  3. Sensbender Micro and v2.2 library
sensebender micro
5 Posts 2 Posters 1.6k Views 2 Watching
    mbj
    wrote on last edited by mbj
    I have a somewhat modified sketch based on the Sensebender Micro sketch and this one failed to compile when changing to the v2.2 library. So I copied the original sketch from the homepage and also this one fails to compile when enabling MY_DEBUG. The error messages are numerous so it is pointless to add them here but a couple of examples are:
    \Arduino\libraries\MySensors-master-v220_180209/core/MyOTAFirmwareUpdate.cpp:63:41: error: expected ')' before 'PRIX16'
    OTA_DEBUG(PSTR("OTA:FRQ:FW REQ,T=%04" PRIX16 ",V=%04" PRIX16 ",B=%04" PRIX16 "\n"),
    \Arduino\libraries\MySensors-master-v220_180209/MyConfig.h:1815:43: note: in definition of macro 'DEBUG_OUTPUT'
    #define DEBUG_OUTPUT(x,...) hwDebugPrint(x, ##VA_ARGS) //!< debug
    \Arduino\libraries\MySensors-master-v220_180209/core/MyOTAFirmwareUpdate.cpp:63:3: note: in expansion of macro 'OTA_DEBUG'
    As this is in the core code it is something I am unable to figure out myself, unfortunately. But as the compilation runs through without problems when disabling MY_DEBUG it is not any mayor issue until the debug output is needed.
    • D
      DavidZH
      What version of the Arduino IDE are you using? I Had a similar problem but I solved that with updating the IDE to the latest version (1.8.5).
      M 2 Replies Last reply
      • D DavidZH
        mbj
        @davidzh Do not know what is going on with my browser, I have replied to your question but cannot see this reply anywhere. Also i did not receive any notification about your question so my reply is late, sorry.
        The issue showed up when compiling for library version 2.2 on Arduino 1.6.12. I will test with the latest version as you suggest, thank's a lot for the info.
        • D DavidZH
          mbj
          @davidzh A change to 1.8.5 did not help. But disabling My_Debug still works so the problem is not critical.
          For the sake of clarity I have also tested with an unmodified Sensebender sketch and also this one gets compilation errors when enabling My_Debug. So the problem comes from the implementation of the debug code.
          D 1 Reply Last reply
          • M mbj
            DavidZH
            @mbj No problem!
            Actually, I've encountered another issue. But I found that that may depend on the bootloader.
            The first time I "solved" the problem was another board with a generic 328p breadboard bootloader (I apparently didn't pay attention when burning the BL for the various boards)
            Last week I had a problem with a board with the Gert Sanders 328p bootloader when I couldn't enable the MY_DEBUG. When I changed the board type it compiled, but wouldn't upload because of the differences in baud rate.
            I will probably have to reflash al boards withe the same bootloader but that means de-solder all radios ... 😣
            When I have time again I will investigate further.
