  2. Announcements
  3. 💬 Air Humidity Sensor - DHT
149 Posts 48 Posters 104.1k Views 38 Watching
    I guess you are using a different dht library version
    scottdube
    @gohan I got it past that point... Now I can't tell what the humidity or temp is? I cannot seem to find where (what file) controls what is being output. See below this is from my serial gateway, I can't figure out what these values represent. :READ,255-255-0,s=36,c=3,t=3,pt=0,l=0,sg=0:
    255;36;3;0;3;
    0;255;3;0;9;0 MCO:BGN:INIT GW,CP=RNNGA---,VER=2.2.0
    0;255;3;0;9;4 TSM:INIT
    0;255;3;0;9;6 TSF:WUR:MS=0
    0;255;3;0;9;14 TSM:INIT:TSP OK
    0;255;3;0;9;17 TSM:INIT:GW MODE
    0;255;3;0;9;20 TSM:READY:ID=0,PAR=0,DIS=0
    0;255;3;0;9;23 MCO:REG:NOT NEEDED
    0;255;0;0;18;2.2.0
    0;255;3;0;9;28 MCO:BGN:STP
    0;255;3;0;9;34 MCO:BGN:INIT OK,TSP=1
    0;255;3;0;9;30224 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    0;255;3;0;9;30231 TSF:MSG:BC
    0;255;3;0;9;30233 TSF:MSG:FPAR REQ,ID=255
    0;255;3;0;9;30237 TSF:PNG:SEND,TO=0
    0;255;3;0;9;30240 TSF:CKU:OK
    0;255;3;0;9;30243 TSF:MSG:GWL OK
    0;255;3;0;9;30832 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
    0;255;3;0;9;32237 TSF:MSG:READ,255-255-0,s=36,c=3,t=3,pt=0,l=0,sg=0:
    255;36;3;0;3;
    0;255;3;0;9;34249 TSF:MSG:READ,255-255-0,s=1,c=3,t=3,pt=0,l=0,sg=0:
    255;1;3;0;3;
    0;255;3;0;9;36260 TSF:MSG:READ,255-255-0,s=220,c=3,t=3,pt=0,l=0,sg=0:
    255;220;3;0;3;
    0;255;3;0;9;38270 TSF:MSG:READ,255-255-0,s=183,c=3,t=3,pt=0,l=0,sg=0:
    255;183;3;0;3;
      The is the log parser on the mysensors site. Anyway that means you didn't set a node ID on your node and it is asking for one but there is no controller providing one.
      S 1 Reply Last reply
      • I
        I
        Ihor
        I have some problem...
        C:\Users\ibaturin\Desktop\DHT\DHT.ino: In function 'void loop()':
        DHT:104: error: no matching function for call to 'DHT::readSensor(bool)'
        dht.readSensor(true);
        C:\Users\ibaturin\Desktop\DHT\DHT.ino:104:22: note: candidate is:
        In file included from C:\Users\ibaturin\Desktop\DHT\DHT.ino:44:0:
        C:\ARDUINO\arduino-nightly\portable\sketchbook\libraries\arduino-DHT-master/DHT.h:83:8: note: void DHT::readSensor()
        void readSensor();
        C:\ARDUINO\arduino-nightly\portable\sketchbook\libraries\arduino-DHT-master/DHT.h:83:8: note: candidate expects 0 arguments, 1 provided
        exit status 1
          did you read this?
          https://forum.mysensors.org/topic/4326/can-t-compile-humidity-sketch-2-0-what-dht-library-do-i-need/18
            scottdube
            @gohan Thank you I was able to resolve that issue and get it communication with the gateway, the vera and now mqtt. Thanks again!
            • joaoabsJ
              joaoabsJ
              joaoabs
              For the ones looking for a library that makes this DHT sketch work, mysensors have compiled a set of libraries that include this DHT.h and many others. Just go to https://www.mysensors.org/about/arduino#optional---install-external-mysensors-examples (yes, the name is not intuitive, maybe the keyword library would make it more obvious?), or jump directly to here and follow the standard library instructions. It took me two hours to find this, hope it saves time for future followers of mysensors like myself.
              Good luck!
              • joaoabsJ
                joaoabsJ
                joaoabs
                Here is the set of libraries where you can find the DHT.h: https://github.com/mysensors/MySensorsArduinoExamples/archive/master.zip
                • P
                  P
                  Pavel Polititsky
                  If I use this string in a code "sleep(dht.getMinimumSamplingPeriod());" DHT22 (AM2320) always read NaN
                  else DHT22 working, but never sleeping
                  What im doing wrong?
                  • joaoabsJ
                    joaoabsJ
                    joaoabs
                    Where are you reading this "NaN"?
                    I sometimes also have it in my OpenHab controller webpage when the node doesn't communicate for a while... But when it does, it changes to the value it read from the sensor.
                    Try to see in the GW if there is traffic comming from that node. Usualy you can read there the values.
                    Good luck!
                    • P
                      P
                      Pavel Polititsky
                      In a serial debug of the sensor module
                      It write something like "Failed to read data humidity (temperature)
                      Also no send any data to gateway
                      Without getMinimumSamplingPeriod I've receiving hum & temp through gateway
                        DHT sensor is not very fast, it needs some times between initialization and the different readings
                          Maschler
                          Hi
                          this program doesn’t work with my setup. For the Gateway I am using a Ardunio nano as a serial Gateway. Thus, I am using the GatewaySerial.ino. Even the Node is based on an Arduino nano with a DHT22 connected. The general communication between both seems to work. But I do not receive any sensor data. When testing the setup with another library for the dht sensor, it works fine (without sending to the gateway, only serial Monitor). Because I am new in the mysensors community there is perhaps a simple mistake which I don’t see… I hope you can help me finding my mistake.
