  3. CNC PCB milling
CNC PCB milling
933 Posts 28 Posters 809.5k Views 27 Watching
  • coddingtonbearC coddingtonbear
    @NeverDie -- the motors used in 1610 CNC mills are generally what are called a "775 Motor". You might be able to find other specs, but the ones I've found suggest that at 24V and no load , they claim 7kRPM -- http://linksprite.com/wiki/index.php5?title=File:Motor_performance_parameter.png; I'm not sure how much slower we could expect it to be while milling. As far as actually measuring this, there are devices you could buy, but you could pretty easily fabricobble your way to an answer if you wanted to make a project out of it: http://www.instructables.com/id/Measure-RPM-DIY-Portable-Digital-Tachometer/.
    I have the same mill as you, and swapped for one of these https://www.amazon.com/gp/product/B074FVKRZM/ and have had much better results so far.
    RFM69R
    RFM69R
    RFM69
    @coddingtonbear What materials are you milling ?
    I want to get a spindle for mostly wood, just hobby, but don't want to go too cheap, and face buying over when I realize its just not > W
    coddingtonbearC 1 Reply Last reply
    • RFM69R RFM69
      I'm also looking for a good spindle so thanks for the links and comments.
      Thought I'd share this link text. Its the 30A High Power Single way H-bridge DC Motor Driver Module. That "Frank From Germany" found and is using as part of his tool changing, along with a current sensor so he can brake, reverse and control speed on his tool changer, via arduino, to make it all work.
      RFM69R
      RFM69R
      RFM69
      wrote on last edited by RFM69
      #612
      Just found a more powerful one...
      @rfm69 link text
      So could this or the 30A version, power an 800w DC 0-48V motor ?
      • RFM69R RFM69
        @rfm69 link text
        #613
        @rfm69
        800/48=16.7amp. Therefore, at least in terms of amps alone, the first (cheaper) one you posted should easily be sufficient, if you're running it just full-on or full-off.
        RFM69R 1 Reply Last reply
          @rfm69
          RFM69R
          RFM69R
          RFM69
          @neverdie Thanks thats what I thought, but I'm confused about the voltage range of some of the spindles. They use variable DC voltage to regulate speed ? I don't thinks so, they use PWM at any voltage I provide it with, no ?
          So the V range specified on DC spindle is just what it can be driven at, and its the PWM which actually controls the speed ? Is this right ?
          • RFM69R RFM69
            @rfm69 I believe so, at least for brush motors. For brushless, I get the impression the motors are missing the electronics which tell them when to alternate their currents internally, so (it appears) you need a special driver to make them move at all. I'm not sure how, or even if, PWM fits into that. Maybe motor speed is all managed entirely through the brushless controller, and all the brushless controller wants as input is pure DC?
            RFM69R coddingtonbearC 2 Replies Last reply
              RFM69R
              RFM69R
              RFM69
              @neverdie :) Now I'm even more confused with this difference between brushed and brushless...
              • RFM69R RFM69
                @rfm69 The main advantages of brushless, as I understand it, are longer motor life (because no brushes to wear out) and probably less EMI if it's done right.
                  Also, I should think it would be easy for a brushless controller to provide accurate tachometer readings.
                    #619
                    I'll probably get this to power my new spindle after it arrives:
                    https://www.amazon.com/gp/product/B0716XVR7P/ref=ox_sc_act_title_1?smid=AFHAE9RJVUMB&psc=1#customerReviews
                    Instead of PWM, I'll just adjust the voltage directly. Wish they could have given it a normal power plug for its AC input voltage....
                      #620
                      In any case, I suspect that greater control over the speed of the spindle will lead to greater control over vibration as well. i.e. select a speed where there is less resonance/vibration of the pcb/spindle. Using an accelerometer to measure vibration, perhaps that could even be made somewhat automatic.
                      Alternatively, a trick I've seen used is to continuously vary the RPM over some range, so that the amount of time spent dwelling at the resonance frequency is reduced. That would also be easier to implement.
                      I imagine that either method might also lead to a generally quieter machine, which, IMHO, is generally desirable.
                        #621
                        BTW, using a dremel or a proxon for cnc may be a bad idea. Tom Sanlanderer tried it (twice) with a Proxon, but the bearings rapidly burned out both times:
                        https://www.youtube.com/watch?v=MDz1A1XDOt8&t=311s
                        On the other hand, etching PCB's shouldn't be as taxing as full-on CNC work, so I'm not yet convinced it wouldn't work for etching PCB's. I think it's worth a try. If 35,000RPM turned out to be a great speed to etch at, then I'd be motivated to upgrade further and try 60,000RPM.
                        Would there be more runout at those higher speeds? On the one hand, the spindle is possibly more precise to begin with. On the other hand, at those rotational speeds, the bit might want to bend just from the centrifugal forces on it, unless it was perfectly balanced. Most etching bits don't even look perfectly balanced though....
