  2. Announcements
  • pepsonP
    pepsonP
    pepson
    wrote on last edited by pepson
    #724
    I use the same version now 2.2.0-rc2 but when i programmed sketch to node it not connection to Gateway... That i want come back to version 2.1.1 gateway but i dont know how ? Or resolved problem Node 2.2.0-rc2 i stay on this.
    But when run debug gateway show this:
    pi@domoticz:~/MySensors $ sudo ./bin/mysgw -d
    mysgw: Starting gateway...
    mysgw: Protocol version - 2.2.0-rc.2
    mysgw: MCO:BGN:INIT GW,CP=RPNGL---,VER=2.2.0-rc.2
    mysgw: TSF:LRT:OK
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: TSM:INIT:TSP OK
    mysgw: TSM:INIT:GW MODE
    mysgw: MCO:REG:NOT NEEDED
    mysgw: MCO:BGN:STP
    mysgw: MCO:BGN:INIT OK,TSP=1
    mysgw: !TSF:SAN:FAIL
    mysgw: TSM:FAIL:CNT=1
    mysgw: TSM:FAIL:DIS
    mysgw: TSF:TDI:TSL
    mysgw: TSM:FAIL:RE-INIT
    mysgw: TSM:INIT
    This is sketch 2.2.0-rc2
       Relay with button sketch
    #define MY_RADIO_RFM69
    #define RFM69_868MHZ
    #define MY_IS_RFM69HW
    #define MY_RFM69_NEW_DRIVER
    //#define MY_NODE_ID 203                       // Node id defaults to AUTO (tries to fetch id from controller)
    #define RELAY_ON 1
    #define RELAY_OFF 0
    Bounce debouncer = Bounce();
    int oldValue = 0;
    bool uplinkAvailable = true;
    bool state = false;
    bool requestState;
    bool firstStart = true;
    unsigned long oldTime = 0;
    unsigned long newTime = 0;
    void setup(){
      debouncer.interval(5);
    void presentation()  {
      sendSketchInfo("1xRelay & Button", "2.2.0-rc2");
      present(CHILD_ID, S_BINARY);
    void loop(){
          uplinkCheckTime = millis();
         else{
          Serial.println(requestState);
      debouncer.update();
        requestTime();
          oldTime = newTime;
      oldValue = value;
    void uplinkCheck() {
        requestTime();
          oldTime = newTime;
      if (firstStart){
        oldTime = time;
        newTime = time;
      else{
      newTime = time;
      Serial.println(time);
    • pepsonP pepson
      mysgw: TSF:LRT:OK
      mysgw: TSM:INIT
      mysgw: TSF:WUR:MS=0
      mysgw: MCO:BGN:STP
      mysgw: TSM:FAIL:DIS
      mysgw: TSF:TDI:TSL
      mysgw: TSM:INIT
      #define RELAY_ON 1
      #define RELAY_OFF 0
      int oldValue = 0;
      bool state = false;
      bool requestState;
      void setup(){
      void loop(){
           else{
        debouncer.update();
          requestTime();
            oldTime = newTime;
        oldValue = value;
          requestTime();
            oldTime = newTime;
        if (firstStart){
          oldTime = time;
          newTime = time;
        else{
        newTime = time;
      zboblamontZ
      zboblamontZ
      zboblamont
      @pepson Let's try the baby steps I referred to earlier.
      The current stable version of MySensors is 2.1. Those using 2.2 tend to be experienced people versed in programming and experimenting and problem solving, hence it is not an official release.... yet you are using it and asking for solutions... Hello ?
      I am and have been for the last few months using a Pro-Mini with RFM69 as nodes and gateway using 2.1 attached to a Pi3 running Domoticz.... No problems, but slowly coming to understand most of what I am doing...
      I am still on baby steps, I don't mind at all, it works.....
      • pepsonP
        pepsonP
        pepson
        Ok but i dont know how build Gateway on version 2.1.1 because when i do step by step as show on mysensors.org it default build me version gateway 2.2.0-rc2
        • pepsonP pepson
          zboblamontZ
          zboblamontZ
          zboblamont
          @pepson As in this page? 2.1.1 - Latest Release ?
          https://www.mysensors.org/download
          • pepsonP
            pepsonP
            pepson
            I found bug in Domoticz BETA 8796. No reconized version gateway in HARDWARE. On stable 8153 works with no problem and correct reconized version gateway 2.2.0-rc2...
