  2. Announcements
  • pepsonP
    pepsonP
    pepson
    Hello
    Thanks for your help. I start from beginning build DOmoticz on my RPi3 with clean latest image. After run in Sudo raspi-config i enable SPI and Serial , then install DOmoticz and now all works OK. Then build Mysensor Gateway and all is ok with no error in Domoticz. Works on /dev/ttyUSB42
    • pepsonP
      pepsonP
      pepson
      But how i can build MySensors Gateway on serial with radio RFM69HW but on old version 2.1.1 ?
      • pepsonP
        pepsonP
        pepson
        And have next problem... i build sketch on version 2.2.0-rc2 but after write to Arduino Mini Pro he is not connected to my Gateway on RPI3.
        This is sketch. What is wrong ?
           Relay with button sketch
        #define MY_RADIO_RFM69
        #define MY_RFM69_FREQUENCY 868
        #define MY_IS_RFM69HW
        #define MY_RFM69_NEW_DRIVER
        //#define MY_NODE_ID 203                       // Node id defaults to AUTO (tries to fetch id from controller)
        #define RELAY_ON 1
        #define RELAY_OFF 0
        Bounce debouncer = Bounce();
        int oldValue = 0;
        bool uplinkAvailable = true;
        bool state = false;
        bool requestState;
        bool firstStart = true;
        unsigned long oldTime = 0;
        unsigned long newTime = 0;
        void setup(){
          debouncer.interval(5);
        void presentation()  {
          sendSketchInfo("1xRelay & Button", "2.2.0-rc2");
          present(CHILD_ID, S_BINARY);
        void loop(){
              uplinkCheckTime = millis();
             else{
              Serial.println(requestState);
          debouncer.update();
            requestTime();
              oldTime = newTime;
          oldValue = value;
        void uplinkCheck() {
            requestTime();
              oldTime = newTime;
          if (firstStart){
            oldTime = time;
            newTime = time;
          else{
          newTime = time;
          Serial.println(time);
        • pepsonP pepson
          #define RELAY_ON 1
          #define RELAY_OFF 0
          int oldValue = 0;
          bool state = false;
          bool requestState;
          void setup(){
          void loop(){
               else{
            debouncer.update();
              requestTime();
                oldTime = newTime;
            oldValue = value;
              requestTime();
                oldTime = newTime;
            if (firstStart){
              oldTime = time;
              newTime = time;
            else{
            newTime = time;
          zboblamontZ
          zboblamontZ
          zboblamont
          @pepson Try walking in little steps trying each stage rather than running into new walls then expressing surprise at broken nose, no offence intended ;)
          Gateway and nodes, same platform, same version..... Otherwise they are speaking Chinese and Swedish hoping for somebody to explain the meaning of fubar...
          • pepsonP
            pepsonP
            pepson
            wrote on last edited by pepson
            #724
            I use the same version now 2.2.0-rc2 but when i programmed sketch to node it not connection to Gateway... That i want come back to version 2.1.1 gateway but i dont know how ? Or resolved problem Node 2.2.0-rc2 i stay on this.
            But when run debug gateway show this:
            pi@domoticz:~/MySensors $ sudo ./bin/mysgw -d
            mysgw: Starting gateway...
            mysgw: Protocol version - 2.2.0-rc.2
            mysgw: MCO:BGN:INIT GW,CP=RPNGL---,VER=2.2.0-rc.2
            mysgw: TSF:LRT:OK
            mysgw: TSM:INIT
            mysgw: TSF:WUR:MS=0
            mysgw: TSM:INIT:TSP OK
            mysgw: TSM:INIT:GW MODE
            mysgw: MCO:REG:NOT NEEDED
            mysgw: MCO:BGN:STP
            mysgw: MCO:BGN:INIT OK,TSP=1
            mysgw: !TSF:SAN:FAIL
            mysgw: TSM:FAIL:CNT=1
            mysgw: TSM:FAIL:DIS
            mysgw: TSF:TDI:TSL
            mysgw: TSM:FAIL:RE-INIT
            mysgw: TSM:INIT
            This is sketch 2.2.0-rc2
            #define RFM69_868MHZ
            #define RELAY_ON 1
            #define RELAY_OFF 0
            int oldValue = 0;
            bool state = false;
            bool requestState;
            void setup(){
            void loop(){
                 else{
              debouncer.update();
                requestTime();
                  oldTime = newTime;
              oldValue = value;
                requestTime();
                  oldTime = newTime;
              if (firstStart){
                oldTime = time;
                newTime = time;
              else{
              newTime = time;
            • pepsonP pepson
              mysgw: TSF:LRT:OK
              mysgw: TSM:INIT
              mysgw: TSF:WUR:MS=0
              mysgw: MCO:BGN:STP
              mysgw: TSM:FAIL:DIS
              mysgw: TSF:TDI:TSL
              mysgw: TSM:INIT
              #define RELAY_ON 1
              #define RELAY_OFF 0
              int oldValue = 0;
              bool state = false;
              bool requestState;
              void setup(){
              void loop(){
                   else{
                debouncer.update();
                  requestTime();
                    oldTime = newTime;
                oldValue = value;
                  requestTime();
                    oldTime = newTime;
                if (firstStart){
                  oldTime = time;
                  newTime = time;
                else{
                newTime = time;
              zboblamontZ
              zboblamontZ
              zboblamont
              @pepson Let's try the baby steps I referred to earlier.
