  2. Announcements
  • pepsonP pepson
    Ok but i dont know how build Gateway on version 2.1.1 because when i do step by step as show on mysensors.org it default build me version gateway 2.2.0-rc2
    zboblamontZ
    zboblamontZ
    zboblamont
    @pepson As in this page? 2.1.1 - Latest Release ?
    https://www.mysensors.org/download
    • pepsonP
      pepsonP
      pepson
      I found bug in Domoticz BETA 8796. No reconized version gateway in HARDWARE. On stable 8153 works with no problem and correct reconized version gateway 2.2.0-rc2...
      And again problem with this:
      CODE: SELECT ALL
      2017-12-28 20:01:32.587 MySensors: retrying in 30 seconds...
      2017-12-28 20:02:08.752 MySensors: Using serial port: /dev/serial0
      2017-12-28 20:02:08.752 MySensors: Gateway Version: 2.2.0-rc.2
      2017-12-28 20:02:08.752 Error: Serial Port closed!... Error: End of file
      2017-12-28 20:02:09.752 MySensors: retrying in 30 seconds...
      2017-12-28 20:02:38.755 MySensors: Using serial port: /dev/serial0
      2017-12-28 20:02:38.755 Error: Serial Port closed!... Error: End of file
      2017-12-28 20:02:39.755 MySensors: retrying in 30 seconds...
      2017-12-28 20:03:08.757 MySensors: Using serial port: /dev/serial0
      2017-12-28 20:03:08.761 Error: Serial Port closed!... Error: End of file
      2017-12-28 20:03:09.758 MySensors: retrying in 30 seconds...
      On beta is problem.
      On stable works correct.
      • M macvictor
        @marceloaqno Thank's for you help. I have other question.. general I try configure my gateway to work with security & signing, but they doesn't work. Where is problem? On the bottom i send point what it do it:
        Gateway:
        2. make
        3. sudo make install
        10. sudo mysgw --gen-aes-key
        Node:
        #define USE_SOFT_SIGNING
        #define STORE_SOFT_KEY
        #define USER_SOFT_KEY
        #define STORE_SOFT_SERIAL
        #define STORE_AES_KEY
        #define USER_AES_KEY
        EEPROM configuration:
        // Enable NRF24L01 radio type
        // Select soft signing
        #define MY_SIGNING_SOFT
        // Enable node whitelisting
        #define MY_REPEATER_FEATURE
        #define BUTTON_PIN  3   // Arduino Digital I/O pin number for button
        #define CHILD_ID 1      // Id of the sensor child
        #define RELAY_ON 1
        #define RELAY_OFF 0
        Bounce debouncer = Bounce();
        int oldValue = 0;
        bool state;
          // Setup the button
          pinMode(BUTTON_PIN, INPUT);
          // Activate internal pull-up
          debouncer.attach(BUTTON_PIN);
          debouncer.interval(5);
          pinMode(RELAY_PIN, OUTPUT);
          state = loadState(CHILD_ID);
          digitalWrite(RELAY_PIN, state ? RELAY_ON : RELAY_OFF);
        void presentation()  {
          debouncer.update();
          // Get the update value
          int value = debouncer.read();
        //  oldValue = value;
          delay(5000);
          if (message.isAck()) {
            // Change relay state
            state = message.getBool();
            // Store state in eeprom
        4 TSM:INIT
        5 TSF:WUR:MS=0
        11 TSM:INIT:TSP OK
        13 TSF:SID:OK,ID=105
        15 TSM:FPAR
        2065 !TSM:FPAR:NO REPLY
        2067 TSM:FPAR
        4117 !TSM:FPAR:NO REPLY
        4119 TSM:FPAR
        6169 !TSM:FPAR:NO REPLY
        6171 TSM:FPAR
        8221 !TSM:FPAR:FAIL
        8222 TSM:FAIL:CNT=1
        8224 TSM:FAIL:PDT
        and in gateway i see:
        sudo mysgw -d
        mysgw: Starting gateway...