            And again problem with this:
            CODE: SELECT ALL
            2017-12-28 20:01:32.587 MySensors: retrying in 30 seconds...
            2017-12-28 20:02:08.752 MySensors: Using serial port: /dev/serial0
            2017-12-28 20:02:08.752 MySensors: Gateway Version: 2.2.0-rc.2
            2017-12-28 20:02:08.752 Error: Serial Port closed!... Error: End of file
            2017-12-28 20:02:09.752 MySensors: retrying in 30 seconds...
            2017-12-28 20:02:38.755 MySensors: Using serial port: /dev/serial0
            2017-12-28 20:02:38.755 Error: Serial Port closed!... Error: End of file
            2017-12-28 20:02:39.755 MySensors: retrying in 30 seconds...
            2017-12-28 20:03:08.757 MySensors: Using serial port: /dev/serial0
            2017-12-28 20:03:08.761 Error: Serial Port closed!... Error: End of file
            2017-12-28 20:03:09.758 MySensors: retrying in 30 seconds...
            On beta is problem.
            On stable works correct.
            • M macvictor
              @marceloaqno Thank's for you help. I have other question.. general I try configure my gateway to work with security & signing, but they doesn't work. Where is problem? On the bottom i send point what it do it:
              Gateway:
              2. make
              3. sudo make install
              10. sudo mysgw --gen-aes-key
              Node:
              #define USE_SOFT_SIGNING
              #define STORE_SOFT_KEY
              #define USER_SOFT_KEY
              #define STORE_SOFT_SERIAL
              #define STORE_AES_KEY
              #define USER_AES_KEY
              EEPROM configuration:
              // Enable NRF24L01 radio type
              // Select soft signing
              #define MY_SIGNING_SOFT
              // Enable node whitelisting
              #define RELAY_ON 1
              #define RELAY_OFF 0
              int oldValue = 0;
              bool state;
                // Setup the button
                pinMode(BUTTON_PIN, INPUT);
                // Activate internal pull-up
                state = loadState(CHILD_ID);
                debouncer.update();
              //  oldValue = value;
                delay(5000);
                if (message.isAck()) {
                  // Change relay state
                  // Store state in eeprom
              4 TSM:INIT
              5 TSF:WUR:MS=0
              11 TSM:INIT:TSP OK
              13 TSF:SID:OK,ID=105
              15 TSM:FPAR
              2065 !TSM:FPAR:NO REPLY
              2067 TSM:FPAR
              4117 !TSM:FPAR:NO REPLY
              4119 TSM:FPAR
              6169 !TSM:FPAR:NO REPLY
              6171 TSM:FPAR
              8221 !TSM:FPAR:FAIL
              8222 TSM:FAIL:CNT=1
              8224 TSM:FAIL:PDT
              and in gateway i see:
              sudo mysgw -d
              mysgw: TSF:LRT:OK
              mysgw: TSM:INIT
              mysgw: TSF:WUR:MS=0
              mysgw: MCO:BGN:STP
              mysgw: connected to 127.0.0.1
              mysgw: MQTT connected
              mysgw: !TSF:MSG:PVER,3=2
              mysgw: !TSF:MSG:PVER,1=2
              mysgw: TSF:MSG:REL MSG
              mysgw: !TSF:RTE:240 UNKNOWN
              mysgw: !TSF:MSG:PVER,0=2
              mysgw: !TSF:RTE:233 UNKNOWN
              mysgw: !TSF:RTE:51 UNKNOWN
              Where is problem?
              pepsonP
              pepsonP
              pepson
              • M macvictor
                Gateway:
                2. make
                Node:
                #define RELAY_ON 1
                #define RELAY_OFF 0
                int oldValue = 0;
                bool state;
                  // Setup the button
                  debouncer.update();
                  delay(5000);
                4 TSM:INIT
                5 TSF:WUR:MS=0
                11 TSM:INIT:TSP OK
                15 TSM:FPAR
                2067 TSM:FPAR
                4119 TSM:FPAR
                6171 TSM:FPAR
                8221 !TSM:FPAR:FAIL
                8222 TSM:FAIL:CNT=1
                8224 TSM:FAIL:PDT
                sudo mysgw -d
                mysgw: TSF:LRT:OK
                mysgw: TSM:INIT
                mysgw: TSF:WUR:MS=0
                mysgw: MCO:BGN:STP
                Where is problem?
