  3. Safe In-Wall AC to DC Transformers??
431 Posts 71 Posters 593.7k Views 69 Watching
  • M matz
    @sundberg84
    Quite small, so.
    In a link above i've seen a review of the HLK from one guy who seems to know about electronics.
    He recommends using the VIGORTRONIX VTX-214-005-105 AC/DC PCB Mount Power Supply . He said "for only a few quid more you win a switch mode PSU that stands a chance of not requiring external components to pass Class B!"
    Anyone here has tested the Vigortronix ? Is it better than HLK ?
    dbemowskD
    dbemowskD
    @matz Never tried the Vigortronix, but I tried some from a company called Recom that were pretty good. Quite a bit higher in price though too.
    • dbemowskD dbemowsk
      matz
      @dbemowsk
      Ok thanks. I will try to build the sundberg84 board but i will try also to find a case built with a 3D printer as i prefer not to let all this stuff unprotected in case someone else than me in the futur open the wall socket
      dbemowskD 1 Reply Last reply
      • M matz
        @dbemowsk
        dbemowskD
        dbemowskD
        @matz Now that I have had my 3D printer for a year, I don't know why I didn't get one sooner. FOr these very reasons. If I need a case for something, I cad it out and make it.
          matz
          @dbemowsk
          I'm planning to buy one, i'm sure there are plenty usage of it (sorry for my bad english i'm french :))
          Concerning the PSU, one question : we could just disasemble an iphone charger, the small one is 5cm x 1,5cm x 3 cm, and reuse it in the wall. IMHO it is more safe than build ourselves a PSU. Has anybody tried this ?
          dbemowskD sundberg84S 2 Replies Last reply
          • M matz
            @dbemowsk
            dbemowskD
            dbemowskD
            @matz Why disassemble it other than to solder on some external power wires. Leave the original protection in place and you shouldn't have to worry about shorting anything out.
              matz
              @dbemowsk
              I'm afraid it won't fit in the wall socket because of the metal stem, so it would be better to solder the power wires to it :
              Nca78N 1 Reply Last reply
              • M matz
                @dbemowsk
                @matz said in Safe In-Wall AC to DC Transformers??:
                Ce n'est pas une excuse valable :P
                @dbemowsk
                It doesn't look like an official charger, or even a branded one ? Then you would meet the same safety problems than the cheap power supplies. In that case have a look at http://lygte-info.dk/ to check if you can find a charger that's on the "safer side" of things.
                • M matz
                  @dbemowsk
                  sundberg84S
                  sundberg84S
                  @matz the problem with phoneadapters are all the fake and truly unsafe ones. Just Google phone charger teardown. If you are sure you are buying a genuine one it's most likely quite expensive. Safety vs money is one of the key aspects in this thread and offcourse you can probably buy smaller and safer ones but you are going to pay for it.
                  jeremushkaJ 1 Reply Last reply
                  • A
                    arp5z5
                    wrote on last edited by arp5z5
                    #414
                    Hi guys (and gals?) new member here, and probably an absolute novice compared to most of you; however, I have been following this thread for quite some time. I recently acquired the components listed out by @petewill (thank you for the inspiration to try the project), and I have constructed the circuit in tune to the schematic also generously provided by @petewill. The only difference in my set up is that I have gone with a WeMos D1 mini instead of the arduino/radio combo solely due to having one laying around. The WeMos to relay connection works (as in flicks on/off the LED on the relay) in tune with the automation software I am using when the WeMos is being powered by micro USB. However, when attempting to power the circuit via a 120V outlet, I seem to keep blowing the 250V 300mA Slow Blow Fuse. In short, the LED on the WeMos briefly emits light, and then shuts off. When troubleshooting the circuit with a multimeter, I find that no current is flowing through the Slow Blow Fuse (therefore blown). I was wondering if anyone might have some ideas as to why this is happening despite the fuse being rated with the proper current and voltage ratings. I assume that there is a short occurring somewhere in the circuit; however, due to my novice knowledge, I have no idea why. I would greatly appreciate any and all pointers/criticism! Thank you. https://imgur.com/0Iy0UwY https://imgur.com/a/ZuSlb
                    • A arp5z5
                      sundberg84S
                      sundberg84S
                      @arp5z5 - my first thought was just like you said - a short. I would 1) remove everything from the DC side and replace the fuse. Then with a multimeter in continuity-mode see that you dont have a short on the AC side between Hot and Neutral. Did you wire everything correctly? If so - might be a bad varistor? If you dont get a beep - (with a new fuse) power everything up (without DC parts and see what happens. Works ok? Continue to add DC parts untill something happens.
