  3. Cannot get RFM69HW connection between ESP8266GW and Pro Mini Sensor
35 Posts 4 Posters 5.5k Views 4 Watching
  • E Offline
    E Offline
    elcaron
    wrote on last edited by elcaron
    Hi, I build my first two test devices on breadboard a while ago, one Wemos D1 mini and one Arduino Pro Mini.
    The D1 is flashed with the GatewayESP8266MWTTClient sketch. The Wifi and MQTT connecion works fine, and it seems to start listening:
    59 MCO:BGN:INIT GW,CP=RRNGE---,VER=2.2.0
    63 TSF:LRT:OK
    64 TSM:INIT
    65 TSF:WUR:MS=0
    68 TSM:INIT:TSP OK
    70 TSM:INIT:GW MODE
    72 TSM:READY:ID=0,PAR=0,DIS=0
    74 MCO:REG:NOT NEEDED
    scandone
    scandone
    state: 0 -> 2 (b0)
    state: 2 -> 3 (0)
    state: 3 -> 5 (10)
    add 0
    aid 6
    cnt
    connected with DiscoveryOneIoT, channel 1
    dhcp client start...
    ip:10.165.20.87,mask:255.255.240.0,gw:10.165.16.1
    578 GWT:TPC:CONNECTING...
    580 GWT:TPC:IP=10.165.20.87
    583 MCO:BGN:STP
    584 MCO:BGN:INIT OK,TSP=1
    588 GWT:TPC:IP=10.165.20.87
    590 GWT:RMQ:MQTT RECONNECT
    664 GWT:RMQ:MQTT CONNECTED
    667 GWT:TPS:TOPIC=home-le/rfm69gateway/out/0/255/0/0/18,MSG SENT
    pm open,type:2 0
    The numbers after 583 are Serial.prints of D1, D8 and the respective MySensors defines, indicating that I actually configured the correct pins - the connection tutorial seems to list a wrong IRQ port, so I became very careful with this stuff. Or rather, the default port 2=GPIO2=D4 in the library is badly chosen, because it is a boot pin of the ESP and it didn't actually boot when I connected it.
    The Pro Mini is flashed with the light sensor sketch (because it just reads an analog pin), and tries to connect but seems to fail. The GW does not report anything at the same time:
     __  __       ____
            |___/                      2.2.0
    16 MCO:BGN:INIT NODE,CP=RRNNA---,VER=2.2.0
    26 TSM:INIT
    28 TSF:WUR:MS=0
    30 TSM:INIT:TSP OK
    32 TSM:FPAR
    1253 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    3262 !TSM:FPAR:NO REPLY
    3264 TSM:FPAR
    4483 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    6492 !TSM:FPAR:NO REPLY
    6494 TSM:FPAR
    7712 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    9721 !TSM:FPAR:NO REPLY
    9723 TSM:FPAR
    10942 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    12951 !TSM:FPAR:FAIL
    12953 TSM:FAIL:CNT=1
    12955 TSM:FAIL:DIS
    12957 TSF:TDI:TSL
    I am using the following defines in both sketches before including MySensors.h:
    #define MY_RADIO_RFM69
    #define MY_RFM69_FREQUENCY (RFM69_868MHZ)
    #if defined ARDUINO_ARCH_ESP8266
    #define MY_RFM69_IRQ_PIN D1
    #define MY_RFM69_CS_PIN D8
    #elif defined ARDUINO_ARCH_AVR
    #define MY_RFM69_IRQ_PIN 2
    #define MY_RFM69_CS_PIN 10
    #define MY_IS_RFM69HW
    #define MY_RFM69_NETWORKID (83)
    #define MY_RFM69_MAX_POWER_LEVEL_DBM (10u)
    Without touching the hardware, I can a reliable connection when I flash the rf69_server/client examples of the RadioHead library, with RH_RF69 rf69(D8, D1); on the D1 and RH_RF69 rf69; on the Pro Mini, so on the hardware side, everything seems to be fine.
