  3. Assistance Needed Completing GAS Air Quality Sensor
airmq2gasquality
15 Posts 5 Posters 8.2k Views 1 Watching
  • K
    K
    Konrad Walsh
    @hek & @BulldogLowell
    Thanks - I will change to that and update you
    The ultimate goal here is to make a 5 in 1 sensor.. So what I have already.. this will finish that off
    • K Konrad Walsh
      BulldogLowellB
      BulldogLowellB
      BulldogLowell
      @Konrad-Walsh
      great...
      So I will hold off finishing the CO/CO2 detector for my factory!!
      Jim
      K 1 Reply Last reply
        @Konrad-Walsh
        great...
        Jim
        K
        K
        Konrad Walsh
        wrote on last edited by Konrad Walsh
        @BulldogLowell LOL .. maybe dont depend on my skills..!! :)
        • epierreE
          epierreE
          epierre
          @Konrad-Walsh it seems there is a multi variable object from the vera store that would be used as an input ?
          for a 5 in one, I would recommend CO2 and PM10 (for @BulldogLowell) for they are the only one calibrated.
          Others would need some adjustements, if you can add some "clean air factor" for each gas in the UI parameters that could be sent to the node, that would be a great leap forward.
          Emmanuel
          z-wave - Vera -> Domoticz
          • epierreE epierre
            Emmanuel
            K
            K
            Konrad Walsh
            @epierre OK.. I wil lget this set up functioning first as a stanadalone device. I have the sketch completed now.. Just finishing off the vera files.. Then I will look at improving things
            • korttomaK
              korttomaK
              korttoma
              @Konrad-Walsh have you had time to look in to the device files? I'm using the once you posted and retrieve value from a sensor using V_VAR1 but it would be nice to get the value to show on the device to and not only under a Variable in the advanced tab. I tried to look in to the device files myself but it seems like it is too complicated for me to figure out what to change. I can help out with some testing if you like.
              • Tomas
              K BulldogLowellB 2 Replies Last reply
              • korttomaK korttoma
                K
                K
                Konrad Walsh
                @korttoma Hey
                Bear with me.. I hope to complete this over the weekend.. work got in the way.. But the goal is to achieve what you requested... I just need to stabilize things first
                korttomaK 1 Reply Last reply
                  BulldogLowellB
                  BulldogLowellB
                  BulldogLowell
                  @korttoma
                  Yes, it is possible to display the V_VAR's on the device panel...
                  • K Konrad Walsh
                    @korttoma Hey
                    korttomaK
                    korttomaK
                    korttoma
                    @Konrad-Walsh hope you have had nice relaxing holiday like me. Have you had any possibility to look in to the device files 😁 ?
                    • Tomas
                      K
                      K
                      Konrad Walsh
                      @korttoma Hey
                      Just back on track from today.. so will getting looking to this again
                      • korttomaK
                        korttomaK
                        korttoma
                        Sorry if I'm nagging at you about this @Konrad-Walsh but maybe you just forgot :)
                        Wish I had to skills to do it myself but I don't (I did try but failed miserably).
                        • Tomas
                        • korttomaK
                          korttomaK
                          korttoma
                          I managed to modify the D_AirQuality1.json file to display the value from V_VAR1 on the Device with the Lable CO2.
                          Here it is incase someone wants it:
                          D_AirQuality1.json
                          • Tomas
