  3. CNC PCB milling
CNC PCB milling
933 Posts 28 Posters 823.4k Views 27 Watching
  • rmtuckerR rmtucker
    @neverdie
    I think you should start by altering the acceleration/Max velocity settings etc in grbl.
    Slow them down a little:grinning:
    #359
    I don't see those parameters exposed in flatcam or in chilipeppr either. I guess I have to set them by issuing the grbl commands manually?
    rmtuckerR 1 Reply Last reply
      rmtuckerR
      rmtuckerR
      rmtucker
      @neverdie
      Yes or use bCNC to set them.
      • sundberg84S
        sundberg84S
        Would this be something good to do? https://www.youtube.com/watch?v=7rVmiRgsI1M
        Cut a complete flat peace of wood with the cnc machine?
          @neverdie
          #362
          @neverdie
          This was good advice! I arbitrarily reduced both to 50% of their default values, and so far it appears that repositional accuracy has improved.
          • rmtuckerR
            rmtuckerR
            rmtucker
            Normally i would turn one up at a time until the motors lose steps,then pull them back 20%.
              #364
              @rmtucker How are you noticing when the motor skips? Is it from noticing a delta in test probe depths?
              Also, what's a reasonable target for repositioning accuracy? i.e. if I set z to zero after doing a test probe, then move it around a bunch, and then return to the same x and y position and drop another test probe, how far off from zero is the second test probe? Presently I only have a few datapoints, but so far it's suggesting maybe a maximum of 0.025mm after having done the 50% reductions, whereas before the reductions (i.e. default values) it was more than 0.05mm (maybe a lot more), which is just too much.
              rmtuckerR 2 Replies Last reply
                rmtuckerR
                rmtuckerR
                rmtucker
                @neverdie
                Hmmm how long is a piece of string.:grinning:
                My machine is on a much larger scale but the principal is the same.
                Is this a mechanical inaccuracy or lost steps?
                Make yourself a small program that rapids each axis in turn from one end of the axis to
                the other.
                On my own machine the motors are running pulleys to the leadscrews/ballscrews.
                I place a mark on the pulleys and a pointer (pin and blue tac) when the machine is at 0,0,0.
                I run the program and adjust the accel and velocity returning to 0,0,0 every time and checking the marks always line up.(If they don't lowering the settings 10% and running again).
                Which eventually proves it is not lost steps.
                  rmtuckerR
                  rmtuckerR
                  rmtucker
                  @neverdie
                  Forget using probe to begin with as this would show lost steps but also any mechanical inaccuracy.
                  Just concentrate on the motors to begin with.
                  • andrewA andrew
                    @neverdie once the assembly is done, you should adjust the stepper drivers' current limiting as well.
                    then, it is always good idea to have the basic settings exported from the board, just in case... you can do it by "$$" command sent from the g code sender gui or directly from the serial terminal.
                    currently I use the following settings, the machine might be able to create nice results with higher feed rates, but I did not have enough time to test it and I sticked to the current working config.
                    isolation routing with 2001 bits:
                    • z cut: -0.05mm
                    • feed rate: 200
                    you can calculate the V carving bit's tool width for the given milling depth with the following formula:
                    tan(bit angle/2) * milling depth * 2 + bit's end width
                    for excel formula the bit angle should be provided in radians, so it should look like this
                    tan(radians(bit angle/2)) * milling depth * 2 + bit's end width
                    edge cut or hole milling with the 0.8mm endmill:
                    • feed rate: 170
                    • z cut: -1.7mm
                    • multi depth, depth/pass: 0.2mm
                    drilling:
                    • feed rate: 130
                    • z cut: -1.8
                    the spindle should be 1000 everywhere.
                    most probably your board will not have a bootloader, so it will not be possible to update the firmware via usb serial connection (with avrdude), but it is worth to try it. for me it did not work, so I traced back the MCU pins to the pin rows and used ISP to upgrade the firmware to grbl v1.1f (the board will come with 0.9j if I remember correctly). do not forget to export the gerber settings before you upgrade the firmware, as it will loose those, and you have to re-assign the given values again, after the update.
                    the ISP pinout (from the pin row's top left corner):
                    Reset -> pin 2
                    SCK -> pin 3
                    MISO -> pin 12
                    MOSI -> pin 13
                    5v -> pin1
                    gnd-> bottom row(!) e.g. pin 1
                    #367
                    Wow, those Pololu directions bear an uncanny resemblance to this:
                    https://www.youtube.com/watch?v=lAdvdX88WDs
                    Jokes aside, the Jack stepper motors appear to be rated at 1.3A. @andrew Is that what you assumed when calibrating yours? If so, what Vref did you use? Since the motor driver board is a knock-off, it's not obvious what current sense resistor value to use. i.e. 0.050 ohm, 0.068 ohm, or something else?
