  2. Announcements
  • pepsonP
    pepsonP
    pepson
    And have next problem... i build sketch on version 2.2.0-rc2 but after write to Arduino Mini Pro he is not connected to my Gateway on RPI3.
    This is sketch. What is wrong ?
       Relay with button sketch
    #define MY_RADIO_RFM69
    #define MY_RFM69_FREQUENCY 868
    #define MY_IS_RFM69HW
    #define MY_RFM69_NEW_DRIVER
    //#define MY_NODE_ID 203                       // Node id defaults to AUTO (tries to fetch id from controller)
    #define RELAY_ON 1
    #define RELAY_OFF 0
    Bounce debouncer = Bounce();
    int oldValue = 0;
    bool uplinkAvailable = true;
    bool state = false;
    bool requestState;
    bool firstStart = true;
    unsigned long oldTime = 0;
    unsigned long newTime = 0;
    void setup(){
      debouncer.interval(5);
    void presentation()  {
      sendSketchInfo("1xRelay & Button", "2.2.0-rc2");
      present(CHILD_ID, S_BINARY);
    void loop(){
          uplinkCheckTime = millis();
         else{
          Serial.println(requestState);
      debouncer.update();
        requestTime();
          oldTime = newTime;
      oldValue = value;
    void uplinkCheck() {
        requestTime();
          oldTime = newTime;
      if (firstStart){
        oldTime = time;
        newTime = time;
      else{
      newTime = time;
      Serial.println(time);
    • pepsonP pepson
      #define RELAY_ON 1
      #define RELAY_OFF 0
      int oldValue = 0;
      bool state = false;
      bool requestState;
      void setup(){
      void loop(){
           else{
        debouncer.update();
          requestTime();
            oldTime = newTime;
        oldValue = value;
          requestTime();
            oldTime = newTime;
        if (firstStart){
          oldTime = time;
          newTime = time;
        else{
        newTime = time;
      zboblamontZ
      zboblamontZ
      zboblamont
      @pepson Try walking in little steps trying each stage rather than running into new walls then expressing surprise at broken nose, no offence intended ;)
      Gateway and nodes, same platform, same version..... Otherwise they are speaking Chinese and Swedish hoping for somebody to explain the meaning of fubar...
      • pepsonP
        pepsonP
        pepson
        wrote on last edited by pepson
        #724
        I use the same version now 2.2.0-rc2 but when i programmed sketch to node it not connection to Gateway... That i want come back to version 2.1.1 gateway but i dont know how ? Or resolved problem Node 2.2.0-rc2 i stay on this.
        But when run debug gateway show this:
        pi@domoticz:~/MySensors $ sudo ./bin/mysgw -d
        mysgw: Starting gateway...
        mysgw: Protocol version - 2.2.0-rc.2
        mysgw: MCO:BGN:INIT GW,CP=RPNGL---,VER=2.2.0-rc.2
        mysgw: TSF:LRT:OK
        mysgw: TSM:INIT
        mysgw: TSF:WUR:MS=0
        mysgw: TSM:INIT:TSP OK
        mysgw: TSM:INIT:GW MODE
        mysgw: MCO:REG:NOT NEEDED
        mysgw: MCO:BGN:STP
        mysgw: MCO:BGN:INIT OK,TSP=1
        mysgw: !TSF:SAN:FAIL
        mysgw: TSM:FAIL:CNT=1
        mysgw: TSM:FAIL:DIS
        mysgw: TSF:TDI:TSL
        mysgw: TSM:FAIL:RE-INIT
        mysgw: TSM:INIT
        This is sketch 2.2.0-rc2
        #define RFM69_868MHZ
        #define RELAY_ON 1
        #define RELAY_OFF 0
        int oldValue = 0;
        bool state = false;
        bool requestState;
        void setup(){
        void loop(){
             else{
          debouncer.update();
            requestTime();
              oldTime = newTime;
          oldValue = value;
            requestTime();
              oldTime = newTime;
          if (firstStart){
            oldTime = time;
            newTime = time;
          else{
          newTime = time;
        • pepsonP pepson
          mysgw: TSF:LRT:OK
          mysgw: TSM:INIT
          mysgw: TSF:WUR:MS=0
          mysgw: MCO:BGN:STP
          mysgw: TSM:FAIL:DIS
          mysgw: TSF:TDI:TSL
          mysgw: TSM:INIT
          #define RELAY_ON 1
          #define RELAY_OFF 0
          int oldValue = 0;
          bool state = false;
          bool requestState;
          void setup(){
          void loop(){
               else{
            debouncer.update();
              requestTime();
                oldTime = newTime;
            oldValue = value;
              requestTime();
                oldTime = newTime;
            if (firstStart){
              oldTime = time;
              newTime = time;
            else{
            newTime = time;
          zboblamontZ
          zboblamontZ
          zboblamont
          @pepson Let's try the baby steps I referred to earlier.