                      A 1 Reply Last reply
                      • sundberg84S sundberg84
                        arp5z5
                        @sundberg84 Thank you for the advice! I will take a look at it tomorrow and see what I can find.
                        • O
                          O
                          Omemanti
                          wrote on last edited by Omemanti
                          #417
                          hey,
                          anyone have experience with:
                          https://nl.mouser.com/ProductDetail/RECOM-Power/RAC01-05SGB?qs=sGAEpiMZZMuWiaalG5TUgCAeS4T2q9hep7l40%2FsKBt80J%252brWHE6eLg%3D%3D
                          It looks affordable and more regulated than the Chines modules.
                          some other variations: https://nl.mouser.com/RECOM/Power/Power-Supplies/AC-DC-Power-Modules/_/N-dv0g5?P=1yx5k7vZ1yzk8kkZ1yxt78rZ1yxt794Z1yxt791&Ns=Pricing|0
                          • O Omemanti
                            hey,
                            dbemowskD
                            dbemowskD
                            @omemanti I have used some other RECOM modules and they are pretty solid. I like the fact that the incoming power leads are spread out to the edges rather than close in the center on the HLK modules. That alone makes them a heap safer.
                            • SoloamS
                              SoloamS
                              Soloam
                              wrote on last edited by Soloam
                              #419
                              I give up on soldering Temperature Fuses, for every one that I'm able to solder I blow up 5 of temperature rising from the solder. It would be a good safety improvement, but I'm going crazy with fazes burning :white_frowning_face: :neutral_face: :triumph: any recommendation? Who are you guys soldering without blowing them up?
                              • SoloamS Soloam
                                dbemowskD
                                dbemowskD
                                @soloam I too had great trouble with this. The best trick that I found was to have the side of the board with the fuse on it resting on a frozen gel pack while soldering. As long as you keep the fuse cold it should not blow. It is called a thermal fuse for a reason. I have talked to others that have had some success with aluminum heat sink clips like these that you would clamp on the lead that you are soldering to pull the heat away before it reaches the fuse.
                                I still prefer the gel pack solution though. If you set yourself up right with the gel pack, you can have the cold pack pressing the thermal fuse against the power supply module as you solder which is where you want it anyway.
                                • SoloamS
                                  SoloamS
                                  Soloam
                                  @dbemowsk are you talking about this:
                                  I'll try it out.
                                  where can I find that clamps? To try out also?
                                  Thank You
                                  • SoloamS Soloam
                                    I'll try it out.
                                    Thank You
                                    dbemowskD
                                    dbemowskD
                                    @soloam Those are the type I am talking about. Put them in the freezer for a bit. They should still be pliable when they come out.
                                    https://www.amazon.com/CLIP-HEAT-SINK-KIT/dp/B0032UYTV6
                                    • TD22057T
                                      TD22057T
                                      TD22057
                                      You don't really have to buy anything - lots of things will work to keep the temperature down. A wet paper towel wrapped around the fuse or submerge it in a small cup of water (easy for through hole components when the board is upside down) or wrap with 2 wet sponges and some rubber bands, etc etc.
                                        jeremushkaJ
                                        jeremushkaJ
                                        jeremushka
                                        @sundberg84 I am building an efficient AC/DC power supply to avoid using the HLK-PM01. I design the power supply with flyback topology with high safety as it is fully isolated.
                                        in the current design i selected the component BF1550. It is a high performance AC/DC power supply control
                                        device which is operating in primary side sensing and regulation. It includes an internal power BJT and is designed for off-line power supplies within 6W output power.
                                        Based on that, i designed the transformer. I need to find a factory to produce it.
                                        My goal is to introduce in any nodes this AC/DC power supply for safety reason and efficiency DC regulation.
                                        • beicB
                                          beicB
                                          beic
                                          I know it's an old topic, but I need to ask...
                                          I read all this things mentioned on this topic, but at the end I did not find any answer to the fuses and for the varistor.
                                          So, I wonder what values was used:
                                          1. for fuses on mains 230v and for the 5V DC side?
                                          2. I don't see any varistor values like 10D271K, 10D471K or 10D561K?
                                          And also one suggestion about that thermal fuse, it would be better to use KSD-01 (normaly closed type) at 65C degree.