                      @andrew Are you planning to provide more detail about how to setup and do double sided PCBs, or is it pretty much RTFM at this point? Just wondering. Your earlier posts were very thorough and helped a lot.
                      andrewA
                      andrewA
                      andrew
                      did you manage to create double sided PCB jobs in the meantime based on my suggestion and on flatcam's documentation? it is not a hardcore process, let me know if you stuck at a given step.
                      regarding to the mentioned upgrades. I agree with @executivul, it doesn't worth to do that with this machine. feedback from steppers, elevation measuring etc are overkill.
                      it's capabilities are more than enough for very precise pcb milling, if you would like to do much more with it, then a different machine could be better instead. if you have issues with the results, then it is configuration / settings / cnc job issue. if you loose steps, then the given stepper driver is not properly adjusted (did you checked the pololu driver configuration from the linked documentation?) or your tool/spindle speed/cutting depth/feed rate is not good for the given job.
                      • andrewA andrew
                        See post immediately above yours.
                        andrewA 1 Reply Last reply
                          I guess measuring Vref is moot, because jack's stepper motor driver included in the kit (https://www.aliexpress.com/store/product/board/424291_32807192686.html?spm=2114.12010612.0.0.e009a31x1CJ1s) does not have an exposed via hole for measuring Vref.
                          So, that leaves the first Pololu method, which is:
                          The A4988 supports such active current limiting, and the trimmer potentiometer on the board can be used to set the current limit. One way to set the current limit is to put the driver into full-step mode and measure the current running through a single motor coil while adjusting the current limit potentiometer. This should be done with the motor holding a fixed position (i.e. without clocking the STEP input). Note that the current you are measuring is only 70% of the actual current limit setting, since both coils are always on and limited to this value in full-step mode, so if you later enable microstepping modes, the current through the coils will be able to exceed this measured full-step current by 40% (1/0.7) on certain steps; please take this into account when using this method to set the current limit. Also, note that you will need to perform this adjustment again if you ever change the logic voltage, Vdd, since the reference voltage that sets the current limit is a function of Vdd.
                          So, it would appear that in order to put the driver into "single step mode," I must remove the driver board and put it into a test jig (or breadboard) which shorts MS1, MS2, AND MS3 to ground, but otherwise wire up the motor according to this diagram:
                          but connecting the STEP pin to Vcc on the logic power supply (?) so as to allow a fixed, but continuous, current through a single motor coil, which is what will be measured.
                          As to the target current through a single coil that I'll be measuring, I guess it should be (0.7)*1.3=0.91amps?
                            andrewA
                            andrewA
                            andrew
                            ok, I thought that you already did it, I told it to you long time ago ;)
                            my controller has 0.1ohm Rcs. the steppers are rated to 1.3A, I configured the drivers to 0.9V which limits the stepper's current to 1.125A.
                              andrewA
                              andrewA
                              andrew
                              @neverdie no. you don't have to remove the drivers. you have to measure everything in place.
                              in the mentioned pololu doc/demonstration it is also noted that the given Vref could be measured on the top of the potentiometer (video 3:15)
                              • andrewA andrew
                                It's done now. The default voltages had been about 0.6v. I just now raised them to 0.9v, same as yours. :)
                                  #374
                                  How many microsteps are being used, anyway? I'm not sure where that's defined. Apparently these drivers support up 1/16 steps, but it might be that larger steps are actually being used (?). If so, then maybe going to smaller steps would help?
                                  I notice one of the Pololu boards has the potential for doing 1/32 steps: https://www.pololu.com/product/2133
                                  and might even be drop-in compatible.
                                    andrewA
                                    andrewA
                                    andrew
                                    wrote on last edited by andrew
                                    #375
                                    How many microsteps are being used, anyway? I'm not sure where that's defined. Apparently these drivers support up 1/16 steps, but it might be that fewer are actually being used (?). If so, then maybe going to smaller steps would help?
                                    this cnc controller board is directly pulls the drivers' MS1,2,3 pins to high, which means that it is "hardcoded" to 1/16 microstep. you really don't need smoother steps than this.
                                      @andrew Great that you're back. Did you alter your max speed and max acceleration values at all from the defaults? You didn't list them in your earlier list of magic numbers.
                                        andrewA
                                        andrewA
                                        andrew
                                        @neverdie I still use my default settings (see below). I re-applied these settings after I flashed the board to grbl 1.1f.
                                        $0=10 (step pulse, usec)
                                        $1=25 (step idle delay, msec)
                                        $6=0 (probe pin invert, bool)
                                        $12=0.002 (arc tolerance, mm)
                                        $13=0 (report inches, bool)
                                        $20=0 (soft limits, bool)
                                        $21=0 (hard limits, bool)
                                        $22=0 (homing cycle, bool)
                                        $100=800.000 (x, step/mm)
                                        $101=800.000 (y, step/mm)
                                        $102=800.000 (z, step/mm)
                                        • andrewA andrew
                                          #378
                                          Looks like the only difference is that your default max rates for x and y were 800, whereas mine were 5000, and your max rate for z was 500, whereas my default was 800 before I cut it by 50% to 400.
                                          In the interest of minimizing differences, I'll adopt your defaults instead.
