  3. OpenHAB
  4. OpenHAB 2.5 MySensors Serial Gateway - How to install
23 Posts 10 Posters 17.0k Views 11 Watching
  • F Offline
    F Offline
    FlipFlap3
    wrote on last edited by FlipFlap3
    [update 2018-03-03 for version 2.2]
    [update 2019-01-05 for version 2.4]
    [updates 2019-04 add esh-io-transport-mqtt (needed even for serial gateway) and stop debug mysensors]
    [updates 2020-02-25 update for zulu openjdk implementation and other minor adjustments]
    Preparing your raspberry with clean install:
    Download RASPBIAN STRETCH LITE from https://www.raspberrypi.org/downloads/raspbian/
    Flash to SD-Card with etcher (https://etcher.io/) or any other flash tool you like
    create empty "ssh" file in root on SD-Card
    Insert SD-Card into raspberry PI, connect with UTP cable to your router and power on.
    Go get some coffee
    Get IP address by pinging raspberrypi.local from commandprompt on your pc
    Start SSH session with putty to the raspberry pi
    Login as "pi" with password "raspberry"
    Initial configuration:
    sudo raspi-config
    Change your password
    Network options\Hostname Change hostname to "openhabpi" or what you want
    [optional: add wifi settings]
    Interfacing Options\SPI enable
    Advanced options\Expand the file system
    Advanced options\Memory split change the memory split for the GPU from "64" to “16”
    Finish + reboot
    sudo apt-get update
    sudo apt-get upgrade
    sudo apt-get install screen mc vim git htop
    Java installation: (updated 2020-02-25)
    echo "deb http://ppa.launchpad.net/webupd8team/java/ubuntu xenial main" | sudo tee /etc/apt/sources.list.d/webupd8team-java.list
    echo "deb-src http://ppa.launchpad.net/webupd8team/java/ubuntu xenial main" | sudo tee -a /etc/apt/sources.list.d/webupd8team-java.list
    sudo apt-key adv --keyserver hkp://keyserver.ubuntu.com:80 --recv-keys EEA14886
    sudo apt-get update
    sudo apt-get install oracle-java8-installer
    sudo apt-get install oracle-java8-set-default
    wget -q -O - http://repos.azulsystems.com/RPM-GPG-KEY-azulsystems | sudo tee /etc/apt/trusted.gpg.d/zulu.asc
    sudo echo 'deb http://repos.azulsystems.com/debian stable main' | sudo tee /etc/apt/sources.list.d/zulu.list
    sudo apt-get update
    sudo apt-get install zulu-embedded-8
    MySensors:
    cd MySensors
    [edit update 2019-01-05]
    sudo nano /home/pi/MySensors/examples_linux/mysgw.cpp
    Uncomment the where needed to make it look like this:
    // Config file
    #define MY_LINUX_CONFIG_FILE "/etc/mysensors.conf"
    #define MY_GATEWAY_MAX_CLIENTS 10
    // Serial config
    // Enable this if you are using an Arduino connected to the USB
    #define MY_LINUX_SERIAL_PORT "/dev/ttyUSB0"
    // Enable this if you need to connect to a controller running on the same device
    // You also need to define MY_LINUX_SERIAL_PORT above with the symlink name for the PTY device
    #define MY_LINUX_SERIAL_IS_PTY
    // Grant access to the specified system group for the serial device
    #define MY_LINUX_SERIAL_GROUPNAME "tty"
    Save & close mysgw.cpp
    note: I have chosen channel 69 for the rf24 network. You can choose your own, but remember to use the same channel in your arduino sketches as you do here.
