  3. Serial Gateway problems
8 Posts 2 Posters 2.1k Views 2 Watching
  • T Offline
    T Offline
    Tommy Petersen
    Hello All
    First time poster here, so I hope I am in the right place.
    At some point the Serial Gateway comes up with TSM:READY:NWD REQ and nothing more happens.
    I have to restart to get it up and running again.
    Now it looks to me that I am missing something, I have been searching the forum for some help but haven't found it.
    I am running a temp sketch on a pro mini and the gateway on a pi.
    • T Tommy Petersen
      Hello All
      Hi @tommy-petersen , welcome to the MySensors community!
      Could you post the entire log, from both the gateway and the node? That would help a lot.
      Please also include the configure comand you used for the gateway.
      • T Offline
        T Offline
        Tommy Petersen
        Normally it takes anywhere from 30 min to 4 hours before it happens, but I will make an update.
        The gateway I made following the guide https://www.mysensors.org/build/raspberry
        With the command --my-transport=nrf24 --my-rf24-irq-pin=15 as I thought that might fix the issue
        The node sketch is this one.
         * Example sketch showing how to send in DS1820B OneWire temperature readings back to the controller
         * http://www.mysensors.org/build/temp
         * The cool thing about this temperature sensor (pun intended) is thay you can attach multiple Dallas temperature sensors outputs to the same arduino pin. They will all automatically be recognised as separate sensors.
         * At the moment of writing (februari 2017) you need older versions of the Dallas and OneWire libraries. Please check the website or forum to see if this is still the case.
         * Modifications by anonymous user so that it can now simultaneously function as a MySensors repeater.
        #define MY_RADIO_NRF24                            // A 2.4Ghz transmitter and receiver, often used with MySensors.
        #define MY_RF24_PA_LEVEL RF24_PA_MAX              // This sets a low-power mode for the radio. Useful if you use the verison with the bigger antenna, but don' want to power that from a separate source. It can also fix problems with fake Chinese versions of the radio.
        //#define MY_RADIO_RFM69                          // 433Mhz transmitter and reveiver.
        // Choose if you want this sensor to also be a repeater.
        // #define MY_REPEATER_FEATURE                    // Just remove the two slashes at the beginning of this line to also enable this sensor to act as a repeater for other sensors. If this node is on battery power, you probably shouldn't enable this.
        // Are you using this sensor on battery power?
        #define BATTERY_POWERED                   // Just remove the two slashes at the beginning of this line if your node is battery powered. It will then go into deep sleep as much as possible. But when it' sleeping it can' work as a repeater.
        #define MY_NODE_ID 20
        #include <OneWire.h>
        // These defines and variables can be changed:
        #define COMPARE_TEMP 1                            // Send temperature only if changed? 1 = Yes 0 = No. Can save battery.
        #define ONE_WIRE_BUS 3                            // Pin where Dallas sensor(s) is/are connected.
        #define MAX_ATTACHED_DS18B20 16                   // Maximum amount of teperature sensors you can connect to this arduino (16).
        unsigned long measurementInterval = 3000;        // Time to wait between reads (in milliseconds).
        // You should not change these:
        OneWire oneWire(ONE_WIRE_BUS);                    // Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
        DallasTemperature sensors(&oneWire);              // Pass the oneWire reference to Dallas Temperature.
        float lastTemperature[MAX_ATTACHED_DS18B20];      // creates an array to hold the previous temperature measurements for each possible sensor.
        int numSensors=0;                                 // variable to contain the number of found attached sensors.
        boolean metric = true;                            // old Mysensors??
        unsigned long measurementSleepTime = 0;           // variable to store the Sleep time if the node is battery powered.
