  3. Using a sensor to sense the presence of copper wire.
44 Posts 11 Posters 9.8k Views 9 Watching
  • ? A Former User
    Please see attached image:
    SchlogS
    SchlogS
    Schlog
    @moparjay
    How about a pressure switch .
    I must be missing something here, what is the end point ?
      A Former User
      If you are referring to a pressure switch for the wire to apply the pressure, the wire will be as small as a human hair. Not capable of applying pressure.
      B 1 Reply Last reply
      • ? A Former User
        B
        B
        boozz
        @moparjay
        have you thought about using a jfet?
        see here for a google search
        ? 1 Reply Last reply
        • dbemowskD
          dbemowskD
          What about something like this:
          https://www.keyence.com/products/sensor/proximity/ta/models/th-305/index.jsp
            It looks interesting, but I haven't seen if it may work with copper too
            • B boozz
              @moparjay
              A Former User
              Thanks for the info. But I'm fine with the simplicity of a momentary, if full-automation-clamping is too difficult...or expensive. LOL
              SchlogS 1 Reply Last reply
              • ? A Former User
                SchlogS
                SchlogS
                Schlog
                @moparjay
                what about when sliding the wire into the top hole you give it a + charge and the base a - charge with a circuit that will do when the 2 touch.
                • SchlogS Schlog
                  @moparjay
                  A Former User
                  If the range of wire size was tighter, this would probably work well. But with the wide range of sizes, trying to make contact with the smallest sizes would be a real pain.
                  • ? A Former User
                    SchlogS
                    SchlogS
                    Schlog
                    @moparjay
                    how about an "S" shape input tube any size would have to touch the tube on the inside the "S" shape tube can be any size you like.
                    • E
                      E
                      executivul
                      1. Optical detection: a light source on one side of the hole and a phototransistor on the other, read as analog values since the small wires won't completely cover the light source
                      2. Inductive sensor, a coil around the hole, and some form of detecting the change of inductance, start by making a small coil and test with a LCR meter
                      3. Capacitive sensor, open air dielectric, plates across the hole, the wire and operator (even holding the insulated wire) will change the capacitor response a lot, test with some capacitive/touch sensing circuitry.
                        A Former User
                        Thanks to all that have given input. I'm going to give in and simply use the momentary to open the cylinder (normally closed). It's just too easy. And going automated is not worth the added expense, as this single cylinder prototype will be duplicated to almost (100) cylinders....each completely independent from one another. Thank you!!!