          The current stable version of MySensors is 2.1. Those using 2.2 tend to be experienced people versed in programming and experimenting and problem solving, hence it is not an official release.... yet you are using it and asking for solutions... Hello ?
          I am and have been for the last few months using a Pro-Mini with RFM69 as nodes and gateway using 2.1 attached to a Pi3 running Domoticz.... No problems, but slowly coming to understand most of what I am doing...
          I am still on baby steps, I don't mind at all, it works.....
          • pepsonP
            pepsonP
            pepson
            Ok but i dont know how build Gateway on version 2.1.1 because when i do step by step as show on mysensors.org it default build me version gateway 2.2.0-rc2
            • pepsonP pepson
              zboblamontZ
              zboblamontZ
              zboblamont
              @pepson As in this page? 2.1.1 - Latest Release ?
              https://www.mysensors.org/download
              • pepsonP
                pepsonP
                pepson
                I found bug in Domoticz BETA 8796. No reconized version gateway in HARDWARE. On stable 8153 works with no problem and correct reconized version gateway 2.2.0-rc2...
                And again problem with this:
                CODE: SELECT ALL
                2017-12-28 20:01:32.587 MySensors: retrying in 30 seconds...
                2017-12-28 20:02:08.752 MySensors: Using serial port: /dev/serial0
                2017-12-28 20:02:08.752 MySensors: Gateway Version: 2.2.0-rc.2
                2017-12-28 20:02:08.752 Error: Serial Port closed!... Error: End of file
                2017-12-28 20:02:09.752 MySensors: retrying in 30 seconds...
                2017-12-28 20:02:38.755 MySensors: Using serial port: /dev/serial0
                2017-12-28 20:02:38.755 Error: Serial Port closed!... Error: End of file
                2017-12-28 20:02:39.755 MySensors: retrying in 30 seconds...
                2017-12-28 20:03:08.757 MySensors: Using serial port: /dev/serial0
                2017-12-28 20:03:08.761 Error: Serial Port closed!... Error: End of file
                2017-12-28 20:03:09.758 MySensors: retrying in 30 seconds...
                On beta is problem.
                On stable works correct.
