  2. Announcements
  3. MySensors 2.2.0 released
33 Posts 16 Posters 14.0k Views 16 Watching
    I think I reported this warning few months ago
    tekkaT 1 Reply Last reply
      tekkaT
      tekkaT
      tekka
      @gohan ok. Did you also open an issue on github back then?
        I think @mfalkvidd did something at the time
          This is the thread gohan is referring to: https://forum.mysensors.org/post/75635
          Looks like it was mentioned in https://forum.mysensors.org/topic/6526/raspberry-pi3-b-dragino-hat-rf95-rfm95-rf24_nop-error as well.
          • I
            I
            Ian Bishop
            Thanks for all the hard work!
            FYI, the version published to PlatformIO reports as 2.2.0-rc.2, doesn't look like there are any changes between the two revisions other than the version number.
            I have tried updating the library and uninstalling/reinstalling and can't get it to bring down 2.2.0.
            • AnticimexA
              AnticimexA
              Anticimex
              Users of security features (signing/encryption) need to do this to use these features from 2.2 onwards if upgrading from a previous official release.
              • F
                F
                flopp
                Thank you very much. I donated USD 10 as a small thank you for all your work. I hope more people do the same.
                Very nice text when you start a node, I have only tried 2.2 on my GW and it looks like some of my sending errors disappeared.
                This is what you see when you start a node
                __  __       ____
                       |___/                      2.2.0
                Why not add two | in the "o" then i will look like this
                 __  __       ____
                | |  | | |_| |___| |  __/ | | \__ \ |_| | |  \__ \
                        |___/                      2.2.0
                • user1306U
                  user1306U
                  user1306
                  wrote on last edited by user1306
                  thank you very much for the hard work
                  i'm very interested in #define MY_SIGNAL_REPORT_ENABLED
                  So apologies for the stupid question but do i need to just enable this on the Node side or also the Gateway, or Config.h (because i saw it was commented out)?
                  Do you know if this is supported by Domoticz?
                  thanks in advance
                  F 1 Reply Last reply
                  • user1306U user1306
                    thanks in advance
                    F
                    F
                    flopp
                    wrote on last edited by flopp
                    @user1306
                    I couldn't find any Signal value in Domoticz
                    What I did was to send that information as a seperate Child
                    use variable transportGetSignalReport(SR_TX_RSSI) to get the value
                    send(RSSIMsg.set(transportGetSignalReport(SR_TX_RSSI)));
                    • F flopp
                      @user1306
                      zboblamontZ
                      zboblamontZ
                      zboblamont
                      @flopp There was always a RF signal level column under Devices in Domoticz, never did try to find out how it was used....
                      • zboblamontZ zboblamont
                        F
                        F
                        flopp
                        @zboblamont
                        It is still there, but I don't think DZ has implemented MYS RF signal, yet :)
                        • user1306U
                          user1306U
                          user1306
                          Thanks all for the help
                          @flopp i added the line like you mentioned.
                          i added it as S_SOUND, V_LEVEL seem to be working fine, thanks. Lets hope Domoticz will include it soon.
                          • user1306U
                            user1306U
                            user1306
                            i have another simple question regarding the RF24_PA level.
                            in the config file i see that its default to RF24_PA_MAX. does this mean that if i dont include anything in my sketch the node will default to MAX?
                            i read somewhere that this could cause the node to fail sometimes if there's not enough current going through, since most of my nodes are run on battery i would like to know if its necessary to modify this?
                              F
                              F
                              flopp
                              @user1306
                              Correct, if you don't define RF24_PA LEVEL in your sketch it will use default values from Config, which in your case seems to be MAX
                              • user1306U
                                user1306U
                                user1306
                                Really appreciate your help thanks @flopp
                                just wondering for normal nrf24l01+ not the PA LNA one, what level are you using? (no sure if mine are original since i bought them from Aliexpress i have my doubts).
                                  F
                                  F
                                  flopp
                                  @user1306
                                  I am using LOW and HIGH. LOW should be enough. I was testing HIGH with some nodes but I dont know if that helped.
                                  I also using nRF from AliE.
                                  I think most of MYS users are using nRF from China, i don't know how to see if it is real or fake.
                                  • ZwaZoZ
                                    ZwaZoZ
                                    ZwaZo
                                    I have a Strange problem appearing since I have started to upgrade my network from 2.1.1 to 2.2.0
                                    I am using a Domoticz v.3.8153 / Raspbian + a serial GW on NRF.
                                    Some of the devices are communicating to the GW through a repeater node equipped with a nrf24l01 PA LNA since they are just too far from the GW.
                                    Not all of the nodes are upgraded to 2.2.0, some are still running 2.1.1
                                    • the battery level reporting disappeared from all of the connected node (but one is still working : a senserblender micro with the original TempHum sketch)
                                    • The repeater node sometime stopped relaying the connection to the GW (on random time ?). Only thing I found is to restart this node)
                                    Any ideas ?
                                    Thanks a lot.
                                    Jef
                                    • maghacM
                                      maghacM
                                      maghac
                                      I've noticed that since the upgrade to 2.2.0 my nodes are now sending some new internal messages every now and then. I'm using a MQTT gateway and sometimes I see these messages coming through:
                                      mysensors-out/1/255/3/0/33 600000
                                      mysensors-out/1/255/3/0/32 500
                                      What are internal messages types 32 and 33? Can't find them in the list on https://www.mysensors.org/download/serial_api_20#internal
                                      AnticimexA 1 Reply Last reply
                                      • maghacM maghac
                                        AnticimexA
                                        AnticimexA
                                        Anticimex
                                        @maghac Hi,
                                        documentation is best found here: https://www.mysensors.org/apidocs/
                                        It is always covering the latest release. Specifically, for message types: https://www.mysensors.org/apidocs/group__MyMessagegrp.html
                                        jjkJ 1 Reply Last reply
                                        • clio75C
                                          clio75C
                                          clio75
                                          Thanx for 2.2.0
                                          But I have a new feature that I did not have before.
                                          I'm using VERA edge and my plugin reports that i don't have any connection to the Gateway.
                                          Please advice :)
                                          korttomaK 1 Reply Last reply
                                          12.5k