    I did run the SecurityPersonalizer sketch on both devices, when I thought this would work with less issues, seting soft signing and a matching AES key, but as you can see above, I did not enable encryption. I am only mentioning this, because at least on the ESP the MySensors library seems to have issues with persistent configurations. The SecurityPersonalizer for example alwas tries to connect to my Wifi on the ESP.
    I am pretty much out of ideas. Anyone?
    Here are some picture, not sure how helpful they are:
    1_1520021752562_IMG_20180302_211301.jpg 0_1520021752562_IMG_20180302_211420.jpg
    mfalkviddM A 2 Replies Last reply
    • E elcaron
      63 TSF:LRT:OK
      64 TSM:INIT
      65 TSF:WUR:MS=0
      68 TSM:INIT:TSP OK
      70 TSM:INIT:GW MODE
      scandone
      scandone
      state: 0 -> 2 (b0)
      state: 2 -> 3 (0)
      state: 3 -> 5 (10)
      add 0
      aid 6
      cnt
      583 MCO:BGN:STP
      pm open,type:2 0
       __  __       ____
              |___/                      2.2.0
      26 TSM:INIT
      28 TSF:WUR:MS=0
      30 TSM:INIT:TSP OK
      32 TSM:FPAR
      3264 TSM:FPAR
      6494 TSM:FPAR
      9723 TSM:FPAR
      12955 TSM:FAIL:DIS
      12957 TSF:TDI:TSL
      @elcaron the only thing I can think of is that the helical antenna is positioned very close to the breadboard, which has lots of metal that will interfere with the signal. You could try bending the antenna so it is upright. You could also try moving the devices further apart - especially the high power radios have a tendency to overpower the receiver if the sender is too close.
      But since sending and receiving works with radiohead, antenna position should not be the problem. Are you using the same output power?
      • E elcaron
        63 TSF:LRT:OK
        64 TSM:INIT
        65 TSF:WUR:MS=0
        68 TSM:INIT:TSP OK
        70 TSM:INIT:GW MODE
        scandone
        scandone
        state: 0 -> 2 (b0)
        state: 2 -> 3 (0)
        state: 3 -> 5 (10)
        add 0
        aid 6
        cnt
        583 MCO:BGN:STP
        pm open,type:2 0
         __  __       ____
                |___/                      2.2.0
        26 TSM:INIT
        28 TSF:WUR:MS=0
        30 TSM:INIT:TSP OK
        32 TSM:FPAR
        3264 TSM:FPAR
        6494 TSM:FPAR
        9723 TSM:FPAR
        12955 TSM:FAIL:DIS
        12957 TSF:TDI:TSL
        A Offline
        A Offline
        Anticimex
        @elcaron you have disabled encryption on both the node and the GW? If one of them has it enabled and the other not, they can't communicate.
        As for the personalizer and the esp, others have problem as well communicating with the atsha. Currently the personalizer has no esp specific management so wifi is not handled at all for instance.
        But you can use the password flags for security to test without having to personalize anything.
        • E Offline
          E Offline
          elcaron
          Do you mean this with output power?:
          @elcaron said in Cannot get RFM69 connection between ESP8266GW and Pro Mini Sensor:
          I use exactly the same includes in both sketches, hence the precompiler if statement. Apart from that, there are of course the very different antennas, but with Radiohead, this test setup has a range and wall penetration that can at least rival my 2.4GHz Wifi (works through a concrete ceiling + wall). I have also moved the sensor a few meters away from the gateway now, no difference.
          As I said, I use exactly the same precompiler defines shown above in both sketches. I have tried it with both encryption activated and deactivated. I tested how encryption behaves using the Radiohead lib and understand that it has to match.
          BTW, I am the guy from two weeks ago who had problems with the ATSHA, but I decided to first get the basic stuff sorted :)
          Guess I have to dig out another Pro Mini to test if at least that communication works.
          A mfalkviddM 2 Replies Last reply
          • E elcaron
            A Offline
            A Offline
            Anticimex
            @elcaron ah, thought it sounded familiar :)
            Then I think we can rule out the security complications.
            Have you tested to move the nodes further apart? I have noticed that if they are too close, or within a certain range in close proximity, rf signal decreases significantly.
