  3. More relay and push botton
relay remotexy
16 Posts 2 Posters 3.0k Views 2 Watching
  • rejoe2R
    rejoe2R
    rejoe2
    You may have a look at this example here to avoid redundancies in your code: https://forum.mysensors.org/topic/4847/multi-button-relay-sketch/33#
    • G
      G
      Gabriele Cirillo
      wrote on last edited by gohan
      Yes, i have try it but unsuccesfull.. this is my sketch
        RemoteXY example.
        Smartphone Ethernet connect over W5100 Ethernet shield or module
        (hardware serial connected).
        This shows an example of using the library RemoteXY.
        In the example you can control the pin 2 using the button on the
        smartphone. You need to connect W5100 Ethernet shield or module.
        W5100 used SPI interface.
        Download the mobile app from the
        website: http://remotexy.com/download/ for connect this sketch.
        Use the website http://remotexy.com/ to create your own management
        interface your arduino with your smartphone or tablet.
        You can create different management interfaces. Use buttons,
        switches, sliders, joysticks (g-sensor) all colors and sizes
        in its interface. Next, you will be able to get the sample
        code for arduino to use your interface for control from a
        smartphone or tablet. You will not need to re-install the
        android app, as it will determine which interface you have
        downloaded the arduino.
      //        RemoteXY include library         //
      /* RemoteXY select connection mode and include library */
      //#define MY_REPEATER_FEATURE
      #define REMOTEXY_MODE__ETHERNET_LIB
      #include <Ethernet.h>
      #include <RemoteXY.h>
      /* RemoteXY connection settings */
      #define REMOTEXY_ETHERNET_MAC "DE:AD:BE:EF:EF:ED"
      #define REMOTEXY_SERVER_PORT 6377
      // RemoteXY configurate
      #pragma pack(push, 1)
      uint8_t RemoteXY_CONF[] =
        { 255,3,0,2,0,48,0,8,13,1,
        1,0,15,37,12,12,2,31,79,78,
        0,65,4,43,38,9,9,1,0,15,
        19,12,12,2,31,79,78,0,65,4,
        43,21,9,9,1,0,27,72,12,12,
        2,31,79,78,0 };
      // this structure defines all the variables of your control interface
      struct {
          // input variable
        uint8_t button_2; // =1 if button pressed, else =0
        uint8_t button_1; // =1 if button pressed, else =0
        uint8_t button_all; // =1 if button pressed, else =0
          // output variable
        uint8_t led_1_r; // =0..255 LED Red brightness
        uint8_t led_2_r; // =0..255 LED Red brightness
          // other variable
        uint8_t connect_flag;  // =1 if wire connected, else =0
      } RemoteXY;
      #pragma pack(pop)
      //           END RemoteXY include          //
         DESCRIPTION
         Based on the RelayWithButtonActuator sketch
      #define RELAY_ON 1
      #define RELAY_OFF 0
      #define SSR_A_ID 1   // Id of the sensor child
      #define SSR_B_ID 2   // Id of the sensor child
      const int buttonPinA = 28;
      const int buttonPinB = 29;
      const int relayPinA = 30;
      const int relayPinB = 31;
      int oldValueA = 0;
      int oldValueB = 0;
      bool stateA = false;
      bool stateB = false;
      Bounce debouncerA = Bounce();
      Bounce debouncerB = Bounce();
      MyMessage msgA(SSR_A_ID, V_STATUS);
      MyMessage msgB(SSR_B_ID, V_STATUS);
        pinMode(buttonPinA, INPUT_PULLUP); // Setup the button Activate internal pull-up
        pinMode(buttonPinB, INPUT_PULLUP); // Setup the button Activate internal pull-up
        pinMode(relayPinA, OUTPUT);
        pinMode(relayPinB, OUTPUT);
        // After setting up the buttons, setup debouncer
        debouncerA.attach(buttonPinA);
        debouncerA.interval(5);
        debouncerB.attach(buttonPinB);
        debouncerB.interval(5);
        digitalWrite(relayPinA, RELAY_OFF);
        digitalWrite(relayPinB, RELAY_OFF);
      void presentation()  {
        sendSketchInfo("Mains Controller", "1.0");
        present(SSR_A_ID, S_LIGHT);
        present(SSR_B_ID, S_LIGHT);
        debouncerA.update();
        // Get the update value
        int valueA = debouncerA.read();
        if (valueA != oldValueA && valueA == 0) {
          send(msgA.set(stateA ? false : true), true); // Send new state and request ack back
        oldValueA = valueA;
        debouncerB.update();
        int valueB = debouncerB.read();
        if (valueB != oldValueB && valueB == 0) {
          send(msgB.set(stateB ? false : true), true); // Send new state and request ack back
        oldValueB = valueB;
          switch (message.sensor) {
            case 1:
              stateA = message.getBool();
              digitalWrite(message.sensor + 4, stateA ? RELAY_ON : RELAY_OFF);
            case 2:
              stateB = message.getBool();
              digitalWrite(message.sensor + 4, stateB ? RELAY_ON : RELAY_OFF);
          Serial.print("from node:");
          Serial.println(message.sender);
      rejoe2R 1 Reply Last reply
      • G Gabriele Cirillo
          RemoteXY example.