    ./configure --my-gateway=serial --my-serial-is-pty --my-rf24-channel=69 --my-transport=rf24 --my-serial-groupname=tty
    make
    sudo ./bin/mysgw --config-file /etc/mysensors.dat --daemon
    sudo make install
    sudo systemctl daemon-reload
    OpenHAB2:
    wget -qO - 'https://bintray.com/user/downloadSubjectPublicKey?username=openhab' | sudo apt-key add -
    echo 'deb http://dl.bintray.com/openhab/apt-repo2 stable main' | sudo tee /etc/apt/sources.list.d/openhab2.list
    sudo apt-get update
    sudo apt-get install openhab2
    sudo apt-get install openhab2-addons
    sudo systemctl start openhab2.service
    sudo systemctl status openhab2.service
    sudo systemctl enable openhab2.service
    Time for coffee again.......
    open web page select expert....
    sudo usermod -a -G dialout openhab
    sudo usermod -a -G tty openhab
    cd /usr/share/openhab2/addons/
    sudo wget http://www.oberfoell.com/openhab2/org.openhab.binding.mysensors-2.5.0-SNAPSHOT.jar
    sudo chown openhab:openhab org.openhab.binding.mysensors-2.5.0-SNAPSHOT.jar
    ssh -p 8101 openhab@localhost (used to fail the first time, but works now at the first attempt)
    pw:habopen
    feature:install openhab-transport-serial
    feature:install openhab-core-io-transport-mqtt
    log:set DEBUG org.openhab.binding.mysensors
    log:tail
    sudo reboot
    Finally:
    web-> paperui/things add MySensors Serial Gateway
    settings:
    Serial Port: /dev/ttyUSB0
    Send Delay: 200
    Baudrate: 115200
    Skip startup connection check: true
    All done. Good luck!
    When all is working well, you can stop debugging mysensors this will help to reduce the log files.
    //start karaf
    //enter password
    habopen
    // stop debugging mysensors and switch to only registring events
    log:set INFO org.openhab.binding.mysensors
    // close karaf
    <ctrl>D
    For further reducing logs you can add them to logrotate
    • T Offline
      T Offline
      TimO
      Hey!
      The MysGW Service is running with root permissions and therefore creates the device "/dev/ttyMySensorsGateway" with owner and group root.
      Please test: "sudo usermod -a -G root openhab"
      Do a restart to be sure the settings are used.
      That shouldn't be the final solution though.
      • F Offline
        F Offline
        FlipFlap3
        Really grateful for your reply. Tried it and it didn't fix my problem unfortenately
        09:43:21.396 [DEBUG] [col.serial.MySensorsSerialConnection] - Connecting to /dev/pts/1 [baudRate:115200]
        09:43:21.398 [DEBUG] [col.serial.MySensorsSerialConnection] - Final port list: /dev/pts/1
        09:43:21.402 [ERROR] [col.serial.MySensorsSerialConnection] - Can't connect to serial port. Wrong port?
        09:43:21.405 [ERROR] [col.serial.MySensorsSerialConnection] - Failed connecting to bridge...next retry in 10 seconds (Retry No.:17)
        09:43:21.407 [DEBUG] [col.serial.MySensorsSerialConnection] - Shutting down serial connection!
        09:45:14.726 [DEBUG] [col.serial.MySensorsSerialConnection] - Connecting to /dev/ttyMySensorsGateway [baudRate:115200]
        09:45:14.728 [DEBUG] [col.serial.MySensorsSerialConnection] - Final port list: /dev/ttyMySensorsGateway
        09:45:14.732 [ERROR] [col.serial.MySensorsSerialConnection] - Can't connect to serial port. Wrong port?