                          Here is a short extract of the Debugging Information’s. As far as I see there are no data transferred.
                          Gateway:
                          0;255;3;0;9;0 MCO:BGN:INIT GW,CP=RRNGA---,VER=2.3.0
                          0;255;3;0;9;9 TSM:INIT:TSP OK
                          0;255;3;0;9;12 TSM:INIT:GW MODE
                          0;255;3;0;9;15 TSM:READY:ID=0,PAR=0,DIS=0
                          0;255;3;0;9;19 MCO:REG:NOT NEEDED
                          0;255;0;0;18;2.3.0
                          0;255;3;0;9;23 MCO:BGN:STP
                          0;255;3;0;9;29 MCO:BGN:INIT OK,TSP=1
                          0;255;3;0;9;1907 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                          0;255;3;0;9;1913 TSF:MSG:BC
                          0;255;3;0;9;1916 TSF:MSG:FPAR REQ,ID=255
                          0;255;3;0;9;1920 TSF:CKU:OK,FCTRL
                          0;255;3;0;9;1923 TSF:MSG:GWL OK
                          0;255;3;0;9;4047 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                          0;255;3;0;9;5136 TSF:MSG:READ,255-255-0,s=187,c=3,t=3,pt=0,l=0,sg=0:
                          255;187;3;0;3;
                          0;255;3;0;9;7150 TSF:MSG:READ,255-255-0,s=155,c=3,t=3,pt=0,l=0,sg=0:
                          255;155;3;0;3;
                          0;255;3;0;9;9164 TSF:MSG:READ,255-255-0,s=123,c=3,t=3,pt=0,l=0,sg=0:
                          255;123;3;0;3;
                          0;255;3;0;9;11179 TSF:MSG:READ,255-255-0,s=91,c=3,t=3,pt=0,l=0,sg=0:
                          255;91;3;0;3;
                          Sensor:
                          16 MCO:BGN:INIT NODE,CP=RRNNA---,VER=2.3.0
                          25 TSM:INIT
                          26 TSF:WUR:MS=0
                          29 TSM:INIT:TSP OK
                          30 TSM:FPAR
                          1250 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          1368 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                          1373 TSF:MSG:FPAR OK,ID=0,D=1
                          1571 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                          1774 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                          1977 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                          3257 TSM:FPAR:OK
                          3258 TSM:ID
                          3259 TSM:ID:REQ
                          3267 TSF:MSG:SEND,255-255-0-0,s=187,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                          5274 TSM:ID
                          5275 TSM:ID:REQ
                          5283 TSF:MSG:SEND,255-255-0-0,s=155,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                          7290 TSM:ID
                          7291 TSM:ID:REQ
                          7299 TSF:MSG:SEND,255-255-0-0,s=123,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                          9306 TSM:ID
                          9307 TSM:ID:REQ
                          9315 TSF:MSG:SEND,255-255-0-0,s=91,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                          11322 !TSM:ID:FAIL
                          11323 TSM:FAIL:CNT=1
                          11325 TSM:FAIL:DIS
                          11327 TSF:TDI:TSL
                          21330 TSM:FAIL:RE-INIT
                          21332 TSM:INIT
                          21335 TSM:INIT:TSP OK
                          21337 TSM:FPAR
                          • bgunnarbB
                            bgunnarbB
                            bgunnarb
                            Hi!
                            What controller are you using?
                            From the logs it seems that the sensor is asking for an ID but does not get any.
                            Node ID is handed out by the controller. Or else you have to set the node ID in the sketch. What does the sketch look like?
                            I have never been so busy since I retired!
                              Maschler
                              Hi
                              thanks for reply. I am using this sketch: https://github.com/mysensors/MySensors/blob/development/examples/GatewaySerial/GatewaySerial.ino
                              The only thing I changed is the radio type and I disabled the inclusion mode.
                              • bgunnarbB
                                bgunnarbB
                                bgunnarb
                                Yes but the issue is with the sensor node. What sketch are you using there?
                                  Maschler
                                  Oh. I am using the sketch in from above and only changed the radio module.
                                    Maschler
                                    @bgunnarb
                                    You are right. I had to define a sensor id and now it works perfectly :) Thank you very much!
                                    • R
                                      R
                                      roachgf85
                                      Note: Double check your DHT11 module! The pinouts of the PCB of my DHT11 module differed from those in this article. My leftmost pin was Data out, the middle pin was VCC and the right was GND.
                                      • cneroneC
                                        cneroneC
                                        cnerone
                                        Hi all,
                                        I recoded this sketch and I posted on GitHub (1 year ago, and I updated it today). It runs good from 1 year with no issues.
                                        I don't know why it's still not merged in master branch. I forgot to do some action??
                                        Can anyone help me? please.
                                        Meanwhile you can download and use it; this is its link:
                                        https://github.com/cnerone/MySensorsArduinoExamples/blob/master/examples/DhtTemperatureAndHumiditySensor/DhtTemperatureAndHumiditySensor.ino
                                        • cneroneC cnerone
                                          Hi all,
                                          @cnerone no you did 't forget anything. It is just that the external examples don't get much attention and are a bit truoublesome (due to the need of handling third party libraries).
