  2. Announcements
  • pepsonP
    pepsonP
    pepson
    Dec 27 21:12:27 domoticz kernel: [    2.675918] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    Dec 27 21:12:27 domoticz kernel: [    3.109172] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
    Dec 27 21:12:27 domoticz kernel: [    3.407342] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
    Dec 27 21:12:27 domoticz kernel: [    3.413382] usbcore: registered new interface driver brcmfmac
    Dec 27 21:12:27 domoticz kernel: [    3.601930] brcmfmac: Firmware version = wl0: Aug  7 2017 00:46:29 version 7.45.41.46 (r666254 CY) FWID 01-f8a78378
    Dec 27 21:12:27 domoticz kernel: [    3.602685] brcmfmac: brcmf_c_preinit_dcmds: CLM version = API: 12.2 Data: 7.11.15 Compiler: 1.24.2 ClmImport: 1.24.1 Creation: 2014-05-26 10:53:55 Inc Data: 9.10.41 Inc Compiler: 1.29.4 Inc ClmImport: 1.36.3 Creation: 2017-08-07 00:37:47
    Dec 27 21:12:27 domoticz avahi-daemon[327]: Successfully called chroot().
    Dec 27 21:12:27 domoticz avahi-daemon[327]: Successfully dropped remaining capabilities.
    Dec 27 21:12:27 domoticz avahi-daemon[327]: No service file found in /etc/avahi/services.
    Dec 27 21:12:27 domoticz systemd[1]: Started Avahi mDNS/DNS-SD Stack.
    Dec 27 21:12:27 domoticz systemd[1]: Reached target System Time Synchronized.
    Dec 27 21:12:27 domoticz avahi-daemon[327]: Network interface enumeration completed.
    Dec 27 21:12:27 domoticz avahi-daemon[327]: Server startup complete. Host name is domoticz.local. Local service cookie is 87145466.
    Dec 27 21:12:27 domoticz systemd[1]: apt-daily.timer: Adding 5h 31min 57.980339s random time.
    Dec 27 21:12:27 domoticz systemd[1]: Started Daily apt download activities.
    Dec 27 21:12:27 domoticz systemd[1]: apt-daily-upgrade.timer: Adding 2min 40.737204s random time.
    Dec 27 21:12:27 domoticz systemd[1]: Started Daily apt upgrade and clean activities.
    Dec 27 21:12:27 domoticz systemd[1]: Reached target Timers.
    Dec 27 21:12:27 domoticz systemd[1]: Started triggerhappy global hotkey daemon.
    Dec 27 21:12:27 domoticz systemd[1]: Started System Logging Service.
    Dec 27 21:12:27 domoticz systemd[1]: Started Save/Restore Sound Card State.
    Dec 27 21:12:27 domoticz dhcpcd[339]: wlan0: starting wpa_supplicant
    Dec 27 21:12:27 domoticz dhcpcd-run-hooks[374]: wlan0: starting wpa_supplicant
    Dec 27 21:12:27 domoticz systemd[1]: Started Login Service.
    Dec 27 21:12:27 domoticz dphys-swapfile[329]: Starting dphys-swapfile swapfile setup ...
    Dec 27 21:12:27 domoticz raspi-config[330]: Checking if shift key is held down:Error opening '/dev/input/event*': No such file or directory
    Dec 27 21:12:27 domoticz raspi-config[330]:  No. Switching to ondemand scaling governor.
    Dec 27 21:12:27 domoticz systemd[1]: Started LSB: Switch to ondemand cpu governor (unless shift key is pressed).
    Dec 27 21:12:27 domoticz OWFS[375]: DEFAULT: owlib.c:(208) Cannot open USB bus master
    Dec 27 21:12:27 domoticz OWFS[375]: DEFAULT: owlib.c:(52) No valid 1-wire buses found
    Dec 27 21:12:27 domoticz systemd[1]: start1wire.service: Control process exited, code=exited status=1
    Dec 27 21:12:27 domoticz systemd[1]: Failed to start LSB: Start OWFS at boot time.
    Dec 27 21:12:27 domoticz systemd[1]: start1wire.service: Unit entered failed state.
    Dec 27 21:12:27 domoticz systemd[1]: start1wire.service: Failed with result 'exit-code'.
