  3. MyController.org
  4. Memory Consumption
Memory Consumption
Scheduled Pinned Locked Moved MyController.org
10 Posts 4 Posters 3.5k Views 4 Watching
  • SoloamS
    SoloamS
    Soloam
    Hello, any one having problem with memory consumption of MyController? I don't know if its normal, but in my case the java process is consuming almost 2Gb of memory of my system. Is this normal? And if yes, is there any way to reduce this value?
    Thank You
      Mine is running on a 20% mem usage on a 30 days uptime
      • SoloamS
        SoloamS
        Soloam
        I have 16Gb on my system, so 20% would be 3.2 Gb, I have 2Gb, and seems a bit high, I had a problem with memory today in my server, and was looking at the top memory users, and found MyController on the top of the list. I sill only installed My controller, nothing configured yet. Only assign the Gateway and it auto discovered the nodes. I even disabled the MQTT server, since I already have one running.
          wrote on last edited by gohan
          sorry, on a raspberry Pi 3, but java is known to be a little resource hungry
          • SoloamS
            SoloamS
            Soloam
            So we are talking about 200Mb of consumption... If its the Rp3 (1Gb Ram)...
            • mfalkviddM
              I have no experience with MyController but the java virtual machine can be set to not expand memory usage above for example 256MB by setting Xmx256m. More info: https://alvinalexander.com/blog/post/java/java-xmx-xms-memory-heap-size-control
              The Xmx parameter is set in the MyController start script: https://github.com/mycontroller-org/mycontroller/blob/development/dist/src/main/package/bin/start.sh#L27
              But it looks like the default setting is 256MB so I don't understand why your instance is using 2GB. Could you check your start script?
              • SoloamS
                SoloamS
                Soloam
                Afther some googling I changed the start.sh
                From This
                #Java Heap settings
                HEAP_MIN=-Xms32m
                HEAP_MAX=-Xmx256m
                To this
                #Java Heap settings
                HEAP_MIN="-Xms32m -XX:PermSize=32m"
                HEAP_MAX="-Xmx256m -XX:MaxPermSize=256m -Xss1m"
                And now the max memory is respected...
                Some dev can pronounce him self if this can give any problems....
                Thank You all
                • SoloamS
                  SoloamS
                  Soloam
                  I can mention that I run MyController in a FreeNas Jail (FreeBSD Jail) and is working well, I had to do some teweeking to make it work. If someone is interested I can Make a tutorial on how to adapt the MyController to work in FreeBSD
                  • SoloamS Soloam
                    From This
                    #Java Heap settings
                    HEAP_MIN=-Xms32m
                    HEAP_MAX=-Xmx256m
                    To this
                    #Java Heap settings
                    Thank You all
                    @soloam great work.
                    Note: If you are able to upgrade to Java 8, you should no longer need to set XX:MaxPermSize
                    If you want to dig deeper into the memory usage, use the command jstat -gcutil to get access to a lot of information.
                    • skywatchS
                      skywatchS
                      skywatch
                      Mine usually tops out at about 30%.
                      What is the output of the following??
                      $ java -version
                      $ javac -version
