  3. Suddenly, the node stopped working.
3 Posts 2 Posters 1.2k Views 2 Watching
  • IgorKI
    IgorKI
    IgorK
    Hi!
    Tell me, please, where to look.
    The problem is as follows. I launched 5 months ago a network on Nrf24, consisting of a gate and one node based on MySensors. Until yesterday everything worked without problems. Yesterday afternoon, for no apparent reason, the node suddenly fell off. I tried to replace the Nrf24 modules and reflash the ARDUINO Mini Pro atmega328 3.3V - nothing has changed. Capacitors are standing.
    Here is a piece of the log at the time of the disappearance of the node:
    Feb 8 12:42:44 raspberrypi mysgw: TSF:MSG:READ,1-1-0,s=1,c=1,t=16,pt=0,l=1,sg=0:1
    Feb 8 12:42:44 raspberrypi mysgw: Sending message on topic: domoticz/in/MyMQTT/1/1/1/0/16
    Feb 8 12:42:48 raspberrypi mysgw: TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    Feb 8 12:42:48 raspberrypi mysgw: TSF:MSG:BC
    Feb 8 12:42:48 raspberrypi mysgw: TSF:MSG:FPAR REQ,ID=1
    Feb 8 12:42:48 raspberrypi mysgw: TSF:PNG:SEND,TO=0
    Feb 8 12:42:48 raspberrypi mysgw: TSF:CKU:OK
    Feb 8 12:42:48 raspberrypi mysgw: TSF:MSG:GWL OK
    Feb 8 12:42:48 raspberrypi mysgw: !TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
    Feb 8 12:42:51 raspberrypi mysgw: TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    Feb 8 12:42:51 raspberrypi mysgw: TSF:MSG:BC
    Feb 8 12:42:51 raspberrypi mysgw: TSF:MSG:FPAR REQ,ID=1
    Feb 8 12:42:51 raspberrypi mysgw: TSF:CKU:OK,FCTRL
    Feb 8 12:42:51 raspberrypi mysgw: TSF:MSG:GWL OK
    Feb 8 12:42:51 raspberrypi mysgw: !TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
    Feb 8 12:42:53 raspberrypi mysgw: TSM:READY:NWD REQ
    Feb 8 12:42:53 raspberrypi mysgw: TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
    Feb 8 12:42:55 raspberrypi mysgw: TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    Feb 8 12:42:55 raspberrypi mysgw: TSF:MSG:BC
    Feb 8 12:42:55 raspberrypi mysgw: TSF:MSG:FPAR REQ,ID=1
    Feb 8 12:42:55 raspberrypi mysgw: TSF:CKU:OK,FCTRL
    Feb 8 12:42:55 raspberrypi mysgw: TSF:MSG:GWL OK
    Here's what the node writes in the logs:
    4 TSM:INIT
    4 TSF:WUR:MS=0
    12 TSM:INIT:TSP OK
    14 !TSF:SID:FAIL,ID=0
    16 TSM:FAIL:CNT=1
    18 TSM:FAIL:PDT
    10020 TSM:FAIL:RE-INIT
    10022 TSM:INIT
    In what direction to dig?
    • IgorKI IgorK
      Hi!
      4 TSM:INIT
      4 TSF:WUR:MS=0
      12 TSM:INIT:TSP OK
      16 TSM:FAIL:CNT=1
      18 TSM:FAIL:PDT
      10022 TSM:INIT
      @igork the node is trying to start with id=0, which is reserved for the gateway.
      Upload and run the cleareepromconfig example and then upload your node sketch again and the node should work.
      Does your sketch write to eeprom?
      IgorKI 1 Reply Last reply
        IgorKI
        IgorKI
        IgorK
        @mfalkvidd said in Suddenly, the node stopped working.:
        Many thanks @mfalkvidd!
        You were right! Something strange happened to Arduino. Moreover, I was able to write down the cleareepromconfig example and clear the memory, but after this procedure I could not write anything into the memory of Arduino.
        I have little experience with Arduino and this happened to me for the first time.
        12.5k
