  2. Announcements
  3. 💬 Air Humidity Sensor - DHT
149 Posts 48 Posters 104.1k Views 38 Watching
    Thanks @cristi
    I have updated the table with the sample rate. Could you check if it looks good?
    For the code change a pull request will be needed. Could you do one? If you can't I'll add it to my todo but it might take a while.
    C
    C
    cristi
    @mfalkvidd
    • there's a typo in the table for DHT-11: it should be '1s per sample' instead of '10s per sample'
    • I created a pull request
    • C cristi
      @mfalkvidd
      @cristi according to http://www.micropik.com/PDF/dht11.pdf typical response time is 10s. Am I looking at the wrong number?
      Great work on the pull request. I'm adding a link in case someone needs it in the future. https://github.com/mysensors/MySensorsArduinoExamples/pull/29/
      C 1 Reply Last reply
        C
        C
        cristi
        @mfalkvidd Indeed, I see that 10 seconds in pdf, but it looks strange. I'd have to re-read to see if I can get what it is supposed to be for.
        But, meanwhile, in the same pdf, you get this note (chapter 6): "Note: Sampling period at intervals should be no less than 1 second.". Also, DHT library is using 1second sampling period.
        • C cristi
          @cristi thanks. I have updated the table.
          • R
            R
            ricmail85
            I've created a DHT11 sensor based on this sketch. However the temperatures (and humidities) are reported as integer numbers in domoticz (either by looking at the devices and setup tabs). In the sketch I've specified the number of decimals like send(msgHum.set(temperatire, 2)). Even if I try larger decimal numbers, nothing change when the value is received in domoticz. What can I do?
            Thanks in advance.
              wrote on last edited by gohan
              #120
              What kind of variable did you set for your "temperature"? If you can post your code it would help
              • R ricmail85
                Thanks in advance.
                @ricmail85 you mean you're only getting integers here?
                • R
                  R
                  ricmail85
                  @mfalkvidd yes I see only integer numbers here and in devices.
                  @gohan I've declared the variable temperature as float. However after I bit of debugging I found that it seems to be related to the dht lib included in the mysensors examples. If the model is dht11 the library is set for 0 decimals. For the dht22 it would be 1 decimal.
                  Am I right? Thanks in advance
                    scottdube
                    NEWBIE ALERT -- Has anyone else had trouble getting the code above to compile? I'm getting the following error.
                    ysensors_Humidity:91: error: 'class DHT' has no member named 'setup'
                    Mysensors_Humidity:92: error: 'class DHT' has no member named 'getMinimumSamplingPeriod'
                    Mysensors_Humidity:97: error: 'class DHT' has no member named 'getMinimumSamplingPeriod'
                    /Users/scottdube/Documents/Arduino/Mysensors_Humidity/Mysensors_Humidity.ino: In function 'void loop()':
                    Mysensors_Humidity:104: error: 'class DHT' has no member named 'readSensor'
                    dht.readSensor(true);
                    Mysensors_Humidity:107: error: 'class DHT' has no member named 'getTemperature'
                    Mysensors_Humidity:114: error: 'class DHT' has no member named 'toFahrenheit'
                    Mysensors_Humidity:131: error: 'class DHT' has no member named 'getHumidity'
                    exit status 1
                    no matching function for call to 'DHT::DHT()'
                      I guess you are using a different dht library version
                      S 1 Reply Last reply
                        scottdube
                        @gohan I got it past that point... Now I can't tell what the humidity or temp is? I cannot seem to find where (what file) controls what is being output. See below this is from my serial gateway, I can't figure out what these values represent. :READ,255-255-0,s=36,c=3,t=3,pt=0,l=0,sg=0:
                        255;36;3;0;3;
                        0;255;3;0;9;0 MCO:BGN:INIT GW,CP=RNNGA---,VER=2.2.0
                        0;255;3;0;9;4 TSM:INIT
                        0;255;3;0;9;6 TSF:WUR:MS=0
                        0;255;3;0;9;14 TSM:INIT:TSP OK
                        0;255;3;0;9;17 TSM:INIT:GW MODE
                        0;255;3;0;9;20 TSM:READY:ID=0,PAR=0,DIS=0
                        0;255;3;0;9;23 MCO:REG:NOT NEEDED
                        0;255;0;0;18;2.2.0
                        0;255;3;0;9;28 MCO:BGN:STP
                        0;255;3;0;9;34 MCO:BGN:INIT OK,TSP=1
                        0;255;3;0;9;30224 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                        0;255;3;0;9;30231 TSF:MSG:BC