              The current stable version of MySensors is 2.1. Those using 2.2 tend to be experienced people versed in programming and experimenting and problem solving, hence it is not an official release.... yet you are using it and asking for solutions... Hello ?
              I am and have been for the last few months using a Pro-Mini with RFM69 as nodes and gateway using 2.1 attached to a Pi3 running Domoticz.... No problems, but slowly coming to understand most of what I am doing...
              I am still on baby steps, I don't mind at all, it works.....
              • pepsonP
                pepsonP
                pepson
                Ok but i dont know how build Gateway on version 2.1.1 because when i do step by step as show on mysensors.org it default build me version gateway 2.2.0-rc2
                • pepsonP pepson
                  zboblamontZ
                  zboblamontZ
                  zboblamont
                  @pepson As in this page? 2.1.1 - Latest Release ?
                  https://www.mysensors.org/download
                  • pepsonP
                    pepsonP
                    pepson
                    I found bug in Domoticz BETA 8796. No reconized version gateway in HARDWARE. On stable 8153 works with no problem and correct reconized version gateway 2.2.0-rc2...
                    And again problem with this:
                    CODE: SELECT ALL
                    2017-12-28 20:01:32.587 MySensors: retrying in 30 seconds...
                    2017-12-28 20:02:08.752 MySensors: Using serial port: /dev/serial0
                    2017-12-28 20:02:08.752 MySensors: Gateway Version: 2.2.0-rc.2
                    2017-12-28 20:02:08.752 Error: Serial Port closed!... Error: End of file
                    2017-12-28 20:02:09.752 MySensors: retrying in 30 seconds...
                    2017-12-28 20:02:38.755 MySensors: Using serial port: /dev/serial0
                    2017-12-28 20:02:38.755 Error: Serial Port closed!... Error: End of file
                    2017-12-28 20:02:39.755 MySensors: retrying in 30 seconds...
                    2017-12-28 20:03:08.757 MySensors: Using serial port: /dev/serial0
                    2017-12-28 20:03:08.761 Error: Serial Port closed!... Error: End of file
                    2017-12-28 20:03:09.758 MySensors: retrying in 30 seconds...
                    On beta is problem.
                    On stable works correct.
