  3. CNC PCB milling
CNC PCB milling
933 Posts 28 Posters 809.5k Views 27 Watching
  • RFM69R RFM69
    @neverdie I saw this stepcraft automatic tool changer, its nice, but the design aproach of Franks is really novel, and way cheapper, simple ingenious. But my skill level is much lower, so I could be wrong :)
    @rfm69 Does he describe in detail somewhere how to make one? I mean, I get the concept, but he did a lot of work on both the hardware and the software to make it functional.
    RFM69R 1 Reply Last reply
      RFM69R
      RFM69R
      RFM69
      @neverdie you mean the tool changer, yes he has a blog and git pages where he shares. Its neccessary to speed control with current limiting breaking the spindle, which he's done via cheap ebay motor controller and arduino. Same goes for the spindle locking mechanism powered by a servo. and the CNC software..
      Heres the git link text
      Heres the blog link text
      Its not step by step, perhaps he'll get their but I know he'll be happy if people copy, or chime in :), or add
        #595
        I noticed that Frank is apparently using carbon fiber tubing on his 3D printer. It turns out that carbon fiber tubing is an easy upgrade, if what you have already is aluminum rod:
        https://youtu.be/0Pg-L1pQ6qU
        However, its Young's modulus appears to be about 10% less than steel, which I interpret to mean that it is a bit less rigid than steel (cf https://www.christinedemerchant.com/youngmodulus.html).
        For the printer in the video that I linked, I can see how reduced weight may be worth the tradeoff.
        However, since weight isn't really much of a factor in the 2418 CNC, I think it makes sense to stick with hardened steel rods.
        Am I missing something? Opinions?
        RFM69R zboblamontZ 2 Replies Last reply
        • andrewA andrew
          @neverdie once the assembly is done, you should adjust the stepper drivers' current limiting as well.
          then, it is always good idea to have the basic settings exported from the board, just in case... you can do it by "$$" command sent from the g code sender gui or directly from the serial terminal.
          currently I use the following settings, the machine might be able to create nice results with higher feed rates, but I did not have enough time to test it and I sticked to the current working config.
          isolation routing with 2001 bits:
          • z cut: -0.05mm
          • feed rate: 200
          you can calculate the V carving bit's tool width for the given milling depth with the following formula:
          tan(bit angle/2) * milling depth * 2 + bit's end width
          for excel formula the bit angle should be provided in radians, so it should look like this
          tan(radians(bit angle/2)) * milling depth * 2 + bit's end width
          edge cut or hole milling with the 0.8mm endmill:
          • feed rate: 170
          • z cut: -1.7mm
          • multi depth, depth/pass: 0.2mm
          drilling:
          • feed rate: 130
          • z cut: -1.8
          the spindle should be 1000 everywhere.
          most probably your board will not have a bootloader, so it will not be possible to update the firmware via usb serial connection (with avrdude), but it is worth to try it. for me it did not work, so I traced back the MCU pins to the pin rows and used ISP to upgrade the firmware to grbl v1.1f (the board will come with 0.9j if I remember correctly). do not forget to export the gerber settings before you upgrade the firmware, as it will loose those, and you have to re-assign the given values again, after the update.
          the ISP pinout (from the pin row's top left corner):
          Reset -> pin 2
          SCK -> pin 3
          MISO -> pin 12
          MOSI -> pin 13
          5v -> pin1
          gnd-> bottom row(!) e.g. pin 1
          B
          B
          bodof1981
          @andrew Hy my name is Ferenc please help me.
          i update the grbl cnc 2418 firmware but dont read settings.
          From where I can download it and how I can write it ?
          My machine does not function properly now unfortunately. Please help thank you.
            I'm noticing that the tips on 0.1mm etching bits last well enough if the PCB substrate if bakelite, but not very long at all if it's FR4. 0.2mm bit tips on FR4 seems to last much better.
