  2. Announcements
    Why do you want to do that? Development version is still work in progress
      A Former User
      wrote on last edited by [[global:former-user]]
      #819
      I'm using a raspberry pi gateway in home-assistant.
      Sometimes my gateway doesn't work anymore, and when I restart the service, it is running good
      I used ./configure --my-transport=nrf24 --my-rf24-irq-pin=15 --my-gateway=ethernet --my-port=5003
        Read the article again, there is the instruction on how to download the development version, but before you have to uninstall the mysgw service and rename the current mysensors folder to keep as backup.
        • ? A Former User
          marceloaqno
          Code Contributor
          @gieljnssns The fixes I mentioned above haven't yet been applied to the development branch. Eventually they will be, but I'm still doing some testing.
          • O
            O
            otto001
            wrote on last edited by otto001
            #822
            @marceloaqno :
            Thank you!!! Should this patch be applied together with your first patch?
            Interesting:
            After some days without problems on the newest raspbian packages the gw hung again, but WITHOUT high cpu usage (and WITHOUT your first patch applied). There were just no more reads from the sensors in the log, only the re-connects of fhem. After restarting the service, everything is fine again.
            Unfortunately I did see your post after that :-(
            But I checked the log and could not find the words "too" or "Too" in the log (running service with -d).
            Some minutes after restarting I checked how many open files there were with the command you supplied: 21
            In the meantime I have created a small udp listening service which restarts the service if a certain string is received, so I can restart the service by double-clicking one of my switches without the need of login to the gw (also for the wife)....
            @gieljnssns : I think you are experiencing exactly the same problem we are discussing :-)
            Thanks again!
            Cheers,
            Otto
              I'm using dietpi and I am not having big issues even running 2 gateway instances with 2 different radios
              ? 1 Reply Last reply
              • O otto001
                @marceloaqno :
                Interesting:
                Thanks again!
                Cheers,
                Otto
                marceloaqno
                Code Contributor
                @otto001 The second patch can be applied without the first one.
                • O
                  O
                  otto001
                  @gohan :
                  gohanG 1 Reply Last reply
                  • O
                    O
                    otto001
                    #826
                    @marceloaqno :
                    Cheers,
                    Otto
                      A Former User
                      Can someone tell me how to apply this patch?
                      • O otto001
                        @gohan :
                        • MasMatM
                          MasMatM
                          MasMat
                          wrote on last edited by MasMat
                          #829
                          I need help with my Rpi mqtt-gw.
                            Mosquitto-log:
                          syslog:
                          GW configure-line:
                            MasMatM 1 Reply Last reply
                              MasMatM
                              MasMatM
                              MasMat
                              @gohan Can I just edit mysgw.cpp and do "daemon-reload"?
                                  MasMatM
                                  MasMatM
                                  MasMat
                                  #833
                                  @gohan OK. I did that, the same socket error remains in Mosquitto just under new id.
                                    • MasMatM MasMat
                                      marceloaqno
                                      Code Contributor
                                      • ? A Former User
                                        marceloaqno
                                        Code Contributor
                                        You can download from:
                                        Here is a step-by-step:
                                        cd MySensors
                                        • M marceloaqno
                                          MasMatM
                                          MasMatM
                                          MasMat
                                          @marceloaqno Mosquitto v1.4.14.