    Dec 27 21:12:27 domoticz dphys-swapfile[329]: want /var/swap=100MByte, checking existing: keeping it
    Dec 27 21:12:27 domoticz kernel: [    4.979888] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
    Dec 27 21:12:27 domoticz kernel: [    4.979897] brcmfmac: power management disabled
    Dec 27 21:12:27 domoticz kernel: [    4.987898] Adding 102396k swap on /var/swap.  Priority:-1 extents:1 across:102396k SSFS
    Dec 27 21:12:27 domoticz dphys-swapfile[329]: done.
    Dec 27 21:12:27 domoticz systemd[1]: Started LSB: Autogenerate and use a swap file.
    Dec 27 21:12:27 domoticz dhcpcd[339]: eth0: waiting for carrier
    Dec 27 21:12:27 domoticz dhcpcd[339]: wlan0: waiting for carrier
    Dec 27 21:12:27 domoticz dhcpcd[339]: wlan0: carrier acquired
    Dec 27 21:12:27 domoticz kernel: [    5.321930] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
    Dec 27 21:12:27 domoticz kernel: [    5.322223] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
    Dec 27 21:12:27 domoticz dhcpcd[339]: DUID 00:01:00:01:21:b0:d9:d9:b8:27:eb:81:d4:7f
    Dec 27 21:12:27 domoticz dhcpcd[339]: wlan0: IAID eb:81:d4:7f
    Dec 27 21:12:27 domoticz dhcpcd[339]: wlan0: adding address fe80::6bd:3cc7:2b64:c842
    Dec 27 21:12:27 domoticz dhcpcd[339]: wlan0: carrier lost
    Dec 27 21:12:28 domoticz dhcpcd[339]: wlan0: deleting address fe80::6bd:3cc7:2b64:c842
    Dec 27 21:12:29 domoticz dhcpcd[339]: eth0: carrier acquired
    Dec 27 21:12:29 domoticz kernel: [    6.725223] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    Dec 27 21:12:29 domoticz kernel: [    6.726375] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
    Dec 27 21:12:29 domoticz dhcpcd[339]: eth0: IAID eb:d4:81:2a
    Dec 27 21:12:29 domoticz dhcpcd[339]: eth0: adding address fe80::7a80:6e8f:27f0:4005
    Dec 27 21:12:29 domoticz dhcpcd[339]: eth0: probing address 192.168.13.5/24
    Dec 27 21:12:29 domoticz dhcpcd[339]: eth0: soliciting an IPv6 router
    Dec 27 21:12:30 domoticz avahi-daemon[327]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::7a80:6e8f:27f0:4005.
    Dec 27 21:12:30 domoticz avahi-daemon[327]: New relevant interface eth0.IPv6 for mDNS.
    Dec 27 21:12:30 domoticz avahi-daemon[327]: Registering new address record for fe80::7a80:6e8f:27f0:4005 on eth0.*.
    Dec 27 21:12:34 domoticz dhcpcd[339]: eth0: using static address 192.168.13.5/24
    Dec 27 21:12:34 domoticz dhcpcd[339]: eth0: adding route to 192.168.13.0/24
    Dec 27 21:12:34 domoticz dhcpcd[339]: eth0: adding default route via 192.168.13.1
    Dec 27 21:12:34 domoticz avahi-daemon[327]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.13.5.
    Dec 27 21:12:34 domoticz avahi-daemon[327]: New relevant interface eth0.IPv4 for mDNS.
    Dec 27 21:12:34 domoticz avahi-daemon[327]: Registering new address record for 192.168.13.5 on eth0.IPv4.
    Dec 27 21:12:34 domoticz dhcpcd[339]: forked to background, child pid 470
    Dec 27 21:12:34 domoticz systemd[1]: Started dhcpcd on all interfaces.
    Dec 27 21:12:34 domoticz systemd[1]: Reached target Network.
    Dec 27 21:12:34 domoticz systemd[1]: Reached target Network is Online.
    Dec 27 21:12:34 domoticz systemd[1]: Starting LSB: Home Automation System...
    Dec 27 21:12:34 domoticz systemd[1]: Starting /etc/rc.local Compatibility...
    Dec 27 21:12:34 domoticz systemd[1]: Starting Permit User Sessions...
    Dec 27 21:12:34 domoticz systemd[1]: Starting OpenBSD Secure Shell server...
    Dec 27 21:12:34 domoticz systemd[1]: Started /etc/rc.local Compatibility.
    Dec 27 21:12:34 domoticz systemd[1]: Started Permit User Sessions.
    Dec 27 21:12:34 domoticz systemd[1]: Starting Hold until boot process finishes up...
    Dec 27 21:12:34 domoticz systemd[1]: Starting Terminate Plymouth Boot Screen...