          2,31,79,78,0 };
        struct {
            // input variable
            // output variable
            // other variable
        } RemoteXY;
        #pragma pack(pop)
           DESCRIPTION
        #define RELAY_ON 1
        #define RELAY_OFF 0
        int oldValueA = 0;
        int oldValueB = 0;
          oldValueA = valueA;
          oldValueB = valueB;
              case 1:
              case 2:
        rejoe2R
        rejoe2R
        rejoe2
        @gabriele-cirillo Can you please reformat your post using code tags (</>-button above the editing field)?
        Wrt. to your sketch: Why do you use different childIDs in the receiving part than in the header?
        Did you have a look at the sketch in the above link? You will have to learn a little, how to use arrays, so please first try to understand how it works. I agree, this is not a very simple example, but as you asked for one...
        Don't really expect me (or somebody else) to deliever completed code - in the end it's up to you to connect your buttons and SSR's to the arduino, so you should know, what you are doing :grinning: .
        • G
          G
          Gabriele Cirillo
          sorry for tag! :)
          this is pratically the code of your link... with some adjustement of my pin configuration... but the output remain LOW...
          i know that is not simply :P
            sorry for tag! :)
            rejoe2R
            rejoe2R
            rejoe2
            @gabriele-cirillo Sorry, but the one you posted may be the sketch of the first post in the linked thread, but my link (at least on my computer here ;-) ) leads to a very different sketch using arrays for assinging PINs and buttons. See post #33 by @korttoma in the linked thread.
            • G
              G
              Gabriele Cirillo
              uh ok, sorry, i use the first, your right!
              now... i have tried this, but always unsuccesfully (i just change the pin)
              #define SN "RelayButtonArray"
              #define SV "1.0"
              #define RELAY_ON 0                      // switch around for ACTIVE LOW / ACTIVE HIGH relay
              #define RELAY_OFF 1
              #define noRelays 4                     //2-4
              const int relayPin[] = {30, 31, 32, 33};       //  switch around pins to your desire
              const int buttonPin[] = {28, 29, 27, 26};   //  switch around pins to your desire
              class Relay             // relay class, store all relevant data (equivalent to struct)
                public:
                  int buttonPin;                   // physical pin number of button
                  int relayPin;             // physical pin number of relay
                  boolean relayState;               // relay status (also stored in EEPROM)
              Relay Relays[noRelays];
              Bounce debouncer[noRelays];
              MyMessage msg[noRelays];
                void before() {
                  pinMode(pin, OUTPUT);
                wait(100);
                for (int i = 0; i < noRelays; i++) {
                  Relays[i].buttonPin = buttonPin[i];              // assign physical pins
                  msg[i].type = V_LIGHT;
                  wait(100);
                  Relays[i].relayState = loadState(i);                               // retrieve last values from EEPROM
                  digitalWrite(Relays[i].relayPin, Relays[i].relayState ? RELAY_ON : RELAY_OFF); // and set relays accordingly
                  send(msg[i].set(Relays[i].relayState ? true : false));                 // make controller aware of last status
                  wait(50);
                  debouncer[i].interval(30);
                  wait(50);
                sendSketchInfo(SN, SV);
                wait(100);
                  present(i, S_LIGHT);                               // present sensor to gateway
                wait(100);
                for (byte i = 0; i < noRelays; i++) {
                  if (debouncer[i].update()) {
                    if ( value == LOW) {
                      // save sensor state in EEPROM (location == sensor number)
                      saveState( i, Relays[i].relayState );
                //wait(20);
                  if (message.sensor < noRelays) {          // check if message is valid for relays..... previous line  [[[ if (message.sensor <=noRelays){ ]]]
                    digitalWrite(Relays[message.sensor].relayPin, Relays[message.sensor].relayState ? RELAY_ON : RELAY_OFF); // and set relays accordingly
                    saveState( message.sensor, Relays[message.sensor].relayState ); // save sensor state in EEPROM (location == sensor number)
                wait(20);
                #define SV "1.0"
                #define RELAY_OFF 1
                  public:
                  void before() {
                  wait(100);
                    wait(100);
                    wait(50);
                    wait(50);
                  wait(100);
                  wait(100);
                  //wait(20);
                  wait(20);
                rejoe2R
                rejoe2R
                rejoe2
                @gabriele-cirillo Can you please be a little more specific: What exactly is not working? What's the serial output?
