  3. πŸ’¬ Soil Moisture Sensor Pro Mini
pro minisoilmoisturemysensornrf24l01
23 Posts 10 Posters 9.5k Views 10 Watching
  • O Offline
    O Offline
    openhardware.io
    https://www.openhardware.io/view/339/Soil-Moisture-Sensor-Pro-Mini
    • J Offline
      J Offline
      Justas
      Great staff :)
      In picture you attached, looks like the led on Arduino Pro is missing. Did you desoldered it or just did something else with it :)?
      Regards
      Justas
      • tonnerre33T Offline
        tonnerre33T Offline
        tonnerre33
        I desoldered it for increase the battery life ;) I did the same for the regulator.
        You can find more informations here : https://www.mysensors.org/build/battery
        Thx for your interest :)
        I have just posted the pictures of the v1.1 version. Have fun.
        • D Offline
          Daanozz
          Realy cool i try it !!!!!
          • J Offline
            J Offline
            Justas
            Hi, again,
            OK, one more question: if you have desoldered regulator, I do not see any voltage step up booster? The batteries will go low eventually, but you could use with the booster little longer...
            Info from the same https://www.mysensors.org/build/battery :)
            L tonnerre33T 2 Replies Last reply
            • J Justas
              Hi, again,
              L Offline
              L Offline
              LastSamurai
              @Justas said in πŸ’¬ Soil Moisture Sensor Pro Mini:
              Hi, again,
              But the booster will also use some energy itself and it introduces noise which in my experience really creates problems with the NRF. Imho its better to simply skip the boost converter as the nrf and arduino both work down to 1.8V
              • J Justas
                Hi, again,
                tonnerre33T Offline
                tonnerre33T Offline
                tonnerre33
                @Justas
                I am agree with @LastSamurai .
                You can find more informations in the @scalz post here https://forum.mysensors.org/topic/5294/inexpensive-3-3v-boost-converter/2 .
                But if you want to use more battery capacity, you need to change the extended fuse of the Atmega328 (i wrote an example in the skecth).
                If you don't do this the pro mini will restart when the voltage will go under 2.7V in general when the he can continue to run with 2.34V at 8mhz.
                • G Offline
                  G Offline
                  Grumpf
                  Know you have a new one but I ordered your PCBs anyway as I had Pro mini laying around. Thank you for your work, I soldered one and it worked immediately. Now I'll go on with the 4 others and try to desolder led/v reg we'll see how many I fucked up this way :)
                  You saved plants lives, know that !
                  Cheers.
                    tonnerre33T Offline
                    tonnerre33
                    @grumpf said in πŸ’¬ Soil Moisture Sensor Pro Mini:
                    Thank you Grumpf ;)
                    For ended well this project i would like to make a beautifull enclosure. But i haven't yet a 3D printer for do it.
                    Maybe in the end of 2018 cause i have many projects before.
                    If you haven't an enclosure i advise you to put a wire between the probe and the node because when you will water the plant, the batteries can be drowned.
                    G 1 Reply Last reply
                    • tonnerre33T tonnerre33
                      Thank you Grumpf ;)
                      G Offline
                      G Offline
                      Grumpf
                      @tonnerre33
                      My wife is known as Hitler's green thumb, so no risk of overwatering here; this node will dissolve into oblivion by normal decaying before any water ever touches it... Gonna solder the other boards tomorrow though, thanks again for all your work, it's really appreciated! Happy NY 2018 :)
                      • G Offline
                        G Offline
                        Grumpf
                        Hi, I soldered 4 others, using AA holder instead, figuring it won't hurt as I have room for it. I changed:
                        /* Initialization */
                        //Setup LED INFO pin
                        pinMode(LED_PIN_INFO, OUTPUT);
                        //Setup LED WARNING pin
                        pinMode(LED_PIN_WARN, OUTPUT);
                        //Set moisutre sensor pins
                        for (int i = 0; i < N_ELEMENTS(SENSOR_ANALOG_PINS); i++)
                        pinMode(SENSOR_ANALOG_PINS[i], OUTPUT);
                        digitalWrite(SENSOR_ANALOG_PINS[i], LOW);
                        //Blink leds to check
                        blinkLed(LED_PIN_INFO,800);
                        blinkLed(LED_PIN_WARN,800);
                        blinkLed(LED_PIN_INFO,400);
                        blinkLed(LED_PIN_WARN,400);
                        blinkLed(LED_PIN_INFO,200);
                        blinkLed(LED_PIN_WARN,200);
                        blinkLed(LED_PIN_INFO,100);
                        blinkLed(LED_PIN_WARN,100);
                        To test Leds when initializing and never managed ot have LED1 blink ? Dunno what I did wrong, I used correct resistor and normal 3mm leds, tested the pads and realizing that GND was the pad further from the edge; aligned with the - from the neighboor capacitor... What did I do wrong ?
                        Grumpf.
                        • G Grumpf
                          Grumpf.
                          tonnerre33T Offline
                          tonnerre33T Offline
                          tonnerre33
                          @grumpf Hello,
                          if i remember well, we can't anymore change the state of the output in the setup function.
                          Try to do this in the presentation function ;)
                          • G Offline
                            G Offline
                            Grumpf
                            Hi, it worked, you still can shake things a lil' bit in setup (sorry wasn't clear I meant the led test is working). Thanks for your time. I ordered more PCBs today and will keep you posted. I expect no trouble at all as it was designed very well. Thank you again for it!
                            • UL7AAjrU Offline
                              UL7AAjrU Offline
                              UL7AAjr
                              Frankenstein monster)
                              • UL7AAjrU Offline
                                UL7AAjrU Offline
                                UL7AAjr
                                Here is a core of my capcitive soil moisture sensor with NRF24L on board. It sends periodically measured value (about once per 10 minutes). Battery is CR2032 able to work about one year. Any two isolated electrodes can be connected.
                                • M Offline
                                  M Offline
                                  MikaelJones
                                  Nice! How long should we expect the 2xAAA batteries to last? Of course depending on quality but more than a year?
                                  UL7AAjrU 1 Reply Last reply
                                  • M MikaelJones
                                    UL7AAjrU Offline
                                    UL7AAjrU Offline
                                    UL7AAjr
                                    @mikaeljones
                                    it's depend of how often sensor will send data. I suppose that much more then one year if exchange data interval will be 5 min. The problem is that nrf24L not reliable especially in "noisy" environment. And finding a free channel will take a time that affect battery lifetime .
                                    • ThucarT Offline
                                      ThucarT Offline
                                      Thucar
                                      @UL7AAjr do you feel like sharing some information on that sweet looking sensor of yours? I'm doing my research on different styles of capacitive soil moisture sensors right now and would love to hear about your solution and the reasoning behind the choices you made :)
                                      Controller: Node-Red
                                      Gateway: SerialGateway & GSMMQTTGateway
                                      MySensors: 2.2.0
                                      • ThucarT Thucar
                                        UL7AAjrU Offline
                                        UL7AAjrU Offline
                                        UL7AAjr
                                        @thucar
                                        Hello, i'm not sure it is to good idea to public links here, but there is my personal website where is some sensors examples in sensors history page http://vegimatics.com/products/history/
                                        And of course, we can discuss here some interesting for you things)
                                        • M Offline
                                          M Offline
                                          MikaelJones
                                          So would you say there are better solutions to building a soil moisture monitoring for many plants ol the cheap? For me, it’s mainly for fun and making sure I don’t miss watering my plants at home :)
                                          With your input, this post could be even better πŸ’—