                pepsonP
                pepsonP
                pepson
                @macvictor said in 💬 Building a Raspberry Pi Gateway:
                Gateway:
                2. make
                Node:
                #define RELAY_ON 1
                #define RELAY_OFF 0
                int oldValue = 0;
                bool state;
                  // Setup the button
                  debouncer.update();
                  delay(5000);
                4 TSM:INIT
                5 TSF:WUR:MS=0
                11 TSM:INIT:TSP OK
                15 TSM:FPAR
                2067 TSM:FPAR
                4119 TSM:FPAR
                6171 TSM:FPAR
                8221 !TSM:FPAR:FAIL
                8222 TSM:FAIL:CNT=1
                8224 TSM:FAIL:PDT
                sudo mysgw -d
                mysgw: TSF:LRT:OK
                mysgw: TSM:INIT
                mysgw: TSF:WUR:MS=0
                mysgw: MCO:BGN:STP
                Where is problem?
                @macvictor
                But how use itn on RFM69HW ? I dont see to be available #define MY_RFM69_ENABLE_ENCRYPTION... Only for #define MY_RF24_ENABLE_ENCRYPTION...
                • pepsonP pepson
                  Gateway:
                  2. make
                  Node:
                  #define RELAY_ON 1
                  #define RELAY_OFF 0
                  int oldValue = 0;
                  bool state;
                    // Setup the button
                    debouncer.update();
                    delay(5000);
                  4 TSM:INIT
                  5 TSF:WUR:MS=0
                  11 TSM:INIT:TSP OK
                  15 TSM:FPAR
                  2067 TSM:FPAR
                  4119 TSM:FPAR
                  6171 TSM:FPAR
                  8221 !TSM:FPAR:FAIL
                  8222 TSM:FAIL:CNT=1
                  8224 TSM:FAIL:PDT
                  sudo mysgw -d
                  mysgw: TSF:LRT:OK
                  mysgw: TSM:INIT
                  mysgw: TSF:WUR:MS=0
                  mysgw: MCO:BGN:STP
                  Where is problem?
                  @macvictor
                  #731
                  @pepson are you asking how to enable encryption on rfm69? (it is a bit unclear what you mean by "itn")
                  In that case, see https://www.mysensors.org/apidocs-beta/group__RFM69SettingGrpPub.html#ga17a7a919994e569f078e3787c2c4ecd2
                  pepsonP 1 Reply Last reply
                    pepsonP
                    pepsonP
                    pepson
                    @mfalkvidd
                    Yes :) Thanks
                    BTW
                    MySensors gateway as you see is problem with latest beta domoticz.
                    • pepsonP pepson
                      @mfalkvidd
                      Yes :) Thanks
                      BTW
                      #733
                      @pepson yes I saw that. Thanks for checking. Have you reported the problem to the Domoticz team?
                        pepsonP
                        pepsonP
                        pepson
                        @mfalkvidd
                        Yes write on forum Domoticz in section BUG
                        • pepsonP pepson
                          @mfalkvidd
                          @pepson great!
                          The report is at https://www.domoticz.com/forum/viewtopic.php?f=6&t=21125&sid=e414507bb1ca4596e93cf885047275a9 in case someone needs to find it in the future.
                          • G
                            G
                            ghiglie
                            Hello!
                            I'm trying to "make" on Alpine Linux in a Docker (ok, maybe it's useless, but way interesting!).
                            With a Debian image it's ok, but I'd like to use Alpine.
                            I get this error:
                            g++ -MT build/drivers/Linux/SPIDEV.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_GATEWAY_LINUX -DMY_GATEWAY_MQTT_CLIENT -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DSPI_SPIDEV_DEVICE=\"/dev/spidev0.0\"  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/SPIDEV.cpp -o build/drivers/Linux/SPIDEV.o
                            In file included from /usr/include/sys/ioctl.h:7:0,
                                             from drivers/Linux/SPIDEV.cpp:27:
                            drivers/Linux/SPIDEV.cpp: In static member function 'static uint8_t SPIDEVClass::transfer(uint8_t)':
                            drivers/Linux/SPIDEV.cpp:153:18: error: '_IOC_SIZEBITS' was not declared in this scope
                              ret = ioctl(fd, SPI_IOC_MESSAGE(1), &tr);
                            drivers/Linux/SPIDEV.cpp: In static member function 'static void SPIDEVClass::transfernb(char*, char*, uint32_t)':
                            drivers/Linux/SPIDEV.cpp:175:18: error: '_IOC_SIZEBITS' was not declared in this scope
                            make: *** [Makefile:99: build/drivers/Linux/SPIDEV.o] Error 1
                            root@local-mysgw-alpine:/opt/MySensors3$ make
                            eIn file included from /usr/include/sys/ioctl.h:7:0,
                            I'm surely missing a package... but can't state one. Any help?