        mysgw: TSF:LRT:OK
        mysgw: TSM:INIT
        mysgw: TSF:WUR:MS=0
        mysgw: TSM:INIT:TSP OK
        mysgw: TSM:INIT:GW MODE
        mysgw: MCO:REG:NOT NEEDED
        mysgw: MCO:BGN:STP
        mysgw: MCO:BGN:INIT OK,TSP=1
        mysgw: connected to 127.0.0.1
        mysgw: MQTT connected
        mysgw: !TSF:MSG:PVER,3=2
        mysgw: !TSF:MSG:PVER,1=2
        mysgw: TSF:MSG:REL MSG
        mysgw: !TSF:RTE:240 UNKNOWN
        mysgw: !TSF:MSG:PVER,0=2
        mysgw: !TSF:RTE:233 UNKNOWN
        mysgw: !TSF:RTE:51 UNKNOWN
        Where is problem?
        pepsonP
        pepsonP
        pepson
        • M macvictor
          Gateway:
          2. make
          Node:
          #define RELAY_ON 1
          #define RELAY_OFF 0
          int oldValue = 0;
          bool state;
            // Setup the button
            debouncer.update();
            delay(5000);
          4 TSM:INIT
          5 TSF:WUR:MS=0
          11 TSM:INIT:TSP OK
          15 TSM:FPAR
          2067 TSM:FPAR
          4119 TSM:FPAR
          6171 TSM:FPAR
          8221 !TSM:FPAR:FAIL
          8222 TSM:FAIL:CNT=1
          8224 TSM:FAIL:PDT
          sudo mysgw -d
          mysgw: TSF:LRT:OK
          mysgw: TSM:INIT
          mysgw: TSF:WUR:MS=0
          mysgw: MCO:BGN:STP
          Where is problem?
          pepsonP
          pepsonP
          pepson
          @macvictor said in 💬 Building a Raspberry Pi Gateway:
          Gateway:
          2. make
          Node:
          #define RELAY_ON 1
          #define RELAY_OFF 0
          int oldValue = 0;
          bool state;
            // Setup the button
            debouncer.update();
            delay(5000);
          4 TSM:INIT
          5 TSF:WUR:MS=0
          11 TSM:INIT:TSP OK
          15 TSM:FPAR
          2067 TSM:FPAR
          4119 TSM:FPAR
          6171 TSM:FPAR
          8221 !TSM:FPAR:FAIL
          8222 TSM:FAIL:CNT=1
          8224 TSM:FAIL:PDT
          sudo mysgw -d
          mysgw: TSF:LRT:OK
          mysgw: TSM:INIT
          mysgw: TSF:WUR:MS=0
          mysgw: MCO:BGN:STP
          Where is problem?
          @macvictor
          But how use itn on RFM69HW ? I dont see to be available #define MY_RFM69_ENABLE_ENCRYPTION... Only for #define MY_RF24_ENABLE_ENCRYPTION...
          • pepsonP pepson
            Gateway:
            2. make
            Node:
            #define RELAY_ON 1
            #define RELAY_OFF 0
            int oldValue = 0;
            bool state;
              // Setup the button
              debouncer.update();
              delay(5000);
            4 TSM:INIT
            5 TSF:WUR:MS=0
            11 TSM:INIT:TSP OK
            15 TSM:FPAR
            2067 TSM:FPAR
            4119 TSM:FPAR
            6171 TSM:FPAR
            8221 !TSM:FPAR:FAIL
            8222 TSM:FAIL:CNT=1
            8224 TSM:FAIL:PDT
            sudo mysgw -d
            mysgw: TSF:LRT:OK
            mysgw: TSM:INIT
            mysgw: TSF:WUR:MS=0
            mysgw: MCO:BGN:STP
            Where is problem?