              RFM69R
              RFM69R
              RFM69
              @neverdie I'm gathering parts to make the same 3d printer with the carbon rods. I understood the weight reduction on the moving parts with carbon rods was the reason to go for them. And with the light 3d printer head that model can print much faster because of the stability and lightness. Which perhaps dosn't apply for the 2418 cnc ?
                zboblamontZ
                zboblamontZ
                zboblamont
                @neverdie Wall thickness as well as the material characteristics determine tube stiffness, comparison on the modulus alone is misleading.
                As well as carrying the load, the section must also support it's own weight, one aspect where carbon fibre will out-perform steel.
                  What's the best way to check the RPM on my spindle? From looking at similar spindles on-line, I think it might be as low as 6000RPM at 24v.
                  So.... if I upgraded to a spindle that could go, say, 12000RPM, could I simply increase my feedrate by 2x and be done twice as fast?
                  • zboblamontZ zboblamont
                    #601
                    Granted. What's a better way to compare them based on the available info?
                      zboblamontZ
                      zboblamontZ
                      zboblamont
                      @neverdie Bluntly no idea whatsoever, I was merely highlighting the incorrect interpretation.
                      There is no magic bullet, that's why engineers are still in business, the analysis can be complex.
                      Were I looking at such a project it would to the lightest and stiffest complex alloy extrusions I would be focusing attention, and figuring out how best to combine them in a frame with minimal deformation.
                      Complex alloy extrusions are cheap sections with known quantified parameters and constraints, composites are relatively new, and their interconnections are less well understood than with conventional materials. unless you work for Lotus or Ferrari...
                      • coddingtonbearC
                        coddingtonbearC
                        coddingtonbear
                        @NeverDie -- the motors used in 1610 CNC mills are generally what are called a "775 Motor". You might be able to find other specs, but the ones I've found suggest that at 24V and no load , they claim 7kRPM -- http://linksprite.com/wiki/index.php5?title=File:Motor_performance_parameter.png; I'm not sure how much slower we could expect it to be while milling. As far as actually measuring this, there are devices you could buy, but you could pretty easily fabricobble your way to an answer if you wanted to make a project out of it: http://www.instructables.com/id/Measure-RPM-DIY-Portable-Digital-Tachometer/.
                        I have the same mill as you, and swapped for one of these https://www.amazon.com/gp/product/B074FVKRZM/ and have had much better results so far.
                        NeverDieN RFM69R 3 Replies Last reply
                        • coddingtonbearC coddingtonbear
                          @adam-coddington said in CNC PCB milling:
                          Any less vibration also?
                          • coddingtonbearC
                            coddingtonbearC
                            coddingtonbear
                            wrote on last edited by coddingtonbear
                            #605
                            I actually haven't had much trouble with vibration, so I can't really speak to that. The problems I've had have mostly been around runout, occasional arcing in the old spindle causing enough EMI to reset the microcontroller, Z-Axis backlash, the super-slow milling speeds necessary when spinning at such a low RPM, copper flakes everywhere, etc. Having the faster (and, maybe unfortunately, heavier) brushless spindle has been great for all of those things.
                            I happened to notice you looking into tool changers; if you're using bCNC, you might not have noticed the tool change workflow -- it's actually pretty elegant and will automatically re-zero your Z-Axis. It does require having a limit switch on at least the top of that axis, though. I used to hate tool changes given how tedious they were, but now they're pretty effortless.
                              #606
                              Seems like most DC CNC spindles can do no more than 12,000RPM (if that). Which leads me to wonder: would replacing a spindle with a dremel be advisable? A dremel has an adjustable range of 5,000 to 35,000RPM.
                              Anyone tried this? Any downsides?
