  3. first RFM node & Gateway !TSM:FPAR:FAIL (solved)
16 Posts 6 Posters 6.3k Views 6 Watching
    Could be a wiring issue on the rfm module, Capacitor not close enough to radio, try changing between power levels, how far apart are radio modules? Try setting radio channel to 1 or 250 in order to move away from other possible interference.
    J
    J
    jeti
    @gohan:
    • recheked wiring checked, it is ok (now... DI00 was missing), still the same troubles
    • thea are roughly 40cm apart (Desk)
    • i am using the nrf2rfm69 adapter board, so capacitor is really close
    • downgrading to 2.0 gets this result:
      "Starting sensor (RRNNA-, 2.0.0)
      TSM:INIT
      TSM:RADIO:OK
      TSP:ASSIGNID:OK (ID=102)
      TSM:FPAR
      TSP:MSG:SEND 102-102-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
      TSM:FPAR
      TSM:FPAR
      TSM:FPAR
      !TSM:FPAR:FAIL
      !TSM:FAILURE
      TSM:PDT"
    • changing channels and wpoerlevel works in MySensors.h? As I am just starting with the RFM i did not come across that yet. I also stumbled over the "Connecting the Radio" howto, where is mentioned that some lines need to be added to MySensors.h. Is this needed? if yes where to add them?
    @maman I know that the NRF is the easier one, and I do have several nodes using it. The range issue of the fake modules is bugging me. therefore is would like to give the RFM a go :grinning:
    thanks for your support !
      I'd put them more than 40cm apart, at least 2 meters, sometimes putting sender and receiver too close causes issues.
        Which model of the RFM69 do you use? H-model?
          Maybe in some case sender and receiver too close can generate issues, but i never got this trouble with rfm69, perhaps i'm lucky.. but always better to try in case ;)
          I'm assuming you have capa for both radio, 10uf is ok.
          Because these logs can show :
          • power issues (often NACK for this)
          • DIO0 not well set on the right pin, and rfm69 is interrupt dependant. So if it doesn't get an irq fired, then no receive msg processed, so no reply seen for the ACK = No parent discovery (FPAR)
          • High power settings not set if using RFM69 high power version
          Note: you're not setting the frequency of your radio module, so default Mysensors settings is 868Mhz. If you need a different frequency regarding where you live, then add and change this define MY_RFM69_FREQUENCY.
          We don't know which RFM69 you're using here.
          If for GW, you're using RFM69H serie.. H means high power. and if this is the case, you may have a missing define in your gateway sketch and it can't work. This define MY_IS_RFM69HW
          Finally, i've not checked this, but maybe the irq settings for your DIO0 of your GW RFM69, could be not good..
          You can try this in case:
          #define MY_RF69_IRQ_PIN 32
          #define MY_RF69_IRQ_NUM 32
          (32) is the arduino corresponding pin for PA13 on atsam mcu. which should be your RFM69 DIO0
          All these defines, of course, need to be added at the top of your sketch, before the mysensors includes.
          Finally, if you want to know more about the RFM69 defines and default settngs, you can take a look to the docs here : https://www.mysensors.org/download/sensor_api_20
          • J
            J
            jeti
            Hi Guys,
            thanks for pointing me in the right direction!
            I was missing some defines:
            #define MY_IS_RFM69HW
            now everything looks fine. The node is already discovered in FHEM and working!
            thanks again!
            • wesW
              wesW
              wes
              I had exact same issue and fixed with same solution.
              Should the example sketches have these lines added to them (commented out by default)?
              Blog: https://www.wes.id.au/
              Nodes: Arduino Pro Mini ATMega328P 3.3V 8MHz, RFM69 433MHz, Canton Power CE024 0.8-3.3V regulator & single AA battery
              Gateway & Controller: Raspberry Pi 3 + Home Assistant
                @Wes
                it depends.. if all optional defines would be included in sketches, that may become messy, less readable.
                by default rfm69 driver is configured for 868mhz and non HW.
                if you want to see all available defines, you can take a look at myconfig.h .
                I don't advice to change myconfig.h, instead pick the defines you need and add them to your sketch.
                There is also the doc: https://www.mysensors.org/download/sensor_api_20#configuration
                gohanG 1 Reply Last reply
                • scalzS scalz
                  @Wes
                  @scalz personally I like to change the myconfig.h because this was I'm sure all my nodes have the same configuration. Of course if I use a HW radio I add the define in sketch and I also keep a copy of the file when I update the library
                    @gohan
                    I should have said "wouldn't advice" instead of "don't" ! :grin:
                    well, I don't need to save a file. make some sense for me, as it is located in lib folder.
                    I don't put my defines in the main .ino. To keep things local, and less lines of code, I usually create (or copy/paste) an additional file for each project, "MyDeviceDefines.h".
                    but if it fits well for you, that's great, different strategy, agreed ;)
                      It is just easier to find the necessary defines :-)
