  3. Whole house power monitoring.
hardware sensor power
44 Posts 11 Posters 14.8k Views 11 Watching
    I am using a couple of sonoff pow to measure kitchen and washing machine as they are the most power hungry devices. I am also using a pulse counter on the electric company meter but I figured it is not really working well in reporting instant power readings, while the pulse counter is counting fine but power calculation by domoticz is too slow and I can't use it to switch off the big loads in case of overload ( over here we have 3000W maximum allowed and if you exceed that for few minutes the main switch will cut the power and I was planning to avoid those situations with the help of the sonoffs pow)
    raptorjrR
    raptorjrR
    raptorjr
    @gohan Just curious, where do you live with those restrictions?
    gohanG 1 Reply Last reply
    • raptorjrR raptorjr
      @raptorjr Italy, that is the most common contract for homes, but there are other contracts with 4500w or more and you get charged with an higher fixed monthly fee for the extra power availability even if you actually use it once a month
        @kimot yeah, 5 minutes intervals are not the best for that kind of statistics; you'd probably better look at influxDB for more accurate statistics
        K
        K
        kimot
        @gohan
        5 min interval is not big problem for me.
        Problem is, that this last 5 min interval in each hour is completely lost.
        They do not add it to next hour.
        Next hour is calculated from hh:mm:00 again.
        So first interval hh:00:00 to hh:mm:04.
        InfluxDB is good, but I want all at one web ( domoticz ).
        I try calculate power consumption myself through some Domoticz script.
        • S shabba
          I see some commercial offering that count meter ticks but are there any clamp style current meters that people have used to measure power usage in a house?
          terryrow
          @shabba I have used a clamp meter and arduino uno to monitor power levels, disadvantages are that you need to full wave rectify, provide load resistor and smoothing. Measurement becomes a bit of guesswork as to how many volts o/p in a Kwh.
          Here in Britain, meters have a LED that flashes 1000 times per Kw. I have used a digital light sensor input into arduino uno digital input and then measured the time between flashes in msecs to give accurate readings. I use have used both methods to monitor solar panel output, then turn on Leaf BEV car when sufficient free power is available and off again when clouds arrive. Next step is to o/p readings to a Nextion for both solar and grid power readings with adjustment of turn on thresholds to optimise summer and winter useage.
          gohanG zboblamontZ 2 Replies Last reply
          • T terryrow
            @terryrow do you mind sharing your pulse meter code?
            • T terryrow
              zboblamontZ
              zboblamontZ
              zboblamont
              @terryrow Out of curiosity, was there no output pulse connection on the meter, or is it a sealed 'smart' meter from the supplier?
              Wh pulses appear to be rare on supplier provided meter which piqued my curiosity, they are generally kWh pulses...
                wrote on last edited by gohan
                #36
                Our utility company meters have a flashing led that flashes 1000 times for every Kwh, so 1 flash is a wh
                  zboblamontZ
                  zboblamontZ
                  zboblamont
                  #37
                  @gohan said in Whole house power monitoring.:
                  Fair comment for Italy, but I do not recall similar for the UK, although I must confess I had little interest with respect to monitoring systems at the time.
                  In Romania they have the habit of placing smart meters with pulse flashers in rather large acrylic bubbles (a la Klockner Moeller) out on the main road, which not only renders optical detection difficult, put potentially removeable by every passing drunk.... Hence placing a padlock on the isolator access to dissuade the same folks from switching off the entire house from the main road...
                  • zboblamontZ zboblamont
                    terryrow
                    @zboblamont I cannot see any sockets for a digital o/p. Neither is a smart meter, but both are only 2 years old. The grid meter has an additional green led when power is going out of the house.
                      terryrow
                      @gohan Sorry I have been so long, some things, apparently, are more important than playing on my laptop. I managed to lose the "saved" copy when looking at Nextion mods. I have recovered/repaired and tidied the code but I need your help as to how to share with you.
                      • T terryrow
                        zboblamontZ
                        zboblamontZ
                        zboblamont
                        @terryrow Sorry, perhaps I am misunderstanding your scenario in thinking it may be similar to my own.
                        I cannot access the supplier's meter or optically couple safely as explained above, but I can shut down power to the house, which allowed fitting of a DIN mounted meter in the consumer box. This has both external flashing LED and 2 connections for pulse measurement via clamp screws.
                        If the house meter is less than two years old, it will be digital, and these USUALLY have a connector for external pulse.
                        If you can physically access the meter, google the make and meter type for info, perhaps you have a model with similar pulse connection available. Hence my query...
                        • T terryrow
                          @terryrow just use pastebin and send the link :-)
                          • T
                            terryrow
                            Hello Gohan, unable to find the paste bin or any help section. I need more precise guidance please.
                              pastebin.com
                                pastebin.com
                                terryrow
                                @gohan Thanks, eventually worked it out. https://pastebin.com/D0Cc8TSG should do it for you. writing to the Nextion is creating difficulties.
