  3. SSL support for MQTT on ESP8266
13 Posts 5 Posters 13.1k Views 5 Watching
  • noelgeorgiN Offline
    noelgeorgiN Offline
    noelgeorgi
    wrote on last edited by noelgeorgi
    @hek @Anticimex First install https://github.com/esp8266/arduino-esp8266fs-plugin and upload the crt file to the ESP8266 file system.
    then issue these command from the folder in which MySensors is installed:
    sed -i 's/WiFiClient/WiFiClientSecure/g' Arduino/libraries/MySensors/core/MyGatewayTransportEthernet.cpp
    sed -i 's/WiFiClient/WiFiClientSecure/g' Arduino/libraries/MySensors/core/MyGatewayTransportMQTTClient.cpp
    change your GatewayESP8266MQTTClient to this:
     * Version 1.0 - Henrik Ekblad
     * The ESP8266 MQTT gateway sends radio network (or locally attached sensors) data to your MQTT broker.
     * The node also listens to MY_MQTT_TOPIC_PREFIX and sends out those messages to the radio network
     * LED purposes:
     * See http://www.mysensors.org/build/esp8266_gateway for wiring instructions.
     * nRF24L01+  ESP8266
     * VCC        VCC
     * CE         GPIO4
     * CSN/CS     GPIO15
     * SCK        GPIO14
     * MISO       GPIO12
     * MOSI       GPIO13
      * Inclusion mode button:
    #include "FS.h"
    #include <EEPROM.h>
    #define MY_BAUD_RATE 9600
    #define MY_GATEWAY_ESP8266
    // Set MQTT client id
    #define MY_MQTT_USER "admin" //your MQTT username
    #define MY_MQTT_PASSWORD "admin" //your MQTT password
    // Set WIFI SSID and password
    #define MY_ESP8266_SSID "yourwifissid"
    #define MY_ESP8266_PASSWORD "yourwifipassword"
    #define MY_IP_ADDRESS 172,16,0,120
    #define MY_IP_GATEWAY_ADDRESS 172,16,0,1
    // MQTT broker ip address.
    #define MY_CONTROLLER_IP_ADDRESS 172, 16, 0, 95
    #define MY_PORT 8883      // note this change its port 8883 as per standard for SSL over MQTT
    // Flash leds on rx/tx/err
    // Set blinking period
    // Enable inclusion mode
    #include <ESP8266WiFi.h>
      if (!SPIFFS.begin()) {
        Serial.println("Failed to mount file system");
        return;
      File ca = SPIFFS.open("/ca.crt", "r"); //replace ca.crt with the ca file name
      if (!ca) {
        Serial.println("Failed to open ca file");
      Serial.println("Successfully opened ca file");
    if(_ethClient.loadCertificate(ca)) //_ethClient as defined in MyGatewayTransportMQTTClient.cpp
      Serial.println("loaded");
      Serial.println("not loaded");
    NB: i used https://github.com/owntracks/tools/raw/master/TLS/generate-CA.sh for generating the ca files
    • A Offline
      A Offline
      Anticimex
      I have no esp hw. And like I said, ssl and MQTT is specific to a certain architecture (from a gw and controller perspective) so I don't want it being mixed in with the existing security infrastructure that goes on every node.
      You are free to implement it as such of course, but I won't bring it into the signing solution.
      • hekH Offline
        hekH Offline
        @Anticimex
        This has nothing to do with the message signing.
        @noelgeorgi
        Good!. Might be good to put this initialization in the optional before()-method instead of setup(), which runs before any other MySensors stuff.