    Dec 27 21:12:34 domoticz systemd[1]: Received SIGRTMIN+21 from PID 190 (plymouthd).
    Dec 27 21:12:34 domoticz systemd[1]: Started Hold until boot process finishes up.
    Dec 27 21:12:34 domoticz systemd[1]: Started Terminate Plymouth Boot Screen.
    Dec 27 21:12:34 domoticz systemd[1]: Started Getty on tty1.
    Dec 27 21:12:34 domoticz systemd[1]: Reached target Login Prompts.
    Dec 27 21:12:34 domoticz systemd[1]: Started OpenBSD Secure Shell server.
    Dec 27 21:12:35 domoticz domoticz.sh[471]: 2017-12-27 21:12:35.467  Domoticz V3.8796 (c)2012-2017 GizMoCuz
    Dec 27 21:12:35 domoticz domoticz.sh[471]: 2017-12-27 21:12:35.467  Build Hash: 2d99bbbc, Date: 2017-12-24 07:06:53
    Dec 27 21:12:35 domoticz domoticz.sh[471]: 2017-12-27 21:12:35.468  Startup Path: /home/pi/domoticz/
    Dec 27 21:12:35 domoticz domoticz.sh[471]: domoticz: Domoticz is starting up....
    Dec 27 21:12:35 domoticz domoticz: Domoticz is starting up....
    Dec 27 21:12:35 domoticz domoticz: Domoticz running...
    Dec 27 21:12:35 domoticz systemd[1]: Started LSB: Home Automation System.
    Dec 27 21:12:35 domoticz systemd[1]: Reached target Multi-User System.
    Dec 27 21:12:35 domoticz systemd[1]: Reached target Graphical Interface.
    Dec 27 21:12:35 domoticz systemd[1]: Starting Update UTMP about System Runlevel Changes...
    Dec 27 21:12:35 domoticz systemd[1]: Started Update UTMP about System Runlevel Changes.
    Dec 27 21:12:35 domoticz systemd[1]: Startup finished in 1.510s (kernel) + 11.498s (userspace) = 13.009s.
    Dec 27 21:12:38 domoticz kernel: [   15.710546] uart-pl011 3f201000.serial: no DMA platform data
    Dec 27 21:12:42 domoticz dhcpcd[470]: eth0: no IPv6 Routers available
    Dec 27 21:12:53 domoticz systemd[1]: Created slice User Slice of pi.
    Dec 27 21:12:53 domoticz systemd[1]: Starting User Manager for UID 1000...
    Dec 27 21:12:53 domoticz systemd[1]: Started Session c1 of user pi.
    Dec 27 21:12:53 domoticz systemd[535]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
    Dec 27 21:12:53 domoticz systemd[535]: Listening on GnuPG cryptographic agent and passphrase cache.
    Dec 27 21:12:53 domoticz systemd[535]: Listening on GnuPG cryptographic agent (access for web browsers).
    Dec 27 21:12:53 domoticz systemd[535]: Reached target Paths.
    Dec 27 21:12:53 domoticz systemd[535]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
    Dec 27 21:12:53 domoticz systemd[535]: Reached target Sockets.
    Dec 27 21:12:53 domoticz systemd[535]: Reached target Timers.
    Dec 27 21:12:53 domoticz systemd[535]: Reached target Basic System.
    Dec 27 21:12:53 domoticz systemd[535]: Reached target Default.
    Dec 27 21:12:53 domoticz systemd[535]: Startup finished in 48ms.
    Dec 27 21:12:53 domoticz systemd[1]: Started User Manager for UID 1000.
    Dec 27 21:13:03 domoticz systemd[535]: Time has been changed
    Dec 27 21:13:03 domoticz systemd[1]: Time has been changed
    Dec 27 21:13:03 domoticz systemd-timesyncd[285]: Synchronized to time server 195.189.85.132:123 (2.debian.pool.ntp.org).
    Dec 27 21:13:03 domoticz systemd[1]: apt-daily.timer: Adding 8h 6min 59.681187s random time.
    Dec 27 21:13:03 domoticz systemd[1]: apt-daily-upgrade.timer: Adding 32min 42.364143s random time.```
    • pepsonP pepson
      @pepson ok, so mysgw does at least log to syslog, as seen here
      Dec 27 21:12:27 domoticz mysgw: Starting gateway...
      Dec 27 21:12:27 domoticz mysgw: Protocol version - 2.2.0-rc.2
      but nothing else. I expected there to be more information, but maybe I'm just not familiar enough with the raspberry pi gateway.