                • M macvictor
                  @marceloaqno Thank's for you help. I have other question.. general I try configure my gateway to work with security & signing, but they doesn't work. Where is problem? On the bottom i send point what it do it:
                  Gateway:
                  2. make
                  3. sudo make install
                  10. sudo mysgw --gen-aes-key
                  Node:
                  #define USE_SOFT_SIGNING
                  #define STORE_SOFT_KEY
                  #define USER_SOFT_KEY
                  #define STORE_SOFT_SERIAL
                  #define STORE_AES_KEY
                  #define USER_AES_KEY
                  EEPROM configuration:
                  // Enable NRF24L01 radio type
                  // Select soft signing
                  #define MY_SIGNING_SOFT
                  // Enable node whitelisting
                  #define RELAY_ON 1
                  #define RELAY_OFF 0
                  int oldValue = 0;
                  bool state;
                    // Setup the button
                    pinMode(BUTTON_PIN, INPUT);
                    // Activate internal pull-up
                    state = loadState(CHILD_ID);
                    debouncer.update();
                  //  oldValue = value;
                    delay(5000);
                    if (message.isAck()) {
                      // Change relay state
                      // Store state in eeprom
                  4 TSM:INIT
                  5 TSF:WUR:MS=0
                  11 TSM:INIT:TSP OK
                  13 TSF:SID:OK,ID=105
                  15 TSM:FPAR
                  2065 !TSM:FPAR:NO REPLY
                  2067 TSM:FPAR
                  4117 !TSM:FPAR:NO REPLY
                  4119 TSM:FPAR
                  6169 !TSM:FPAR:NO REPLY
                  6171 TSM:FPAR
                  8221 !TSM:FPAR:FAIL
                  8222 TSM:FAIL:CNT=1
                  8224 TSM:FAIL:PDT
                  and in gateway i see:
                  sudo mysgw -d
                  mysgw: TSF:LRT:OK
                  mysgw: TSM:INIT
                  mysgw: TSF:WUR:MS=0
                  mysgw: MCO:BGN:STP
                  mysgw: connected to 127.0.0.1
                  mysgw: MQTT connected
                  mysgw: !TSF:MSG:PVER,3=2
                  mysgw: !TSF:MSG:PVER,1=2
                  mysgw: TSF:MSG:REL MSG
                  mysgw: !TSF:RTE:240 UNKNOWN
                  mysgw: !TSF:MSG:PVER,0=2
                  mysgw: !TSF:RTE:233 UNKNOWN
                  mysgw: !TSF:RTE:51 UNKNOWN
                  Where is problem?
                  pepsonP
                  pepsonP
                  pepson
                  • M macvictor
                    Gateway:
                    2. make
                    Node:
                    #define RELAY_ON 1
                    #define RELAY_OFF 0
                    int oldValue = 0;
                    bool state;
                      // Setup the button
                      debouncer.update();
                      delay(5000);
                    4 TSM:INIT
                    5 TSF:WUR:MS=0
                    11 TSM:INIT:TSP OK
                    15 TSM:FPAR
                    2067 TSM:FPAR
                    4119 TSM:FPAR
                    6171 TSM:FPAR
                    8221 !TSM:FPAR:FAIL
                    8222 TSM:FAIL:CNT=1
                    8224 TSM:FAIL:PDT
                    sudo mysgw -d
                    mysgw: TSF:LRT:OK
                    mysgw: TSM:INIT
                    mysgw: TSF:WUR:MS=0
                    mysgw: MCO:BGN:STP
                    Where is problem?
                    pepsonP
                    pepsonP
                    pepson
                    @macvictor said in 💬 Building a Raspberry Pi Gateway:
                    Gateway:
                    2. make
                    Node:
                    #define RELAY_ON 1
                    #define RELAY_OFF 0
                    int oldValue = 0;
                    bool state;
                      // Setup the button
                      debouncer.update();
                      delay(5000);
                    4 TSM:INIT
                    5 TSF:WUR:MS=0
                    11 TSM:INIT:TSP OK
                    15 TSM:FPAR
                    2067 TSM:FPAR
                    4119 TSM:FPAR
                    6171 TSM:FPAR
                    8221 !TSM:FPAR:FAIL
                    8222 TSM:FAIL:CNT=1
                    8224 TSM:FAIL:PDT
                    sudo mysgw -d
                    mysgw: TSF:LRT:OK
                    mysgw: TSM:INIT
                    mysgw: TSF:WUR:MS=0
                    mysgw: MCO:BGN:STP
                    Where is problem?
                    @macvictor
                    But how use itn on RFM69HW ? I dont see to be available #define MY_RFM69_ENABLE_ENCRYPTION... Only for #define MY_RF24_ENABLE_ENCRYPTION...
