  3. Minimal design thoughts
299 Posts 34 Posters 276.4k Views 17 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    #93
    @ServiceXp
    In the "lab" at the moment, testing the first prototype build.. I got the humidity / temperature "bug" sorted out. Replaced the Si7021 chip on my board, and the new one responded as expected, at least with correct temperature. (humidity is a bit off, I think.. I don't have another humidity sensor at hand here in the lab, so can't compare it..)
    I also got the radio up. I haven't done any distance measurements yet, but I can reach the gw in the main building (6-7m away throug a couple of brick walls). Added a 2.2uF cap to the radio. It's still running off the bench power supply. I don't see any problems at the atmel side of things when radio is transmitting.
    I just made a test, supplying the setup with 1.9V, and the GW still received the temperature updates :) (somehow my humidity readings don't get through to pidome on the GW, so have to check my setsup again).
    I'm waiting for a peer review of the pcb layout, before I push the button for the next batch of proto pcb's. btw. on the next prototype build, I have removed the bmp180, but exposed the SDA/SCL pins on a connector, so it can be attached externally..
    And here is a small preview of the upcomming board prototype.. I had to make the board 1.5mm wider, to make it fit a multiple of 0.1mil between the pinheaders on each side of the pcb. So it will be more versatile to other people as well.. (if any one should want to build them)
    • tbowmoT
      tbowmoT
      tbowmo
      small update again
      Did a small rangetest, and it seems that the range is equal to my other sensor (based on arduino mini and batteries). Also moved the node to the main builidng, besides the weatherstation that I got for christmas (which have hygrometer buildin). It seems that the humidity level on both my sensor node, and the weatherstation is almost comparable.
      RJ_MakeR 1 Reply Last reply
      • tbowmoT tbowmo
        small update again
        RJ_MakeR
        RJ_MakeR
        RJ_Make
        @tbowmo That is great news! Did you have any thoughts/plans on packaging these up for DIY kit sales? Did you have a chance to test the EEPROM?
        Thanks for the Update!
        RJ_Make
        • tbowmoT
          tbowmoT
          tbowmo
          @ServiceXp
          Haven't tested the eeprom yet, as I don't have any use for it right now. And also need to verify the 32khz crystal oscillator (currently running on the internal rc oscillator). Come to think about it, I need to think up some scenarios where the crystal could come in handy.
          Investigations are undergoing, to make something for the "public". Can't say anymore at the moment :)
          • tbowmoT tbowmo
            @ServiceXp
            RJ_MakeR
            RJ_MakeR
            RJ_Make
            @tbowmo Gotcha, thanks again for all your hard work, for those of us who simply don't have the skill set to create a good pcb, I really appreciate your work.
            I'm looking forward to your other MySensors pcb projects... ;-)
            RJ_Make
            • tbowmoT
              tbowmoT
              tbowmo
              And sensor #2 is build.. This time the radio module is soldered directly to the sensor module, making it a realy small device now..
              • tbowmoT
                tbowmoT
                tbowmo
                #99
                hmm.. Now I've had the two sensors on the table beside each other (sensor #1 and #2).
                Temperature is off by 1.6 degrees celcius, and humidity 2% difference. Could be it's the different temperature, that makes the RH calculation differ a bit..
                And for some build data.. It took me a good hour to populate all the parts. This one also have the additional eeprom mounted. but still need something for verifying that it works..
                RJ_MakeR 2 Replies Last reply
                • tbowmoT tbowmo
                  RJ_MakeR
                  RJ_MakeR
                  RJ_Make
                  @tbowmo what is the margin of error for the sensors?
                  RJ_Make
                  • tbowmoT tbowmo
                    RJ_MakeR
                    RJ_MakeR
                    RJ_Make
                    @tbowmo Oh and is that an hour using hand soldering?
                    RJ_Make
                    • tbowmoT
                      tbowmoT
                      tbowmo
                      #102
                      @ServiceXp
                      according to the datasheet the precision on temperature is +/- 0.4 degrees celcius, and +/- 3% RH.