                    • M macvictor
                      @marceloaqno Thank's for you help. I have other question.. general I try configure my gateway to work with security & signing, but they doesn't work. Where is problem? On the bottom i send point what it do it:
                      Gateway:
                      2. make
                      3. sudo make install
                      10. sudo mysgw --gen-aes-key
                      Node:
                      #define USE_SOFT_SIGNING
                      #define STORE_SOFT_KEY
                      #define USER_SOFT_KEY
                      #define STORE_SOFT_SERIAL
                      #define STORE_AES_KEY
                      #define USER_AES_KEY
                      EEPROM configuration:
                      // Enable NRF24L01 radio type
                      // Select soft signing
                      #define MY_SIGNING_SOFT
                      // Enable node whitelisting
                      #define RELAY_ON 1
                      #define RELAY_OFF 0
                      int oldValue = 0;
                      bool state;
                        // Setup the button
                        pinMode(BUTTON_PIN, INPUT);
                        // Activate internal pull-up
                        state = loadState(CHILD_ID);
                        debouncer.update();
                      //  oldValue = value;
                        delay(5000);
                        if (message.isAck()) {
                          // Change relay state
                          // Store state in eeprom
                      4 TSM:INIT
                      5 TSF:WUR:MS=0
                      11 TSM:INIT:TSP OK
                      13 TSF:SID:OK,ID=105
                      15 TSM:FPAR
                      2065 !TSM:FPAR:NO REPLY
                      2067 TSM:FPAR
                      4117 !TSM:FPAR:NO REPLY
                      4119 TSM:FPAR
                      6169 !TSM:FPAR:NO REPLY
                      6171 TSM:FPAR
                      8221 !TSM:FPAR:FAIL
                      8222 TSM:FAIL:CNT=1
                      8224 TSM:FAIL:PDT
                      and in gateway i see:
                      sudo mysgw -d
                      mysgw: TSF:LRT:OK
                      mysgw: TSM:INIT
                      mysgw: TSF:WUR:MS=0
                      mysgw: MCO:BGN:STP
                      mysgw: connected to 127.0.0.1
                      mysgw: MQTT connected
                      mysgw: !TSF:MSG:PVER,3=2
                      mysgw: !TSF:MSG:PVER,1=2
                      mysgw: TSF:MSG:REL MSG
                      mysgw: !TSF:RTE:240 UNKNOWN
                      mysgw: !TSF:MSG:PVER,0=2
                      mysgw: !TSF:RTE:233 UNKNOWN
                      mysgw: !TSF:RTE:51 UNKNOWN
                      Where is problem?
                      pepsonP
                      pepsonP
                      pepson
                      • M macvictor
                        Gateway:
                        2. make
                        Node:
                        #define RELAY_ON 1
                        #define RELAY_OFF 0
                        int oldValue = 0;
                        bool state;
                          // Setup the button
                          debouncer.update();
                          delay(5000);
                        4 TSM:INIT
                        5 TSF:WUR:MS=0
                        11 TSM:INIT:TSP OK
                        15 TSM:FPAR
                        2067 TSM:FPAR
                        4119 TSM:FPAR
                        6171 TSM:FPAR
                        8221 !TSM:FPAR:FAIL
                        8222 TSM:FAIL:CNT=1
                        8224 TSM:FAIL:PDT
                        sudo mysgw -d
                        mysgw: TSF:LRT:OK
                        mysgw: TSM:INIT
                        mysgw: TSF:WUR:MS=0
                        mysgw: MCO:BGN:STP
                        Where is problem?
                        pepsonP
                        pepsonP
                        pepson
                        @macvictor said in 💬 Building a Raspberry Pi Gateway:
                        Gateway:
                        2. make
                        Node:
                        #define RELAY_ON 1
                        #define RELAY_OFF 0
                        int oldValue = 0;
                        bool state;
                          // Setup the button
                          debouncer.update();
                          delay(5000);
                        4 TSM:INIT
                        5 TSF:WUR:MS=0
                        11 TSM:INIT:TSP OK
                        15 TSM:FPAR
                        2067 TSM:FPAR
                        4119 TSM:FPAR
                        6171 TSM:FPAR
                        8221 !TSM:FPAR:FAIL
                        8222 TSM:FAIL:CNT=1
                        8224 TSM:FAIL:PDT
                        sudo mysgw -d
                        mysgw: TSF:LRT:OK
                        mysgw: TSM:INIT
                        mysgw: TSF:WUR:MS=0
                        mysgw: MCO:BGN:STP
                        Where is problem?
                        @macvictor
                        But how use itn on RFM69HW ? I dont see to be available #define MY_RFM69_ENABLE_ENCRYPTION... Only for #define MY_RF24_ENABLE_ENCRYPTION...
                        • pepsonP pepson
                          Gateway:
                          2. make
                          Node:
                          #define RELAY_ON 1
                          #define RELAY_OFF 0
                          int oldValue = 0;
                          bool state;
                            // Setup the button
                            debouncer.update();
                            delay(5000);
                          4 TSM:INIT
                          5 TSF:WUR:MS=0
                          11 TSM:INIT:TSP OK
                          15 TSM:FPAR
                          2067 TSM:FPAR
                          4119 TSM:FPAR
                          6171 TSM:FPAR
                          8221 !TSM:FPAR:FAIL
                          8222 TSM:FAIL:CNT=1
                          8224 TSM:FAIL:PDT
                          sudo mysgw -d
                          mysgw: TSF:LRT:OK
                          mysgw: TSM:INIT
                          mysgw: TSF:WUR:MS=0
                          mysgw: MCO:BGN:STP
                          Where is problem?