        noelgeorgiN A 2 Replies Last reply
          @Anticimex
          @noelgeorgi
          noelgeorgiN Offline
          noelgeorgiN Offline
          noelgeorgi
          @hek I didnt know there was an optional method. Thanks
            @Anticimex
            @noelgeorgi
            A Offline
            A Offline
            Anticimex
            @hek i know that perfectly well, but since I am adressed, I just want to make clear I do not consider myself involved :)
              noelgeorgiN Offline
              noelgeorgi
              @hek pubsubclient has issues with ssl connection, frequent disconnections. Adafruit's MQTT library works like charm, trying to integrate into MySensors
                noelgeorgiN Offline
                noelgeorgi
                @hek I somewhat succesfully integrated Adafruit MQTT library into MySensors, i am able to sent out data but not able to receive (subscribe). These are the changes i made:
                diff output
                • MySesnors.h
                < #if defined(MY_GATEWAY_SERIAL) || defined(MY_GATEWAY_W5100) || defined(MY_GATEWAY_ENC28J60) || defined(MY_GATEWAY_ESP8266) || defined(MY_GATEWAY_MQTT_CLIENT) || defined(MY_GATEWAY_MQTT_SECURE_CLIENT)
                55,59d54
                < #if defined(MY_GATEWAY_MQTT_SECURE_CLIENT)
                < 	#include "drivers/Adafruit_MQTT_Library/Adafruit_MQTT.cpp"
                < 	#include "drivers/Adafruit_MQTT_Library/Adafruit_MQTT_Client.cpp"
                < #endif
                180c175
                < #if defined(MY_GATEWAY_MQTT_CLIENT) || defined(MY_GATEWAY_MQTT_SECURE_CLIENT)
                • keywords.txt
                < MY_GATEWAY_MQTT_SECURE_CLIENT LITERAL 1
                36,40c36
                < 		#define EthernetClient WiFiClientSecure
                < 	#else
                < 	#endif
                54,277d49
                < 	Adafruit_MQTT_Client mqtt(&_ethClient
                < 				 #if defined(MY_CONTROLLER_IP_ADDRESS)
                <  				, _brokerIp
                < 				#else
                < 				, MY_CONTROLLER_URL_ADDRESS
                < 				#endif
                < 				, MY_PORT
                < 				#if defined(MY_MQTT_USER) && defined(MY_MQTT_PASSWORD)
                < 				, MY_MQTT_USER, MY_MQTT_PASSWORD
                < 				#endif
                < Adafruit_MQTT_Subscribe feed = Adafruit_MQTT_Subscribe(&mqtt,MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "/+/+/+/+/+" );
                < Adafruit_MQTT_Subscribe *subscription;
                < bool _connecting = true;
                < bool _available = false;
                < char _convBuffer[MAX_PAYLOAD*2+1];
                < char _fmtBuffer[MY_GATEWAY_MAX_SEND_LENGTH];
                < MyMessage _mqttMsg;
                < bool gatewayTransportSend(MyMessage &message) {
                < 	if (!mqtt.connected())
                < 		return false;
                < 	snprintf_P(_fmtBuffer, MY_GATEWAY_MAX_SEND_LENGTH, PSTR(MY_MQTT_PUBLISH_TOPIC_PREFIX "/%d/%d/%d/%d/%d"), message.sender, message.sensor, mGetCommand(message), mGetAck(message), message.type);
                < 	debug(PSTR("Sending message on topic: %s\n"), _fmtBuffer);
                < 	return mqtt.publish(_fmtBuffer, message.getString(_convBuffer));
                < void incomingMQTT(char* topic, byte* payload,
                <                         unsigned int length)
                < 	debug(PSTR("Message arrived on topic: %s\n"), topic);
                < 	char *str, *p;
                < 	uint8_t i = 0;
                < 	uint8_t bvalue[MAX_PAYLOAD];
                < 	uint8_t blen = 0;
                < 	uint8_t command = 0;
                < 	for (str = strtok_r(topic, "/", &p); str && i <= 5;
                < 			str = strtok_r(NULL, "/", &p)) {
                < 		switch (i) {
                < 			case 0: {
                < 				// Topic prefix
                < 				if (strcmp(str, MY_MQTT_SUBSCRIBE_TOPIC_PREFIX) != 0) {
                < 					// Message not for us or malformed!
                < 					return;
                < 				break;
                < 			case 1: {
                < 				// Node id
                < 				_mqttMsg.destination = atoi(str);
                < 				break;
                < 			case 2: {
                < 				// Sensor id
                < 				_mqttMsg.sensor = atoi(str);
                < 				break;
                < 			case 3: {
                < 				// Command type
                < 				command = atoi(str);
                < 				mSetCommand(_mqttMsg, command);
                < 				break;
                < 			case 4: {
                < 				// Ack flag
                < 				mSetRequestAck(_mqttMsg, atoi(str)?1:0);
                < 				break;
                < 			case 5: {
                < 				// Sub type
                < 				_mqttMsg.type = atoi(str);
                < 				// Add payload
                < 				if (command == C_STREAM) {
                < 					blen = 0;
                < 					uint8_t val;
                < 					while (*payload) {
                < 						val = protocolH2i(*payload++) << 4;
                < 						val += protocolH2i(*payload++);
                < 						bvalue[blen] = val;
                < 						blen++;
                < 					_mqttMsg.set(bvalue, blen);
                < 				} else {
                < 					char* ca;
                < 					ca = (char *) payload;
                < 					ca += length;
                < 					*ca = '\0';
                < 					_mqttMsg.set((const char*) payload);
                < 				_available = true;
                < 		i++;
                < bool reconnectMQTT() {
                < 	debug(PSTR("Attempting MQTT connection...\n"));
                < 	// Attempt to connect
                < int8_t ret;
                <   // Stop if already connected.
                <   if (mqtt.connected()) {
                <     return true;
                <   //Serial.print("Connecting to MQTT... ");
                <   uint8_t retries = 3;
                <   while ((ret = mqtt.connect()) != 0) { // connect will return 0 for connected
                <        Serial.println(mqtt.connectErrorString(ret));
                <        Serial.println("Retrying MQTT connection in 5 seconds...");
                <        mqtt.disconnect();
                <        delay(5000);  // wait 5 seconds
                <        retries--;
                <        if (retries == 0) {
                <          // basically die and wait for WDT to reset me
                <          while (1);
                <   //Serial.println("MQTT Connected!");
                < 		debug(PSTR("MQTT connected\n"));
                < 		// Once connected, publish an announcement...