        09:45:14.735 [ERROR] [col.serial.MySensorsSerialConnection] - Failed connecting to bridge...next retry in 10 seconds (Retry No.:1)
        09:45:14.737 [DEBUG] [col.serial.MySensorsSerialConnection] - Shutting down serial connection!
        lrwxrwxrwx 1 root root          10 apr 23 09:35 ttyMySensorsGateway -> /dev/pts/1
        pi@Controller:/dev/pts $ ls -l
        totaal 0
        crw--w---- 1 pi   tty  136, 0 apr 23  2017 0
        crw--w---- 1 root tty  136, 1 apr 23 09:35 1
        crw--w---- 1 pi   tty  136, 2 apr 23 09:41 2
        c--------- 1 root root   5, 2 jan  1  1970 ptmx
        In my /etc/group I have this (filtered out some stuff this noob thinks is obsolete ;-) )
        root:x:0:openhab
        daemon:x:1:
        bin:x:2:
        sys:x:3:
        adm:x:4:pi
        tty:x:5:
        dialout:x:20:pi,openhab
        sudo:x:27:pi
        www-data:x:33:
        pi:x:1000:
        spi:x:999:pi
        i2c:x:998:pi
        gpio:x:997:pi
        openhab:x:119:```
        • F Offline
          F Offline
          FlipFlap3
          solved it
          Inside "/home/pi/MySensors/example_linux/mysgw.cpp" or where you downloaded the "git clone https://github.com/mysensors/MySensors.git --branch master" there is this option:
          //#define MY_LINUX_SERIAL_GROUPNAME "tty"
          uncomment to
          save file
          stop mysgw with "sudo systemctl stop mysgw.service"
          remove mysgw from auto start with "sudo systemctl disable mysgw.service"
          uninstall with "sudo make uninstall"
          installed again
          I added openhab to the tty group using "sudo usermod -a -G tty openhab"
          full reboot
          and it works!
          • F Offline
            F Offline
            FlipFlap3
            Made a reïnstall again and found that something was incomplete and that it didn't work anymore with the stable branche.
            Missing in "initial config" is enabling SPI through raspi-config at the start
            At installing MySensors replace:
            with:
            git clone https://github.com/mysensors/MySensors.git --branch development
            Now needs to be:
            echo 'deb https://dl.bintray.com/openhab/apt-repo2 stable main' | sudo tee /etc/apt/sources.list.d/openhab2.list
            sudo wget http://www.oberfoell.com/openhab2/org.openhab.binding.mysensors-2.2.0-SNAPSHOT.jar
            sudo chown openhab:openhab org.openhab.binding.mysensors-2.2.0-SNAPSHOT.jar
            Somehow this next one always times-out the first time. 2nd attempt does give me a connection after a while
            JicJ 1 Reply Last reply
            • F FlipFlap3
              with:
              Now needs to be:
              JicJ Offline
              JicJ Offline
              Jic
              @flipflap3
              I still have problem with with org.openhab.binding.mysensors-2.2.0-SNAPSHOT.jar and org.openhab.binding.mysensors-2.3.0-SNAPSHOT.jar
              I get always de Mysensors Serial Gateway offline with this error
              2018-03-01 21:36:47.880 [DEBUG] [col.serial.MySensorsSerialConnection] - Connecting to /dev/ttyMySensorsGateway [baudRate:115200]
              2018-03-01 21:36:47.890 [ERROR] [col.serial.MySensorsSerialConnection] - No such port: /dev/ttyMySensorsGateway
              gnu.io.NoSuchPortException: null
              	at gnu.io.CommPortIdentifier.getPortIdentifier(CommPortIdentifier.java:273) [25:com.neuronrobotics.nrjavaserial:3.12.0.OH]
              	at org.openhab.binding.mysensors.internal.protocol.serial.MySensorsSerialConnection.establishConnection(MySensorsSerialConnection.java:51) [195:org.openhab.binding.mysensors:2.3.0.201802141500]
              	at org.openhab.binding.mysensors.internal.protocol.MySensorsAbstractConnection.connect(MySensorsAbstractConnection.java:148) [195:org.openhab.binding.mysensors:2.3.0.201802141500]
              	at org.openhab.binding.mysensors.internal.protocol.MySensorsAbstractConnection.run(MySensorsAbstractConnection.java:127) [195:org.openhab.binding.mysensors:2.3.0.201802141500]
              	at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:?]
              	at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) [?:?]
              	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) [?:?]
              	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) [?:?]
