  2. Announcements
  3. 💬 Relay
💬 Relay
139 Posts 47 Posters 82.5k Views 45 Watching
  • fhenrycoF fhenryco
    wow! fantastic! ... the github link readme warns that it's not yet fully ready but the interface is already impressive!
    I still have the same question i had for nodemanager though : for measuring another battery than the one that feeds Vcc obviously another pin is needed, however why not propose as well the option of measuring such pin voltage but with Vcc as the reference rather than the internal 1.1V which most of the time makes necessary a voltage divider ? Actually i did the modification in nodemanager.cpp to use DEFAULT (~3.3V) rather than INTERNAL (1.1V) reference for a 3.3 pro mini and i can get the expected battery level without any voltage divider.
    Another unrelated question i have is : could there be any way to adapt the idea of the readVcc method (which is to measure the internal 1.1V against the Vcc reference to get Vcc) but using any voltage applied to a pin as the reference to again measure the internal 1.1 against it ? This would allow the masurement of any voltage greater than 1.1 without voltage divider while the usual method would be applied for measuring any voltage lower than 1.1 ... what did i miss that makes this impossible ?
    fhenrycoF
    fhenrycoF
    fhenryco
    wrote on last edited by fhenryco
    #92
    i also just realized that there is a special AREF pin intended for what i was thinking about ... but it's not available on the mini pro.
    My measurements using Vcc as Ref have been indeed very fluctuating, however what i get was highly sufficient to monitor the battery feeding a 3.3v step up regulator to the arduino and help anticipate failure
    • skywatchS
      skywatchS
      skywatch
      I just noticed another thing that should be changed in the 'relay with button' sketch....
      S_LIGHT should be S_BINARY
      V_LIGHT shoud be V_STATUS
      • A
        APL2017
        I would like to clarify operation of the sketch, where more than 1 sensors input are used along with more than 1 relay actuator. in one node
        1. Does node need unique child ID for each sensor input AND relay output?
        2. If that is the case how child ID is assigned to relay actuators in the above examples?
        • jopebeJ
          jopebeJ
          jopebe
          wrote on last edited by jopebe
          #95
          This is a nice sketch and it is very universal for relays. Now m looking for a similar sketch for digital inputs such as buttons i.e.. I would like to join both. The problem: I want to use a mega for reading status of a lot of digital outputs (min.20) of another ISP. It is only High or Low. Only when the level changes, I want the mega send a message to the gateway. I tried this "for" loop, but it didnt help. There are too many informations sent to the gateway. I imagine a solution, where only a change at the pin will create an information, that is sent to the gateway.
          Here my test, which didnt run:
          for (int sensor=16, pin=BIN_1; sensor<=NUMBER_OF_BIN; sensor++, pin++)
          int BUTT;
          int BUTTOLD;
          BUTT =digitalRead(pin);
          if (BUTT != BUTTOLD && BUTT !=0){
          MyMessage msg(sensor, V_TRIPPED);
          send(msg.set(BUTT ? "1" : "0"));
          BUTTOLD = BUTT;
          wait (900);
          Has anybody an idea or a hint for me?
            I believe there is a logic error in the sketch as you would need to declare global variables BUTTOLD_XX unique for each button, otherwise how can you keep track of the variable between each loop and FOR iteraction?
            • jopebeJ
              jopebeJ
              jopebe
              Thank You for Your quick answer.
              Do I understand You correctly: I must index the BUTTOLD?
              As BUTTOLD[pin) for example or how? Where?
                You need to create the single variables one by one, unless somebody else has a better way to do it
                • Mitja BlazinsekM
                  Mitja BlazinsekM
                  Mitja Blazinsek
                  why i can't compile for arduino pro mini on other boards i can upload
                  • Mitja BlazinsekM Mitja Blazinsek
                    @mitja-blazinsek the error messages are usually essential to figuring out. Did you get any?
                    • Mitja BlazinsekM
                      Mitja BlazinsekM
                      Mitja Blazinsek
                      Arduino: 1.8.1 (Windows 7), Board: "Arduino Pro or Pro Mini, ATmega168 (5V, 16 MHz)"
                      In file included from c:\users\mitja\appdata\local\arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2\avr\include\avr\io.h:99:0,
                                   from c:\users\mitja\appdata\local\arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2\avr\include\avr\pgmspace.h:90,
                                   from C:\Users\mitja\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.20\cores\arduino/Arduino.h:28,
                                   from sketch\button_relay.ino.cpp:1:
                      C:\Users\mitja\Documents\Arduino\libraries\MySensors/hal/architecture/AVR/MyHwAVR.cpp: In function 'bool hwUniqueID(uint8_t (*)[16])':
                      C:\Users\mitja\Documents\Arduino\libraries\MySensors/hal/architecture/AVR/MyHwAVR.cpp:246:26: error: 'SIGRD' was not declared in this scope
                      ((uint8_t)uniqueID) = boot_signature_byte_get(0x00);
                      C:\Users\mitja\Documents\Arduino\libraries\MySensors/hal/architecture/AVR/MyHwAVR.cpp:247:30: error: 'SIGRD' was not declared in this scope
                      ((uint8_t)uniqueID + 1) = boot_signature_byte_get(0x02);
                      C:\Users\mitja\Documents\Arduino\libraries\MySensors/hal/architecture/AVR/MyHwAVR.cpp:248:30: error: 'SIGRD' was not declared in this scope
                      ((uint8_t)uniqueID + 2) = boot_signature_byte_get(0x04);
                      C:\Users\mitja\Documents\Arduino\libraries\MySensors/hal/architecture/AVR/MyHwAVR.cpp:249:30: error: 'SIGRD' was not declared in this scope
                      ((uint8_t)uniqueID + 3) = boot_signature_byte_get(0x01); //OSCCAL
                      Multiple libraries were found for "Bounce2.h"
                      Used: C:\Users\mitja\Documents\Arduino\libraries\Bounce2
                      Not used: C:\Users\mitja\Documents\Arduino\libraries\Bounce2-master
                      exit status 1
                      Error compiling for board Arduino Pro or Pro Mini.
