  3. OpenHAB
  4. OpenHAB 2.5 MySensors Serial Gateway - How to install
23 Posts 10 Posters 17.7k Views 11 Watching
  • F
    F
    FlipFlap3
    wrote on last edited by FlipFlap3
    2.3 snapshot doesn't work. 2.2 does
    Updated opening post for step by step instruction on installing openhab2.2 with mysensors 2.2 serial gateway binding. If you have any questions, just post them here.
    • JicJ
      JicJ
      Jic
      Seem it's working know.
      • F
        F
        FrozenYack
        wrote on last edited by FrozenYack
        I am trying to follow these instructions to set up OpenHab with the MySensors Serial Gateway, but ran into a problem when installing the Java (Third command.). Here is a copy of the command and error:
        pi@openhabpi:~ $ sudo apt-key adv --keyserver hkp://keyserver.ubuntu.com:80 --recv-keys EEA14886
        Executing: /tmp/apt-key-gpghome.3nAEDiCNLy/gpg.1.sh --keyserver hkp://keyserver.ubuntu.com:80 --recv-keys EEA14886
        gpg: failed to start the dirmngr '/usr/bin/dirmngr': No such file or directory
        gpg: connecting dirmngr at '/tmp/apt-key-gpghome.3nAEDiCNLy/S.dirmngr' failed: No such file or directory
        gpg: keyserver receive failed: No dirmngr
        Please let me know if I missed something.
        BTW, this is using the raspbian stretch lite version, dated 2018-03-13.
        Thank you!
        F 1 Reply Last reply
        • G
          G
          GreyLinux
          @FlipFlap3
          Firstly well done for the brilliant instructions . I too have been attempting to use Openhab with my sensors over the last year and to be honest although I've had relative success, because of the limited amount of, up to date and accurate tutorials its been a steep slope to climb. Currently I have Openhabian installed on a Raspberry pi with a Gateway connected to the I/O pins of the Pi and a couple of temp sensors connected ( all be it with difficulty ). It's setup as an Ethernet Gateway but I did try once to setup it up as a serial gateway, unsuccessfully I might add. Out of interest if I did re- install using your setup instructions, Is a serial Gateway better or easier in any way ? it does seem like the most supported option of the 3 for most people on the forum .
          • F FrozenYack
            Thank you!
            F
            F
            FlipFlap3
            @frozenyack Sorry, I can't remember seeing an error like that before.
            • G GreyLinux
              @FlipFlap3
              F
              F
              FlipFlap3
              @greymarvel said in OpenHAB 2.2 MySensors Serial Gateway - How to install:
              @FlipFlap3
              Sorry for late response (busy with anual reporting lately).
              I have tried MTTQ first myself, but I didn't get things working smoothly. 2nd attempt was with serial gateway. Even though I had some problems at first, I did manage to get it working. I had a hard time finding a good tutorial though, so I wrote down the steps I took carefully. Reason for me to put it here was to have a personal backup for my notes and if it would be helpful for anyone else that would be an awesome bonus ;-)
              I didn't try ethernet gateway yet cause I am happy with the current setup.
              • joaoabsJ
                joaoabsJ
                joaoabs
                wrote on last edited by joaoabs
                The mysgw seems to be creating a link to the wrong TTY.
                When I connect the arduino gateway, I get the /dev/ttyUSB1 device.
                Insert Code Herepi@nettemp:~/MySensors $ ls /dev/tty*
                /dev/tty    /dev/tty15  /dev/tty22  /dev/tty3   /dev/tty37  /dev/tty44  /dev/tty51  /dev/tty59  /dev/tty9
                /dev/tty0   /dev/tty16  /dev/tty23  /dev/tty30  /dev/tty38  /dev/tty45  /dev/tty52  /dev/tty6   /dev/ttyAMA0
                /dev/tty1   /dev/tty17  /dev/tty24  /dev/tty31  /dev/tty39  /dev/tty46  /dev/tty53  /dev/tty60  /dev/ttyUSB0
                /dev/tty10  /dev/tty18  /dev/tty25  /dev/tty32  /dev/tty4   /dev/tty47  /dev/tty54  /dev/tty61  /dev/ttyUSB1
                /dev/tty11  /dev/tty19  /dev/tty26  /dev/tty33  /dev/tty40  /dev/tty48  /dev/tty55  /dev/tty62  /dev/ttyprintk
                /dev/tty12  /dev/tty2   /dev/tty27  /dev/tty34  /dev/tty41  /dev/tty49  /dev/tty56  /dev/tty63
                /dev/tty13  /dev/tty20  /dev/tty28  /dev/tty35  /dev/tty42  /dev/tty5   /dev/tty57  /dev/tty7
                /dev/tty14  /dev/tty21  /dev/tty29  /dev/tty36  /dev/tty43  /dev/tty50  /dev/tty58  /dev/tty8
                Then I start the mysgw and a new tty is created: "/dev/ttyMySensorsGateway", which looks nice. However, the mysgw returns lots of errors:
                mysgw: Starting gateway...