              	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) [?:?]
              	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) [?:?]
              	at java.lang.Thread.run(Thread.java:745) [?:?]
              I back to org.openhab.binding.mysensors-2.1.0-SNAPSHOT.jar and now it's working again. Any ideas?
              F 1 Reply Last reply
              • JicJ Jic
                @flipflap3
                F Offline
                F Offline
                FlipFlap3
                @jic Nope sry, BUT.. I am going to do a fresh install again today. Will check if I can get it to work and make updates to this howto where needed.
                • F Offline
                  F Offline
                  FlipFlap3
                  2.3 snapshot doesn't work. 2.2 does
                  Updated opening post for step by step instruction on installing openhab2.2 with mysensors 2.2 serial gateway binding. If you have any questions, just post them here.
                  • JicJ Offline
                    JicJ Offline
                    Jic
                    Seem it's working know.
                    • F Offline
                      F Offline
                      FrozenYack
                      wrote on last edited by FrozenYack
                      I am trying to follow these instructions to set up OpenHab with the MySensors Serial Gateway, but ran into a problem when installing the Java (Third command.). Here is a copy of the command and error:
                      pi@openhabpi:~ $ sudo apt-key adv --keyserver hkp://keyserver.ubuntu.com:80 --recv-keys EEA14886
                      Executing: /tmp/apt-key-gpghome.3nAEDiCNLy/gpg.1.sh --keyserver hkp://keyserver.ubuntu.com:80 --recv-keys EEA14886
                      gpg: failed to start the dirmngr '/usr/bin/dirmngr': No such file or directory
                      gpg: connecting dirmngr at '/tmp/apt-key-gpghome.3nAEDiCNLy/S.dirmngr' failed: No such file or directory
                      gpg: keyserver receive failed: No dirmngr
                      Please let me know if I missed something.
                      BTW, this is using the raspbian stretch lite version, dated 2018-03-13.
                      Thank you!
                      • G Offline
                        G Offline
                        GreyLinux
                        @FlipFlap3
                        Firstly well done for the brilliant instructions . I too have been attempting to use Openhab with my sensors over the last year and to be honest although I've had relative success, because of the limited amount of, up to date and accurate tutorials its been a steep slope to climb. Currently I have Openhabian installed on a Raspberry pi with a Gateway connected to the I/O pins of the Pi and a couple of temp sensors connected ( all be it with difficulty ). It's setup as an Ethernet Gateway but I did try once to setup it up as a serial gateway, unsuccessfully I might add. Out of interest if I did re- install using your setup instructions, Is a serial Gateway better or easier in any way ? it does seem like the most supported option of the 3 for most people on the forum .
                        • F FrozenYack
                          Thank you!
                          F Offline
                          F Offline
                          FlipFlap3
                          @frozenyack Sorry, I can't remember seeing an error like that before.
                          • G GreyLinux
                            @FlipFlap3
                            F Offline
                            F Offline
                            FlipFlap3
                            @greymarvel said in OpenHAB 2.2 MySensors Serial Gateway - How to install:
                            @FlipFlap3
                            Sorry for late response (busy with anual reporting lately).
                            I have tried MTTQ first myself, but I didn't get things working smoothly. 2nd attempt was with serial gateway. Even though I had some problems at first, I did manage to get it working. I had a hard time finding a good tutorial though, so I wrote down the steps I took carefully. Reason for me to put it here was to have a personal backup for my notes and if it would be helpful for anyone else that would be an awesome bonus ;-)
                            I didn't try ethernet gateway yet cause I am happy with the current setup.
                            • joaoabsJ Offline
                              joaoabsJ Offline
                              joaoabs
                              wrote on last edited by joaoabs
                              The mysgw seems to be creating a link to the wrong TTY.
                              When I connect the arduino gateway, I get the /dev/ttyUSB1 device.