                          RFM69R
                          RFM69R
                          RFM69
                          @neverdie so to get the max rated RPM out of a dc motor you need to operate at its max rated voltage ? with no PWM ?
                          Running a DC motor rated at say 12-60V with PWM at only 12V would never get to top speed ?
                          Am I understanding correctly ? Thanks for the link
                          • RFM69R RFM69
                            @rfm69 AFAIK, yes.
                            • E
                              E
                              executivul
                              1. Dc aka brushed spindles run on constant (dc) current&voltage. They have some limits. Power it under minimum voltage and they will stall (stop rotating) and only one coil will be energised, heat up and blow. Over maximum voltage they overheat and burn (logically).
                                You can use a constant voltage source or pwm a maximum voltage since the electro-mechanical inertia will act as an integrator and smooth out the pwm pulses asuming pwm frequency is high enough. The driving circuit can be as simple as a high power FET or a complex constant dc voltage source. You control that circuit via a low power pwm or voltage signal. Pwm can be easily converted to dc by a low-pass RC filter.
                              2. Brushless motors NEED a driver, same as steppers, since phases must be shifted in syncronisation to shaft speed and position. The control of the driving circuit is the same pwm or dc voltage talk as above.
                              • E executivul
                                RFM69R
                                RFM69R
                                RFM69
                                @executivul Thanks makes sense and I just started to read simular explaination in other places, but yours helped.
                                How about rpm ? Is it generally considered that higher RPM is better, or at least not being limited by a low speed ? I've seen 1 300w spindle rated at 60,000rpm would this be better than a higher power slower spindle ?
                                E 1 Reply Last reply
                                • E
                                  E
                                  executivul
                                  @NeverDie I use my 60k rpm spindle at 30-40k rpm most of the time. I manualy crank the vfd pot to max rpm, then slowly start lowering taking notes where the lowest harmonic resonance points are, then chose the highest acceptable one. Eg 100% rpm high noise, 94% rpm low noise, 93-84% rpm noise again, 83%rpm even lower noise, 82-xxx% noise again. I chose 83%. Most Vcarve milling bits are rated to 40k rpm anyways. This speed / resonance tuning must be done after every tool change, even a slight tightening of the tool a bit more can change balancing.
                                  IMHO 24k rpm are enough for up to 1000mm/min pcb milling.
                                  • E executivul
                                    @executivul Which 60K rpm spindle is it that you are using? Are you generally happy with it, even if you tend to run in the 30-40K rpm range most of the time? i.e. would you buy it again, or would you maybe get something different?
                                    • RFM69R RFM69
                                      E
                                      E
                                      executivul
                                      @rfm69 the honest answear: "It depends!"
                                      I've had much better luck at higher rpm. I've even posted a gcode to determine the best feed/rpm in this thread.
                                      To mathematically know for sure you would need a few hundred thousand dollars worth of equipment, engraving pcbs is not milling, so chipload calculators won't work. Lower rpm rips the copper leaving rough edges, too high of a rpm increases runout. As I've said IMHO 24-30k rpm is enough for our machines, you need a far better, stiffer frame, servos instead of steppers and a very good controller board to be able to go over 1000mm/s (400in/s).
                                        E
                                        E
                                        executivul
                                        @neverdie i would go for a 24k 800W water cooled spindle, far better "all around" tool, can mill wood or aluminium easier
                                        The 60k is great for pcbs and that's about it.
                                        A larger wattage, lower max rpm spindle has a larger and heavier rotor, higher inertia, can withstand higher chiploads.
                                        Remember, as in stepper's case, running a spindle at 50% of max rpm yelds far less than 50% of power, maybe as low as 10%. Going under 50% you get as low as 3-5% of max rated power. For pcbs that's no biggie, but for anything else... And you can't mill wood or metals at 60k rpm because of the feedrate needed to keep the chipload and the cooling needed not to burn the tool and stock.
                                          Quoting DavidSohlstrom from a thread on a different forum (https://discuss.inventables.com/t/runout-of-24v-dc-spindle/9984/11) in reference to vibration:
                                          I've said it before and I'll say it again. This is a low cost DC motor that has a ER collet adapter attached to it. It is not a CNC spindle that incorporates the tool holder right into spindle with a minimum of stick out from the housing.
                                          There is no bearing preload and the bearings are low cost bearings that have a lot of slop in them.
                                          A bent motor shaft of just a couple of thou will cause a large run out at the tool.
                                          I notice that a lot of the available spindles are exactly that: a motor with an ER11 collet attached. So, the stickout is going to be greater. I haven't yet tried to find a proper CNC spindle like what he describes, where there's minimal stickout. In a perfect world, it sounds like that may be the way to go though.
