  3. Any RFM95 user reports?
56 Posts 8 Posters 20.4k Views 8 Watching
    MikeR
    Triple checked the wiring. .. through a level shifter,
    DIO0 - D2
    NSS - D10
    MOSI - D11
    MISO - D12
    SCK - D13
    GND - GND (only one on the radio, do they all need to be connected?)
    VDD - 3V3
    Does that code look fine?
    Might change the hardware out if that is the case.
    • M MikeR
      @mfalkvidd Thank you, looks like that will help me as well.
      Have had a bit of a tinker and still not getting the transport to initialise.
      #define MY_DEBUG_VERBOSE_RFM95
      #define MY_RADIO_RFM95
      #define RFM95_434MHZ
      #define MY_RFM95_MODEM_CONFIGRUATION RFM95_BW125CR48SF4096
      #define MY_GATEWAY_SERIAL
      // Enable inclusion mode
      Thats what i have for the gateway and this is the response
      0;255;3;0;9;MCO:BGN:INIT GW,CP=RLNGA--,VER=2.1.1
      0;255;3;0;9;TSM:INIT
      0;255;3;0;9;TSF:WUR:MS=0
      0;255;3;0;9;RFM95:INIT
      0;255;3;0;9;TSM:FAIL:CNT=1
      0;255;3;0;9;TSM:FAIL:PDT```
      Anyone able to assist? is the code right and its a hardware issue or is there more that needs to be in the code?
      #42
      @MikeR see if defining these helps (matching the pins you have wired):
      #define 	MY_RFM95_IRQ_PIN
      #define 	MY_RFM95_IRQ_NUM
      #define 	MY_RFM95_CS_PIN
      • mfalkviddM
        #43
        This is what I used for a RFM69 gateway on an esp8266. Something similar should work for RFM95:
        #define MY_RF69_IRQ_PIN D1
        #define MY_RF69_SPI_CS D2 // NSS
        Maybe MY_RF69_IRQ_NUM should be defined as digitalPinToInterrupt(MY_RF69_IRQ_PIN).
        • R
          R
          ricorico94
          I'm very interested in the LoRa thing : it' probably the only way to connect a node to a gateway through several floors of concrete in building.. (or do you think the NRF24 could do it ?)
          Could you share your experience on how you wired your hardware ? (including how you power the RFM95 if the arduino pins can not supply enough power -I read somewhere that Lora require up to 200mA, more than the 20-40mA available on Arduino Pro Mini for instance).
          br,
          • N
            N
            nelsonov
            I'm also having trouble with RFM95's. I'm confused about MY_RFM95_IRQ_PIN and MY_RFM95_IRQ_NUM. Does PIN mean the GPIO pin number or the interrupt pin number? I've noticed that the same physical pin has different numbers depending on their use.
            Also, what is the distinction between MY_RFM95_IRQ_PIN andMY_RFM95_IRQ_NUM?
            https://keybase.io/nelsonov
              Sweeman
              wrote on last edited by Sweeman
              #46
              I don't know whether this helps, but I am also experiencing some trouble testing an RFM95 module.
              I am using the Moteino with FTDI adapter.
              I found that the connection is really instable (I should use some capacitors for a more stable connection I guess, even though there's no problem with the RFM69 433mHz version).
              My configuration is the default one. Don't know if I even have to define it that way, just did it because I had to with the last ones:
              #define MY_DEBUG                                  // used by MySensor (Print debug messages via serial)
              #define MY_RADIO_RFM95                            // Select Radio-Module RFM95
              #define MY_RFM95_FREQUENCY 868            // Define our Frequency of 868 MHz
              #define MY_RFM95_MODEM_CONFIGRUATION RFM95_BW125CR45SF128 //Default for medium Range and medium speed: RFM95_BW125CR45SF128 ; For long range and slow speed: RFM95_BW125CR48SF4096
              #define MY_RFM95_NETWORKID 100                  // leave out for gateway selection
              #define   MY_RFM95_IRQ_PIN   DEFAULT_RFM95_IRQ_PIN
              #define MY_RFM95_IRQ_NUM   DEFAULT_RFM95_IRQ_NUM
              #define MY_RFM95_CS_PIN   DEFAULT_RFM95_CS_PIN
              #define MY_NODE_ID 224                            // Node ID
              #define MY_BAUD_RATE 38400
              Also I am trying to use it with an RPi and FHEM. But this didn't work so far.
              But I do get it to work over the PC-USB using the Arduino Serial-Monitor... Strange.
                How are you powering the radio module?
                S 1 Reply Last reply
                  Sweeman
                  @gohan
                  I am powering the sensor-sided Moteino with 3AA batteries.
                  When I unplug the 433MHz-Gateway from the RPi I at least get an autocreate and exactly one temperature reading.
                  Then it is dead again :expressionless:
                    I'm referring to the vcc of the Rfm95, where are you getting the power from?
                      Sweeman
                      #50
                      @gohan
                      Ah sorry, I misunderstood.
                      The RFM95s VCC is factory-wired to a regulator on the moteino. It is an out of the box MCU+Radio-Unit.
                      See this link for clarification:
                      Moteino with RFM95
                      Sorry for the confusion.
                      EDIT: I just tried changing my normal 433MHz Gateway with Arduino Nano + RFM69HCW on the RPi for a Moteino-integrated-RFM69HCW one.
                      I have the same problem with that as with the LoRa Moteino GW... It works fine with the PC and even gets readings far away, I normally do not get.
                      Hooking it up to the RPi with FHEM it stops working...
                      I can't really explain that? :confused:
                      EDIT 2: I checked the debug of the sensor-sided unit. It says st=OK...
                      So I guess I'll have to check my hardware (FTDI etc.)
                        Ok, the on board regulator should able to provide 250mA while the Rfm95 uses 120mA max, so that should be OK.
                          Sweeman
                          #52
                          @gohan
                          Your point made me look something up. Even though I do use the 2.5 amps powersupply for the RPi3 Model B I did find, that the RPi can only take up to 1Amp max. and depending on what's it doing, it can consume between 700-1000 mA.
                          So hooking up the Moteino + FTDI may max that out even though the USB-Port should supply up to 500mA.
                          raspberrypi.org
                          Typically, the model B uses between 700-1000mA depending on what peripherals are connected; the model A can use as little as 500mA with no peripherals attached. The maximum power the Raspberry Pi can use is 1 Amp. If you need to connect a USB device that will take the power requirements above 1 Amp, then you must connect it to an externally-powered USB hub.
                          So I'll try an active HUB next. And if that works I might give this a try:
                          Boost USB-Power
                          This site claims that a change in the RPi's config file should boost the max output current to 1.2 A... Sounds a little wild and unhealthy but I'll give it a shot.
                          Also FTDIchip.com claims that you should use an external USB-power-supply when powering devices with more than 100mA. Everything points into one direction :scream:
                            From my tests I did draw more than 1A when using an 8 relays board attached to the Pi 3, but still it is worth a look at increasing power delivery quality
                              Sweeman
                              Hey guys, a little later but still I've got "kind of" news.
                              Everything I tried to get the Moteino as GW to work consistently failed.
                              It seems the problem either lay with the FTDI or the Moteino as GW. Since I am using a Nano with an Adafruit Breakout RFM95W everything just works fine. It is a little unsatisfying but as I only need Moteinos for Nodes (low battery drain) I will go with this (cheaper) GW.
                                Are you powering the gateway throught the FTDI?
                                  Sweeman
                                  I tried both. 3.3/5V over FTDI and 5V externally.
