27 21:12:35.467  Domoticz V3.8796 (c)2012-2017 GizMoCuz
              Dec 27 21:12:35 domoticz domoticz.sh[471]: 2017-12-27 21:12:35.467  Build Hash: 2d99bbbc, Date: 2017-12-24 07:06:53
              Dec 27 21:12:35 domoticz domoticz.sh[471]: 2017-12-27 21:12:35.468  Startup Path: /home/pi/domoticz/
              Dec 27 21:12:35 domoticz domoticz.sh[471]: domoticz: Domoticz is starting up....
              Dec 27 21:12:35 domoticz domoticz: Domoticz is starting up....
              Dec 27 21:12:35 domoticz domoticz: Domoticz running...
              Dec 27 21:12:35 domoticz systemd[1]: Started LSB: Home Automation System.
              Dec 27 21:12:35 domoticz systemd[1]: Reached target Multi-User System.
              Dec 27 21:12:35 domoticz systemd[1]: Reached target Graphical Interface.
              Dec 27 21:12:35 domoticz systemd[1]: Starting Update UTMP about System Runlevel Changes...
              Dec 27 21:12:35 domoticz systemd[1]: Started Update UTMP about System Runlevel Changes.
              Dec 27 21:12:35 domoticz systemd[1]: Startup finished in 1.510s (kernel) + 11.498s (userspace) = 13.009s.
              Dec 27 21:12:38 domoticz kernel: [   15.710546] uart-pl011 3f201000.serial: no DMA platform data
              Dec 27 21:12:42 domoticz dhcpcd[470]: eth0: no IPv6 Routers available
              Dec 27 21:12:53 domoticz systemd[1]: Created slice User Slice of pi.
              Dec 27 21:12:53 domoticz systemd[1]: Starting User Manager for UID 1000...
              Dec 27 21:12:53 domoticz systemd[1]: Started Session c1 of user pi.
              Dec 27 21:12:53 domoticz systemd[535]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
              Dec 27 21:12:53 domoticz systemd[535]: Listening on GnuPG cryptographic agent and passphrase cache.
              Dec 27 21:12:53 domoticz systemd[535]: Listening on GnuPG cryptographic agent (access for web browsers).
              Dec 27 21:12:53 domoticz systemd[535]: Reached target Paths.
              Dec 27 21:12:53 domoticz systemd[535]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
              Dec 27 21:12:53 domoticz systemd[535]: Reached target Sockets.
              Dec 27 21:12:53 domoticz systemd[535]: Reached target Timers.
              Dec 27 21:12:53 domoticz systemd[535]: Reached target Basic System.
              Dec 27 21:12:53 domoticz systemd[535]: Reached target Default.
              Dec 27 21:12:53 domoticz systemd[535]: Startup finished in 48ms.
              Dec 27 21:12:53 domoticz systemd[1]: Started User Manager for UID 1000.
              Dec 27 21:13:03 domoticz systemd[535]: Time has been changed
              Dec 27 21:13:03 domoticz systemd[1]: Time has been changed
              Dec 27 21:13:03 domoticz systemd-timesyncd[285]: Synchronized to time server 195.189.85.132:123 (2.debian.pool.ntp.org).
              Dec 27 21:13:03 domoticz systemd[1]: apt-daily.timer: Adding 8h 6min 59.681187s random time.
              Dec 27 21:13:03 domoticz systemd[1]: apt-daily-upgrade.timer: Adding 32min 42.364143s random time.```
              • pepsonP pepson
                @pepson ok, so mysgw does at least log to syslog, as seen here
                but nothing else. I expected there to be more information, but maybe I'm just not familiar enough with the raspberry pi gateway.
                • pepsonP
                  pepsonP
                  pepson
                  Yes but only one time read and then start the problem.
                    Can you try building the ethernet gateway instead?
                    • pepsonP
                      pepsonP
                      pepson
                      Ethernet work ok. But i better want serial and found bug and solution why not working serial...
                        I just wanted to make sure at least it was working OK as ethernet.
                        • pepsonP
                          pepsonP
                          pepson
                          Problem is only on serial...
                          • pepsonP
                            pepsonP
                            pepson
                            Please help...
                            • pepsonP pepson
                              Please help...
                              zboblamontZ
                              zboblamontZ
                              zboblamont
                              @pepson Just a suggestion, but are you sure the Pi3 is looking at ttyUSB1, ie have you confirmed this is the Gateway serial connection ?
                              I am using direct serial connection to the pi3 GPIO as ttySO with Domoticz, but when I tried a USB Gateway at one point, the connection was NOT working using the expected ttyUSB quoted. I had to check the tty connections via Putty to establish the actual link...
                              • pepsonP
                                pepsonP
                                pepson
                                But can you give me commend to build it as you use ttySO ?
                                • pepsonP
                                  pepsonP
                                  pepson
                                  I build it as ttySO
                                  ./configure --my-transport=rfm69 --my-rfm69-frequency=868 --my-is-rfm69hw --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttySO
                                  and i have and info:
                                  2017-12-28 15:40:21.822 MySensors: Using serial port: /dev/ttyS0
                                  2017-12-28 15:40:21.832 Error: MySensors: Error opening serial port!
                                  • pepsonP
                                    pepsonP
                                    pepson
                                    Then build as /dev/serial0 and the same problem. This is show in log Domoticz. One read version and port closed.
                                    2017-12-28 15:48:14.418 MySensors: Using serial port: /dev/serial0
                                    2017-12-28 15:48:14.418 MySensors: Gateway Version: 2.2.0-rc.2
                                    2017-12-28 15:48:14.418 Error: Serial Port closed!... Error: End of file
                                    2017-12-28 15:48:15.418 MySensors: retrying in 30 seconds...
                                    • pepsonP pepson
                                      @pepson could you post your hardware settings in Domoticz? This is what works for me:
                                      Could you also try building the gateway without rfm69 support, to check if the problem is generic or related to rfm69. Use this:
                                      ./configure --my-transport=none --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB42
                                      make && sudo ./bin/mysgw -d
                                      • pepsonP
                                        pepsonP
                                        pepson
                                        Hello
                                        Thanks for your help. I start from beginning build DOmoticz on my RPi3 with clean latest image. After run in Sudo raspi-config i enable SPI and Serial , then install DOmoticz and now all works OK. Then build Mysensor Gateway and all is ok with no error in Domoticz. Works on /dev/ttyUSB42
                                        • pepsonP
                                          pepsonP
                                          pepson
                                          But how i can build MySensors Gateway on serial with radio RFM69HW but on old version 2.1.1 ?
