  3. SSL support for MQTT on ESP8266
13 Posts 5 Posters 13.2k Views 5 Watching
    @Anticimex
    This has nothing to do with the message signing.
    @noelgeorgi
    Good!. Might be good to put this initialization in the optional before()-method instead of setup(), which runs before any other MySensors stuff.
    noelgeorgiN AnticimexA 2 Replies Last reply
      @Anticimex
      @noelgeorgi
      noelgeorgiN
      noelgeorgiN
      noelgeorgi
      @hek I didnt know there was an optional method. Thanks
        @Anticimex
        @noelgeorgi
        AnticimexA
        AnticimexA
        Anticimex
        @hek i know that perfectly well, but since I am adressed, I just want to make clear I do not consider myself involved :)
        • noelgeorgiN
          noelgeorgiN
          noelgeorgi
          wrote on last edited by noelgeorgi
          @hek pubsubclient has issues with ssl connection, frequent disconnections. Adafruit's MQTT library works like charm, trying to integrate into MySensors
          • noelgeorgiN
            noelgeorgiN
            noelgeorgi
            @hek I somewhat succesfully integrated Adafruit MQTT library into MySensors, i am able to sent out data but not able to receive (subscribe). These are the changes i made:
            diff output
            • MySesnors.h
            < #if defined(MY_GATEWAY_SERIAL) || defined(MY_GATEWAY_W5100) || defined(MY_GATEWAY_ENC28J60) || defined(MY_GATEWAY_ESP8266) || defined(MY_GATEWAY_MQTT_CLIENT) || defined(MY_GATEWAY_MQTT_SECURE_CLIENT)
            55,59d54
            < #if defined(MY_GATEWAY_MQTT_SECURE_CLIENT)
            < 	#include "drivers/Adafruit_MQTT_Library/Adafruit_MQTT.cpp"
            < 	#include "drivers/Adafruit_MQTT_Library/Adafruit_MQTT_Client.cpp"
            < #endif
            180c175
            < #if defined(MY_GATEWAY_MQTT_CLIENT) || defined(MY_GATEWAY_MQTT_SECURE_CLIENT)
            • keywords.txt
            < MY_GATEWAY_MQTT_SECURE_CLIENT LITERAL 1
            MyGatewayTransportMQTTClient.cpp
            36,40c36
            < 		#define EthernetClient WiFiClientSecure
            < 	#else
            < 	#endif
            54,277d49
            < 	Adafruit_MQTT_Client mqtt(&_ethClient
            < 				 #if defined(MY_CONTROLLER_IP_ADDRESS)
            <  				, _brokerIp
            < 				#else
            < 				, MY_CONTROLLER_URL_ADDRESS
            < 				#endif
            < 				, MY_PORT
            < 				#if defined(MY_MQTT_USER) && defined(MY_MQTT_PASSWORD)
            < 				, MY_MQTT_USER, MY_MQTT_PASSWORD
            < 				#endif
            < Adafruit_MQTT_Subscribe feed = Adafruit_MQTT_Subscribe(&mqtt,MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "/+/+/+/+/+" );
            < Adafruit_MQTT_Subscribe *subscription;
            < bool _connecting = true;
            < bool _available = false;
            < char _convBuffer[MAX_PAYLOAD*2+1];
            < char _fmtBuffer[MY_GATEWAY_MAX_SEND_LENGTH];
            < MyMessage _mqttMsg;
            < bool gatewayTransportSend(MyMessage &message) {
            < 	if (!mqtt.connected())
            < 		return false;
            < 	snprintf_P(_fmtBuffer, MY_GATEWAY_MAX_SEND_LENGTH, PSTR(MY_MQTT_PUBLISH_TOPIC_PREFIX "/%d/%d/%d/%d/%d"), message.sender, message.sensor, mGetCommand(message), mGetAck(message), message.type);
            < 	debug(PSTR("Sending message on topic: %s\n"), _fmtBuffer);
            < 	return mqtt.publish(_fmtBuffer, message.getString(_convBuffer));
            < void incomingMQTT(char* topic, byte* payload,
            <                         unsigned int length)
            < 	debug(PSTR("Message arrived on topic: %s\n"), topic);
            < 	char *str, *p;
            < 	uint8_t i = 0;
            < 	uint8_t bvalue[MAX_PAYLOAD];
            < 	uint8_t blen = 0;
            < 	uint8_t command = 0;
            < 	for (str = strtok_r(topic, "/", &p); str && i <= 5;
            < 			str = strtok_r(NULL, "/", &p)) {
            < 		switch (i) {
            < 			case 0: {
            < 				// Topic prefix
            < 				if (strcmp(str, MY_MQTT_SUBSCRIBE_TOPIC_PREFIX) != 0) {
            < 					// Message not for us or malformed!
