  3. CNC PCB milling
CNC PCB milling
933 Posts 28 Posters 809.5k Views 27 Watching
  • dbemowskD
    dbemowskD
    What end mill bits should I get for doing PCB work? Do you just use a V bit and a drill?
    • dbemowskD dbemowsk
      #645
      Yup
        #646
        Interesting way to make an inexpensive closed-loop stepper motor:
        https://youtu.be/s2dpCpUqGnE
        I think a better way to do it would be to directly couple the encoder to a dual-shaft stepper motor, but that would, of course, mean purchasing a new stepper motor. Nonetheless, these small stepper's are pretty cheap.
        The other way to do it with the existing single shaft stepper but without a belt might be to use a magnetic encoder, but I can't say that I've tried that, so I'm not sure how hard the retrofit would be.
        Also, I guess the main point in doing this would be to hotrod your CNC, to make it move faster without skipping steps. i.e. you probably don't absolutely need to hotrod your CNC.
        dbemowskD 1 Reply Last reply
          dbemowskD
          dbemowskD
          I never looked, but do they make a dual notched pulley? Then you would only need to buy a pulley vs an entire stepper.
            I don't know what that is.
            • E executivul
              @neverdie it might be better than a rigid x axis aluminium profile dangling on some wheels all together. Then comes the profile joining piece dance.
              On the cnczone forums people go like: linear rails are the best, round bars are good, wheels on rails are for toys. That is for normal milling on a small machine. These things are routers by the way, real mills are taig style and are small size and meant for steel and heavy metal milling (no pun intended). For wood, plastic, soft stuff it might be acceptable though.
              For pcbs you need high precision, flatness, high rpm etc.
              For wood you need large size, think of table or door pieces. Tolerances are not so tight. You won't go like: look! Your door engraving is 0.1mm off in that corner!
              For metal you need precision, high rigidity and power at lower spindle speed.
              The classic ebay cnc is a good all around tool but excels at nothing 😁
              #649
              @executivul
              This guy bought a 6040 CNC with supported y-axis rails (just like the RATTM one), but starting at time index 4:52 he discusses the "well known problem" of flexing on the 6040's unsupported x-axis when milling aluminum:
              https://youtu.be/6a57KtmIu-4
              He concludes that upgrades to the 6040 (e.g. possibly a supported x-axis rail) will be necessary.
              It's just a pitty that an inexpensive, already "upgraded," 6040 isn't for sale. Instead, it becomes a DIY quest.
              In fact, this guy did do the x-axis supported rail upgrade, but it solved only 50% of the problem:
              https://youtu.be/ABLXVCkXmpg
                #650
                @executivul
                Do you suppose that linear rails, rather than supported rods, would fix this twisting problem that people seem to be having?
                i.e. Notionally, something like:
                https://www.ebay.com/itm/Portable-Steel-MGN12H-Linear-Sliding-Rail-Block-Tool-250-550mm-CNC-3D-Printer/382360155951?var=651145928342&hash=item590670f72f:m:mah05n6MWl2QkZTLIZW2vJQ
                that's made out of steel.
                E 1 Reply Last reply
                • RFM69R RFM69
                  @coddingtonbear What materials are you milling ?
                  I want to get a spindle for mostly wood, just hobby, but don't want to go too cheap, and face buying over when I realize its just not > W
                  coddingtonbearC
                  coddingtonbearC
                  coddingtonbear
                  @rfm69 Almost always just PCBs. Maybe sometimes some acrylic, but nothing very solid, if that's what you're asking. Those little 1610 CNCs have so many plastic parts, that I'm not sure it'd perform very well cutting anything much harder than plastic.
                    @rfm69 I believe so, at least for brush motors. For brushless, I get the impression the motors are missing the electronics which tell them when to alternate their currents internally, so (it appears) you need a special driver to make them move at all. I'm not sure how, or even if, PWM fits into that. Maybe motor speed is all managed entirely through the brushless controller, and all the brushless controller wants as input is pure DC?
                    coddingtonbearC
                    coddingtonbearC
                    coddingtonbear
                    @neverdie Yes; brushless motors are for sure more technically complex than brushed, and usually require an external driver. Most of the time those drivers have inputs allowing you to control the speed via PWM or an analog voltage.
                    Adapting the 1610's woodpecker board to supply that PWM speed control signal to an external driver is super easy -- I can show you a photo of what I did to mine if it'd help.
                      @executivul
                      E
                      E
                      executivul
                      @executivul
                      Yes, but MGN15 or larger and of better quality, but that is expensive...
                      • E executivul
                        @executivul
                        @executivul
                        I guess the difficulty of finding a satisfying solution to this problem explains why milling machines are built around a stationary, highly rigid z-axis. ;)
                          @executivul
                          E
                          E
                          executivul
                          @neverdie And finding a good tool at an affordable price is a challenge. Specialised machines do a s specific job better than general purpose ones, but only do that job. Professional machines do a better job at a higher price tag. We are just poor hobbyists :)
                          I'm so happy with my $50 UT61E, what a great multimeter, of course I would rather have a HP 8.5 digit one any day but I'd rather spend that money on a holiday or something since I don't need that 0.0001uV precision anyway, at 1V a 3V bat is as empty as a 0.9999999987V one if you get my point. Too many times I've spent a fortune for professional tools which I don't use/need so I tend to get what I need + a small margin, for eg I got a huge DSLR and lenses, used a few times, great photos, but lately, guess what, I tend to use my phone for taking photos 99.9% of the time, the camera backpack is just too heavy to carry arround .