                              Insert Code Herepi@nettemp:~/MySensors $ ls /dev/tty*
                              /dev/tty    /dev/tty15  /dev/tty22  /dev/tty3   /dev/tty37  /dev/tty44  /dev/tty51  /dev/tty59  /dev/tty9
                              /dev/tty0   /dev/tty16  /dev/tty23  /dev/tty30  /dev/tty38  /dev/tty45  /dev/tty52  /dev/tty6   /dev/ttyAMA0
                              /dev/tty1   /dev/tty17  /dev/tty24  /dev/tty31  /dev/tty39  /dev/tty46  /dev/tty53  /dev/tty60  /dev/ttyUSB0
                              /dev/tty10  /dev/tty18  /dev/tty25  /dev/tty32  /dev/tty4   /dev/tty47  /dev/tty54  /dev/tty61  /dev/ttyUSB1
                              /dev/tty11  /dev/tty19  /dev/tty26  /dev/tty33  /dev/tty40  /dev/tty48  /dev/tty55  /dev/tty62  /dev/ttyprintk
                              /dev/tty12  /dev/tty2   /dev/tty27  /dev/tty34  /dev/tty41  /dev/tty49  /dev/tty56  /dev/tty63
                              /dev/tty13  /dev/tty20  /dev/tty28  /dev/tty35  /dev/tty42  /dev/tty5   /dev/tty57  /dev/tty7
                              /dev/tty14  /dev/tty21  /dev/tty29  /dev/tty36  /dev/tty43  /dev/tty50  /dev/tty58  /dev/tty8
                              Then I start the mysgw and a new tty is created: "/dev/ttyMySensorsGateway", which looks nice. However, the mysgw returns lots of errors:
                              mysgw: Starting gateway...
                              mysgw: Protocol version - 2.2.0
                              mysgw: Serial port /dev/ttyMySensorsGateway (115200 baud) created
                              mysgw: TSF:LRT:OK
                              mysgw: TSM:INIT
                              mysgw: TSF:WUR:MS=0
                              mysgw: !TSM:INIT:TSP FAIL
                              mysgw: TSM:FAIL:CNT=1
                              mysgw: TSM:FAIL:DIS
                              mysgw: TSF:TDI:TSL
                              mysgw: TSM:INIT
                              mysgw: TSM:FAIL:CNT=2
                              mysgw: TSM:FAIL:DIS
                              mysgw: TSF:TDI:TSL
                              Then I go check what is wrong an I see the pointer wasn't created towards "/dev/ttyUSB1", but "/dev/pts/1":
                              pi@nettemp:~/MySensors $ ls -larth /dev/ttyMySensorsGateway
                              lrwxrwxrwx 1 root root 10 Apr 26 18:27 /dev/ttyMySensorsGateway -> /dev/pts/1
                              Taking a look into the /dev/ttyUSB1 directly I can see it is fine, the problem is the GW software on the Raspberry PI that is pointing towards the wrong tty:
                              pi@nettemp:~ $ stty -F /dev/ttyUSB1 cs8 115200 ignbrk -brkint -icrnl -imaxbel -opost -onlcr -isig -icanon -iexten -echo -echoe -echok -echoctl -echoke noflsh -ixon -crtscts
                              pi@nettemp:~ $ cat /dev/ttyUSB1
                              0;255;3;0;9;0 MCO:BGN:INIT GW,CP=RNNGAS--,VER=2.2.0
                              0;255;3;0;9;0;255;3;0;9;0 MCO:BGN:INIT GW,CP=RNNGAS--,VER=2.2.0
                              0;255;3;0;9;26 SGN:PER:OK
                              0;255;3;0;9;64 SGN:INI:BND OK
                              0;255;3;0;9;67 TSM:INIT
                              0;255;3;0;9;69 TSF:WUR:MS=0
                              0;255;3;0;9;77 TSM:INIT:TSP OK
                              0;255;3;0;9;79 TSM:INIT:GW MODE
                              0;255;3;0;9;82 TSM:READY:ID=0,PAR=0,DIS=0
                              0;255;3;0;9;87 MCO:REG:NOT NEEDED
                              0;255;0;0;18;2.2.0
                              0;255;3;0;9;91 MCO:BGN:STP
                              0;255;3;0;9;98 MCO:BGN:INIT OK,TSP=1
                              Any idea of how to make this work?