            • E Offline
              E Offline
              elcaron
              In the last test , they where 5m apart. With radiohead, they work both 20cm away and 20m away with one concrete wall and one ceiling.
              Seems like I have to decide soon if it is easier to dust off the logic analyser and find out what is going on, or to implement HMAC with Radiohead :)
              • E elcaron
                @elcaron sorry for being unclear. I was asking if you used 10dBm output power when testing with the radiohead client/server.
                If you are using less power with radiohead, that could be the answer. As I said, too much power often causes problems.
                • E Offline
                  E Offline
                  elcaron
                  Looking at the Radiohead sketch
                  rf69.setTxPower(14, true);
                  it rather looks like I used it with more power. But then also, I tested Radiohead between 50cm and the abovementioned 20m+wall+ceiling, while ich tested MySensors with 10dB at 50cm and 5m LoS
                    Why don't you leave atc adjusting TX power automatically?
                    • E Offline
                      E Offline
                      elcaron
                      As far as I understand the documentation, I still have ATC enabled, as I did not set #define MY_RFM69_ATC_MODE_DISABLED
                      With MY_RFM69_MAX_POWER_LEVEL_DBM, i could go up to 14dBm for my local legislation, but I stayed a little below it, because I wasn't sure about the antenna gain on the gateway. Do you actually think 10mW compared to the legally possible 25mW are the problem, given that I test at 50cm and 5m line of sight?
                        wrote on last edited by gohan
                        I was just asking since I saw you playing with TX power. Maybe you could give a try without touching the TX power. BTW did you set a node ID on the node?
                        • E Offline
                          E Offline
                          elcaron
                          Ok, I have quoted that line for completeness. No change. I have also set MY_SIGNING_SIMPLE_PASSWD on both nodes to try to rule out issues with encryption:
                          These are my radio related precompiler statements right now:
                          #define MY_SIGNING_SIMPLE_PASSWD "MyInsecurePassword"
                          //#define MY_RFM69_MAX_POWER_LEVEL_DBM (10u)
                          //#define MY_RFM69_SPI_SPEED (800000ul)
                          A 1 Reply Last reply
                          • E elcaron
                            A Offline
                            A Offline
                            Anticimex
                            @elcaron looked like you had encryption disabled previously, so I don't think any security feature is the cause of these issues. Unless you had it defined mysensors.h by accident.
                            E 1 Reply Last reply
                            • A Anticimex
                              E Offline
                              E Offline
                              elcaron
                              @anticimex Didn't expect that either, but better safe than sorry.
                              • E elcaron
                                A Offline
                                A Offline
                                Anticimex
                                @elcaron true, but by using the password flag you actually enable security, so it introduced yet another variable. But since you did not see any difference, I think it is rf related as well.
                                • E Offline
                                  E Offline
                                  elcaron
                                  For further testing, I have set up two Pro Mini now. With these, I get some communication.