        // Mysensors settings
        MyMessage msg(0,V_TEMP);                          // Sets up the message format that we'l be sending to the MySensors gateway later.
        void before()
           sensors.begin();                              // Startup up the OneWire library. It allows multiple sensors to talk over one wire (one pin).
           for(int i=0; i<MAX_ATTACHED_DS18B20; i++) {
              lastTemperature[i] = 0;  //Pre-filling array with 0's.
           sensors.setWaitForConversion(false);            // requestTemperatures() will not block current thread
        #ifdef BATTERY_POWERED
           measurementSleepTime = measurementInterval;
           measurementInterval = 1;                    // We'll let Sleep take over the scheduling. When the arduino is asleep, millis doesn't increment anymore (time stops as it were). To fix this, we'l set the measurement interval time to 1, so that when the arduino wakes up it will immediately try to measure again.
           Serial.begin(115200);                           // for serial debugging.
           Serial.print("Hello world, I am a sensor. \n ");
           sendSketchInfo("Temperature Sensor", "1.2");    // Send the sketch version information to the gateway and Controller
           numSensors = sensors.getDeviceCount();          // Fetch the number of attached temperature sensors
              present(i, S_TEMP);                          // Present all sensors to controller (16 maximum).
           // You should not change these variables:
           static boolean isMeasuring = true;                // Used to indicate when the time is right for a new measurement to be made.
           static boolean isCalculating = false;                     // Used to bridge the time that is needed to calculate the temperature values by the Dallas library.
           static unsigned long currentMillis = 0;                   // The millisecond clock in the main loop.
           static unsigned long previousMeasurementMillis = 0;       // Used to remember the time of the last temperature measurement.
           static int16_t conversionTime = 0;                        // Used to store the time needed to calculate the temperature from measurements.
           currentMillis = millis(); // The time since the sensor started, counted in milliseconds. This script tries to avoid using the Sleep function, so that it could at the same time be a MySensors repeater.
           // Let's measure the temperature
           if(isMeasuring == true && currentMillis - previousMeasurementMillis >= measurementInterval) { // If we're not calculating, and enough time has passed, we'll start again.
              isMeasuring = false; // We're measuring, so let's take it off our to-do list.
              Serial.print("Starting new measurement(s)\n");
              previousMeasurementMillis = currentMillis; // Mark the time of the initialiation of this measurement.
              // query conversion time. Apparently it takes a while to calculate.
              //CONVERSION_TIME = sensors.millisToWaitForConversion(sensors.getResolution());
              conversionTime = millisToWaitForConversion(sensors.getResolution());
              isCalculating = true; //Next step is to re-calculate the temperature again.
           // Next, let's calculate and send the temperature
           if(isCalculating == true && currentMillis > previousMeasurementMillis + conversionTime ) {
              isCalculating = false; // check calculating off the to-do list too.
              for (int i=0; i<numSensors && i<MAX_ATTACHED_DS18B20; i++) {    // Loop through all the attached temperatur sensors.
                 float temperature = static_cast<float>(static_cast<int>((getControllerConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;   // Fetch and round temperature to one decimal
                 Serial.print("Sensor #");
                 Serial.print(i);
                 Serial.print(" says it is ");
                 Serial.print(temperature);
                 Serial.print(" degrees\n");
                 if(temperature != -127.00 && temperature != 85.00) { // avoid working with measurement errors.
                    if (COMPARE_TEMP == 1 && lastTemperature[i] == temperature) {
                       Serial.print("Not sending it though, because it's the same temperature as before.\n");
                       Serial.print("Sending the temperature to the gateway.\n");
                       lastTemperature[i] = temperature; // Save new temperatures to be able to compare in the next round.
              // Both tasks are done. Time to wait until we should measure again.