                mysgw: Protocol version - 2.2.0
                mysgw: Serial port /dev/ttyMySensorsGateway (115200 baud) created
                mysgw: TSF:LRT:OK
                mysgw: TSM:INIT
                mysgw: TSF:WUR:MS=0
                mysgw: !TSM:INIT:TSP FAIL
                mysgw: TSM:FAIL:CNT=1
                mysgw: TSM:FAIL:DIS
                mysgw: TSF:TDI:TSL
                mysgw: TSM:INIT
                mysgw: TSM:FAIL:CNT=2
                mysgw: TSM:FAIL:DIS
                mysgw: TSF:TDI:TSL
                Then I go check what is wrong an I see the pointer wasn't created towards "/dev/ttyUSB1", but "/dev/pts/1":
                pi@nettemp:~/MySensors $ ls -larth /dev/ttyMySensorsGateway
                lrwxrwxrwx 1 root root 10 Apr 26 18:27 /dev/ttyMySensorsGateway -> /dev/pts/1
                Taking a look into the /dev/ttyUSB1 directly I can see it is fine, the problem is the GW software on the Raspberry PI that is pointing towards the wrong tty:
                pi@nettemp:~ $ stty -F /dev/ttyUSB1 cs8 115200 ignbrk -brkint -icrnl -imaxbel -opost -onlcr -isig -icanon -iexten -echo -echoe -echok -echoctl -echoke noflsh -ixon -crtscts
                pi@nettemp:~ $ cat /dev/ttyUSB1
                0;255;3;0;9;0 MCO:BGN:INIT GW,CP=RNNGAS--,VER=2.2.0
                0;255;3;0;9;0;255;3;0;9;0 MCO:BGN:INIT GW,CP=RNNGAS--,VER=2.2.0
                0;255;3;0;9;26 SGN:PER:OK
                0;255;3;0;9;64 SGN:INI:BND OK
                0;255;3;0;9;67 TSM:INIT
                0;255;3;0;9;69 TSF:WUR:MS=0
                0;255;3;0;9;77 TSM:INIT:TSP OK
                0;255;3;0;9;79 TSM:INIT:GW MODE
                0;255;3;0;9;82 TSM:READY:ID=0,PAR=0,DIS=0
                0;255;3;0;9;87 MCO:REG:NOT NEEDED
                0;255;0;0;18;2.2.0
                0;255;3;0;9;91 MCO:BGN:STP
                0;255;3;0;9;98 MCO:BGN:INIT OK,TSP=1
                Any idea of how to make this work?
                Where can I see the alternatives for the "
                ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyMySensorsGateway --my-rf24-channel=69 --my-transport=nrf24 --my-serial-groupname=tty --my-config-file=/etc/mysensors.dat" command?
                • joaoabsJ joaoabs
                  mysgw: TSF:LRT:OK
                  mysgw: TSM:INIT
                  mysgw: TSF:WUR:MS=0
                  mysgw: TSM:FAIL:DIS
                  mysgw: TSF:TDI:TSL
                  mysgw: TSM:INIT
                  mysgw: TSM:FAIL:DIS
                  mysgw: TSF:TDI:TSL
                  0;255;0;0;18;2.2.0
                  F
                  F
                  FlipFlap3
                  @joaoabs
                  I had to re-install myself and found my how to wasn't 100% correct for OpenHAB 2.4 so I updated it.
                  Works with OpenHAB 2.4 and @TimO 's 2.4 jar. Kudos to him for this!
                  • N
                    N
                    nizoo91
                    wrote on last edited by nizoo91
                    My god, had everything almost working and now my PaperUI disappeared on me for the 2nd time.....
                    I was trying to remove and reinstall MySensors but this is the second time this happens to me :/ I don't want to re-install everything again! Any ideas on how I can get the paperUI back?