                < 		//_client.publish("outTopic","hello world");
                < 		// ... and resubscribe
                < 		mqtt.subscribe(&feed);
                < 		return true;
                < 	return false;
                < bool gatewayTransportInit() {
                < 	_connecting = true;
                < 	//#if defined(MY_CONTROLLER_IP_ADDRESS)
                < 	//	_client.setServer(_brokerIp, MY_PORT);
                < 	//#else
                < 	//	_client.setServer(MY_CONTROLLER_URL_ADDRESS, MY_PORT);
                < 	//#endif
                < 	//_client.setCallback(incomingMQTT);
                <  if((subscription = mqtt.readSubscription(10))) {
                <     if (subscription == &feed)
                <       Serial.print(F("Got: "));
                <       Serial.println((char *)feed.lastread);
                <   	#if defined(MY_GATEWAY_ESP8266)
                < 		// Turn off access point
                < 		WiFi.mode (WIFI_STA);
                < 		(void)WiFi.begin(MY_ESP8266_SSID, MY_ESP8266_PASSWORD);
                < 		#ifdef MY_IP_ADDRESS
                < 			WiFi.config(_clientIp, _gatewayIp, _subnetIp);
                < 		#endif
                < 		while (WiFi.status() != WL_CONNECTED)
                < 			delay(500);
                < 			MY_SERIALDEVICE.print(".");
                < 			yield();
                < 		MY_SERIALDEVICE.print("IP: ");
                < 		MY_SERIALDEVICE.println(WiFi.localIP());
                < 	#else
                < 			Ethernet.begin(_clientMAC, _clientIp);
                < 		#else
                < 			// Get IP address from DHCP
                < 			if (!Ethernet.begin(_clientMAC))
                < 				MY_SERIALDEVICE.print("DHCP FAILURE...");
                < 				_connecting = false;
                < 				return false;
                < 			MY_SERIALDEVICE.println(Ethernet.localIP());
                < 		#endif
                < 		// give the Ethernet interface a second to initialize
                < 		// TODO: use HW delay
                < 		wait(1000);
                < 	#endif
                < 	return true;
                < bool gatewayTransportAvailable() {
                < 	if (_connecting)
                < 		return false;
                < 	//keep lease on dhcp address
                < 	//Ethernet.maintain();
                < 	if (!_ethClient.connected()) {
                < 		//reinitialise client
                < 		if (gatewayTransportInit())
                < 			reconnectMQTT();
                < 		return false;
                < 	//_ethClient.loop();
                < 	return _available;
                < MyMessage & gatewayTransportReceive() {
                < 	// Return the last parsed message
                < 	_available = false;
                < 	return _mqttMsg;
                < #else
                279d50
                456c227
                < #endif
                • GatewWay Code
                 * LED purposes:
                 * nRF24L01+  ESP8266
                 * VCC        VCC
                 * CE         GPIO4
                 * CSN/CS     GPIO15
                 * SCK        GPIO14
                 * MISO       GPIO12
                 * MOSI       GPIO13
                #include <EEPROM.h>
                //#define MY_BAUD_RATE 9600
                #define MY_GATEWAY_MQTT_SECURE_CLIENT
                #define MY_MQTT_USER "user"
                #define MY_MQTT_PASSWORD "pass"
                #define MY_ESP8266_SSID "ssid"
                #define MY_ESP8266_PASSWORD "password"
                #define MY_CONTROLLER_URL_ADDRESS "domain.com"
                Any help would be really appreciated???
                • hekH Offline
                  hekH Offline
                  wrote on last edited by hek
                  Isn't incomingMQTT() ever called?
                  You seem to have commented away this line:
                  noelgeorgiN 1 Reply Last reply
                    noelgeorgiN Offline
                    noelgeorgiN Offline
                    noelgeorgi
                    @hek i am trying to do that in void loop{} will update once it gets working properly and will do a pull request, the problem is that i can subscribe to a main topic but not its subfeeds
                      noelgeorgiN Offline
                      noelgeorgi
                      @hek Adafruit's MQTT libarary doesnt have wildcard subscriptions switching to https://github.com/256dpi/arduino-mqtt SSL seems to be working and library has callback support
                      monteM 1 Reply Last reply
                      • noelgeorgiN noelgeorgi
                        monteM Offline
                        monteM Offline
                        monte
                        @noelgeorgi so do you have a working code already? It would be great to try it out.
                        • S Offline
                          Soloam
                          Also looking at this... was this ever implemented? And where your trials on server encryption or also in client authentication?
                          Thank You
                          • S Soloam
                            Thank You
                            monteM Offline
                            monteM Offline
                            monte
                            @soloam look at this https://forum.mysensors.org/topic/8863/esp8266-mqtt-gateway-ssl-connection/1