                          @macvictor
                          #731
                          @pepson are you asking how to enable encryption on rfm69? (it is a bit unclear what you mean by "itn")
                          In that case, see https://www.mysensors.org/apidocs-beta/group__RFM69SettingGrpPub.html#ga17a7a919994e569f078e3787c2c4ecd2
                          pepsonP 1 Reply Last reply
                            pepsonP
                            pepsonP
                            pepson
                            @mfalkvidd
                            Yes :) Thanks
                            BTW
                            MySensors gateway as you see is problem with latest beta domoticz.
                            • pepsonP pepson
                              @mfalkvidd
                              Yes :) Thanks
                              BTW
                              #733
                              @pepson yes I saw that. Thanks for checking. Have you reported the problem to the Domoticz team?
                                pepsonP
                                pepsonP
                                pepson
                                @mfalkvidd
                                Yes write on forum Domoticz in section BUG
                                • pepsonP pepson
                                  @mfalkvidd
                                  @pepson great!
                                  The report is at https://www.domoticz.com/forum/viewtopic.php?f=6&t=21125&sid=e414507bb1ca4596e93cf885047275a9 in case someone needs to find it in the future.
                                  • G
                                    G
                                    ghiglie
                                    Hello!
                                    I'm trying to "make" on Alpine Linux in a Docker (ok, maybe it's useless, but way interesting!).
                                    With a Debian image it's ok, but I'd like to use Alpine.
                                    I get this error:
                                    g++ -MT build/drivers/Linux/SPIDEV.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_GATEWAY_LINUX -DMY_GATEWAY_MQTT_CLIENT -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DSPI_SPIDEV_DEVICE=\"/dev/spidev0.0\"  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/SPIDEV.cpp -o build/drivers/Linux/SPIDEV.o
                                    In file included from /usr/include/sys/ioctl.h:7:0,
                                                     from drivers/Linux/SPIDEV.cpp:27:
                                    drivers/Linux/SPIDEV.cpp: In static member function 'static uint8_t SPIDEVClass::transfer(uint8_t)':
                                    drivers/Linux/SPIDEV.cpp:153:18: error: '_IOC_SIZEBITS' was not declared in this scope
                                      ret = ioctl(fd, SPI_IOC_MESSAGE(1), &tr);
                                    drivers/Linux/SPIDEV.cpp: In static member function 'static void SPIDEVClass::transfernb(char*, char*, uint32_t)':
                                    drivers/Linux/SPIDEV.cpp:175:18: error: '_IOC_SIZEBITS' was not declared in this scope
                                    make: *** [Makefile:99: build/drivers/Linux/SPIDEV.o] Error 1
                                    root@local-mysgw-alpine:/opt/MySensors3$ make
                                    eIn file included from /usr/include/sys/ioctl.h:7:0,
                                    I'm surely missing a package... but can't state one. Any help?
                                    @macvictor thanks for your post, it will help me a lot, I'm trying the same way.
                                    atmega328p serial killer
                                    HomeAssistant / gateway: ESP8266 & NRF24L01+ gateway
                                    • G ghiglie
                                      Hello!
                                      I get this error:
                                      @ghiglie https://lists.yoctoproject.org/pipermail/yocto/2016-January/028233.html seems to suggest that adding
                                      #include <asm/ioctl.h>
                                      would solve the problem. Could you try that?
                                      G 1 Reply Last reply
                                        sineverba
                                        wrote on last edited by sineverba
                                        #738
                                        Was my fault!
                                        **When copy and past command from word, for example, pay attention that software doesn't substitute the single "-" with a "-" longer. :dizzy_face:
                                        I have a word with all commands, to replicate installation very fast. Was my fault (errr... Word fault.... but you understand). Have a nice day!
                                        I cannot go over the initialization of command.
                                        RPI3 + Amplified antenna by GertSander (https://www.openhardware.io/view/17/Raspberry-Pi2-GPIO-interface-for-NRF24L01). Power from 5v/3A and power for antenna taken from both 5V via the 3.3v stepper down.
                                        RPI3 is new, has about 12h (got yesterday).
                                        Yesterday it did work at first attempt. Today I would replicate so I did delete the uSD and restart over. No way to get the gateway on work.
                                        I did try 3 amplified antenna + 2 normal. No way.
                                        I did enable from raspi-config the SPI (and only it).
                                        It hangs on second line of output.
                                        These are the logs:
                                        sineverba@raspberrypi:~/MySensors $ ./configure --my-transport=nrf24 --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB020
                                          [OK] SPI driver detected:BCM.
