  3. Remote password assign
16 Posts 3 Posters 2.8k Views 3 Watching
  • Kestutis MockusK Offline
    Kestutis Mockus
    Hi all.
    I was wondering if there is a possibility to remotely assign password to node from controller, that is used for signing?
    Currently you have to hardcode your password in gateway and nodes if you want to do signing. I think it would be really cool if secret password assigning could be achieved remotely without needing to edit sketch file and node would be easily reused in other secured network, by resetting its eeprom data with custom reset button.
    Also you could change password in all nodes remotely if it gots leaked somehow without reprogramming each node separately .
    A 2 Replies Last reply
    • Kestutis MockusK Kestutis Mockus
      Hi all.
      A Offline
      A Offline
      Anticimex
      @kestutis-mockus how would you keep the password secret if it is sent OTA?
        Hi all.
        A Offline
        A Offline
        Anticimex
        @kestutis-mockus in theory, you could use encryption and deploy an OTA firmware that carry the new password. But that node would not be able to communicate with the rest of the network until all other nodes and gateway are updated with a matching password.
          you can use a dual gateway setup: one with old password and one with new, but at this point you could very well use the signing chip and you are good to go
          A 1 Reply Last reply
            A Offline
            A Offline
            Anticimex
            @gohan I am not sure how nice two gateways on the same network will play with each other. If they are on separate networks, the same problem arise, one sketch version will use with one gw, another with the second. Thus not providing any benefit from the first option, to just transmit the new firmware OTA encrypted with the old key.
            However, considering that the most probable reason for changing the key is that the old one was compromised, this is a valid option either.
            All in all, transmitting keys OTA is never under any circumstances a good idea with the current security scheme.
              Of course sending keys OTA is not advised, but still if you have someone sniffing your wireless mysensors data it must be really motivated to get into your house :D
              Actually I said 2 gateways but they would need to be on separate networks: one taking care of the FOTA on old nodes and the other configured to get the nodes reprogrammed.
                A Offline
                A Offline
                Anticimex
                @gohan I understood the part of 2 gateways, and as I said, assuming they are on separate networks, separate sketches will be needed so I don't understand what that would solve compared to my initial proposal.
                  Once fota process has been completed for all the nodes, you just kill the old gateway
                    A Offline
                    A Offline
                    Anticimex
                    @gohan and how is that different from "once the nodes have the new key, change the key on the gateway"?
                      No big difference besides that you actually get a monitor if everything is going well.
                        A Offline
                        A Offline
                        Anticimex
                        @gohan maybe, at the cost of the hassle of having to mess a lot with the controller to handle two gateways which most likely will cause the nodes to get new id:s and loose any existing configurations.
                        But this is an academic discussion, pulling the stunt of changing security keys OTA is not advised, and there will be no official support for a dedicated command to do this in 2.x.x versions due to the security implications.
                        I have loosened security by supporting the "password" option too much for my comfort already :)
                          Kestutis Mockus
                          Sorry for delay. I mean send password not in FOTA but as separate command. In that case gateway should communicate with signed and not signed password nodes. From insecure node only limited commands would be accepted by the gateway, so no hacks would be available like door opening and etc.
                          The controller would initiate process of changing or assigning password.
                          So if password gets leaked or node stolen, you would need only initiate password change command in controller without re flashing all nodes with new password.
                          I know it maybe a security issue, but it would be a lot easier to use same node firmware version for multiple signed passwords.
                            A Offline
                            A Offline
                            Anticimex
                            @kestutis-mockus I don't understand. If you send the password using rf to a node, that password can be sniffed and used by nodes other than your own which would be able to make themself indistinguishable from your own nodes to your gateway/controller.
                              A Offline
                              A Offline
                              Anticimex
                              @kestutis-mockus I should also clarify that by OTA I mean "Over the Air", as opposed to FOTA witch is "Firmware Over the Air".
                              Any OTA message can be sniffed by others. To prevent that, encryption can be used, but in this case the usecase is to change encryption password which is a bad idea since some nodes might get the message and change their key. Others might miss it and then won't be able to decrypt future communications as the gateway would have to start using the new password to communicate with the nodes that changed theirs.
                              All in all, the solution will just be complicated and prone to errors, something the password option was designed to be anything but.
                                Kestutis Mockus
                                Well to check if password is changed, verify message could be sent with new encryption, if no replay - send new password change command again. For password sending in OTA - new password could encrypted with predefined encryption key which would be safely saved in atcha and defined uniquely by each developer.
                                It is just my thoughts, as I understand it cannot be accomplished easily without modifining core files and private modificated files would be overwriten by updates.
                                Will waot for future updates if something similiar will be developed.
                                Thanks and sorry for english :)
                                  A Offline
                                  A Offline
                                  Anticimex
                                  @kestutis-mockus I still think it is too complicated for what the basic feature actually provide (which is weak security) and it relies on a atsha which on its own implement stronger security based on personalization, something the entire password feature was designed to circumvent. But if you feel the feature is strongly desired, feel free to file a pr (and maintain) the feature and if it is well designed it can be incorporated in the core.
                                  But personally I don't feel it gives enough benefit for being worth the effort of implementation and maintenance.
                                  I'd rather focus on development of the next generation security which is designed to replace the current encryption/signing solution in its entirety (the current solution will remain an option for those who prefer it though). But this will be first in mysensors v3.
