  3. No matching function for call 'DHT::DHT()'
6 Posts 3 Posters 8.4k Views 3 Watching
  • DickD Offline
    DickD Offline
    Dick
    First of all 'Happy new year!'. I am working on the example script of the DHT22 https://www.mysensors.org/build/humidity. I read already some other builders about the library (I use version 2.1.1) I already downloaded the the DHT lib from gidhub but still the error as mentioned in the title. Who can help me. I use an Arduino nano.
    D 1 Reply Last reply
    • DickD Dick
      @dick Sounds like a possible library issue. The example code actually uses a modified DHT library which can be found in the libraries folder in this zip file. Try that and see if that fixes your issue.
      Happy new year to you also.
      DickD 1 Reply Last reply
      • D dbemowsk
        DickD Offline
        DickD Offline
        Dick
        wrote on last edited by Dick
        @dbemowsk Thanks for the reply. After a fresh install of the Arduino IDE and adding the MySensors lib and the DHT lib you send me in the link, the compiling finished without errors but Now I have another strange behaviour where I work already on the whole day but I cannot find it. Looking on the serial monitor I see, (and I include a log from another already working switch)
        0 MCO:BGN:INIT REPEATER,CP=RNNRA--,VER=2.1.1
        3 MCO:BGN:BFR
        5 TSM:INIT
        6 TSF:WUR:MS=0
        13 TSM:INIT:TSP OK
        15 TSF:SID:OK,ID=6
        16 TSM:FPAR
        58 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        181 TSF:MSG:READ,0-0-6,s=255,c=3,t=8,pt=1,l=1,sg=0:0
        186 TSF:MSG:FPAR OK,ID=0,D=1
        329 TSF:MSG:READ,3-3-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
        334 TSF:MSG:BC
        2065 TSM:FPAR:OK
        2066 TSM:ID
        2067 TSM:ID:OK
        2069 TSM:UPL
        2073 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
        2084 TSF:MSG:READ,0-0-6,s=255,c=3,t=25,pt=1,l=1,sg=0:1
        2089 TSF:MSG:PONG RECV,HP=1
        2093 TSM:UPL:OK
        2094 TSM:READY:ID=6,PAR=0,DIS=1
        2102 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
        2111 TSF:MSG:READ,0-0-6,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
        2119 TSF:MSG:SEND,6-6-0-0,s=255,c=0,t=18,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
        2128 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
        2144 TSF:MSG:READ,0-0-6,s=255,c=3,t=6,pt=0,l=1,sg=0:M
        2152 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=11,pt=0,l=5,sg=0,ft=0,st=OK:Relay
        2161 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
        2169 TSF:MSG:SEND,6-6-0-0,s=1,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
        2179 TSF:MSG:SEND,6-6-0-0,s=2,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
        2184 MCO:REG:REQ
        2189 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
        2197 TSF:MSG:READ,0-0-6,s=255,c=3,t=27,pt=1,l=1,sg=0:1
        2202 MCO:PIM:NODE REG=1
        2204 MCO:BGN:STP
        2206 MCO:BGN:INIT OK,TSP=1
        After loading the same script on the same device, the result is:
        3 MCO:BGN:BFR
        5 TSM:INIT
        6 TSF:WUR:MS=0
        12 TSM:INIT:TSP OK
        14 TSF:SID:OK,ID=6
        16 TSM:FPAR
        52 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        2059 !TSM:FPAR:NO REPLY
        2061 TSM:FPAR
        2097 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        4105 !TSM:FPAR:NO REPLY
        4107 TSM:FPAR
        4143 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        6151 !TSM:FPAR:NO REPLY
        6153 TSM:FPAR
        6189 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        8197 !TSM:FPAR:FAIL
        8198 TSM:FAIL:CNT=1
        8200 TSM:FAIL:PDT
        18203 TSM:FAIL:RE-INIT
        18205 TSM:INIT
        18212 TSM:INIT:TSP OK
        18214 TSF:SID:OK,ID=6
        18216 TSM:FPAR
        18252 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        20260 !TSM:FPAR:NO REPLY
        20262 TSM:FPAR
        20299 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        22306 !TSM:FPAR:NO REPLY
        22308 TSM:FPAR
        22345 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        24352 !TSM:FPAR:NO REPLY
        24354 TSM:FPAR
        24391 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        26398 !TSM:FPAR:FAIL
        26399 TSM:FAIL:CNT=2
        26401 TSM:FAIL:PDT
        This "!TSM:FPAR:FAIL" I get also in my DHT project. It is strange that a working divice (4 days ago), load the same script again and I get an error. Any ideas in wat direction I have to look? Could it be something in the config file?? I do not know.
        • DickD Dick
          3 MCO:BGN:BFR
          5 TSM:INIT
          6 TSF:WUR:MS=0
          13 TSM:INIT:TSP OK
          15 TSF:SID:OK,ID=6
          16 TSM:FPAR
          334 TSF:MSG:BC
          2065 TSM:FPAR:OK
          2066 TSM:ID
          2067 TSM:ID:OK
          2069 TSM:UPL
          2093 TSM:UPL:OK
          2184 MCO:REG:REQ
          2204 MCO:BGN:STP
          3 MCO:BGN:BFR
          5 TSM:INIT
          6 TSF:WUR:MS=0
          12 TSM:INIT:TSP OK
          14 TSF:SID:OK,ID=6
          16 TSM:FPAR
          2061 TSM:FPAR
          4107 TSM:FPAR
          6153 TSM:FPAR
          8197 !TSM:FPAR:FAIL
          8198 TSM:FAIL:CNT=1
          8200 TSM:FAIL:PDT
          18205 TSM:INIT
          18216 TSM:FPAR
          20262 TSM:FPAR
          22308 TSM:FPAR
          24354 TSM:FPAR
          26401 TSM:FAIL:PDT
          @dick great work. I see you're reusing the same id (6) on the new device. Is this done intentionally? Are you sure there is only one node with the same id running?
            DickD Offline
            DickD Offline
            Dick
            @mfalkvidd You are right. This was the problem. I forgot to check that. thanks for the Direction!
            • DickD Dick
              @dick great. Thanks for reporting back.
              12.1k
