  3. Help Finding Problem
nrf24nodemqtterrorgateway
6 Posts 2 Posters 2.3k Views 1 Watching
  • SoloamS
    SoloamS
    Soloam
    wrote on last edited by Soloam
    Hello all, I've been tring finnaly to assemble my mysensors, and I can't get the gateway to work with the node. I installed de MQTT Gateway on a Arduino Nano, I'm using a NRF24L as radio and a W5100 internet module. So I used The GatewayW5100MQTTClient.
    The Gateway is able to gain IP and connect to my MQTT server, I can see the messages and if I publish a message in "mygateway1-in" I can see them in my serial monitot
    When I connect the node to the power I can see a new message on my MQTT server, and a new input on my Gateway serial:
    0;255;3;0;9;TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    0;255;3;0;9;TSF:MSG:BC
    0;255;3;0;9;TSF:MSG:FPAR REQ,ID=255
    0;255;3;0;9;TSF:PNG:SEND,TO=0
    0;255;3;0;9;TSF:CKU:OK
    0;255;3;0;9;TSF:MSG:GWL OK
    0;255;3;0;9;TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
    0;255;3;0;9;TSF:MSG:READ,255-255-0,s=255,c=3,t=3,pt=0,l=0,sg=0:
    0;255;3;0;9;Sending message on topic: mygateway1-out/255/255/3/0/3
    But in my node I get:
    x00x000 MCO:BGN:INIT NODE,CP=RNNNA--,VER=2.1.1
    4 TSM:INIT
    4 TSF:WUR:MS=0
    12 TSM:INIT:TSP OK
    14 TSM:FPAR
    16 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    36 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    43 TSF:MSG:FPAR OK,ID=0,D=1
    2025 TSM:FPAR:OK
    2025 TSM:ID
    2027 TSM:ID:REQ
    2031 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    4038 TSM:ID
    4038 TSM:ID:REQ
    4042 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    6049 TSM:ID
    6049 TSM:ID:REQ
    6053 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    8062 TSM:ID
    8062 TSM:ID:REQ
    8067 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    10074 !TSM:ID:FAIL
    10076 TSM:FAIL:CNT=1
    10078 TSM:FAIL:PDT
    20082 TSM:FAIL:RE-INIT
    20084 TSM:INIT
    20090 TSM:INIT:TSP OK
    20094 TSM:FPAR
    20097 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    20830 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    20836 TSF:MSG:FPAR OK,ID=0,D=1
    22106 TSM:FPAR:OK
    22108 TSM:ID
    22108 TSM:ID:REQ
    22112 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    24121 TSM:ID
    24121 TSM:ID:REQ
    24125 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    I tried to replace the radios on both, and double checked the connections. I'm using the schematic from https://www.mysensors.org/build/ethernet_gateway on WizNET (W5100) Ethernet module.
    Any ideas?
    Thank You
    Best Regards
    SoloamS 1 Reply Last reply
    • SoloamS Soloam
      4 TSM:INIT
      4 TSF:WUR:MS=0
      12 TSM:INIT:TSP OK
      14 TSM:FPAR
      2025 TSM:FPAR:OK
      2025 TSM:ID
      2027 TSM:ID:REQ
      4038 TSM:ID
      4038 TSM:ID:REQ
      6049 TSM:ID
      6049 TSM:ID:REQ
      8062 TSM:ID
      8062 TSM:ID:REQ
      10074 !TSM:ID:FAIL
      10078 TSM:FAIL:PDT
      20084 TSM:INIT
      20094 TSM:FPAR
      22106 TSM:FPAR:OK
      22108 TSM:ID
      22108 TSM:ID:REQ
      24121 TSM:ID
      24121 TSM:ID:REQ
      Any ideas?