            @macvictor
            #731
            @pepson are you asking how to enable encryption on rfm69? (it is a bit unclear what you mean by "itn")
            In that case, see https://www.mysensors.org/apidocs-beta/group__RFM69SettingGrpPub.html#ga17a7a919994e569f078e3787c2c4ecd2
            pepsonP 1 Reply Last reply
              pepsonP
              pepsonP
              pepson
              @mfalkvidd
              Yes :) Thanks
              BTW
              MySensors gateway as you see is problem with latest beta domoticz.
              • pepsonP pepson
                @mfalkvidd
                Yes :) Thanks
                BTW
                #733
                @pepson yes I saw that. Thanks for checking. Have you reported the problem to the Domoticz team?
                  pepsonP
                  pepsonP
                  pepson
                  @mfalkvidd
                  Yes write on forum Domoticz in section BUG
                  • pepsonP pepson
                    @mfalkvidd
                    @pepson great!
                    The report is at https://www.domoticz.com/forum/viewtopic.php?f=6&t=21125&sid=e414507bb1ca4596e93cf885047275a9 in case someone needs to find it in the future.
                    • G
                      G
                      ghiglie
                      Hello!
                      I'm trying to "make" on Alpine Linux in a Docker (ok, maybe it's useless, but way interesting!).
                      With a Debian image it's ok, but I'd like to use Alpine.
                      I get this error:
                      g++ -MT build/drivers/Linux/SPIDEV.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_GATEWAY_LINUX -DMY_GATEWAY_MQTT_CLIENT -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DSPI_SPIDEV_DEVICE=\"/dev/spidev0.0\"  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/SPIDEV.cpp -o build/drivers/Linux/SPIDEV.o
                      In file included from /usr/include/sys/ioctl.h:7:0,
                                       from drivers/Linux/SPIDEV.cpp:27:
                      drivers/Linux/SPIDEV.cpp: In static member function 'static uint8_t SPIDEVClass::transfer(uint8_t)':
                      drivers/Linux/SPIDEV.cpp:153:18: error: '_IOC_SIZEBITS' was not declared in this scope
                        ret = ioctl(fd, SPI_IOC_MESSAGE(1), &tr);
                      drivers/Linux/SPIDEV.cpp: In static member function 'static void SPIDEVClass::transfernb(char*, char*, uint32_t)':
                      drivers/Linux/SPIDEV.cpp:175:18: error: '_IOC_SIZEBITS' was not declared in this scope
                      make: *** [Makefile:99: build/drivers/Linux/SPIDEV.o] Error 1
                      root@local-mysgw-alpine:/opt/MySensors3$ make
                      eIn file included from /usr/include/sys/ioctl.h:7:0,
                      I'm surely missing a package... but can't state one. Any help?
                      @macvictor thanks for your post, it will help me a lot, I'm trying the same way.
                      atmega328p serial killer
                      HomeAssistant / gateway: ESP8266 & NRF24L01+ gateway
                      • G ghiglie
                        Hello!
                        I get this error:
                        @ghiglie https://lists.yoctoproject.org/pipermail/yocto/2016-January/028233.html seems to suggest that adding
                        #include <asm/ioctl.h>
                        would solve the problem. Could you try that?
                        G 1 Reply Last reply
                          sineverba
                          wrote on last edited by sineverba
                          #738
                          Was my fault!
                          **When copy and past command from word, for example, pay attention that software doesn't substitute the single "-" with a "-" longer. :dizzy_face:
                          I have a word with all commands, to replicate installation very fast. Was my fault (errr... Word fault.... but you understand). Have a nice day!
                          I cannot go over the initialization of command.
                          RPI3 + Amplified antenna by GertSander (https://www.openhardware.io/view/17/Raspberry-Pi2-GPIO-interface-for-NRF24L01). Power from 5v/3A and power for antenna taken from both 5V via the 3.3v stepper down.