                      • Mitja BlazinsekM
                        Mitja BlazinsekM
                        Mitja Blazinsek
                        OK it's probaly because ia have mini with 168 chip i have to buys 328 :( again wait 1month to arive from china
                        • L
                          L
                          lekeb
                          hello.
                          I am building a node with several kind of sensors and two relays.
                          My sensors use CHILD ID from 0 to 3. I would like to start child ID of relay from 4.
                          How I can't do that with this sketch?
                          I guess I have to change this part of sketch :
                          "for (int sensor=1, pin=RELAY_PIN; sensor<=NUMBER_OF_RELAYS; sensor++, pin++) {
                          present(sensor, S_BINARY);"
                          correct?
                          thanks
                          rejoe2R 1 Reply Last reply
                          • L lekeb
                            hello.
                            correct?
                            thanks
                            rejoe2R
                            rejoe2R
                            rejoe2
                            wrote on last edited by rejoe2
                            #104
                            @lekeb
                            You may do something like this:
                            In Header:
                            uint8_t DS_First_Child_ID = 7; //First Child-ID to be used by Dallas Bus
                            an then in presentation():
                            for (int i = 0; i < numSensors && i < MAX_ATTACHED_DS18B20; i++) {
                                present(i + DS_First_Child_ID, S_TEMP);
                            But afaik, it's not recommended to shift the ChildID's for relays but always start with 1. Imo it's better to change the ChildID's of the other attached sensors. You may also take care (in case of shifting ID's) about a consistent mapping from ID to the PINs where the relays are attached.
                              Agreed, set you sensors to higher ID numbers like 20 or 30 and you are good to go .
                              • L
                                L
                                lekeb
                                ok thanks a lot I will try this night
                                • L
                                  L
                                  lekeb
                                  perfect it works great. I started my temperature sensor at CHILD ID 4 and let relays from 1 to 2. I had to add also "DS_First_Child_ID" in the sent message to gateway.
                                  thanks
                                  • pepsonP
                                    pepsonP
                                    pepson
                                    Hi
                                    Please put to this topic code your sketch....
                                    • L
                                      L
                                      lekeb
                                      Sur,
                                      my node controls two relays, one water pressure sensor and three DS18b20
                                       code pour controle cave a vin, temp et pression
                                      #define MY_REPEATER_FEATURE
                                      #define MY_NODE_ID 15
                                      #include <OneWire.h>
                                      #define BARO_CHILD 0 //Child ID for pressure sensor
                                      #define BAR_SENSOR_ANALOG_PIN 0 // pin for pressure sensor
                                      #define ONE_WIRE_BUS 5 // Pin where dallase sensor is connected
                                      #define RELAY_PIN 3 //pin for first relay
                                      #define NUMBER_OF_RELAYS 2
                                      int numSensors=0;
                                      bool receivedConfig = false;
                                      bool metric = true;
                                      float lastpression;
                                      uint8_t DS_First_Child_ID = 4; //First Child-ID to be used by Dallas Bus
                                      MyMessage msg(0,V_TEMP);
                                      void before()
                                              pinMode(pin, OUTPUT);
                                        sensors.begin();
                                          sendSketchInfo("Buanderie node", "1.0");
                                          //present pressure sensor
                                          present(BARO_CHILD, S_BARO);
                                        //read water pressure
                                      int lecture_adc = analogRead(BAR_SENSOR_ANALOG_PIN);
                                        float pression = ((lecture_adc*5/1024.0)-0.50)/1.7;
                                        if(pression != lastpression) {
                                            send(pressureMsg.set(pression, 2));
                                        lastpression = pression;
                                        sleep(conversionTime);
                                          #if COMPARE_TEMP == 1
                                            send(msg.setSensor(i + DS_First_Child_ID).set(temperature,1));
                                          if (message.type==V_STATUS) {
                                              // Change relay state
                                              digitalWrite(message.sensor-1+RELAY_PIN, message.getBool()?RELAY_ON:RELAY_OFF);
                                              // Store state in eeprom
                                      gohanG 1 Reply Last reply
                                      • L lekeb
                                        Sur,
                                        int numSensors=0;
                                        bool metric = true;
                                        float lastpression;
                                        void before()
                                          sensors.begin();
                                        @lekeb said in 💬 Relay:
                                        Why are you using the same child ID (since you set #define BARO_CHILD 0)?
                                          rejoe2R
                                          rejoe2R
                                          rejoe2
                                          @gohan Effectively, he will never report any temp reading under ChildID 0. Within presentation() and the send() commands, the "0" is replaced by "i + DS_First_Child_ID".
                                          But you are partly right, to avoid any misunderstandings wrt. that the statement could also be written as follows:
                                          MyMessage msg(DS_First_Child_ID,V_TEMP);
