  2. Announcements
  • Nick WillisN
    Nick WillisN
    Nick Willis
    I've been using your restarting method and its been working ok and has done one restart in 5 days.
    However I now see something else where altho cpu use is fine, none of my nodes can communicate to the gateway. My controller can connect to the gateway no problem but there are no messages received. Restarting nodes does not help. Only a manual restart of the gateway gets things going again - at least for a while anyway.
    Where is the log output from the gateway to be found? I know it can be run from the bash prompt to write the output to screen but how about logging the installed service output?
    • Nick WillisN Nick Willis
      #812
      @nick-willis the log is sent to syslog by default. See https://www.mysensors.org/build/raspberry#troubleshooting for details.
      • O
        O
        otto001
        wrote on last edited by otto001
        #813
        @marceloaqno : This is strange. I am using a RPi 1 on this gateway with raspbian Jessie. Beside the GW-service there is only a small python programm which listens on an UPD-Port and plays an mp3 if it receives suitable data (for doorbell). Since March 4, 20:15 there were several restarts due to high cpu usage (after dis-applying your patch):
        2018-03-04 23:01:03 cpu (99.7) very high! --> restarting service
        2018-03-05 07:31:03 cpu (99.7) very high! --> restarting service
        2018-03-05 11:01:03 cpu (98.7) very high! --> restarting service
        2018-03-05 13:31:04 cpu (94.7) very high! --> restarting service
        2018-03-06 11:31:03 cpu (99.7) very high! --> restarting service
        2018-03-06 12:31:03 cpu (98.7) very high! --> restarting service
        2018-03-07 06:01:03 cpu (94.8) very high! --> restarting service
        2018-03-07 22:31:03 cpu (99.8) very high! --> restarting service
        With this "auto-restarts" the sensors are working fine, I did not notice any problems.
        However, I just upgraded to the recent Stretch (what takes a LONG time on RPi 1 and made me struggle a little bit with the new network names). I also rebuilt the GW of course and will report here what will happen....
        @Nick-Willis : did you apply the patch of marceloaqno or not? Did you enable debugging? (see here )
        Cheers,
        Otto
        • O otto001
          Cheers,
          Otto
          marceloaqno
          Code Contributor
          wrote on last edited by marceloaqno
          #814
          @otto001 In a new attempt to trigger this problem, I am using a script that will force the fhem controller to reconnect every 30s to the gateway (built with mysensors master branch, unpatched), and sends me a note in case of high CPU usage:
          I'll leave it running for a few days to see what happens.
          Here is the script, if anyone is interested:
          #!/bin/sh
          while true; do
            (echo "set mysgw disconnect"; echo "quit") | telnet localhost 7072 > /dev/null 2>&1
            sleep 1
            (echo "set mysgw connect"; echo "quit") | telnet localhost 7072 > /dev/null 2>&1
            sleep 1
            cpu_percent=$(ps -C "mysgw" -o %cpu=)
            cpu_percent=${cpu_percent%%.*}
            if [ "$cpu_percent" -ge 90 ]
            then
              echo "ALERT: HIGH CPU USAGE"
              # pushbullet script from https://gist.github.com/outadoc/189bd3ccbf5d6e0f39e4
              /home/pi/pushbullet.sh "RPi1: HIGH CPU USAGE"
              exit
            fi
            sleep 30
          done
          • O
            O
            otto001
            @marceloaqno : Thank you!
            Just a notice: I do NOT disconnect, I just connect every 30 minutes. Has been working for me since more than 2 years (ancient ms-gw version on RPi).
            Yesterday I did a dist-upgrade to stretch on the "problematic" gw (as mentioned above) - without your patch but with my monitoring-script running. It is a little bit to early I presume, but no high cpu problems so far. I will report back here in a few days. Maybe this problem is really related to old libraries or something?! If this is running stable for a few days I will apply your patch and see what happens.
            Thanks again!
            Cheers,
            Pula
              marceloaqno
              Code Contributor
              @otto001 After a few hours running the reconnect script, I noticed several error messages in my gateway log:
              accept(): Too many open files
              The problem was that the gateway wasn't releasing the socket descriptor after each disconnection of the controller. After reaching the limit (mine was 1036) the controller can't connect.
              I'm not entirely sure that this problem is related to what you're having. You can check how many file descriptors currently opened by the gateway with the command below
              sudo lsof -u root |grep mysgw |wc -l
              The fix:
              https://github.com/marceloaqno/MySensors/commit/a40d4441b7460225100398ff6f2581c2b0df36ea
                A Former User
                How do I update from master branch to development branch?
                  Why do you want to do that? Development version is still work in progress
                    A Former User
                    wrote on last edited by [[global:former-user]]
                    #819
                    I'm using a raspberry pi gateway in home-assistant.
                    Sometimes my gateway doesn't work anymore, and when I restart the service, it is running good
                    I used ./configure --my-transport=nrf24 --my-rf24-irq-pin=15 --my-gateway=ethernet --my-port=5003
                      Read the article again, there is the instruction on how to download the development version, but before you have to uninstall the mysgw service and rename the current mysensors folder to keep as backup.
                      • ? A Former User
                        marceloaqno
                        Code Contributor
                        @gieljnssns The fixes I mentioned above haven't yet been applied to the development branch. Eventually they will be, but I'm still doing some testing.
                        • O
                          O
                          otto001
                          #822
                          @marceloaqno :
                          Thank you!!! Should this patch be applied together with your first patch?
                          Interesting:
                          After some days without problems on the newest raspbian packages the gw hung again, but WITHOUT high cpu usage (and WITHOUT your first patch applied). There were just no more reads from the sensors in the log, only the re-connects of fhem. After restarting the service, everything is fine again.
                          Unfortunately I did see your post after that :-(
                          But I checked the log and could not find the words "too" or "Too" in the log (running service with -d).
                          Some minutes after restarting I checked how many open files there were with the command you supplied: 21
                          In the meantime I have created a small udp listening service which restarts the service if a certain string is received, so I can restart the service by double-clicking one of my switches without the need of login to the gw (also for the wife)....
                          @gieljnssns : I think you are experiencing exactly the same problem we are discussing :-)
                          Thanks again!
                          Cheers,
                          Otto
                            I'm using dietpi and I am not having big issues even running 2 gateway instances with 2 different radios
                            ? 1 Reply Last reply
                            • O otto001
                              @marceloaqno :
                              Interesting:
                              Thanks again!
                              Cheers,
                              Otto
                              marceloaqno
                              Code Contributor
                              @otto001 The second patch can be applied without the first one.
                              • O
                                O
                                otto001
                                @gohan :
                                gohanG 1 Reply Last reply
                                • O
                                  O
                                  otto001
                                  #826
                                  @marceloaqno :
                                  Cheers,
                                  Otto
                                    A Former User
                                    Can someone tell me how to apply this patch?
                                    • O otto001
                                      @gohan :
                                      • MasMatM
                                        MasMatM
                                        MasMat
                                        wrote on last edited by MasMat
                                        #829
                                        I need help with my Rpi mqtt-gw.
                                          Mosquitto-log:
                                        syslog:
                                        GW configure-line:
                                          MasMatM 1 Reply Last reply