                          RPI3 is new, has about 12h (got yesterday).
                          Yesterday it did work at first attempt. Today I would replicate so I did delete the uSD and restart over. No way to get the gateway on work.
                          I did try 3 amplified antenna + 2 normal. No way.
                          I did enable from raspi-config the SPI (and only it).
                          It hangs on second line of output.
                          These are the logs:
                          sineverba@raspberrypi:~/MySensors $ ./configure --my-transport=nrf24 --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB020
                            [OK] SPI driver detected:BCM.
                          [OK] Finished.
                          sineverba@raspberrypi:~/MySensors $ make
                          gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/log.c -o build/drivers/Linux/log.o
                          g++ -MT build/drivers/Linux/IPAddress.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/IPAddress.cpp -o build/drivers/Linux/IPAddress.o
                          g++ -MT build/drivers/Linux/noniso.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/noniso.cpp -o build/drivers/Linux/noniso.o
                          g++ -MT build/drivers/Linux/GPIO.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/GPIO.cpp -o build/drivers/Linux/GPIO.o
                          g++ -MT build/drivers/Linux/SPIDEV.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/SPIDEV.cpp -o build/drivers/Linux/SPIDEV.o
                          g++ -MT build/drivers/Linux/Print.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/Print.cpp -o build/drivers/Linux/Print.o
                          g++ -MT build/drivers/Linux/EthernetClient.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/EthernetClient.cpp -o build/drivers/Linux/EthernetClient.o
                          g++ -MT build/drivers/Linux/compatibility.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/compatibility.cpp -o build/drivers/Linux/compatibility.o
                          g++ -MT build/drivers/Linux/SerialPort.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/SerialPort.cpp -o build/drivers/Linux/SerialPort.o
                          g++ -MT build/drivers/Linux/Stream.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/Stream.cpp -o build/drivers/Linux/Stream.o
                          g++ -MT build/drivers/Linux/interrupt.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/interrupt.cpp -o build/drivers/Linux/interrupt.o
                          g++ -MT build/drivers/Linux/SerialSimulator.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/SerialSimulator.cpp -o build/drivers/Linux/SerialSimulator.o
                          g++ -MT build/drivers/Linux/SoftEeprom.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/SoftEeprom.cpp -o build/drivers/Linux/SoftEeprom.o
                          g++ -MT build/drivers/Linux/EthernetServer.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/EthernetServer.cpp -o build/drivers/Linux/EthernetServer.o
                          g++ -MT build/examples_linux/mysgw.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c examples_linux/mysgw.cpp -o build/examples_linux/mysgw.o
                          gcc -MT build/drivers/BCM/bcm2835.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/BCM/bcm2835.c -o build/drivers/BCM/bcm2835.o
                          g++ -MT build/drivers/BCM/BCM.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/BCM/BCM.cpp -o build/drivers/BCM/BCM.o
                          g++ -MT build/drivers/BCM/SPIBCM.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/BCM/SPIBCM.cpp -o build/drivers/BCM/SPIBCM.o
                          g++ -MT build/drivers/BCM/Wire.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/BCM/Wire.cpp -o build/drivers/BCM/Wire.o
                          g++ -MT build/drivers/BCM/RPi.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/BCM/RPi.cpp -o build/drivers/BCM/RPi.o
                          g++ -pthread  -o bin/mysgw build/drivers/Linux/log.o build/drivers/Linux/IPAddress.o build/drivers/Linux/noniso.o build/drivers/Linux/GPIO.o build/drivers/Linux/SPIDEV.o build/drivers/Linux/Print.o build/drivers/Linux/EthernetClient.o build/drivers/Linux/compatibility.o build/drivers/Linux/SerialPort.o build/drivers/Linux/Stream.o build/drivers/Linux/interrupt.o build/drivers/Linux/SerialSimulator.o build/drivers/Linux/SoftEeprom.o build/drivers/Linux/EthernetServer.o build/examples_linux/mysgw.o build/drivers/BCM/bcm2835.o build/drivers/BCM/BCM.o build/drivers/BCM/SPIBCM.o build/drivers/BCM/Wire.o build/drivers/BCM/RPi.o
                          sineverba@raspberrypi:~/MySensors $ sudo ./bin/mysgw –d
                          [sudo] password for sineverba:
                          mysgw: Protocol version - 2.2.0-rc.2
                            sineverba
                            Hi to all,
                            I'm testing an ethernet gateway on RPI3, with nrf24 + 1 node with a relay.