                        0;255;3;0;9;30233 TSF:MSG:FPAR REQ,ID=255
                        0;255;3;0;9;30237 TSF:PNG:SEND,TO=0
                        0;255;3;0;9;30240 TSF:CKU:OK
                        0;255;3;0;9;30243 TSF:MSG:GWL OK
                        0;255;3;0;9;30832 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                        0;255;3;0;9;32237 TSF:MSG:READ,255-255-0,s=36,c=3,t=3,pt=0,l=0,sg=0:
                        255;36;3;0;3;
                        0;255;3;0;9;34249 TSF:MSG:READ,255-255-0,s=1,c=3,t=3,pt=0,l=0,sg=0:
                        255;1;3;0;3;
                        0;255;3;0;9;36260 TSF:MSG:READ,255-255-0,s=220,c=3,t=3,pt=0,l=0,sg=0:
                        255;220;3;0;3;
                        0;255;3;0;9;38270 TSF:MSG:READ,255-255-0,s=183,c=3,t=3,pt=0,l=0,sg=0:
                        255;183;3;0;3;
                          The is the log parser on the mysensors site. Anyway that means you didn't set a node ID on your node and it is asking for one but there is no controller providing one.
                          • I
                            I
                            Ihor
                            I have some problem...
                            C:\Users\ibaturin\Desktop\DHT\DHT.ino: In function 'void loop()':
                            DHT:104: error: no matching function for call to 'DHT::readSensor(bool)'
                            C:\Users\ibaturin\Desktop\DHT\DHT.ino:104:22: note: candidate is:
                            In file included from C:\Users\ibaturin\Desktop\DHT\DHT.ino:44:0:
                            C:\ARDUINO\arduino-nightly\portable\sketchbook\libraries\arduino-DHT-master/DHT.h:83:8: note: void DHT::readSensor()
                            void readSensor();
                            C:\ARDUINO\arduino-nightly\portable\sketchbook\libraries\arduino-DHT-master/DHT.h:83:8: note: candidate expects 0 arguments, 1 provided
                            exit status 1
                              did you read this?
                              https://forum.mysensors.org/topic/4326/can-t-compile-humidity-sketch-2-0-what-dht-library-do-i-need/18
                                scottdube
                                @gohan Thank you I was able to resolve that issue and get it communication with the gateway, the vera and now mqtt. Thanks again!
                                • joaoabsJ
                                  joaoabsJ
                                  joaoabs
                                  For the ones looking for a library that makes this DHT sketch work, mysensors have compiled a set of libraries that include this DHT.h and many others. Just go to https://www.mysensors.org/about/arduino#optional---install-external-mysensors-examples (yes, the name is not intuitive, maybe the keyword library would make it more obvious?), or jump directly to here and follow the standard library instructions. It took me two hours to find this, hope it saves time for future followers of mysensors like myself.
                                  Good luck!
                                  • joaoabsJ
                                    joaoabsJ
                                    joaoabs
                                    Here is the set of libraries where you can find the DHT.h: https://github.com/mysensors/MySensorsArduinoExamples/archive/master.zip
                                    • P
                                      P
                                      Pavel Polititsky
                                      If I use this string in a code "sleep(dht.getMinimumSamplingPeriod());" DHT22 (AM2320) always read NaN
                                      else DHT22 working, but never sleeping
                                      What im doing wrong?
                                      • joaoabsJ
                                        joaoabsJ
                                        joaoabs
                                        Where are you reading this "NaN"?
                                        I sometimes also have it in my OpenHab controller webpage when the node doesn't communicate for a while... But when it does, it changes to the value it read from the sensor.
                                        Try to see in the GW if there is traffic comming from that node. Usualy you can read there the values.
                                        Good luck!
                                        • P
                                          P
                                          Pavel Polititsky
                                          In a serial debug of the sensor module
                                          It write something like "Failed to read data humidity (temperature)
                                          Also no send any data to gateway
                                          Without getMinimumSamplingPeriod I've receiving hum & temp through gateway