                I have to admit, I never directly used @korttoma's sketch directly, but used the principles he applied to make own things happen. So if you want to dig into this a little more in depth, you may have a look at these here and here (the later not yet finisched, but button+relay-wise working).
                • G
                  G
                  Gabriele Cirillo
                  If i trigger the input pin, the output still to LOW
                  this is the serial code
                  TDI:TSL
                  T NODE,CP=RNNNA---,VER=2.2.0
                  25 TSM:INIT
                  26 TSF:WUR:MS=0
                  33 !TSM:INIT:TSP FAIL
                  35 TSM:FAIL:CNT=1
                  37 TSM:FAIL:DIS
                  38 TSF:TDI:TSL
                  &"⸮q_⸮⸮!⸮D⸮⸮⸮s⸮ ⸮⸮ED⸮⸮A
                  Et⸮EE⸮⸮AEň⸮1⸮⸮⸮
                  • rejoe2R
                    rejoe2R
                    rejoe2
                    OK, this is a different topic: as long as there is no uplink to the controller, your sketch will never enter loop() and so on.
                    Sounds like there is no radio module attached? Please see hints in troubleshooting, especially: log parser.
                    As a workaround you may get node starting without radio by using
                    #define MY_TRANSPORT_WAIT_READY_MS 3000
                    But some remark wrt applying fixes like that: It's kind of frustrating to discuss basic things when beeing asked for help on really advanced features. Imo, you might get some more basic examples to work first before starting projects like the one here.
                    Just my2ct...
                    G 1 Reply Last reply
                    • G
                      G
                      Gabriele Cirillo
                      you are right and sorry
                      But I search for a simply code for x input and for x relay asking the best method for the code...
                      now i start from 0 and try simply code! ty
                      • rejoe2R rejoe2
                        Just my2ct...
                        G
                        G
                        Gabriele Cirillo
                        @rejoe2 ok, i try with succesfully to make a sketch like my initial requests with array function :)
                        for you is so simply, but for me no! :p
                        all is ok, only a problem: at boot, at the first pression of one button (pin 27, 28 or 29) put high all 3 output... with another pression of button, all go ok... you see something that i can't see? :) ty
                        int buttPin[3] = {27,28,29};// you do not want to use digital pins 0 or 1
                        int relayPin[3] = {30,31,32};
                        int lastButtState[3];
                        int buttState[3];
                        int debounceDelay = 50;
                        int ledState[3];
                        int reading[3];
                        unsigned long lastDebounceTime[3];
                          for (int i = 0; i < 3; i++)
                            pinMode(relayPin[i], OUTPUT);
                            pinMode(buttPin[i], INPUT_PULLUP);
                            reading[i] = digitalRead(buttPin[i]);
                            if (reading[i] != lastButtState[i])
                              lastDebounceTime[i] = millis();
                              lastButtState[i] = reading[i];
                            if ((millis() - lastDebounceTime[i]) > debounceDelay) {
                               if (buttState[i] != lastButtState[i]) {
                                   buttState[i] = lastButtState[i];
                                   if (buttState[i] == HIGH) {
                                         ledState[i] = !ledState[i];
                                         digitalWrite(relayPin[i], ledState[i]);
                        • rejoe2R
                          rejoe2R
                          rejoe2
                          To me, these things are also quite close to magic, don't worry :smile: .
                          I don't know, what is going on at bootup, but my assumption wold be the PINs are somehow floating, as you didn't do some kind of initialisation in setup() or comparable.
                          Add. remark:
                          You also deleted the original debouncing function - that's possible, but as you seem to be quite good in adopting things (imo you made a big step forward). So you may review your code once more wrt that; could be the debouncer-function does a little more than just wait some time ;-) .
                          • rejoe2R rejoe2
                            Add. remark:
                            G
                            G
                            Gabriele Cirillo
                            @rejoe2 i use the pullup input and i try in setup to write relayPin to LOW, to put LOW the variable but with no success...
                            ps: i deleted what??!?!? :P
                              rejoe2R
                              rejoe2R
                              rejoe2
                              @gabriele-cirillo said in More relay and push botton:
                              Your code was to some extend very close to @korttoma's. So I thougt you started with a "cleaner" version ot this base and let out some parts - especially things related to
                              • G
                                G
                                Gabriele Cirillo
                                ahhhhh! no, I start from 0 with an example found on the web, the @korttoma sketch is too complicated for me :P