                    I tried removing my "addons.config" from "/var/lib/openhab2/config/org/openhab"
                    didn't help, also opened it and it didn't have the paperui option, manually added it and still didn't work :(
                    I am about to give up on OpenHab lol, is there any easier controller to setup? I heard good things about Domoticz but I JUST got OH to kinda work! I was just receiving the wrong values and thought it could of been because of some errors, so decided to re-compile MySensors and install it again.. and then poooof, the whole UI isn't there anymore :face_palm: :face_palm: :face_palm: :face_palm: :face_palm: :face_palm: :face_palm: :face_palm: :face_palm: :face_palm: :face_palm: :face_palm: :face_palm: :face_palm: :face_palm: :face_palm: :face_palm: :face_palm: :face_palm:
                    EDIT: oh great, even more stuff disappeared, now I only have HOMEBUILDER left! :man-facepalming:
                    • N nizoo91
                      TimO
                      @nizoo91 Stick to addons.cfg in /etc/openhab2/conf/services and don't fiddle with the file you mentioned above.
                      With package=standard (look for the examples in the comments) the UIs should reappear.
                      • N
                        N
                        nizoo91
                        @flipflap3 said in OpenHAB 2.4 MySensors Serial Gateway - How to install:
                        feature:install openhab-transport-serial
                        can you please add
                        "feature:install esh-io-transport-mqtt"
                        to the tutorial it is required to get it to work even in Serial :)
                        • N nizoo91
                          can you please add
                          F
                          F
                          FlipFlap3
                          @nizoo91 Just found out myself as well that this was missing. Thanks!
                          • I
                            I
                            iamtheghost
                            sudo apt-get install oracle-java8-installer
                            This package has been removed and can't be installed as instructed in the tutorial. As of April, I believe it was removed from that repo.
                            Reading package lists... Done
                            Building dependency tree
                            Reading state information... Done
                            Package oracle-java8-installer is not available, but is referred to by another package.
                            This may mean that the package is missing, has been obsoleted, or
                            is only available from another source
                            E: Package 'oracle-java8-installer' has no installation candidate
                            Unsure of how to proceed.
                            TRS-80T 1 Reply Last reply
                            • I iamtheghost
                              TRS-80T
                              TRS-80T
                              TRS-80
                              wrote on last edited by TRS-80
                              #21
                              @iamtheghost,
                              I realize it's been few months, but I will post this anyway. As I also recently went through the same ordeal.
                              Thanks to OP for posting an easy to follow guide.
                              I found the official install instructions at OpenHAB quite good: https://www.openhab.org/docs/installation/linux.html
                              ...with one exception. Currently, it seems there is some bug going on with their build system or something. I actually had lodged an issue of my own (and even had submitted a PR to correct the documentation) before someone replied, pointing me to the root issue. So for the time being, instead of using https://dl.bintray.com/openhab/apt-repo2 location, you should use https://openhab.jfrog.io/openhab/openhab-linuxpkg repository location.
                              Further, if you care about issues such as software freedom (which I do a great deal) you might want to consider installing Azul/Zulu Java 8 (make sure it's 8!) which I have done, instead of Oracle Java. Azul's (also excellent) instructions can be found linked from the OpenHAB Linux install instructions. And that would also solve your missing repo problem, obviously.
                              A 1 Reply Last reply
                              • TRS-80T TRS-80
                                @iamtheghost,
                                alphaHotel
                                wrote on last edited by alphaHotel
                                #22
                                @trs-80 said in OpenHAB 2.4 MySensors Serial Gateway - How to install:
                                I ran into the same thing. Specifically, to get around this, the second instruction under the OpenHAB portion of the original post can be substituted with this:
                                echo 'deb https://openhab.jfrog.io/openhab/openhab-linuxpkg stable main' | sudo tee /etc/apt/sources.list.d/openhab2.list
                                EDIT: I've just noticed that they've updated the Package Repository Installation instructions to add the command above.
                                If using Zulu Java, beware that the repos are not being maintained and are behind (see reference for manual instructions).
                                I used OpenJDK 8 for java with sudo apt install openjdk-8-jdk-headless.
                                I'm using an Ethernet gateway (on a separate Raspberry Pi) though which is a twist on all of this.
                                --Allen
                                • F
                                  F
                                  FlipFlap3
                                  Updated to OpenHAB 2.5 with step-by-step instructions
                                  switched to Zulu Java