                              [Edit: I see that a number of the AC powered spindles can go as high as 24,000RPM. e.g.: https://www.aliexpress.com/item/1-5kw-Air-Cooled-Motor-cnc-Spindle-Motor-Spindle-110v-220v-ER11-CNC-Square-Milling-Machine/32850346694.html?spm=2114.search0104.3.53.6e8c5be0Uqy1Fs&ws_ab_test=searchweb0_0,searchweb201602_5_10152_5711320_10151_10065_10344_10068_10130_10324_10342_10547_10325_10343_10546_10340_10548_10341_10545_10084_10083_10618_10307_5711220_5722420_10313_10059_10534_100031_10103_10627_10626_10624_10623_10622_10621_10620,searchweb201603_25,ppcSwitch_5&algo_expid=42fb944e-06c3-4821-8a8b-3b49200ec2fd-8&algo_pvid=42fb944e-06c3-4821-8a8b-3b49200ec2fd&transAbTest=ae803_3&priceBeautifyAB=0
                              Interestingly, I did find one that claims to do up to 60,000RPM: https://www.aliexpress.com/item/800W-electric-water-cooling-spindle-110V-ER11-with-65MM-diameter-158MM-length-for-cnc-router/32653823271.html?spm=2114.search0104.3.1.3bda4ab3F2KVPE&ws_ab_test=searchweb0_0,searchweb201602_5_10152_5711320_10151_10065_10344_10068_10130_10324_10342_10547_10325_10343_10546_10340_10548_10341_10545_10084_10083_10618_10307_5711220_5722420_10313_10059_10534_100031_10103_10627_10626_10624_10623_10622_10621_10620,searchweb201603_25,ppcSwitch_5&algo_expid=9a9cc87f-4ffa-46c7-bca9-1bba7f82e5bc-0&algo_pvid=9a9cc87f-4ffa-46c7-bca9-1bba7f82e5bc&transAbTest=ae803_3&priceBeautifyAB=0
                              That sure would be interesting!
                                I suppose another factor worth considering is audible noise. Here's one that claims to be relatively quiet:
                                https://www.inventables.com/technologies/quiet-cut-spindle
                                https://www.youtube.com/watch?v=g259rm2tfbA
                                It only goes to 12,000RPM, but I may be willing to trade speed for quiet. I can only assume that the 60000RPM unit isn't very quiet. Not at all sure how the brushless motor would compare. Possibly quieter?
                                  I upgraded my CNC LoRa remote monitor into a more universal remote control by making it more compact and giving it 14 buttons:
                                  It turns out I can count the number of auto-leveling probes performed, in real time, because the total CNC current briefly drops to almost zero each time the probe makes contact with the PCB. Thus, this gives me a way of tracking auto-leveling progress remotely. :)
                                    #609
                                    I went ahead and ordered this spindle upgrade, which looks as though it may be the same (?) as the Quiet Cut spindle.
                                    https://www.aliexpress.com/item/BEST-300W-Mini-Spindle-motor-DC12-48V-ER11-12000rpm-Engraving-milling-grind-air-cooling-spindle-motor/32799767627.html?spm=a2g0s.13010208.99999999.262.sgcb5Q
                                    • RFM69R
                                      RFM69R
                                      RFM69
                                      I'm also looking for a good spindle so thanks for the links and comments.
                                      Thought I'd share this link text. Its the 30A High Power Single way H-bridge DC Motor Driver Module. That "Frank From Germany" found and is using as part of his tool changing, along with a current sensor so he can brake, reverse and control speed on his tool changer, via arduino, to make it all work.
                                        RFM69R
                                        RFM69R
                                        RFM69
                                        @coddingtonbear What materials are you milling ?
                                        I want to get a spindle for mostly wood, just hobby, but don't want to go too cheap, and face buying over when I realize its just not > W
                                        coddingtonbearC 1 Reply Last reply
                                        • RFM69R RFM69
                                          RFM69R
                                          RFM69R
                                          RFM69
                                          wrote on last edited by RFM69
                                          #612
                                          Just found a more powerful one...
                                          @rfm69 link text
                                          So could this or the 30A version, power an 800w DC 0-48V motor ?
