  3. 💬 simple MySensors MultiSensor Board
mysensorshtu21dldrsensor
6 Posts 5 Posters 3.8k Views 4 Watching
  • openhardware.ioO
    openhardware.ioO
    openhardware.io
    https://www.openhardware.io/view/562/simple-MySensors-MultiSensor-Board
    • R
      R
      Robbie_
      wrote on last edited by Robbie_
      Hi, i printed ur boards, its cool thank you :-). However i'm having some trouble getting the radio working properly.
      It only works good when i touch the antenna..
      Im not using the ceramic 0.1uf cap. and the 10k resistor..
      is the 0.1uf cap. needed for the radio to work stable?
      And yes, im using the 4.7 - 47uF Capacitor (Elko)
      Thanks again, every cool board
      • dirkcD
        dirkcD
        dirkc
        I always suggest to use caps wherever you power the board, because it "levels" or "balances" the current so it has more "stability". The resistor connected to reset is always needed as "pull-up", without that, the processor will either reboot or be unstable.
        Controller: Home Assistant & FHEM - Gateway: ESP8266wifi - MySensors: 2.3.2 (nRF24)
        • T
          terxw
          Hi, I placed an order with allpcb, but during review there was error no noc drill file, can samobody help me to generate them from brd file or is the file missing? Thanx for good board!
          dirkcD 1 Reply Last reply
          • T terxw
            dirkcD
            dirkcD
            dirkc
            @terxw all files from https://www.openhardware.io/view/562/simple-MySensors-MultiSensor-Board were sufficient, when I ordered my boards at allpcb. But you can create them with eagle on your own.
              momo90
              Hi!
              I have the same problem as terxw. allpcb.com is missing the "NC drill date". Unfortunately I am not able to create this on my own. Can anybody upload this file?