                    • pepsonP pepson
                      Gateway:
                      2. make
                      Node:
                      #define RELAY_ON 1
                      #define RELAY_OFF 0
                      int oldValue = 0;
                      bool state;
                        // Setup the button
                        debouncer.update();
                        delay(5000);
                      4 TSM:INIT
                      5 TSF:WUR:MS=0
                      11 TSM:INIT:TSP OK
                      15 TSM:FPAR
                      2067 TSM:FPAR
                      4119 TSM:FPAR
                      6171 TSM:FPAR
                      8221 !TSM:FPAR:FAIL
                      8222 TSM:FAIL:CNT=1
                      8224 TSM:FAIL:PDT
                      sudo mysgw -d
                      mysgw: TSF:LRT:OK
                      mysgw: TSM:INIT
                      mysgw: TSF:WUR:MS=0
                      mysgw: MCO:BGN:STP
                      Where is problem?
                      @macvictor
                      #731
                      @pepson are you asking how to enable encryption on rfm69? (it is a bit unclear what you mean by "itn")
                      In that case, see https://www.mysensors.org/apidocs-beta/group__RFM69SettingGrpPub.html#ga17a7a919994e569f078e3787c2c4ecd2
                      pepsonP 1 Reply Last reply
                        pepsonP
                        pepsonP
                        pepson
                        @mfalkvidd
                        Yes :) Thanks
                        BTW
                        MySensors gateway as you see is problem with latest beta domoticz.
                        • pepsonP pepson
                          @mfalkvidd
                          Yes :) Thanks
                          BTW
                          #733
                          @pepson yes I saw that. Thanks for checking. Have you reported the problem to the Domoticz team?
                            pepsonP
                            pepsonP
                            pepson
                            @mfalkvidd
                            Yes write on forum Domoticz in section BUG
                            • pepsonP pepson
                              @mfalkvidd
                              @pepson great!
                              The report is at https://www.domoticz.com/forum/viewtopic.php?f=6&t=21125&sid=e414507bb1ca4596e93cf885047275a9 in case someone needs to find it in the future.
                              • G
                                G
                                ghiglie
                                Hello!
                                I'm trying to "make" on Alpine Linux in a Docker (ok, maybe it's useless, but way interesting!).
                                With a Debian image it's ok, but I'd like to use Alpine.
                                I get this error:
                                g++ -MT build/drivers/Linux/SPIDEV.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_GATEWAY_LINUX -DMY_GATEWAY_MQTT_CLIENT -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DSPI_SPIDEV_DEVICE=\"/dev/spidev0.0\"  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/SPIDEV.cpp -o build/drivers/Linux/SPIDEV.o
                                In file included from /usr/include/sys/ioctl.h:7:0,
                                                 from drivers/Linux/SPIDEV.cpp:27:
                                drivers/Linux/SPIDEV.cpp: In static member function 'static uint8_t SPIDEVClass::transfer(uint8_t)':
                                drivers/Linux/SPIDEV.cpp:153:18: error: '_IOC_SIZEBITS' was not declared in this scope
                                  ret = ioctl(fd, SPI_IOC_MESSAGE(1), &tr);
                                drivers/Linux/SPIDEV.cpp: In static member function 'static void SPIDEVClass::transfernb(char*, char*, uint32_t)':
                                drivers/Linux/SPIDEV.cpp:175:18: error: '_IOC_SIZEBITS' was not declared in this scope
                                make: *** [Makefile:99: build/drivers/Linux/SPIDEV.o] Error 1
                                root@local-mysgw-alpine:/opt/MySensors3$ make
                                eIn file included from /usr/include/sys/ioctl.h:7:0,
                                I'm surely missing a package... but can't state one. Any help?
                                @macvictor thanks for your post, it will help me a lot, I'm trying the same way.
                                atmega328p serial killer
                                HomeAssistant / gateway: ESP8266 & NRF24L01+ gateway
                                • G ghiglie
                                  Hello!