                            @macvictor thanks for your post, it will help me a lot, I'm trying the same way.
                            atmega328p serial killer
                            HomeAssistant / gateway: ESP8266 & NRF24L01+ gateway
                            • G ghiglie
                              Hello!
                              I get this error:
                              @ghiglie https://lists.yoctoproject.org/pipermail/yocto/2016-January/028233.html seems to suggest that adding
                              #include <asm/ioctl.h>
                              would solve the problem. Could you try that?
                              G 1 Reply Last reply
                                sineverba
                                wrote on last edited by sineverba
                                #738
                                Was my fault!
                                **When copy and past command from word, for example, pay attention that software doesn't substitute the single "-" with a "-" longer. :dizzy_face:
                                I have a word with all commands, to replicate installation very fast. Was my fault (errr... Word fault.... but you understand). Have a nice day!
                                I cannot go over the initialization of command.
                                RPI3 + Amplified antenna by GertSander (https://www.openhardware.io/view/17/Raspberry-Pi2-GPIO-interface-for-NRF24L01). Power from 5v/3A and power for antenna taken from both 5V via the 3.3v stepper down.
                                RPI3 is new, has about 12h (got yesterday).
                                Yesterday it did work at first attempt. Today I would replicate so I did delete the uSD and restart over. No way to get the gateway on work.
                                I did try 3 amplified antenna + 2 normal. No way.
                                I did enable from raspi-config the SPI (and only it).
                                It hangs on second line of output.
                                These are the logs:
                                sineverba@raspberrypi:~/MySensors $ ./configure --my-transport=nrf24 --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB020
                                  [OK] SPI driver detected:BCM.
                                [OK] Finished.
                                sineverba@raspberrypi:~/MySensors $ make
                                gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/log.c -o build/drivers/Linux/log.o
                                g++ -MT build/drivers/Linux/IPAddress.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/IPAddress.cpp -o build/drivers/Linux/IPAddress.o
                                g++ -MT build/drivers/Linux/noniso.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/noniso.cpp -o build/drivers/Linux/noniso.o
                                g++ -MT build/drivers/Linux/GPIO.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/GPIO.cpp -o build/drivers/Linux/GPIO.o
                                g++ -MT build/drivers/Linux/SPIDEV.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/SPIDEV.cpp -o build/drivers/Linux/SPIDEV.o
                                g++ -MT build/drivers/Linux/Print.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/Print.cpp -o build/drivers/Linux/Print.o
                                g++ -MT build/drivers/Linux/EthernetClient.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/EthernetClient.cpp -o build/drivers/Linux/EthernetClient.o
                                g++ -MT build/drivers/Linux/compatibility.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/compatibility.cpp -o build/drivers/Linux/compatibility.o
                                g++ -MT build/drivers/Linux/SerialPort.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/SerialPort.cpp -o build/drivers/Linux/SerialPort.o
                                g++ -MT build/drivers/Linux/Stream.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/Stream.cpp -o build/drivers/Linux/Stream.o
                                g++ -MT build/drivers/Linux/interrupt.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/interrupt.cpp -o build/drivers/Linux/interrupt.o
                                g++ -MT build/drivers/Linux/SerialSimulator.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/SerialSimulator.cpp -o build/drivers/Linux/SerialSimulator.o
                                g++ -MT build/drivers/Linux/SoftEeprom.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/SoftEeprom.cpp -o build/drivers/Linux/SoftEeprom.o
                                g++ -MT build/drivers/Linux/EthernetServer.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/EthernetServer.cpp -o build/drivers/Linux/EthernetServer.o
                                g++ -MT build/examples_linux/mysgw.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c examples_linux/mysgw.cpp -o build/examples_linux/mysgw.o
                                gcc -MT build/drivers/BCM/bcm2835.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/BCM/bcm2835.c -o build/drivers/BCM/bcm2835.o
                                g++ -MT build/drivers/BCM/BCM.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/BCM/BCM.cpp -o build/drivers/BCM/BCM.o
                                g++ -MT build/drivers/BCM/SPIBCM.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/BCM/SPIBCM.cpp -o build/drivers/BCM/SPIBCM.o