                              Where can I see the alternatives for the "
                              ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyMySensorsGateway --my-rf24-channel=69 --my-transport=nrf24 --my-serial-groupname=tty --my-config-file=/etc/mysensors.dat" command?
                              • joaoabsJ joaoabs
                                mysgw: TSF:LRT:OK
                                mysgw: TSM:INIT
                                mysgw: TSF:WUR:MS=0
                                mysgw: TSM:FAIL:DIS
                                mysgw: TSF:TDI:TSL
                                mysgw: TSM:INIT
                                mysgw: TSM:FAIL:DIS
                                mysgw: TSF:TDI:TSL
                                0;255;0;0;18;2.2.0
                                F Offline
                                F Offline
                                FlipFlap3
                                @joaoabs
                                I had to re-install myself and found my how to wasn't 100% correct for OpenHAB 2.4 so I updated it.
                                Works with OpenHAB 2.4 and @TimO 's 2.4 jar. Kudos to him for this!
                                • N Offline
                                  N Offline
                                  nizoo91
                                  wrote on last edited by nizoo91
                                  My god, had everything almost working and now my PaperUI disappeared on me for the 2nd time.....
                                  I was trying to remove and reinstall MySensors but this is the second time this happens to me :/ I don't want to re-install everything again! Any ideas on how I can get the paperUI back?
                                  I tried removing my "addons.config" from "/var/lib/openhab2/config/org/openhab"
                                  didn't help, also opened it and it didn't have the paperui option, manually added it and still didn't work :(
                                  I am about to give up on OpenHab lol, is there any easier controller to setup? I heard good things about Domoticz but I JUST got OH to kinda work! I was just receiving the wrong values and thought it could of been because of some errors, so decided to re-compile MySensors and install it again.. and then poooof, the whole UI isn't there anymore :face_palm: :face_palm: :face_palm: :face_palm: :face_palm: :face_palm: :face_palm: :face_palm: :face_palm: :face_palm: :face_palm: :face_palm: :face_palm: :face_palm: :face_palm: :face_palm: :face_palm: :face_palm: :face_palm:
                                  EDIT: oh great, even more stuff disappeared, now I only have HOMEBUILDER left! :man-facepalming:
                                  • N nizoo91
                                    T Offline
                                    T Offline
                                    TimO
                                    @nizoo91 Stick to addons.cfg in /etc/openhab2/conf/services and don't fiddle with the file you mentioned above.
                                    With package=standard (look for the examples in the comments) the UIs should reappear.
                                    • N Offline
                                      N Offline
                                      nizoo91
                                      @flipflap3 said in OpenHAB 2.4 MySensors Serial Gateway - How to install:
                                      can you please add
                                      "feature:install esh-io-transport-mqtt"
                                      to the tutorial it is required to get it to work even in Serial :)
                                      • N nizoo91
                                        can you please add
                                        F Offline
                                        F Offline
                                        FlipFlap3
                                        @nizoo91 Just found out myself as well that this was missing. Thanks!
                                        • I Offline
                                          I Offline
                                          iamtheghost
                                          This package has been removed and can't be installed as instructed in the tutorial. As of April, I believe it was removed from that repo.
                                          Reading package lists... Done
                                          Building dependency tree
                                          Reading state information... Done
                                          Package oracle-java8-installer is not available, but is referred to by another package.
                                          This may mean that the package is missing, has been obsoleted, or
                                          is only available from another source
                                          E: Package 'oracle-java8-installer' has no installation candidate
                                          Unsure of how to proceed.
                                          TRS-80T 1 Reply Last reply
                                          12.1k