              Serial.print("zzzzZZZZzzzzZZZZzzzz\n");
              unsigned long quicktimecheck = millis(); // check how much time has passed during the measurement (can be up to 750 milliseconds), and then calculate from that how long to sleep until the next intended measuring time.
              unsigned long sleeptime = measurementSleepTime - (quicktimecheck - previousMeasurementMillis); //How much time has passed already during the calculating? Subtract that from the intended interval time.
              sleep (sleeptime);
              isMeasuring = true;
        // This function helps to avoid a problem with the latest Dallas temperature library.
        int16_t millisToWaitForConversion(uint8_t bitResolution)
           switch (bitResolution) {
           case 9:
              return 94;
           case 10:
              return 188;
           case 11:
              return 375;
           default:
              return 750;
          T Offline
          T Offline
          Tommy Petersen
          @mfalkvidd
          So this is the log from the gateway.
          mysgw: TSF:MSG:READ,20-20-0,s=0,c=1,t=0,pt=7,l=5,sg=0:-1.5
          mysgw: TSF:MSG:READ,20-20-0,s=0,c=1,t=0,pt=7,l=5,sg=0:-1.4
          mysgw: TSM:READY:NWD REQ
          mysgw: TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
          mysgw: TSF:MSG:READ,20-20-0,s=0,c=1,t=0,pt=7,l=5,sg=0:-1.3
          mysgw: TSF:SAN:OK
          mysgw: TSF:MSG:READ,20-20-0,s=0,c=1,t=0,pt=7,l=5,sg=0:-1.2
          This is the log from the node.
          12202557 MCO:SLP:MS=2216,SMS=0,I1=255,M1=255,I2=255,M2=255
          12202567 TSF:TDI:TSL
          12202569 MCO:SLP:WUP=-1
          12202573 TSF:TRI:TSB
          Sensor #0 says it is -1.20 degrees
          12203384 TSF:MSG:SEND,20-20-0-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:-1.2
          12203395 MCO:SLP:MS=2180,SMS=0,I1=255,M1=255,I2=255,M2=255
          12203401 TSF:TDI:TSL
          12203403 MCO:SLP:WUP=-1
          12203407 TSF:TRI:TSB
          12204193 MCO:SLP:MS=2216,SMS=0,I1=255,M1=255,I2=255,M2=255
          12204204 TSF:TDI:TSL
          12204206 MCO:SLP:WUP=-1
          12204210 TSF:TRI:TSB
          12204996 MCO:SLP:MS=2216,SMS=0,I1=255,M1=255,I2=255,M2=255
          12205006 TSF:TDI:TSL
          12205008 MCO:SLP:WUP=-1
          12205012 TSF:TRI:TSB
          12205799 MCO:SLP:MS=2216,SMS=0,I1=255,M1=255,I2=255,M2=255
          12205809 TSF:TDI:TSL
          12205811 MCO:SLP:WUP=-1
          12205815 TSF:TRI:TSB
          12206602 MCO:SLP:MS=2215,SMS=0,I1=255,M1=255,I2=255,M2=255
          12206612 TSF:TDI:TSL
          12206614 MCO:SLP:WUP=-1
          12206618 TSF:TRI:TSB
          12207405 MCO:SLP:MS=2215,SMS=0,I1=255,M1=255,I2=255,M2=255
          12207415 TSF:TDI:TSL
          12207417 MCO:SLP:WUP=-1
          12207421 TSF:TRI:TSB
          12208207 MCO:SLP:MS=2216,SMS=0,I1=255,M1=255,I2=255,M2=255
          12208218 TSF:TDI:TSL
          12208220 MCO:SLP:WUP=-1
          12208224 TSF:TRI:TSB
          12209010 MCO:SLP:MS=2216,SMS=0,I1=255,M1=255,I2=255,M2=255
          12209020 TSF:TDI:TSL
          12209022 MCO:SLP:WUP=-1
          12209027 TSF:TRI:TSB