            < 					return;
            < 				break;
            < 			case 1: {
            < 				// Node id
            < 				_mqttMsg.destination = atoi(str);
            < 				break;
            < 			case 2: {
            < 				// Sensor id
            < 				_mqttMsg.sensor = atoi(str);
            < 				break;
            < 			case 3: {
            < 				// Command type
            < 				command = atoi(str);
            < 				mSetCommand(_mqttMsg, command);
            < 				break;
            < 			case 4: {
            < 				// Ack flag
            < 				mSetRequestAck(_mqttMsg, atoi(str)?1:0);
            < 				break;
            < 			case 5: {
            < 				// Sub type
            < 				_mqttMsg.type = atoi(str);
            < 				// Add payload
            < 				if (command == C_STREAM) {
            < 					blen = 0;
            < 					uint8_t val;
            < 					while (*payload) {
            < 						val = protocolH2i(*payload++) << 4;
            < 						val += protocolH2i(*payload++);
            < 						bvalue[blen] = val;
            < 						blen++;
            < 					_mqttMsg.set(bvalue, blen);
            < 				} else {
            < 					char* ca;
            < 					ca = (char *) payload;
            < 					ca += length;
            < 					*ca = '\0';
            < 					_mqttMsg.set((const char*) payload);
            < 				_available = true;
            < 		i++;
            < bool reconnectMQTT() {
            < 	debug(PSTR("Attempting MQTT connection...\n"));
            < 	// Attempt to connect
            < int8_t ret;
            <   // Stop if already connected.
            <   if (mqtt.connected()) {
            <     return true;
            <   //Serial.print("Connecting to MQTT... ");
            <   uint8_t retries = 3;
            <   while ((ret = mqtt.connect()) != 0) { // connect will return 0 for connected
            <        Serial.println(mqtt.connectErrorString(ret));
            <        Serial.println("Retrying MQTT connection in 5 seconds...");
            <        mqtt.disconnect();
            <        delay(5000);  // wait 5 seconds
            <        retries--;
            <        if (retries == 0) {
            <          // basically die and wait for WDT to reset me
            <          while (1);
            <   //Serial.println("MQTT Connected!");
            < 		debug(PSTR("MQTT connected\n"));
            < 		// Once connected, publish an announcement...
            < 		//_client.publish("outTopic","hello world");
            < 		// ... and resubscribe
            < 		mqtt.subscribe(&feed);
            < 		return true;
            < 	return false;
            < bool gatewayTransportInit() {
            < 	_connecting = true;
            < 	//#if defined(MY_CONTROLLER_IP_ADDRESS)
            < 	//	_client.setServer(_brokerIp, MY_PORT);
            < 	//#else
            < 	//	_client.setServer(MY_CONTROLLER_URL_ADDRESS, MY_PORT);
            < 	//#endif
            < 	//_client.setCallback(incomingMQTT);
            <  if((subscription = mqtt.readSubscription(10))) {
            <     if (subscription == &feed)
            <       Serial.print(F("Got: "));
            <       Serial.println((char *)feed.lastread);
            <   	#if defined(MY_GATEWAY_ESP8266)
            < 		// Turn off access point
            < 		WiFi.mode (WIFI_STA);
            < 		(void)WiFi.begin(MY_ESP8266_SSID, MY_ESP8266_PASSWORD);
            < 		#ifdef MY_IP_ADDRESS
            < 			WiFi.config(_clientIp, _gatewayIp, _subnetIp);
            < 		#endif
            < 		while (WiFi.status() != WL_CONNECTED)
            < 			delay(500);
            < 			MY_SERIALDEVICE.print(".");
            < 			yield();
            < 		MY_SERIALDEVICE.print("IP: ");
            < 		MY_SERIALDEVICE.println(WiFi.localIP());
            < 	#else
            < 			Ethernet.begin(_clientMAC, _clientIp);
            < 		#else
            < 			// Get IP address from DHCP
            < 			if (!Ethernet.begin(_clientMAC))
            < 				MY_SERIALDEVICE.print("DHCP FAILURE...");
            < 				_connecting = false;
