  3. Clearance, creepage and other safety aspects in "MySensors" PCBs.
pcbac powercreepageclearanceacdc
17 Posts 6 Posters 26.6k Views 12 Watching
    Samuel235
    Will contribute as, when or if needed.
    MySensors 2.1.1
    • dpressleD
      dpressleD
      dpressle
      Great post, thanks for the effort.
      I didn't see any reference to current(amp) values, from what i could understand it has a lot of meaning in calculating the clearance/creepage
      • sundberg84S
        sundberg84S
        @dpressle -I have seen some tables with current in it. And also some overvoltage protection... but have not got my head around it yet. Also there is some trace WIDTH calculators and they are offcourse dependent on current. Do you have any good ideas where to start or any references?
        dpressleD 1 Reply Last reply
        • sundberg84S sundberg84
          dpressleD
          dpressleD
          dpressle
          @sundberg84 I cant find it but i do remember there was reference somewhere, maybe its not that important if its not mentioned in most places.
          • T
            TNI
            Hey Sundberg84
            First of all great article. When I look through it, I share the same interpretations of the clearance and creepage but again I also see something I not fully agree on
            iF You are interrested in having a further discussion it could be great
            Let me know
            Thomas
            • T TNI
              Hey Sundberg84
              Let me know
              Thomas
              sundberg84S
              sundberg84S
              @TNI I'm not a electrical engineer and this article is my learning and understanding along the way. I'm really interested in a discussion so I can learn more. Please post your thoughts!
                TNI
                @sundberg84 - I would take a little different approach. First of all I would find the product standard that my product needs to fulfill. Product standards do not always have the same requirments to determine the clearance (creepage the often have). I am working alot with IEC/EN/UL61800-5-1 and IEC/EN/UL60730-1. In 61800-5-1 the clearance shall be determined either by
                • Impulse voltage
                  ------This is based on the system voltage (phase to PE) and also the Over voltage cat. The value found is called basic. For reinforced next higher step shall be used. For Functional, the MOV determine the impulse. If it shall be one or two times below the basic insualtion. Normally PD do not affect the clearances at higher impulse voltages like 2.5kV, 4KV etc. The impulse voltage can be transfered into a distance in mm
                • Temporary Over Voltage
                  ------ In 61800-5-1 it is determined by 1200+the line voltage. So for a 240V it would be 1440V. This can also be transfered into a distance in mm
                  . Working Voltage including recurring peak
                  ------this has to be simulated, calculated or measured by the engineer. Values can also be transfered into distances in mm
                Worst case of above determine the clearance value for the product
                In 60730 only the impulse voltage is used to determine the clearance. They determine it the same as 61800-5-1. This is due to both uses 60664-1
                Often the impusle voltage is worst case.
                For creepage it is the working voltage (RMS or DC) that is permanent accros the two polarities. The voltage can also be transfered into a distance of mm.
                Alot of the standards (also the two i have mentioned) have two columns dedicated for the PWB regarding creepage.
                For creepage the standards (at least the two i have mentioned) state that if a creepage distance is less than 1mm it will become a clearance.
                It is very difficult to write in this, so please add you email, I will prefer to write directly to You
                Thomas
                • T TNI
                  • Impulse voltage
                  Thomas
                  sundberg84S
                  sundberg84S
                  @TNI - Thanks for your input!
                  • How do you find the right product standard for your product? Ie, a AC/DC PCB board?
                  • So when you find your standard (I think I have been working alot with the standard for high voltage boards?) you find which creepage/clearance you need to work with? Can you give an example?
                    -Simulating and calculating by engineers isnt a option for us, this is open source hardware / DIY and this means "we do it on our own risk"... thats why im trying to gather as much info as possible - what would your recommendations be?
                  • I have noted Basic/reinforces above, but not connected the info to Impulse voltage. Can you give an example or my conclusions regargind Basic/reinforces isnt correct?