                          Get a 3d printer, get a 3040/6040 cnc, get a 40/50W laser, get a lathe if you have space for it, maybe get a vertical mill for metal parts and you'll have a maker space of your own, as long as you won't start manufacturing space ships ebay tool tolerances will be ok.
                            #656
                            Reminds me of a quote from the MPCNC website (https://www.v1engineering.com/frequently-asked-questions/ ) :
                            Diminishing returns kicks in really fast in the CNC world.
                              #657
                              I suppose, in theory, that somehow replacing the x and z-axis with these might mitigate against the twist problem:
                              https://www.aliexpress.com/item/Heavy-Load-X-Y-Z-Axis-Sliding-Table-Cross-Slide-SFU1605-Ballscrew-Linear-Stage-Motion-Actuator/32835796713.html?spm=2114.10010108.0.0.79cb34f4UvKwO7&traffic_analysisId=recommend_2049_1_83259_iswiall&scm=1007.12908.83259.0&pvid=bbdc7491-5b3e-4b23-8add-c7ddaed83f21&tpp=1
                              Presumably the rails are precisely spaced and held perfectly flat by the base plate, so you'd avoid binding problems that might otherwise arise from a purely DIY manual retrofit of just the rails.
                              I don't know what the MGN number is for that rail though, so I don't know whether its MGN15, MGN20, or something else.
                                dbemowskD
                                dbemowskD
                                @neverdie
                                I wasn't sure of the exact name for it, but I was referring to something like this:
                                https://www.amazon.com/ReliaBot-Aluminum-Timing-Pulley-Printer/dp/B079JGYYKV/ref=sr_1_5?s=industrial&ie=UTF8&qid=1520378263&sr=1-5&keywords=dual+timing+pulley
                                  #659
                                  @dbemowsk
                                  I take back what I said earlier. I like the way this guy did it better, because with the gearing you can get even more resolution out of your encoder:
                                  https://youtu.be/wu-1f2CMlmY
                                    @dbemowsk
                                    dbemowskD
                                    dbemowskD
                                    @neverdie I agree, that that may be better. To change the precision, you would just have to change the gear ratio of the two meshing gears.
                                      #661
                                      I did some more reading about CNC'ing aluminum, and it's being claimed that virtually any CNC machine can cut aluminum, provided it uses the right depth of cut and speeds and feeds. i.e. it may simply take a lot longer than you would prefer if your machine isn't already super rigid. If that's true, I can probably live with that.
                                      Meanwhile, it has been suggested that using PID might improve things. There's SuperPID for AC powered spindles and I'm not sure what for DC powered spindles. Regardless, I'll need to sense the RPM of the spindle, or it won't work, so that's now on the critical path. I think I'll try a spinning magnet and a hall sensor to sense the RPM.
                                      • coddingtonbearC coddingtonbear
                                        @NeverDie -- the motors used in 1610 CNC mills are generally what are called a "775 Motor". You might be able to find other specs, but the ones I've found suggest that at 24V and no load , they claim 7kRPM -- http://linksprite.com/wiki/index.php5?title=File:Motor_performance_parameter.png; I'm not sure how much slower we could expect it to be while milling. As far as actually measuring this, there are devices you could buy, but you could pretty easily fabricobble your way to an answer if you wanted to make a project out of it: http://www.instructables.com/id/Measure-RPM-DIY-Portable-Digital-Tachometer/.
                                        I have the same mill as you, and swapped for one of these https://www.amazon.com/gp/product/B074FVKRZM/ and have had much better results so far.
                                        @coddingtonbear said in CNC PCB milling:
                                        Does the controller that comes with your motor allow you to set the RPM of the motor, or does it just set the voltage? If it knows RPM and can act like a PID (i.e. adapts to maintain the target RPM even under varying loads), then it would be very attractive.
                                        coddingtonbearC 1 Reply Last reply
                                          #663
                                          I went ahead and orderd the Hall Effect version, which appears to come with some kind of DSP PID controller to control the speed of its DC spindle.
                                          https://www.aliexpress.com/item/Freeshipping-Brushless-spindle-motor-driver-Motor-base-kit-BL-Engraver-Spindle-Motor-24VDC-60VDC-12000RPM-ER8/32849306845.html?spm=2114.search0204.3.72.2cc61acfYE6xkB&ws_ab_test=searchweb0_0,searchweb201602_5_10152_5711320_10151_10065_10344_10068_10130_10324_10342_10547_10325_10343_10546_10340_10548_10341_10545_10084_10083_10618_10307_5711220_5722420_10313_10059_10534_100031_10103_10627_10626_10624_10623_10622_10621_10620,searchweb201603_25,ppcSwitch_5_ppcChannel&algo_expid=7790ac4f-6dbd-47b4-9574-1d713348386c-11&algo_pvid=7790ac4f-6dbd-47b4-9574-1d713348386c&transAbTest=ae803_3&priceBeautifyAB=0