                                  I get this error:
                                  @ghiglie https://lists.yoctoproject.org/pipermail/yocto/2016-January/028233.html seems to suggest that adding
                                  #include <asm/ioctl.h>
                                  would solve the problem. Could you try that?
                                  G 1 Reply Last reply
                                    sineverba
                                    wrote on last edited by sineverba
                                    #738
                                    Was my fault!
                                    **When copy and past command from word, for example, pay attention that software doesn't substitute the single "-" with a "-" longer. :dizzy_face:
                                    I have a word with all commands, to replicate installation very fast. Was my fault (errr... Word fault.... but you understand). Have a nice day!
                                    I cannot go over the initialization of command.
                                    RPI3 + Amplified antenna by GertSander (https://www.openhardware.io/view/17/Raspberry-Pi2-GPIO-interface-for-NRF24L01). Power from 5v/3A and power for antenna taken from both 5V via the 3.3v stepper down.
                                    RPI3 is new, has about 12h (got yesterday).
                                    Yesterday it did work at first attempt. Today I would replicate so I did delete the uSD and restart over. No way to get the gateway on work.
                                    I did try 3 amplified antenna + 2 normal. No way.
                                    I did enable from raspi-config the SPI (and only it).
                                    It hangs on second line of output.
                                    These are the logs:
                                    sineverba@raspberrypi:~/MySensors $ ./configure --my-transport=nrf24 --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB020
                                      [OK] SPI driver detected:BCM.
                                    [OK] Finished.
                                    sineverba@raspberrypi:~/MySensors $ make
                                    gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/log.c -o build/drivers/Linux/log.o
                                    g++ -MT build/drivers/Linux/IPAddress.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/IPAddress.cpp -o build/drivers/Linux/IPAddress.o
                                    g++ -MT build/drivers/Linux/noniso.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/noniso.cpp -o build/drivers/Linux/noniso.o
                                    g++ -MT build/drivers/Linux/GPIO.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/GPIO.cpp -o build/drivers/Linux/GPIO.o
                                    g++ -MT build/drivers/Linux/SPIDEV.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/SPIDEV.cpp -o build/drivers/Linux/SPIDEV.o
                                    g++ -MT build/drivers/Linux/Print.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/Print.cpp -o build/drivers/Linux/Print.o
                                    g++ -MT build/drivers/Linux/EthernetClient.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/EthernetClient.cpp -o build/drivers/Linux/EthernetClient.o
                                    g++ -MT build/drivers/Linux/compatibility.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/compatibility.cpp -o build/drivers/Linux/compatibility.o
                                    g++ -MT build/drivers/Linux/SerialPort.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/SerialPort.cpp -o build/drivers/Linux/SerialPort.o
                                    g++ -MT build/drivers/Linux/Stream.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/Stream.cpp -o build/drivers/Linux/Stream.o
                                    g++ -MT build/drivers/Linux/interrupt.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/interrupt.cpp -o build/drivers/Linux/interrupt.o
                                    g++ -MT build/drivers/Linux/SerialSimulator.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/SerialSimulator.cpp -o build/drivers/Linux/SerialSimulator.o
                                    g++ -MT build/drivers/Linux/SoftEeprom.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/SoftEeprom.cpp -o build/drivers/Linux/SoftEeprom.o
                                    g++ -MT build/drivers/Linux/EthernetServer.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/EthernetServer.cpp -o build/drivers/Linux/EthernetServer.o
                                    g++ -MT build/examples_linux/mysgw.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c examples_linux/mysgw.cpp -o build/examples_linux/mysgw.o
                                    gcc -MT build/drivers/BCM/bcm2835.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/BCM/bcm2835.c -o build/drivers/BCM/bcm2835.o
                                    g++ -MT build/drivers/BCM/BCM.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/BCM/BCM.cpp -o build/drivers/BCM/BCM.o