          12209813 MCO:SLP:MS=2216,SMS=0,I1=255,M1=255,I2=255,M2=255
          12209823 TSF:TDI:TSL
          12209825 MCO:SLP:WUP=-1
          12209829 TSF:TRI:TSB
          12210616 MCO:SLP:MS=2215,SMS=0,I1=255,M1=255,I2=255,M2=255
          12210626 TSF:TDI:TSL
          12210628 MCO:SLP:WUP=-1
          12210632 TSF:TRI:TSB
          12211419 MCO:SLP:MS=2215,SMS=0,I1=255,M1=255,I2=255,M2=255
          12211429 TSF:TDI:TSL
          12211431 MCO:SLP:WUP=-1
          12211435 TSF:TRI:TSB
          12212221 MCO:SLP:MS=2216,SMS=0,I1=255,M1=255,I2=255,M2=255
          12212232 TSF:TDI:TSL
          12212234 MCO:SLP:WUP=-1
          12212238 TSF:TRI:TSB
          12213024 MCO:SLP:MS=2216,SMS=0,I1=255,M1=255,I2=255,M2=255
          12213035 TSF:TDI:TSL
          12213037 MCO:SLP:WUP=-1
          12213041 TSF:TRI:TSB
          12213827 MCO:SLP:MS=2216,SMS=0,I1=255,M1=255,I2=255,M2=255
          12213837 TSF:TDI:TSL
          12213839 MCO:SLP:WUP=-1
          12213843 TSF:TRI:TSB
          12214630 MCO:SLP:MS=2216,SMS=0,I1=255,M1=255,I2=255,M2=255
          12214640 TSF:TDI:TSL
          12214642 MCO:SLP:WUP=-1
          12214646 TSF:TRI:TSB
          12215433 MCO:SLP:MS=2215,SMS=0,I1=255,M1=255,I2=255,M2=255
          12215443 TSF:TDI:TSL
          12215445 MCO:SLP:WUP=-1
          12215449 TSF:TRI:TSB
          12216236 MCO:SLP:MS=2215,SMS=0,I1=255,M1=255,I2=255,M2=255
          12216246 TSF:TDI:TSL
          12216248 MCO:SLP:WUP=-1
          12216252 TSF:TRI:TSB
          12217038 MCO:SLP:MS=2216,SMS=0,I1=255,M1=255,I2=255,M2=255
          12217049 TSF:TDI:TSL
          12217051 MCO:SLP:WUP=-1
          12217055 TSF:TRI:TSB
          12217841 MCO:SLP:MS=2216,SMS=0,I1=255,M1=255,I2=255,M2=255
          12217851 TSF:TDI:TSL
          12217853 MCO:SLP:WUP=-1
          12217858 TSF:TRI:TSB
          12218644 MCO:SLP:MS=2216,SMS=0,I1=255,M1=255,I2=255,M2=255
          12218654 TSF:TDI:TSL
          12218656 MCO:SLP:WUP=-1
          12218660 TSF:TRI:TSB
          12219447 MCO:SLP:MS=2215,SMS=0,I1=255,M1=255,I2=255,M2=255
          12219457 TSF:TDI:TSL
          12219459 MCO:SLP:WUP=-1
          12219463 TSF:TRI:TSB
          12220250 MCO:SLP:MS=2215,SMS=0,I1=255,M1=255,I2=255,M2=255
          12220260 TSF:TDI:TSL
          12220262 MCO:SLP:WUP=-1
          12220266 TSF:TRI:TSB
          12221052 MCO:SLP:MS=2216,SMS=0,I1=255,M1=255,I2=255,M2=255
          12221063 TSF:TDI:TSL
          12221065 MCO:SLP:WUP=-1
          12221069 TSF:TRI:TSB
          12221855 MCO:SLP:MS=2216,SMS=0,I1=255,M1=255,I2=255,M2=255
          12221865 TSF:TDI:TSL
          12221868 MCO:SLP:WUP=-1
          12221872 TSF:TRI:TSB
          12222658 MCO:SLP:MS=2216,SMS=0,I1=255,M1=255,I2=255,M2=255
          12222668 TSF:TDI:TSL
          12222670 MCO:SLP:WUP=-1
          12222674 TSF:TRI:TSB
          12223461 MCO:SLP:MS=2215,SMS=0,I1=255,M1=255,I2=255,M2=255
          12223471 TSF:TDI:TSL
          12223473 MCO:SLP:WUP=-1
          12223477 TSF:TRI:TSB
          12224264 MCO:SLP:MS=2215,SMS=0,I1=255,M1=255,I2=255,M2=255
          12224274 TSF:TDI:TSL
          12224276 MCO:SLP:WUP=-1
          12224280 TSF:TRI:TSB
          12225067 MCO:SLP:MS=2215,SMS=0,I1=255,M1=255,I2=255,M2=255