                  Thanks for your info Thomas! If possible I would be glad to keep the discussion here for others to see... thats what open source is all about :)
                    TNI
                    @sundberg84 - Actually before finding the standard You would need to identify which area. Exmaple. In Europe there would be a directive (2014/35/EU is the new LVD directive, there are also for EMC, RED, ATEX etc.) When You have identified which directives You would need to comply with you can see which standards they have as harmonized (to fulfill the directive). If You are certifying for North America/Canada You use cULus (Listed) or cURus (recognized) and other countries have others like EAC for Russia, Belarus etc. and so on
                    But it can be a tough job finding the correct standard and even harder to find the end product standard (if your product is used inside another application). Example. A controller (certified according to 60730-1) which is used in 60335-1, 2-89 application (normally it is our customers who uses the end application standard). Here You would also need to check if the end application standard(s) have more severe requirments than 60730-1, if so You would need to adopt these into the certification of your product, else he/she might fail his certification. I am working with controllers. For industrial it is 61800-5-1 and for household it is 60730-1 or 60335-1 directly. It is important to check normative in the end product standard and see if the standard You are using is mentioned. Example. 60335-1 mentioned 60730-1 but not 61800-5-1. So the industrial standard cannot be used if You know that the end application would be 60335-1 and 2-?.
                    Fulfilling a standard is not only clearance and creepage but we will only look at that here
                    My examples are from 61800-5-1 (i cannot insert tables, that was why I would like mails, but I will just refere to the tables)
                    Clearance. As previous told this standard has 3 ways to determine the clearance. By Impulse Voltage (table 7) or by Temporary Overvoltage (Table 9) or Wokring Voltage including recurring peak (table 9).
                    For the determine by impulse You would beed to know the OVC (Over Votlage Cat). Fix installed is normally OVC III and plugable is OVCII. System voltage is (phase to PE voltage). So if You have a 3 phase 500V in a TN grid the system voltage would be 500/squareroot(3) = 288V. In table 7 the voltages are 150, 300, 600. So here the 300V (remember that interpolation is not permitted) at OVC III should be used (we only make for fixed installation). That would give an impulse of 4KV. So the basic insulation (phase to PE) shall withstand 4KV (and that is all components that are bridging the basic insualtion. Now the Functional insulation can be determined. By using MOV You can supress the Impulse and hereby choose 2.5KV or 1.5KV or even less. Depeding on what the MOV is rated. Remember that there is NO MOV to basic insualtion. If You have it can be there for two reasons. 1. EMC purpose or 2. spacing reduction. If You use it for spacing reduction it has to be monitored so if it is broken the user is informed. For reinforced (live parts to PELV or SELV) You would need one level higher whih is 6KV.
                    In table 9 these impulse values can be transfered into a distance in mm. T.O.W which is also determined from table 9 is 1200V plus the voltage so in this case it would be (between the phase) squareroot(2)*500 = 707V. This can also be calculated into a distance in mm (here interpolation is permitted). If this value is less than the value from impulse, the impulse voltage is used. For the WV including recurring peak You would need to measure it on an actual board in the worst case condition You allow (since You do not have the option to simulate/calculate). Value measured can be calculated in to a distance in mm (table 9). All values are compared and the worst case is giving the clearance.
                    Creepage. Table 10 is used. Table 10 has values for PWB and also other insulators. The PWB column (PD1 and PD2) can be used on PWBs. Requirement is that CTI > 175. If You have components that are designed by You (e.g. DC coils, RFI choke, SMPS transformers, BUS bars etc. these would have to comply with other insulators. This menas that CTI value of all parts within the component has to be evaulated. Example. According to table 10 @ 500V for PWB at PD2 you would need 2.5mm. If we design a RFI choke (between phases, R, S and T) there should be 2.5mm bwtween the phases. Other insulators have 3 groups, I = CTI >600, II = 400<CTI<600 and IIIa/b = CTI less than 250. So if distance on the choke shall be 2.5mm the piolymeric used around the core shall have a CTI of 600, if we choose a polymeric with a lower CTI the creepage would be either 3.6mm or 5mm (taken at 500V in table 10). I cannot tell You why, personally I think it is crazy that CTI on PWB of 175 = 2.5mm and CTI of polymeric on choke of 175 = 5 is not the same. Table 10 is for functional and basic insulation. So if You would need to find the value to either PELV or SELV (reinforced You would need to multiply the distance You find by 2.
                    Remember that the standard also state that a creepage cannot be less than a clearance.
                    Thomas
                    • SoloamS
                      SoloamS
                      Soloam
                      wrote on last edited by Soloam
                      Hello @sundberg84 , this is a topic that I have made some research myself, I wanted to make my PCB the safest possible. One question that I would like to put you is the development in KiCad (don't know if you use it), but one thing that I KiCad doesn't take into account, is the "air gap". You put in your design rules that you what to have 8mm of isolation, and if you are required to have less, by layout constrains, and put a air gap in between pads to raise the creepage, Kicad will still give you a error on the design verification. What do you do in this situations? Ignore the errors?