      • pepsonP
        pepsonP
        pepson
        Yes but only one time read and then start the problem.
          Can you try building the ethernet gateway instead?
          • pepsonP
            pepsonP
            pepson
            Ethernet work ok. But i better want serial and found bug and solution why not working serial...
              I just wanted to make sure at least it was working OK as ethernet.
              • pepsonP
                pepsonP
                pepson
                Problem is only on serial...
                • pepsonP
                  pepsonP
                  pepson
                  Please help...
                  • pepsonP pepson
                    Please help...
                    zboblamontZ
                    zboblamontZ
                    zboblamont
                    @pepson Just a suggestion, but are you sure the Pi3 is looking at ttyUSB1, ie have you confirmed this is the Gateway serial connection ?
                    I am using direct serial connection to the pi3 GPIO as ttySO with Domoticz, but when I tried a USB Gateway at one point, the connection was NOT working using the expected ttyUSB quoted. I had to check the tty connections via Putty to establish the actual link...
                    • pepsonP
                      pepsonP
                      pepson
                      But can you give me commend to build it as you use ttySO ?
                      • pepsonP
                        pepsonP
                        pepson
                        I build it as ttySO
                        ./configure --my-transport=rfm69 --my-rfm69-frequency=868 --my-is-rfm69hw --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttySO
                        and i have and info:
                        2017-12-28 15:40:21.822 MySensors: Using serial port: /dev/ttyS0
                        2017-12-28 15:40:21.832 Error: MySensors: Error opening serial port!
                        • pepsonP
                          pepsonP
                          pepson
                          Then build as /dev/serial0 and the same problem. This is show in log Domoticz. One read version and port closed.
                          2017-12-28 15:48:14.418 MySensors: Using serial port: /dev/serial0
                          2017-12-28 15:48:14.418 MySensors: Gateway Version: 2.2.0-rc.2
                          2017-12-28 15:48:14.418 Error: Serial Port closed!... Error: End of file
                          2017-12-28 15:48:15.418 MySensors: retrying in 30 seconds...
                          • pepsonP pepson
                            @pepson could you post your hardware settings in Domoticz? This is what works for me:
                            Could you also try building the gateway without rfm69 support, to check if the problem is generic or related to rfm69. Use this:
                            ./configure --my-transport=none --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB42
                            make && sudo ./bin/mysgw -d
                            • pepsonP
                              pepsonP
                              pepson
                              Hello
                              Thanks for your help. I start from beginning build DOmoticz on my RPi3 with clean latest image. After run in Sudo raspi-config i enable SPI and Serial , then install DOmoticz and now all works OK. Then build Mysensor Gateway and all is ok with no error in Domoticz. Works on /dev/ttyUSB42
                              • pepsonP
                                pepsonP
                                pepson
                                But how i can build MySensors Gateway on serial with radio RFM69HW but on old version 2.1.1 ?
                                • pepsonP
                                  pepsonP
                                  pepson
                                  And have next problem... i build sketch on version 2.2.0-rc2 but after write to Arduino Mini Pro he is not connected to my Gateway on RPI3.
                                  This is sketch. What is wrong ?
                                     Relay with button sketch
                                  #define MY_RADIO_RFM69
                                  #define MY_RFM69_FREQUENCY 868
                                  #define MY_IS_RFM69HW
                                  #define MY_RFM69_NEW_DRIVER
                                  //#define MY_NODE_ID 203                       // Node id defaults to AUTO (tries to fetch id from controller)
                                  #define RELAY_ON 1
                                  #define RELAY_OFF 0
                                  Bounce debouncer = Bounce();
                                  int oldValue = 0;
                                  bool uplinkAvailable = true;
                                  bool state = false;
                                  bool requestState;
                                  bool firstStart = true;
                                  unsigned long oldTime = 0;
                                  unsigned long newTime = 0;
                                  void setup(){
                                    debouncer.interval(5);
                                  void presentation()  {
                                    sendSketchInfo("1xRelay & Button", "2.2.0-rc2");
                                    present(CHILD_ID, S_BINARY);
                                  void loop(){
                                        uplinkCheckTime = millis();
                                       else{
                                        Serial.println(requestState);
                                    debouncer.update();
                                      requestTime();
                                        oldTime = newTime;
                                    oldValue = value;
                                  void uplinkCheck() {
                                      requestTime();
                                        oldTime = newTime;
                                    if (firstStart){
                                      oldTime = time;
                                      newTime = time;
                                    else{
                                    newTime = time;
                                    Serial.println(time);
                                  • pepsonP pepson
                                    #define RELAY_ON 1
                                    #define RELAY_OFF 0
                                    int oldValue = 0;
                                    bool state = false;
                                    bool requestState;
                                    void setup(){
                                    void loop(){
                                         else{
                                      debouncer.update();
                                        requestTime();
                                          oldTime = newTime;
                                      oldValue = value;
                                        requestTime();
                                          oldTime = newTime;
                                      if (firstStart){
                                        oldTime = time;
                                        newTime = time;
                                      else{
                                      newTime = time;
                                    zboblamontZ
                                    zboblamontZ
                                    zboblamont
                                    @pepson Try walking in little steps trying each stage rather than running into new walls then expressing surprise at broken nose, no offence intended ;)
                                    Gateway and nodes, same platform, same version..... Otherwise they are speaking Chinese and Swedish hoping for somebody to explain the meaning of fubar...