          12225077 TSF:TDI:TSL
          12225079 MCO:SLP:WUP=-1
          12225083 TSF:TRI:TSB
          12225869 MCO:SLP:MS=2216,SMS=0,I1=255,M1=255,I2=255,M2=255
          12225880 TSF:TDI:TSL
          12225882 MCO:SLP:WUP=-1
          12225886 TSF:TRI:TSB
          12226672 MCO:SLP:MS=2216,SMS=0,I1=255,M1=255,I2=255,M2=255
          12226682 TSF:TDI:TSL
          12226684 MCO:SLP:WUP=-1
          12226689 TSF:TRI:TSB
          12227475 MCO:SLP:MS=2216,SMS=0,I1=255,M1=255,I2=255,M2=255
          12227485 TSF:TDI:TSL
          12227487 MCO:SLP:WUP=-1
          12227491 TSF:TRI:TSB
          12228278 MCO:SLP:MS=2215,SMS=0,I1=255,M1=255,I2=255,M2=255
          12228288 TSF:TDI:TSL
          12228290 MCO:SLP:WUP=-1
          12228294 TSF:TRI:TSB
          12229081 MCO:SLP:MS=2215,SMS=0,I1=255,M1=255,I2=255,M2=255
          12229091 TSF:TDI:TSL
          12229093 MCO:SLP:WUP=-1
          12229097 TSF:TRI:TSB
          12229883 MCO:SLP:MS=2216,SMS=0,I1=255,M1=255,I2=255,M2=255
          12229894 TSF:TDI:TSL
          12229896 MCO:SLP:WUP=-1
          12229900 TSF:TRI:TSB
          12230686 MCO:SLP:MS=2216,SMS=0,I1=255,M1=255,I2=255,M2=255
          12230696 TSF:TDI:TSL
          12230699 MCO:SLP:WUP=-1
          12230703 TSF:TRI:TSB
          12231489 MCO:SLP:MS=2216,SMS=0,I1=255,M1=255,I2=255,M2=255
          12231499 TSF:TDI:TSL
          12231501 MCO:SLP:WUP=-1
          12231505 TSF:TRI:TSB
          12232292 MCO:SLP:MS=2215,SMS=0,I1=255,M1=255,I2=255,M2=255
          12232302 TSF:TDI:TSL
          12232304 MCO:SLP:WUP=-1
          12232308 TSF:TRI:TSB
          12233095 MCO:SLP:MS=2215,SMS=0,I1=255,M1=255,I2=255,M2=255
          12233105 TSF:TDI:TSL
          12233107 MCO:SLP:WUP=-1
          12233111 TSF:TRI:TSB
          12233897 MCO:SLP:MS=2216,SMS=0,I1=255,M1=255,I2=255,M2=255
          12233908 TSF:TDI:TSL
          12233910 MCO:SLP:WUP=-1
          12233914 TSF:TRI:TSB
          12234700 MCO:SLP:MS=2216,SMS=0,I1=255,M1=255,I2=255,M2=255
          12234711 TSF:TDI:TSL
          12234713 MCO:SLP:WUP=-1
          12234717 TSF:TRI:TSB
          12235503 MCO:SLP:MS=2216,SMS=0,I1=255,M1=255,I2=255,M2=255
          12235513 TSF:TDI:TSL
          12235515 MCO:SLP:WUP=-1
          12235520 TSF:TRI:TSB
          12236306 MCO:SLP:MS=2216,SMS=0,I1=255,M1=255,I2=255,M2=255
          12236316 TSF:TDI:TSL
          12236318 MCO:SLP:WUP=-1
          12236322 TSF:TRI:TSB
          12237109 MCO:SLP:MS=2215,SMS=0,I1=255,M1=255,I2=255,M2=255
          12237119 TSF:TDI:TSL
          12237121 MCO:SLP:WUP=-1
          12237125 TSF:TRI:TSB
          12237912 MCO:SLP:MS=2215,SMS=0,I1=255,M1=255,I2=255,M2=255
          12237922 TSF:TDI:TSL
          12237924 MCO:SLP:WUP=-1
          12237928 TSF:TRI:TSB
          Sensor #0 says it is -1.10 degrees
          12238747 !TSF:MSG:SEND,20-20-0-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=NACK:-1.1
          12238757 MCO:SLP:MS=2173,SMS=0,I1=255,M1=255,I2=255,M2=255
          12238764 TSF:TDI:TSL
          12238766 MCO:SLP:WUP=-1
          12238770 TSF:TRI:TSB
          Sensor #0 says it is -0.80 degrees
          12239587 TSF:MSG:SEND,20-20-0-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=1,st=OK:-0.8
