  3. First MySensors project with hard start :-)
8 Posts 2 Posters 1.8k Views 2 Watching
  • M Offline
    M Offline
    MrRose
    wrote on last edited by MrRose
    Hey together,
    I try my first MySensors Project with two Nodemcu´s and NRF24 radios.
    The first Nodemcu working as gateway with a additional NRF24 radio (wired by the manual, sketsh GatewayESP8266 ). And shows after boot the following.
    ⸮-S⸮⸮40 MCO:BGN:INIT GW,CP=RNNGE---,VER=2.2.0
    83 TSF:LRT:OK
    98 TSM:INIT
    111 TSF:WUR:MS=0
    135 TSM:INIT:TSP OK
    155 TSM:INIT:GW MODE
    scandone
    state: 0 -> 2 (b0)
    state: 2 -> 3 (0)
    state: 3 -> 5 (10)
    add 0
    aid 2
    cnt
    connected with MyWlan, channel 1
    dhcp client start...
    ip:192.168.7.35,mask:255.255.255.0,gw:192.168.7.1
    380 TSM:READY:ID=0,PAR=0,DIS=0
    412 MCO:REG:NOT NEEDED
    scandone
    937 GWT:TIN:CONNECTING...
    964 GWT:TIN:IP=192.168.7.35
    993 MCO:BGN:STP
    1010 MCO:BGN:INIT OK,TSP=1
    The second Nodemcu uses the same NRF24 radio with a simple sketsh BinarySwitchSleepSensor shows the following serial Log:
    57 MCO:BGN:INIT NODE,CP=RNNNE---,VER=2.2.0
    72 TSM:INIT
    73 TSF:WUR:MS=0
    80 TSM:INIT:TSP OK
    82 TSF:SID:OK,ID=2
    84 TSM:FPAR
    2329 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    4336 !TSM:FPAR:NO REPLY
    scandone
    no Sevelen found, reconnect after 1s
    4342 TSM:FPAR
    Soft WDT reset
    ctx: cont
    sp: 3ffef720 end: 3ffefa90 offset: 01b0
    >>>stack>>>
    3ffef8d0:  40106870 00000000 3ffefb68 40106969
    3ffef8e0:  00000000 3ffefb68 00000000 40202486
    3ffef8f0:  001e8480 3ffe0001 3ffefaf3 402024e6
    3ffef900:  00000000 0000000e 00000000 000000ff
    3ffef910:  00000000 00000000 000000ff 00000030
    3ffef920:  00000000 0000ef8e 0000000e 402025a1
    3ffef930:  00000000 3ffefaec 00000000 40202668
    3ffef940:  00000007 52415046 3ffe000a 40204850
    3ffef950:  3ffefb3c 40237470 3ffefd74 000000ff
    3ffef960:  3ffefb3c 3ffefb38 3ffefaec 40203037
    3ffef970:  000a594c 3fffc6fc 00000001 00000000
    3ffef980:  3ffefb68 3ffefb3c 0000004a 00000030
    3ffef990:  00000000 3ffefb3c 0000004a 00000030
    3ffef9a0:  00000002 00000002 000000ff 00000017
    3ffef9b0:  00000000 3ffefb68 3ffef9e0 3ffef9d0
    3ffef9c0:  00000004 00000000 3ffefb68 40106969
    3ffef9d0:  00000000 00000020 00000011 0000004a
    3ffef9e0:  3ffefb3c 000000ff 3ffefb3c 40203157
    3ffef9f0:  00000001 00000000 3ffefb3c 40203310
    3ffefa00:  0000001d 00000000 00000000 402029ed
    3ffefa10:  3ffefb3c 00000000 3ffefb3c 40202abc
    3ffefa20:  00029cc0 00000000 00000000 40202bd9
    3ffefa30:  00000525 00a61ac0 00000000 40203d25
    3ffefa40:  3fffdad0 3ffefae8 00000000 40203ee3
    3ffefa50:  600000ff ff000000 3ffefd54 3ffeea68
    3ffefa60:  3fffdad0 3ffefae8 3ffefd54 40203fa8
    3ffefa70:  feefeffe 00000000 3ffeea18 4020416c
    3ffefa80:  feefeffe feefeffe 3ffeea70 40100108
    <<<stack<<<
     ets Jan  8 2013,rst cause:2, boot mode:(3,6)
    load 0x4010f000, len 1384, room 16
    tail 8
    chksum 0x2d
    csum 0x2d
    v4ceabea9
    ~ld
    To me looks not like the GW get any connection to the second node. Due to i put to each radio the explained capacitor (100uF)
    As Controller i try FHEM and Domoticz both connect to the gw without problems.
    But the result is the same. Any ideas?
    Thanks for your help.