                      Another thing that you must also take into consideration is the cooper width, this also is very important.
                      Thank You and nice work
                      • SoloamS Soloam
                        sundberg84S
                        sundberg84S
                        @soloam - hi!
                        Thanks for your input. Yes I use KiCad.
                        Yes, clearance is only calculated in the designrules and not creepage and that can be a issue. I have seen some posts on KiCad forum about this. In normal situations i try to avoid slots ("air gaps") as much as I can but when I add them, I need to manually calculate the creepage with the ruler och creating a track along the shortest point-point and measure that track length.
                        From one of the sources:
                        Clearance is measured in air (line of sight), so there is little that can be done at the layout level to reduce the required spac­ing. Careful placement does make a difference, but the more signifi­cant reductions in spacing can be achieved by using insulating materi­als and, when possible, by double-sided assembly.
                        Clearance is generally less than creepage so I always try to set my designrules for the creepage values. If they are impossible to maintain... I try to redesign first and second i add slots and ignore the error after manually measured the creepage.
                        • SoloamS
                          SoloamS
                          Soloam
                          That is what I do, I create a rule to pads with creepage and rely on my calculations. I'm rebuilding my current switch board to make it safer to use in more polluted environment, I need to use one outside (in a box, but better safe than sorry), and in a bathroom.
                          I think that the main problem with the pads and traces spacing is the design constrains. I need to keep it in a 5x5 cm board and that is not easy, especially when you have a AC and DC circuit! I never considered the distance between AC and DC, and that is the main reason for me to rebuild my boards. After reading your post I made some researches, and I found that I had a design problem. Like you stated, I'm not a electrical engineer, and we are always learning :)
                          • J
                            J
                            JohanH
                            That's some impressive research. Personally I think you don't have to be that hard on yourself when creating hobbyist equipment and devices. With that I mean you might not have to build the device according to the most rigorous safety level. It of course depends on what you are building and how it is going to be used. (Disclaimer; I have a degree in electrical engineering, but I haven't been working with this stuff actively, only as a hobby).
                            Now there is another aspect also (that is mentioned in this thread). There are competing standards that might or might not be applied in various countries. And most importantly, if you build a device for commercial use, you have to follow the standards in your own area. This might take years of research and work and isn't possible for the hobbyist.
                            There are of course the general IP classes. If you build a device for IP level 20, the standard says:
                            "Parts in mains voltage potential should have at least a 6 mm aerial distance and 3 mm insulated distance to conductive parts that the user of the appliance can touch"
                            This means for instance the distance between a circuit board with mains voltage and the chassis.
                            Then there is IPC-9592 for power conversion devices. It defines a safe creepage distance as:
                            0.6 + voltage * 0.005 = creepage distance in mm.
                            For instance for 250V that would be 1.85 mm, which I think is quite a good rule of thumb for hobbyist applications. That is around Pollution degree 2, II, in your table (which was from DIN EN 60664-1?).
                            Then there is UL 6500, which is an older standard for audio equipment. They define "The least safe distance in mm between the two differentials in voltage" as:
                            d = 10^(0.78log(U/300))
                            Where d is in mm and U in volt. Thus 250 V would be 0.87 mm. That seems rather low, though, if comparing with other standards.
                            As has been already said in this thread, you have to look at what standards you need to adhere to. But for hobbyist stuff and for devices you build for yourself, you yourself ultimately have the responsibility. And maybe you don't have to follow the most rigorous standard.
                            Hopefully people that build commercial devices have this all covered. I couldn't imagine that they copy a design from a hobbyist board and create a commercial device based on that. Not when it involves mains voltage. Low voltage stuff is maybe another matter.
                            • J JohanH
                              sundberg84S
                              sundberg84S
                              @JohanH - thanks for your reply! I also hope and think people who build commercial products have knowledge of this :)
                              But as a hobbyist, there are two ways to go - either you dont have to care or go bare minimum, if something happens its your own fault, or you can try to make is as safe as possible.
                              My idea was never to make this thread a information source for a commercial product. I wanted to try to make my own products as safe as possible since I have children around. With that in mind, i want to be on the safe side of things so some things i use from here might be exaggerated.
                              But my PCB (HLK-PM01 breakout) is working great, and I feel safe. I have had it outdoors (under roof covered in IP5* box, -20 to +30 aprox) and its been working for me for a couple of years now. Better than I had before, when i just stripped an old fake samsung charger.
                              /Andreas