            < 				return false;
            < 			MY_SERIALDEVICE.println(Ethernet.localIP());
            < 		#endif
            < 		// give the Ethernet interface a second to initialize
            < 		// TODO: use HW delay
            < 		wait(1000);
            < 	#endif
            < 	return true;
            < bool gatewayTransportAvailable() {
            < 	if (_connecting)
            < 		return false;
            < 	//keep lease on dhcp address
            < 	//Ethernet.maintain();
            < 	if (!_ethClient.connected()) {
            < 		//reinitialise client
            < 		if (gatewayTransportInit())
            < 			reconnectMQTT();
            < 		return false;
            < 	//_ethClient.loop();
            < 	return _available;
            < MyMessage & gatewayTransportReceive() {
            < 	// Return the last parsed message
            < 	_available = false;
            < 	return _mqttMsg;
            < #else
            279d50
            456c227
            < #endif
            • GatewWay Code
             * Version 1.0 - Henrik Ekblad
             * The ESP8266 MQTT gateway sends radio network (or locally attached sensors) data to your MQTT broker.
             * The node also listens to MY_MQTT_TOPIC_PREFIX and sends out those messages to the radio network
             * LED purposes:
             * See http://www.mysensors.org/build/esp8266_gateway for wiring instructions.
             * nRF24L01+  ESP8266
             * VCC        VCC
             * CE         GPIO4
             * CSN/CS     GPIO15
             * SCK        GPIO14
             * MISO       GPIO12
             * MOSI       GPIO13
              * Inclusion mode button:
            #include <EEPROM.h>
            //#define MY_BAUD_RATE 9600
            #define MY_GATEWAY_MQTT_SECURE_CLIENT
            #define MY_GATEWAY_ESP8266
            // Set MQTT client id
            #define MY_MQTT_USER "user"
            #define MY_MQTT_PASSWORD "pass"
            // Set WIFI SSID and password
            #define MY_ESP8266_SSID "ssid"
            #define MY_ESP8266_PASSWORD "password"
            #define MY_IP_ADDRESS 172,16,0,120
            #define MY_IP_GATEWAY_ADDRESS 172,16,0,1
            // MQTT broker ip address.
            #define MY_CONTROLLER_URL_ADDRESS "domain.com"
            #define MY_PORT 8883
            // Flash leds on rx/tx/err
            // Set blinking period
            // Enable inclusion mode
            #include <ESP8266WiFi.h>
            Any help would be really appreciated???
              wrote on last edited by hek
              Isn't incomingMQTT() ever called?
              You seem to have commented away this line:
              noelgeorgiN 1 Reply Last reply
                noelgeorgiN
                noelgeorgiN
                noelgeorgi
                @hek i am trying to do that in void loop{} will update once it gets working properly and will do a pull request, the problem is that i can subscribe to a main topic but not its subfeeds
                • noelgeorgiN
                  noelgeorgiN
                  noelgeorgi
                  @hek Adafruit's MQTT libarary doesnt have wildcard subscriptions switching to https://github.com/256dpi/arduino-mqtt SSL seems to be working and library has callback support
                  monteM 1 Reply Last reply
                  • noelgeorgiN noelgeorgi
                    monteM
                    monteM
                    monte
                    @noelgeorgi so do you have a working code already? It would be great to try it out.
                    • SoloamS
                      SoloamS
                      Soloam
                      Also looking at this... was this ever implemented? And where your trials on server encryption or also in client authentication?
                      Thank You
                      • SoloamS Soloam
                        Thank You
                        monteM
                        monteM
                        monte
                        @soloam look at this https://forum.mysensors.org/topic/8863/esp8266-mqtt-gateway-ssl-connection/1