                                        [OK] Finished.
                                        sineverba@raspberrypi:~/MySensors $ make
                                        gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/log.c -o build/drivers/Linux/log.o
                                        g++ -MT build/drivers/Linux/IPAddress.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/IPAddress.cpp -o build/drivers/Linux/IPAddress.o
                                        g++ -MT build/drivers/Linux/noniso.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/noniso.cpp -o build/drivers/Linux/noniso.o
                                        g++ -MT build/drivers/Linux/GPIO.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/GPIO.cpp -o build/drivers/Linux/GPIO.o
                                        g++ -MT build/drivers/Linux/SPIDEV.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/SPIDEV.cpp -o build/drivers/Linux/SPIDEV.o
                                        g++ -MT build/drivers/Linux/Print.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/Print.cpp -o build/drivers/Linux/Print.o
                                        g++ -MT build/drivers/Linux/EthernetClient.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/EthernetClient.cpp -o build/drivers/Linux/EthernetClient.o
                                        g++ -MT build/drivers/Linux/compatibility.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/compatibility.cpp -o build/drivers/Linux/compatibility.o
                                        g++ -MT build/drivers/Linux/SerialPort.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/SerialPort.cpp -o build/drivers/Linux/SerialPort.o
                                        g++ -MT build/drivers/Linux/Stream.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/Stream.cpp -o build/drivers/Linux/Stream.o
                                        g++ -MT build/drivers/Linux/interrupt.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/interrupt.cpp -o build/drivers/Linux/interrupt.o
                                        g++ -MT build/drivers/Linux/SerialSimulator.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/SerialSimulator.cpp -o build/drivers/Linux/SerialSimulator.o
                                        g++ -MT build/drivers/Linux/SoftEeprom.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/SoftEeprom.cpp -o build/drivers/Linux/SoftEeprom.o
                                        g++ -MT build/drivers/Linux/EthernetServer.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/EthernetServer.cpp -o build/drivers/Linux/EthernetServer.o
                                        g++ -MT build/examples_linux/mysgw.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c examples_linux/mysgw.cpp -o build/examples_linux/mysgw.o
                                        gcc -MT build/drivers/BCM/bcm2835.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/BCM/bcm2835.c -o build/drivers/BCM/bcm2835.o
                                        g++ -MT build/drivers/BCM/BCM.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/BCM/BCM.cpp -o build/drivers/BCM/BCM.o
                                        g++ -MT build/drivers/BCM/SPIBCM.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/BCM/SPIBCM.cpp -o build/drivers/BCM/SPIBCM.o
                                        g++ -MT build/drivers/BCM/Wire.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/BCM/Wire.cpp -o build/drivers/BCM/Wire.o
                                        g++ -MT build/drivers/BCM/RPi.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_SERIAL -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_SERIAL_PTY=\"/dev/ttyUSB020\" -DMY_LINUX_IS_SERIAL_PTY  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/BCM/RPi.cpp -o build/drivers/BCM/RPi.o
                                        g++ -pthread  -o bin/mysgw build/drivers/Linux/log.o build/drivers/Linux/IPAddress.o build/drivers/Linux/noniso.o build/drivers/Linux/GPIO.o build/drivers/Linux/SPIDEV.o build/drivers/Linux/Print.o build/drivers/Linux/EthernetClient.o build/drivers/Linux/compatibility.o build/drivers/Linux/SerialPort.o build/drivers/Linux/Stream.o build/drivers/Linux/interrupt.o build/drivers/Linux/SerialSimulator.o build/drivers/Linux/SoftEeprom.o build/drivers/Linux/EthernetServer.o build/examples_linux/mysgw.o build/drivers/BCM/bcm2835.o build/drivers/BCM/BCM.o build/drivers/BCM/SPIBCM.o build/drivers/BCM/Wire.o build/drivers/BCM/RPi.o
                                        sineverba@raspberrypi:~/MySensors $ sudo ./bin/mysgw –d
                                        [sudo] password for sineverba:
                                          sineverba
                                          Hi to all,
                                          I'm testing an ethernet gateway on RPI3, with nrf24 + 1 node with a relay.
                                          I want introduce security and signing. On Arduino gateway / node no problem at all, but, how to do on the RPI3 as gateway?
                                          I would get / create / set a software serial on PI itself and whitelisting it on the node, after I will introduce the AES Key and signing.
                                          Cannot find in documentation how do it on PI3. Thank you very much!