    • M MrRose
      Hey together,
      83 TSF:LRT:OK
      98 TSM:INIT
      111 TSF:WUR:MS=0
      135 TSM:INIT:TSP OK
      scandone
      state: 0 -> 2 (b0)
      state: 2 -> 3 (0)
      state: 3 -> 5 (10)
      add 0
      aid 2
      cnt
      scandone
      993 MCO:BGN:STP
      72 TSM:INIT
      73 TSF:WUR:MS=0
      80 TSM:INIT:TSP OK
      82 TSF:SID:OK,ID=2
      84 TSM:FPAR
      scandone
      4342 TSM:FPAR
      Soft WDT reset
      ctx: cont
      >>>stack>>>
      <<<stack<<<
      tail 8
      chksum 0x2d
      csum 0x2d
      v4ceabea9
      ~ld
      Hi @mrrose, welcome to the forum!
      Yes all nrf24 radios need capacitor for stable operation.
      Could you post the gateway log from where the (second) node boots up and asks for parent?
      • M Offline
        M Offline
        MrRose
        Hi
        each nrf24 has as 100uF capacitor.
        The log did at the GW did not change during the ask for parent. In remains on the posted log.
        • M MrRose
          Hi
          @mrrose interesting. Could there be another MySensors gateway within range? Maybe a neighbor?
          Edit: I am asking because st=OK means that a node has acknowledged that it did receive the message.
          • M Offline
            M Offline
            MrRose
            Ok that will be a good idea in that case a change the nrf24 channel inside the myConfig.h will change the situation right?
            • M MrRose
              @mrrose yes that's the easiest way. Remember to re-upload sketches to both nodes after the change.
              • M Offline
                M Offline
                MrRose
                • M Offline
                  M Offline
                  MrRose
                  Channel now: 83
                  Gw:
                  ⸮⸮⸮=C⸮⸮40 MCO:BGN:INIT GW,CP=RNNGE---,VER=2.2.0
                  83 TSF:LRT:OK
                  97 TSM:INIT
                  110 TSF:WUR:MS=0
                  134 TSM:INIT:TSP OK
                  scandone
                  state: 0 -> 2 (b0)
                  state: 2 -> 3 (0)
                  state: 3 -> 5 (10)
                  add 0
                  aid 2
                  cnt
                  262 TSM:READY:ID=0,PAR=0,DIS=0
                  295 MCO:REG:NOT NEEDED
                  scandone
                  819 GWT:TIN:CONNECTING...
                  connected with SevelenKeller, channel 1
                  1346 GWT:TIN:CONNECTING...
                  1374 GWT:TIN:IP=192.168.7.35
                  1405 MCO:BGN:STP
                  1422 MCO:BGN:INIT OK,TSP=1
                  2014 GWT:TSA:C=0,CONNECTED
                  3006 GWT:RFC:C=0,MSG=0;0;3;0;2;
                  3041 GWT:RFC:C=0,MSG=0;0;3;0;2;Get Version
                  3086 GWT:RFC:C=0,MSG=0;0;3;0;18;PING
                  pm open,type:2 0
                  13056 GWT:RFC:C=0,MSG=0;0;3;0;18;PING
                  23091 GWT:RFC:C=0,MSG=0;0;3;0;18;PING
                  33126 GWT:RFC:C=0,MSG=0;0;3;0;18;PING
                  43059 GWT:RFC:C=0,MSG=0;0;3;0;18;PING
                  53097 GWT:RFC:C=0,MSG=0;0;3;0;18;PING
                  63129 GWT:RFC:C=0,MSG=0;0;3;0;18;PING
                  Node:
                  __  __       ____
                          |___/                      2.2.0
                  51 MCO:BGN:INIT NODE,CP=RNNNE---,VER=2.2.0
                  66 TSM:INIT
                  67 TSF:WUR:MS=0
                  75 TSM:INIT:TSP OK
                  77 TSF:SID:OK,ID=2
                  78 TSM:FPAR
                  2323 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  scandone
                  state: 0 -> 2 (b0)
                  state: 2 -> 0 (2)
                  reconnect
                  scandone
                  reconnect
                  4333 !TSM:FPAR:NO REPLY
                  4335 TSM:FPAR
                  Soft WDT reset
                  ctx: cont
                  sp: 3ffef710 end: 3ffefa90 offset: 01b0
                  >>>stack>>>
                  3ffef8c0:  00000000 3ffefb68 3ffefb68 402046c3
                  3ffef8e0:  00000000 3ffefb68 00000000 402024e6
                  3ffef920:  00000000 0000efd6 0000000e 402025a1
                  3ffef980:  3ffefb68 3ffefb3c 00000045 00000030
                  3ffef990:  00000000 3ffefb3c 00000045 00000030
                  3ffef9d0:  00000000 00000020 00000011 00000045
                  3ffefa00:  000003f9 00000000 00000000 402029ed
                  3ffefa30:  00000750 00a61ac0 00000000 40203d25
                  <<<stack<<<
                  tail 8
                  chksum 0x2d
                  csum 0x2d
                  v4ceabea9
                  ~ld
                  GW Log did not change by power on the node. Only now i get Ping again and again.
                  12.1k