                                g++ -MT build/drivers/BCM/Wire.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/BCM/Wire.cpp -o build/drivers/BCM/Wire.o
                                g++ -MT build/drivers/BCM/RPi.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/BCM/RPi.cpp -o build/drivers/BCM/RPi.o
                                g++ -pthread  -o bin/mysgw build/drivers/Linux/log.o build/drivers/Linux/IPAddress.o build/drivers/Linux/noniso.o build/drivers/Linux/GPIO.o build/drivers/Linux/SPIDEV.o build/drivers/Linux/Print.o build/drivers/Linux/EthernetClient.o build/drivers/Linux/compatibility.o build/drivers/Linux/SerialPort.o build/drivers/Linux/Stream.o build/drivers/Linux/interrupt.o build/drivers/Linux/SerialSimulator.o build/drivers/Linux/SoftEeprom.o build/drivers/Linux/EthernetServer.o build/examples_linux/mysgw.o build/drivers/BCM/bcm2835.o build/drivers/BCM/BCM.o build/drivers/BCM/SPIBCM.o build/drivers/BCM/Wire.o build/drivers/BCM/RPi.o
                                sineverba@raspberrypi:~/MySensors $ sudo ./bin/mysgw –d
                                [sudo] password for sineverba:
                                  sineverba
                                  Hi to all,
                                  I'm testing an ethernet gateway on RPI3, with nrf24 + 1 node with a relay.
                                  I want introduce security and signing. On Arduino gateway / node no problem at all, but, how to do on the RPI3 as gateway?
                                  I would get / create / set a software serial on PI itself and whitelisting it on the node, after I will introduce the AES Key and signing.
                                  Cannot find in documentation how do it on PI3. Thank you very much!
                                  • S sineverba
                                    Hi to all,
                                    G
                                    G
                                    ghiglie
                                    @sineverba said in 💬 Building a Raspberry Pi Gateway:
                                    Hi to all,
                                    Earlier in this forum... https://forum.mysensors.org/topic/4803/building-a-raspberry-pi-gateway/350
                                    S 1 Reply Last reply
                                      G
                                      G
                                      ghiglie
                                      wrote on last edited by ghiglie
                                      #741
                                      @mfalkvidd I'm trying today, but to compile correctly the Docker image I'll have to clone to my github account :( or at least locally. My Dockerfile for the "Alpine edition" for Hass.io is simply:
                                      ARG BUILD_FROM
                                      ARG BUILD_ARCH
                                      ARG BUILD_DATE
                                      ARG BUILD_REF
                                      ARG BUILD_VERSION
                                      FROM ${BUILD_FROM}
                                      ENV CONFIG_PATH=/data/options.json
                                      ENV APPDIR=/opt/MySensors
                                      RUN apt-get update && apt-get install -y --force-yes \
                                          make \
                                      	 g++ \
                                      	 git \
                                      	 && rm -rf /var/lib/apt/lists/* /tmp/* /var/tmp/* ~/.cache \
                                      	 && git clone https://github.com/mysensors/MySensors.git --branch development $APPDIR
                                      # Copy root filesystem
                                      COPY rootfs /
                                      #CMD [ "/run.sh" ]
                                      I deleted the LABELS 'cause... the data is still too rawly "buried" from others. :tongue:
                                      The Configure and Make is in run.sh.
                                      BTW, I still need to figure out how to start mysgw as service... Mainlyt I'd like to redirect the log: how can I do this safely?
                                      And... can I use the rx/tx/err led feature on Raspi too (aside being in a Docker) ?
                                      EDIT: the code add works!
                                      Another question: I'm not getting far from this... what is it trying to do?
                                      : MCO:BGN:INIT GW,CP=RNNGL---,VER=2.2.0-rc.2
                                      : TSF:LRT:OK
                                      : TSM:INIT
                                      : TSF:WUR:MS=0
                                      • G ghiglie
                                        Hi to all,
                                        sineverba
                                        @ghiglie Thank you, I did see that was for 2.1.1. Just playing with them!
                                        • alowhumA
                                          alowhumA
                                          alowhum
                                          Does the Pi Gateway support the MY_SIGNING_SIMPLE_PASSWD option? I couldn't find anything about that. I've been gearing up to use that feature in my network, but I've also been playing with moving my gateway onto my Pi Zero W.
                                          gohanG M 2 Replies Last reply