          12239595 MCO:SLP:MS=2177,SMS=0,I1=255,M1=255,I2=255,M2=255
          12239601 TSF:TDI:TSL
          12239605 MCO:SLP:WUP=-1
          12239607 TSF:TRI:TSB
          Sensor #0 says it is -0.40 degrees
          12240427 !TSF:MSG:SEND,20-20-0-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=NACK:-0.4
          12240437 MCO:SLP:MS=2172,SMS=0,I1=255,M1=255,I2=255,M2=255
          12240443 TSF:TDI:TSL
          12240445 MCO:SLP:WUP=-1
          12240449 TSF:TRI:TSB
          Sensor #0 says it is -0.10 degrees
          12241254 TSF:MSG:SEND,20-20-0-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=1,st=OK:-0.1
          12241262 MCO:SLP:MS=2189,SMS=0,I1=255,M1=255,I2=255,M2=255
          12241270 TSF:TDI:TSL
          12241272 MCO:SLP:WUP=-1
          12241274 TSF:TRI:TSB
          Sensor #0 says it is 0.00 degrees
          12242067 TSF:MSG:SEND,20-20-0-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:0.0
          I took sensor in door again, so that's why the temperature went up again in the last readings.
          But as of right now the serial is just standing on NWD REQ and nothing else happens.
          I hope this helps
          • T Tommy Petersen
            @mfalkvidd
            mysgw: TSF:SAN:OK
            I hope this helps
            @tommy-petersen strange.
            This is the last line from the sensor. st=OK means the gateway acknowledged that it had received this message. So 0.0 should definitely show up in the gateway log.
            Above line is from two messages earlier, when trying to send the value -0.4. st=NACK means that the sensor did not receive acknowledgement from the gateway that the message was received. So this message was probably lost.
            I have no idea how the gateway could acknowledge a message without printing a debug message about it.
            Could there be another MySensors gateway within range, maybe a neighbor or something?
            How is the sensor powered?
            Which capacitors do you have on the gateway and the sensor?
            T 2 Replies Last reply
              T Offline
              T Offline
              Tommy Petersen
              @mfalkvidd
              ohh I think I might have found the problem.
              I was running the gateway as a service from when I followed the guide on my PI.
              and was also running sudo ./bin/mysgw -d in Putty, so the might have been the issue.
              I have just restarted my test to see if that fixes the problem.
              The sensor is powered via batteries and a booster up to 3,3 volt,
              along with some stabilization circuit and a 1mF on the NRF power
              On the gateway I use a 100µf.
                T Offline
                T Offline
                Tommy Petersen
                @mfalkvidd
                Looks like running 2 gateways was the issue, have been stabil ever since I shut down one of them.
                Thanks a lot for the help.
                • T Tommy Petersen
                  @mfalkvidd
                  @tommy-petersen great work. Thanks for reporting back.