      Thank You
      Best Regards
      SoloamS
      SoloamS
      Soloam
      Just to colmplete, my Full Log
      Gateway
      x00x000;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGA--,VER=2.1.1
      0;255;3;0;9;TSM:INIT
      0;255;3;0;9;TSF:WUR:MS=0
      0;255;3;0;9;TSM:INIT:TSP OK
      0;255;3;0;9;TSM:INIT:GW MODE
      IP: 192.168.2.30
      0;255;3;0;9;MCO:BGN:STP
      IP: 192.168.2.30
      0;255;3;0;9;MQTT connected
      0;255;3;0;9;TSF:CKU:OK,FCTRL
      Node
      4 TSM:INIT
      4 TSF:WUR:MS=0
      12 TSM:INIT:TSP OK
      14 TSM:FPAR
      59 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
      65 TSF:MSG:FPAR OK,ID=0,D=1
      2025 TSM:FPAR:OK
      2025 TSM:ID
      2027 TSM:ID:REQ
      4038 TSM:ID
      4038 TSM:ID:REQ
      6049 TSM:ID
      6049 TSM:ID:REQ
      8062 TSM:ID
      8062 TSM:ID:REQ
      10074 !TSM:ID:FAIL
      10078 TSM:FAIL:PDT
      20084 TSM:INIT
      20094 TSM:FPAR
      20930 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
      20936 TSF:MSG:FPAR OK,ID=0,D=1
      22106 TSM:FPAR:OK
      22108 TSM:ID
      22108 TSM:ID:REQ
      24121 TSM:ID
      24121 TSM:ID:REQ
      26134 TSM:ID
      26134 TSM:ID:REQ
      26138 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      28147 TSM:ID
      28147 TSM:ID:REQ
      28151 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      30162 !TSM:ID:FAIL
      30164 TSM:FAIL:CNT=2
      30167 TSM:FAIL:PDT
      40171 TSM:FAIL:RE-INIT
      40173 TSM:INIT
      40179 TSM:INIT:TSP OK
      40183 TSM:FPAR
      40185 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      40794 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
      40800 TSF:MSG:FPAR OK,ID=0,D=1
      42196 TSM:FPAR:OK
      42199 TSM:ID
      42199 TSM:ID:REQ
      42203 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      44212 TSM:ID
      44212 TSM:ID:REQ
      44216 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      46225 TSM:ID
      46225 TSM:ID:REQ
      46229 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      48238 TSM:ID
      48238 TSM:ID:REQ
      48242 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      50251 !TSM:ID:FAIL
      50253 TSM:FAIL:CNT=3
      50255 TSM:FAIL:PDT
      60258 TSM:FAIL:RE-INIT
      60260 TSM:INIT
      60266 TSM:INIT:TSP OK
      60270 TSM:FPAR
      60272 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      62281 !TSM:FPAR:NO REPLY
      62283 TSM:FPAR
      62285 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      62638 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
      62644 TSF:MSG:FPAR OK,ID=0,D=1
      64296 TSM:FPAR:OK
      64299 TSM:ID
      64299 TSM:ID:REQ
      64303 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      66312 TSM:ID
      66312 TSM:ID:REQ
      66316 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      68325 TSM:ID
      68325 TSM:ID:REQ
      68329 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      70338 TSM:ID
      70338 TSM:ID:REQ
      70342 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      72351 !TSM:ID:FAIL
      72353 TSM:FAIL:CNT=4
      72355 TSM:FAIL:PDT
      82358 TSM:FAIL:RE-INIT
      82360 TSM:INIT
      82366 TSM:INIT:TSP OK
      82370 TSM:FPAR
      82372 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      84381 !TSM:FPAR:NO REPLY
      84383 TSM:FPAR
      84385 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      84475 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
      84482 TSF:MSG:FPAR OK,ID=0,D=1
      86394 TSM:FPAR:OK
      86396 TSM:ID
      86396 TSM:ID:REQ
      86401 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      88410 TSM:ID
      88410 TSM:ID:REQ
      88414 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      90423 TSM:ID
      90423 TSM:ID:REQ
      90427 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      92436 TSM:ID
      92436 TSM:ID:REQ
      92440 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      94449 !TSM:ID:FAIL
      94451 TSM:FAIL:CNT=5
      94453 TSM:FAIL:PDT
      104456 TSM:FAIL:RE-INIT
      104458 TSM:INIT
      104466 TSM:INIT:TSP OK
      104468 TSM:FPAR
      104470 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      105340 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
      105347 TSF:MSG:FPAR OK,ID=0,D=1
      106479 TSM:FPAR:OK
      106481 TSM:ID
      106481 TSM:ID:REQ
      106485 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      108494 TSM:ID
      108494 TSM:ID:REQ
      108498 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      110508 TSM:ID
      110508 TSM:ID:REQ
      110512 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      112521 TSM:ID
      112521 TSM:ID:REQ
      112525 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      114534 !TSM:ID:FAIL
      114536 TSM:FAIL:CNT=6
      114538 TSM:FAIL:PDT
      • SoloamS
        SoloamS
        Soloam
        I can get the node to go to the loop method... I think That it will only go when resisted with the GW
        • SoloamS Soloam
          @soloam communication works fine (indicated by ST=ok).
          The node is asking your controller for an ID, but gets no reply (indicated by !TSM:ID:FAIL)
          Most controllers can not hand out IDs over MQTT.
          Most simple solution is to set a static ID on the node by using
          #define MY_NODE_ID
          (reference)
          The log parser can be useful when troubleshooting.
          • SoloamS
            SoloamS
            Soloam
            OH MY GOD... THAT WAS IT =D
            Thank You
            • SoloamS
              SoloamS
              Soloam
              Just one final question... is the approach to MQTT correct or should I stick with simple Ethernet? I was planning on using OpenHab or Home Assistant.
              Thank You all