                            I want introduce security and signing. On Arduino gateway / node no problem at all, but, how to do on the RPI3 as gateway?
                            I would get / create / set a software serial on PI itself and whitelisting it on the node, after I will introduce the AES Key and signing.
                            Cannot find in documentation how do it on PI3. Thank you very much!
                            • S sineverba
                              Hi to all,
                              G
                              G
                              ghiglie
                              @sineverba said in 💬 Building a Raspberry Pi Gateway:
                              Hi to all,
                              Earlier in this forum... https://forum.mysensors.org/topic/4803/building-a-raspberry-pi-gateway/350
                              S 1 Reply Last reply
                                G
                                G
                                ghiglie
                                wrote on last edited by ghiglie
                                #741
                                @mfalkvidd I'm trying today, but to compile correctly the Docker image I'll have to clone to my github account :( or at least locally. My Dockerfile for the "Alpine edition" for Hass.io is simply:
                                ARG BUILD_FROM
                                ARG BUILD_ARCH
                                ARG BUILD_DATE
                                ARG BUILD_REF
                                ARG BUILD_VERSION
                                FROM ${BUILD_FROM}
                                ENV CONFIG_PATH=/data/options.json
                                ENV APPDIR=/opt/MySensors
                                RUN apt-get update && apt-get install -y --force-yes \
                                    make \
                                	 g++ \
                                	 git \
                                	 && rm -rf /var/lib/apt/lists/* /tmp/* /var/tmp/* ~/.cache \
                                	 && git clone https://github.com/mysensors/MySensors.git --branch development $APPDIR
                                # Copy root filesystem
                                COPY rootfs /
                                #CMD [ "/run.sh" ]
                                I deleted the LABELS 'cause... the data is still too rawly "buried" from others. :tongue:
                                The Configure and Make is in run.sh.
                                BTW, I still need to figure out how to start mysgw as service... Mainlyt I'd like to redirect the log: how can I do this safely?
                                And... can I use the rx/tx/err led feature on Raspi too (aside being in a Docker) ?
                                EDIT: the code add works!
                                Another question: I'm not getting far from this... what is it trying to do?
                                : MCO:BGN:INIT GW,CP=RNNGL---,VER=2.2.0-rc.2
                                : TSF:LRT:OK
                                : TSM:INIT
                                : TSF:WUR:MS=0
                                • G ghiglie
                                  Hi to all,
                                  sineverba
                                  @ghiglie Thank you, I did see that was for 2.1.1. Just playing with them!
                                  • alowhumA
                                    alowhumA
                                    alowhum
                                    Does the Pi Gateway support the MY_SIGNING_SIMPLE_PASSWD option? I couldn't find anything about that. I've been gearing up to use that feature in my network, but I've also been playing with moving my gateway onto my Pi Zero W.
                                    gohanG M 2 Replies Last reply
                                    • alowhumA alowhum
                                      @alowhum If you want to just encrypt data, just add the encryption key in the myconfig.h file and compile it
                                      MasMatM 1 Reply Last reply
                                        MasMatM
                                        MasMatM
                                        MasMat
                                        @gohan N00b question, but which steps from the step-by-step need to be redone to "compile it" after altering myconfig.h? Or can you just post the command lines? :flushed:
                                          As soon as you do the changes in myconfig.h before the MAKE, you are fine