                      They did however release a new chip revision (Si7021-A20) just after I bought mine (which is A10), they had some problems where the chip didn't enter standby correctly. Maybe that is the problem (also battery drain has been quicker than what I expected on the new node)
                      and yes, it's about an hour handsoldering things, and also programming the sensor, which also caused some troubles. Had to reprogram a lot of times, because of checksum errors. This could be caused by the fact that I have both eeprom, and nrf24l chip hanging on the SPI bus on the atmega, this is the same bus that is used by my ISP programmer (jtag ice3).
                      Think I have to get a proper bootloader into the device, so I can use the serialport to download instead.
                      • tbowmoT
                        tbowmoT
                        tbowmo
                        and now the external SPI flash is verified as working, just with a simple program, reading out the manufacturer ID, and writing / reading data to/from the device.
                        Next step I wanted to get a bootloader working, so I could use standard arduino to download firmware, and also (at some point in time) utilize the flash for OTA updates. However, I can't seem to get bootloader support working..
                        I have tried to get DualOptiboot from lowpowerlabs working now, with several rebuilds etc., it seems like it is running fine (LED is blinking a couple of times, when it boots) but arduino wont sync to the bootloader, so either it runs on a wrong baudrate, or something else is wrong in the setup. But so far I haven't suceeded in figuring out what it is..
                        (Anyone else that has some knowledge on bootloaders, that could have an idea to what to look at?)
                        / Thomas
                        B 1 Reply Last reply
                        • tbowmoT
                          tbowmoT
                          tbowmo
                          #104
                          I am almost ready for a second prototype spin of the PCB, but before doing that I could use some input from the community,
                          If this board was going into "mass production", is there any features that I should consider adding? Any missing parts? Anything that you think that I have forgotten?
                          The schematics for revision 2 is a couple of posts back in the thread.
                          I have considered adding a ATSHA204 for future security purposes, but can't seem to find a suitable spot for it (maybe I'm just too tired to see things clearly at the moment :)).
                          • tbowmoT tbowmo
                            / Thomas
                            B
                            B
                            boozz
                            @tbowmo
                            Does this link help you? Some explanation on bootloaders and practical stuff to help you burn botloaders on the ao Atmega326...
                            BR
                            Boozz
                            tbowmoT 1 Reply Last reply
                            • B boozz
                              @tbowmo
                              BR
                              Boozz
                              tbowmoT
                              tbowmoT
                              tbowmo
                              @boozz said:
                              @tbowmo
                              BR
                              Boozz
                              I can program a standard arduino bootloader, which works. I just want to use the one from lowpowerlabs, dual optiboot, so i can utilise the external Flash chip. But i Can't get it to work at all.
                              • tbowmoT tbowmo
                                @boozz said:
                                @tbowmo
                                BR
                                Boozz
                                B
                                B
                                boozz
                                @tbowmo
                                Ok, I misinterpreted your question. Can't help you on that one, sorry :-)
                                • tbowmoT tbowmo
                                  RJ_MakeR
                                  RJ_MakeR
                                  RJ_Make
                                  I would work on trying to get the ATSHA204 included, even if it means the dims get a little larger. The one thing that I really don't like about MySensors is the lack of any wireless security.. Would love to see this implemented.
                                  RJ_Make
                                  • tbowmoT tbowmo
                                    R
                                    R
                                    rdevine
                                    @tbowmo Maybe i missed it but do you have an image with the si7021 attached to the radio and pcb?
                                    • R rdevine
                                      tbowmoT
                                      tbowmoT
                                      tbowmo
                                      Look in post #93 the small white dot on the pcb is the si7021 :)
                                      • RJ_MakeR RJ_Make
                                        tbowmoT
                                        tbowmoT
                                        tbowmo
                                        For one second, I thought you where danish :), as the word "dims" usually refers to a small gadget like device, that you don't have a name for at the moment (or even components, screws, bolts, anything small could be a "dims") :)
                                        • T
                                          Tibus
                                          @tbowmo said:
                                          ATSHA204
                                          This module is verry interesting but how it work? What you have to do in code to make it work, crypting messages,...?
