  3. Battery percentage gone wild [SOLVED]
27 Posts 6 Posters 5.4k Views 6 Watching
  • rozpruwaczR
    rozpruwaczR
    rozpruwacz
    what is the reference voltage of the ADC ? You will get negative batteryPcnt values for sensorValue lower than 837, what happens with the batteryPcnt values ? maybe thaey are treated somewhere as unsigned ? You say You use voltage divider but I don't see that your code is handling the voltage divider.
      He is using internal reference
        Strixx
        @zboblamont Yes. 3V Mini Pro
        @gohan Yes. 0.1uF capacitor.
        @rozpruwacz Internal reference 1.1V. Have a external divider exactly as the example schematics on the home page, to get maximal 1.1 V with two AA batteries.
        As a first step I am trying to understand how the batteryPcnt can ever be higher than 100. With my code that should be impossible. Even if i put 5V on A0.
        vBat should never be able to be higher than v_MAX
        and therefore batteryPcnt should never be able to be higher than 100.
        • S Strixx
          zboblamontZ
          zboblamontZ
          zboblamont
          @strixx What does your #ifdef MY_DEBUG sequence spit out?
            Strixx
            @zboblamont Nothing strange. sensorValues between 800 and 1023, and correct corresponding vBat and batteryPcnt according to my formulas. But that's when I have the serial programmer connected.
            I don't know how to get the serial output from debug without having it connected.
            The strange values only appear when on battery.
            • S Strixx
              zboblamontZ
              zboblamontZ
              zboblamont
              @strixx I think you can disconnect power from the FTDI to the board and leave the battery connected, so long as gnd etc remain connected from FTDI...
              Perhaps somebody can correct me if I'm wrong...
                yes, just unplug the vcc cable
                • K
                  K
                  kimot
                  I always think about this battery percentage. Where it gives its limits.
                  Then I see some project - "NodeManager"
                  GitHub
                  And there was some functions :
                   // [11] the expected vcc when the batter is fully discharged, used to calculate the percentage (default: 2.7)
                        void setBatteryMin(float value);
                        // [12] the expected vcc when the batter is fully charged, used to calculate the percentage (default: 3.3)```
                    as @sundberg84 made in his examples I do an average of the last 4 battery readings
                    • K kimot
                      GitHub
                      zboblamontZ
                      zboblamontZ
                      zboblamont
                      @kimot If there were a problem with the sketch it would equally apply when the ftdi is connected with the sensors connected.
                      I believe that is why @sundberg84 suggested measuring the voltage at A0... ;)
                        Strixx
                        @zboblamont
                        The voltage at A0 is at steady 0,8V with batteries.
                        Which should give sensor value 744.
                        The voltage of the two batteries is 2,88V.
                        But as I wrote earlier it must be so that my multimeters internal resistance is not high enough. And is messing up the divider when measuring.
                        The calculated voltage at A0 should be 0,89V
                        Which should give sensorValue 828
                        My sensors right now is reporting 100% then 253% and now 236%.
                          Strixx
                          @gohan Cant unplug the Vcc from FTDI. Not without cutting the pin on my Mini.
                          And it will not help do average from 4 or even 10 readings. It will still show a messed up percentage. Non of the readings is below 100%
                            use jumper wires
                              Strixx
                              @gohan Thinking outside the box... :joy: will do..
                                Strixx
                                Ok. So connecting the node to serial interface, but without power from it. And power from same batteries.
                                The calculations is correct and multimeter is not measuring correct.
                                This is debug out put:
                                First loop:
                                Sensor value: 1023
                                Battery Voltage: 3.30 V
                                Battery percent: 100 %
                                Second and the following loops:
                                Sensor value: 877
                                Battery Voltage: 2.83 V
                                Battery percent: 21 %
                                So back to square one. When serial output is connected it works perfect.
                                When disconnected it starts reporting all messed up readings!
                                  Do you have an ldo voltage regulator? Maybe you could try 3 batteries for 4.5v output and use a linear regulator to have 3.3v or use 2 fully charged alkaline and power node without booster, as it could be the booster a bit too noisy.
                                  My personal favorite solution is using a single LiFePo4 AA battery and vcc library, no buck/booster and voltage divider, everything much simpler
                                    Strixx
                                    @gohan No regulator except the built in on the card. I also tried with two new AA and when not reporting crazy values it is reporting 74% correlating to calculated vBat of 3,14 and the actual voltage 3,24.
                                    So again; working just fine.
                                      I meant if you have one regulator to try, I think there may be something related to the booster. Try also a bigger capacitor on the booster output, and a big ceramic one if you have on the vcc of arduino
                                      S zboblamontZ 2 Replies Last reply
                                        Strixx
                                        @gohan Well. I think I have found the problem. Investigating now. I will get back during the day when I have tested some more times.
                                          zboblamontZ
                                          zboblamontZ
                                          zboblamont
                                          @gohan Something doesn't make sense here, if the onboard voltage regulator is removed and battery power is connected to Vcc via a booster it should provide a constant supply.
                                          If the divider to A0 is fed with the raw battery supply, it should be relatively constant although decaying over time.
                                          Something is wrong with the circuit I suspect....
                                          S 1 Reply Last reply