                                    g++ -MT build/drivers/BCM/SPIBCM.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/BCM/SPIBCM.cpp -o build/drivers/BCM/SPIBCM.o
                                    g++ -MT build/drivers/BCM/Wire.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/BCM/Wire.cpp -o build/drivers/BCM/Wire.o
                                    g++ -MT build/drivers/BCM/RPi.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/BCM/RPi.cpp -o build/drivers/BCM/RPi.o
                                    g++ -pthread  -o bin/mysgw build/drivers/Linux/log.o build/drivers/Linux/IPAddress.o build/drivers/Linux/noniso.o build/drivers/Linux/GPIO.o build/drivers/Linux/SPIDEV.o build/drivers/Linux/Print.o build/drivers/Linux/EthernetClient.o build/drivers/Linux/compatibility.o build/drivers/Linux/SerialPort.o build/drivers/Linux/Stream.o build/drivers/Linux/interrupt.o build/drivers/Linux/SerialSimulator.o build/drivers/Linux/SoftEeprom.o build/drivers/Linux/EthernetServer.o build/examples_linux/mysgw.o build/drivers/BCM/bcm2835.o build/drivers/BCM/BCM.o build/drivers/BCM/SPIBCM.o build/drivers/BCM/Wire.o build/drivers/BCM/RPi.o
                                    sineverba@raspberrypi:~/MySensors $ sudo ./bin/mysgw –d
                                    [sudo] password for sineverba:
                                      sineverba
                                      Hi to all,
                                      I'm testing an ethernet gateway on RPI3, with nrf24 + 1 node with a relay.
                                      I want introduce security and signing. On Arduino gateway / node no problem at all, but, how to do on the RPI3 as gateway?
                                      I would get / create / set a software serial on PI itself and whitelisting it on the node, after I will introduce the AES Key and signing.
                                      Cannot find in documentation how do it on PI3. Thank you very much!
                                      • S sineverba
                                        Hi to all,
                                        G
                                        G
                                        ghiglie
                                        @sineverba said in 💬 Building a Raspberry Pi Gateway:
                                        Hi to all,
                                        Earlier in this forum... https://forum.mysensors.org/topic/4803/building-a-raspberry-pi-gateway/350
                                        S 1 Reply Last reply
                                          G
                                          G
                                          ghiglie
                                          wrote on last edited by ghiglie
                                          #741
                                          @mfalkvidd I'm trying today, but to compile correctly the Docker image I'll have to clone to my github account :( or at least locally. My Dockerfile for the "Alpine edition" for Hass.io is simply:
                                          ARG BUILD_FROM
                                          ARG BUILD_ARCH
                                          ARG BUILD_DATE
                                          ARG BUILD_REF
                                          ARG BUILD_VERSION
                                          FROM ${BUILD_FROM}
                                          ENV CONFIG_PATH=/data/options.json
                                          ENV APPDIR=/opt/MySensors
                                          RUN apt-get update && apt-get install -y --force-yes \
                                              make \
                                          	 g++ \
                                          	 git \
                                          	 && rm -rf /var/lib/apt/lists/* /tmp/* /var/tmp/* ~/.cache \
                                          	 && git clone https://github.com/mysensors/MySensors.git --branch development $APPDIR
                                          # Copy root filesystem
                                          COPY rootfs /
                                          #CMD [ "/run.sh" ]
                                          I deleted the LABELS 'cause... the data is still too rawly "buried" from others. :tongue:
                                          The Configure and Make is in run.sh.
                                          BTW, I still need to figure out how to start mysgw as service... Mainlyt I'd like to redirect the log: how can I do this safely?
                                          And... can I use the rx/tx/err led feature on Raspi too (aside being in a Docker) ?
                                          EDIT: the code add works!
                                          Another question: I'm not getting far from this... what is it trying to do?
                                          : MCO:BGN:INIT GW,CP=RNNGL---,VER=2.2.0-rc.2
                                          : TSF:LRT:OK
                                          : TSM:INIT
                                          : TSF:WUR:MS=0