                                  SerialGateway:
                                  0;255;3;0;9;0 MCO:BGN:INIT GW,CP=RRNGA---,VER=2.2.0
                                  0;255;3;0;9;4 TSM:INIT
                                  0;255;3;0;9;6 TSF:WUR:MS=0
                                  0;255;3;0;9;10 TSM:INIT:TSP OK
                                  0;255;3;0;9;14 TSM:INIT:GW MODE
                                  0;255;3;0;9;16 TSM:READY:ID=0,PAR=0,DIS=0
                                  0;255;3;0;9;22 MCO:REG:NOT NEEDED
                                  0;255;0;0;18;2.2.0
                                  0;255;3;0;9;28 MCO:BGN:STP
                                  0;255;3;0;9;34 MCO:BGN:INIT OK,TSP=1
                                  0;255;3;0;9;3753 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                                  0;255;3;0;9;3760 TSF:MSG:BC
                                  0;255;3;0;9;3764 TSF:MSG:FPAR REQ,ID=255
                                  0;255;3;0;9;3768 TSF:CKU:OK,FCTRL
                                  0;255;3;0;9;3770 TSF:MSG:GWL OK
                                  0;255;3;0;9;5695 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                  0;255;3;0;9;6993 TSF:MSG:READ,255-255-0,s=192,c=3,t=3,pt=0,l=0,sg=0:
                                  255;192;3;0;3;
                                  0;255;3;0;9;9218 TSF:MSG:READ,255-255-0,s=161,c=3,t=3,pt=0,l=0,sg=0:
                                  255;161;3;0;3;
                                  0;255;3;0;9;11239 TSF:MSG:READ,255-255-0,s=79,c=3,t=3,pt=0,l=0,sg=0:
                                  255;79;3;0;3;
                                  0;255;3;0;9;13258 TSF:MSG:READ,255-255-0,s=49,c=3,t=3,pt=0,l=0,sg=0:
                                  255;49;3;0;3;
                                  Client:
                                  26 TSM:INIT
                                  28 TSF:WUR:MS=0
                                  30 TSM:INIT:TSP OK
                                  32 TSM:FPAR
                                  1374 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                  1380 TSF:MSG:FPAR OK,ID=0,D=1
                                  1576 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                  1779 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                  3262 TSM:FPAR:OK
                                  3262 TSM:ID
                                  3264 TSM:ID:REQ
                                  3274 TSF:MSG:SEND,255-255-0-0,s=192,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                                  5281 TSM:ID
                                  5281 TSM:ID:REQ
                                  5494 TSF:MSG:SEND,255-255-0-0,s=161,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                                  7503 TSM:ID
                                  7503 TSM:ID:REQ
                                  7514 TSF:MSG:SEND,255-255-0-0,s=79,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                                  9521 TSM:ID
                                  9521 TSM:ID:REQ
                                  9531 TSF:MSG:SEND,255-255-0-0,s=49,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                                  11538 !TSM:ID:FAIL
                                  11540 TSM:FAIL:CNT=1
                                  11542 TSM:FAIL:DIS
                                  11544 TSF:TDI:TSL
                                  It looks like they exchange packages about the parent, but the gateway never answers the id request for some reason.
                                  I have quoted all lines regarding inclusion mode in the gateway sketch.
                                  Is this because no controller is configured?
                                  Interestingly, falshed as a node, the ESP8266 now also shows up on the gateway, with the same issues.
                                    I asked you earlier if you set a NODE ID, if not you have to add
                                    #define MY_NODE_ID 1
                                    before the include mysensors.h in your node sketch
                                    • A Offline
                                      A Offline
                                      Anticimex
                                      Exactly. If no controller is configured, nobody assigns a node id, so you need to define it yourself.
                                        E Offline
                                        E Offline
                                        elcaron
                                        @gohan Oh, I missed that bit. It wasn't essential until now, though, as it seems, since with the ESP gateway, there wasn't even an answer to the parent request.
                                        Then I'll try and connect it to my openhab.
                                        • E Offline
                                          E Offline
                                          elcaron
                                          Ok, I have finally identified the issue.
                                          I did some more testing with the switched roles, ESP8266 as (light) sensor, Pro Mini as serial gateway, hardcoded MY_NODE_ID. According to the logs, the ESP sends the parent quest, the Pro Mini answers, but never gets an ACK. The ESP does not report any answer. Ergo, the interrupt doesn't work.
                                          So I scoped it, electrically, everything was fine. I tried D2 instead of D1, no change. Then I remembered that the default in the code was GPIO2, which is D4. This is a really stupid choice, because if you connect it like that, the ESP will not boot. GPIO2 needs to be pulled up during boot, and DIO0 from the RFM69 pulls it down. What works though is to first boot, then connect the cable.
                                          Lo and behold - everything suddenly worked. So either I am the idiot and #define MY_RFM69_IRQ_PIN D1 is not how you set the interrupt, or whoever thought that it was clever to default the interrupt to a pin that prevents booting also decided to ignore the configured value ...
                                          I'll dig into the code to find out, but of course wouldn't mind if anybody who knows the code better would be faster :)
                                          Will file an issue or pull request if I find something.
                                          12.0k
