  3. NOT WORKING: DHT and RELAYS on Ethernet GW
20 Posts 3 Posters 4.3k Views 3 Watching
    "Wait" will keep the rest of the GW functions running, it is not like "delay" that blocks the code execution
    rejoe2R
    rejoe2R
    rejoe2
    @gohan said in NOT WORKING: DHT and RELAYS on Ethernet GW:
    Thx for clarification :+1:
    • Z
      Z
      ZachFlem
      OK folks, so I've got it going to some extent.
      Added the wait(), and that seems to have calmed things down a bit, but I also added an external 5v power supply to the sensor and relay board
      The relays are working, and the temp and humidity are being reported on the serial monitor, but there is no value coming back to MyController from the DHT22.
      Sketch @ https://pastebin.com/mMxh65xp
      As always, your help is appreciated.
        Is the gateway actually sending the temperature? Do you see it in the logs?
        Z 1 Reply Last reply
          Z
          Z
          ZachFlem
          @gohan nope, just checked, and I can see the presentation, and my manual trigger of the relays, but no data back from the sensor.
          I'm also only getting the humidity presented to MyController
            DHT sensors are quite lazy so they need their time, try adding a wait(1000) before the
            • rejoe2R
              rejoe2R
              rejoe2
              @zachflem said in NOT WORKING: DHT and RELAYS on Ethernet GW:
              This also indicates some trouble in the communication between GW and Controller. For debugging, you may also add some wait()-time in between the presentation of the individual child-ID's.
              • Z
                Z
                ZachFlem
                So I've moved inside (it was bloody hot in the shed) and I'm working on my development board (it's a mirror of the setup in the shed, minus the external power supply for the sensors)
                But with the shed sketch loaded into this MEGA, I'm getting the DHT values in the Serial Monitor, I'll hook it up proper to the network and see how we go.
                  As a personal suggestion, I'd start looking at better sensors like the I2C ones (SHT31, SHT21, Si7021, BME280, etc)
                    Z
                    Z
                    ZachFlem
                    So far I've done this, and I have a value coming from the GW for humidity, and I'm seeing a presentation for the temp sensor in the logs, but nothing comes up when I discover the GW...
                      What kind of gateway are you running?
                        Z
                        Z
                        ZachFlem
                        An arduino mega clone with a w5100 based ethernet shield.
                        I think I might have found the problem, the humidity sensor reports as ID 0, the 2 relays as 1 and 2, and the temp sensor is showing up as 1, but before the relay.
                        So I think i need to add something to the sketch so that each type of sensor has a different prefix.
                        i.e. relays are 1XX, temp are 2XX etc
                        any thoughts?
                        rejoe2R 1 Reply Last reply
                        • Z ZachFlem
                          any thoughts?
                          rejoe2R
                          rejoe2R
                          rejoe2
                          any thoughts?
                          Not sure about if that's still valid, but there had been the recommendation to use ChildID 1 for the first relay. So you may use 3+4 for temp/hum or start with 10, 20 (or whatever you like) as proposed to have room for further relays or other type of switches.
                          • rejoe2R rejoe2
                            any thoughts?
                            Z
                            Z
                            ZachFlem
                            @rejoe2 said in NOT WORKING: DHT and RELAYS on Ethernet GW:
                            any thoughts?
                            Yeah, just re-read it and found the hard define for the IDs of those, and set them to 100 and 101.
                            Now I have the 2 relays defined as 1 & 2 and the Humidity as 100 and Temp as 101.
                            Can see all 4 sensors but only getting a value from the temp sensor.
