  3. Any RFM95 user reports?
56 Posts 8 Posters 20.4k Views 8 Watching
    Sweeman
    wrote on last edited by Sweeman
    #46
    I don't know whether this helps, but I am also experiencing some trouble testing an RFM95 module.
    I am using the Moteino with FTDI adapter.
    I found that the connection is really instable (I should use some capacitors for a more stable connection I guess, even though there's no problem with the RFM69 433mHz version).
    My configuration is the default one. Don't know if I even have to define it that way, just did it because I had to with the last ones:
    #define MY_DEBUG                                  // used by MySensor (Print debug messages via serial)
    #define MY_RADIO_RFM95                            // Select Radio-Module RFM95
    #define MY_RFM95_FREQUENCY 868            // Define our Frequency of 868 MHz
    #define MY_RFM95_MODEM_CONFIGRUATION RFM95_BW125CR45SF128 //Default for medium Range and medium speed: RFM95_BW125CR45SF128 ; For long range and slow speed: RFM95_BW125CR48SF4096
    #define MY_RFM95_NETWORKID 100                  // leave out for gateway selection
    #define   MY_RFM95_IRQ_PIN   DEFAULT_RFM95_IRQ_PIN
    #define MY_RFM95_IRQ_NUM   DEFAULT_RFM95_IRQ_NUM
    #define MY_RFM95_CS_PIN   DEFAULT_RFM95_CS_PIN
    #define MY_NODE_ID 224                            // Node ID
    #define MY_BAUD_RATE 38400
    Also I am trying to use it with an RPi and FHEM. But this didn't work so far.
    But I do get it to work over the PC-USB using the Arduino Serial-Monitor... Strange.
      How are you powering the radio module?
      S 1 Reply Last reply
        Sweeman
        @gohan
        I am powering the sensor-sided Moteino with 3AA batteries.
        When I unplug the 433MHz-Gateway from the RPi I at least get an autocreate and exactly one temperature reading.
        Then it is dead again :expressionless:
          I'm referring to the vcc of the Rfm95, where are you getting the power from?
            Sweeman
            #50
            @gohan
            Ah sorry, I misunderstood.
            The RFM95s VCC is factory-wired to a regulator on the moteino. It is an out of the box MCU+Radio-Unit.
            See this link for clarification:
            Moteino with RFM95
            Sorry for the confusion.
            EDIT: I just tried changing my normal 433MHz Gateway with Arduino Nano + RFM69HCW on the RPi for a Moteino-integrated-RFM69HCW one.
            I have the same problem with that as with the LoRa Moteino GW... It works fine with the PC and even gets readings far away, I normally do not get.
            Hooking it up to the RPi with FHEM it stops working...
            I can't really explain that? :confused:
            EDIT 2: I checked the debug of the sensor-sided unit. It says st=OK...
            So I guess I'll have to check my hardware (FTDI etc.)
              Ok, the on board regulator should able to provide 250mA while the Rfm95 uses 120mA max, so that should be OK.
                Sweeman
                #52
                @gohan
                Your point made me look something up. Even though I do use the 2.5 amps powersupply for the RPi3 Model B I did find, that the RPi can only take up to 1Amp max. and depending on what's it doing, it can consume between 700-1000 mA.
                So hooking up the Moteino + FTDI may max that out even though the USB-Port should supply up to 500mA.
                raspberrypi.org
                Typically, the model B uses between 700-1000mA depending on what peripherals are connected; the model A can use as little as 500mA with no peripherals attached. The maximum power the Raspberry Pi can use is 1 Amp. If you need to connect a USB device that will take the power requirements above 1 Amp, then you must connect it to an externally-powered USB hub.
                So I'll try an active HUB next. And if that works I might give this a try:
                Boost USB-Power
                This site claims that a change in the RPi's config file should boost the max output current to 1.2 A... Sounds a little wild and unhealthy but I'll give it a shot.
                Also FTDIchip.com claims that you should use an external USB-power-supply when powering devices with more than 100mA. Everything points into one direction :scream:
                  From my tests I did draw more than 1A when using an 8 relays board attached to the Pi 3, but still it is worth a look at increasing power delivery quality
                    Sweeman
                    Hey guys, a little later but still I've got "kind of" news.
                    Everything I tried to get the Moteino as GW to work consistently failed.
                    It seems the problem either lay with the FTDI or the Moteino as GW. Since I am using a Nano with an Adafruit Breakout RFM95W everything just works fine. It is a little unsatisfying but as I only need Moteinos for Nodes (low battery drain) I will go with this (cheaper) GW.
                      Are you powering the gateway throught the FTDI?
                        Sweeman
                        I tried both. 3.3/5V over FTDI and 5V externally.