                                    • pepsonP
                                      pepsonP
                                      pepson
                                      wrote on last edited by pepson
                                      #724
                                      I use the same version now 2.2.0-rc2 but when i programmed sketch to node it not connection to Gateway... That i want come back to version 2.1.1 gateway but i dont know how ? Or resolved problem Node 2.2.0-rc2 i stay on this.
                                      But when run debug gateway show this:
                                      pi@domoticz:~/MySensors $ sudo ./bin/mysgw -d
                                      mysgw: MCO:BGN:INIT GW,CP=RPNGL---,VER=2.2.0-rc.2
                                      mysgw: TSF:LRT:OK
                                      mysgw: TSM:INIT
                                      mysgw: TSF:WUR:MS=0
                                      mysgw: TSM:INIT:TSP OK
                                      mysgw: TSM:INIT:GW MODE
                                      mysgw: MCO:REG:NOT NEEDED
                                      mysgw: MCO:BGN:STP
                                      mysgw: MCO:BGN:INIT OK,TSP=1
                                      mysgw: !TSF:SAN:FAIL
                                      mysgw: TSM:FAIL:CNT=1
                                      mysgw: TSM:FAIL:DIS
                                      mysgw: TSF:TDI:TSL
                                      mysgw: TSM:FAIL:RE-INIT
                                      mysgw: TSM:INIT
                                      This is sketch 2.2.0-rc2
                                      #define RFM69_868MHZ
                                      #define RELAY_ON 1
                                      #define RELAY_OFF 0
                                      int oldValue = 0;
                                      bool state = false;
                                      bool requestState;
                                      void setup(){
                                      void loop(){
                                           else{
                                        debouncer.update();
                                          requestTime();
                                            oldTime = newTime;
                                        oldValue = value;
                                          requestTime();
                                            oldTime = newTime;
                                        if (firstStart){
                                          oldTime = time;
                                          newTime = time;
                                        else{
                                        newTime = time;
                                      • pepsonP pepson
                                        mysgw: TSF:LRT:OK
                                        mysgw: TSM:INIT
                                        mysgw: TSF:WUR:MS=0
                                        mysgw: MCO:BGN:STP
                                        mysgw: TSM:FAIL:DIS
                                        mysgw: TSF:TDI:TSL
                                        mysgw: TSM:INIT
                                        #define RELAY_ON 1
                                        #define RELAY_OFF 0
                                        int oldValue = 0;
                                        bool state = false;
                                        bool requestState;
                                        void setup(){
                                        void loop(){
                                             else{
                                          debouncer.update();
                                            requestTime();
                                              oldTime = newTime;
                                          oldValue = value;
                                            requestTime();
                                              oldTime = newTime;
                                          if (firstStart){
                                            oldTime = time;
                                            newTime = time;
                                          else{
                                          newTime = time;
                                        zboblamontZ
                                        zboblamontZ
                                        zboblamont
                                        @pepson Let's try the baby steps I referred to earlier.
                                        The current stable version of MySensors is 2.1. Those using 2.2 tend to be experienced people versed in programming and experimenting and problem solving, hence it is not an official release.... yet you are using it and asking for solutions... Hello ?
                                        I am and have been for the last few months using a Pro-Mini with RFM69 as nodes and gateway using 2.1 attached to a Pi3 running Domoticz.... No problems, but slowly coming to understand most of what I am doing...
                                        I am still on baby steps, I don't mind at all, it works.....
                                        • pepsonP
                                          pepsonP
                                          pepson
                                          Ok but i dont know how build Gateway on version 2.1.1 because when i do step by step as show on mysensors.org it default build me version gateway 2.2.0-rc2
