  2. Announcements
  • O
    O
    otto001
    wrote on last edited by otto001
    #851
    Yesterday I cloned the latest version on a recent raspbian (9.3) and I applied the first patch of @marceloaqno .
    Cheers,
    Otto
      • R
        R
        romeo01
        How can I monitor the traffic data between the raspberry and RF module (NRF24L01) on a Ethernet gateway ??
        • R romeo01
          @romeo01 see instructions at https://www.mysensors.org/build/raspberry#troubleshooting
          R 1 Reply Last reply
          • M marceloaqno
              No LSB modules are available.
              Distributor ID: Raspbian
              Release:        9.1
              Codename:       stretch
              persistence true
              allow_anonymous false
            mysgw: Starting gateway...
            mysgw: Protocol version - 2.2.0
            mysgw: TSF:LRT:OK
            mysgw: TSM:INIT
            mysgw: TSF:WUR:MS=0
            mysgw: TSM:INIT:TSP OK
            mysgw: TSM:INIT:GW MODE
            mysgw: MCO:REG:NOT NEEDED
            mysgw: MCO:BGN:STP
            mysgw: MCO:BGN:INIT OK,TSP=1
            mysgw: GWT:RMQ:MQTT RECONNECT
            mysgw: connected to 127.0.0.1
            mysgw: GWT:RMQ:MQTT CONNECTED
            mysgw: GWT:TPS:TOPIC=mysensors-out/0/255/0/0/18,MSG SENT
            MasMatM
            MasMatM
            MasMat
            wrote on last edited by MasMat
            #855
            @marceloaqno What does your mosquitto.log show?
            So is this normal?
            • O
              O
              otto001
              #856
              @MasMat : what does your mysgw.log show?
              MasMatM 1 Reply Last reply
                R
                R
                romeo01
                @mfalkvidd Thanks fer info, now I can see the serial protocol as well in the syslog. Next step should be to have a logfile dedicated to mysgw.
                • O otto001
                  MasMatM
                  MasMatM
                  MasMat
                  @otto001
                  Syslog:
                  Mar 21 20:06:05 DietPi systemd[1]: Started MySensors Gateway daemon.
                  Mar 21 20:06:05 DietPi mysgw: Starting gateway...
                  Mar 21 20:06:05 DietPi mysgw: Protocol version - 2.2.0
                  Mar 21 20:06:05 DietPi mysgw: MCO:BGN:INIT GW,CP=RNNGL---,VER=2.2.0
                  Mar 21 20:06:05 DietPi mysgw: TSF:LRT:OK
                  Mar 21 20:06:05 DietPi mysgw: TSM:INIT
                  Mar 21 20:06:05 DietPi mysgw: TSF:WUR:MS=0
                  Mar 21 20:06:05 DietPi mysgw: TSM:INIT:TSP OK
                  Mar 21 20:06:05 DietPi mysgw: TSM:INIT:GW MODE
                  Mar 21 20:06:05 DietPi mysgw: TSM:READY:ID=0,PAR=0,DIS=0
                  Mar 21 20:06:05 DietPi mysgw: MCO:REG:NOT NEEDED
                  Mar 21 20:06:05 DietPi mysgw: MCO:BGN:STP
                  Mar 21 20:06:05 DietPi mysgw: MCO:BGN:INIT OK,TSP=1
                  Mar 21 20:06:05 DietPi mysgw: GWT:RMQ:MQTT RECONNECT
                  Mar 21 20:06:05 DietPi mysgw: connected to 127.0.0.1
                  Mar 21 20:06:05 DietPi mysgw: GWT:RMQ:MQTT CONNECTED
                  Mar 21 20:06:05 DietPi mysgw: GWT:TPS:TOPIC=mysensors-out/0/255/0/0/18,MSG SENT
                  Where is mysgw.log?
                  • O
                    O
                    otto001
                    @MasMat : I just forgot, that I reconfigured rsyslogd to log mysgw to a different file. syslog is correct.
                    I do not use mqtt for mysensors yet, but the syslog seems good?
                    • Richard van der PlasR
                      Was pointed here from another post, having serious issues with high CPU utilization op the gateway, is there any workaround and the moment?
                      top:
                      asks: 157 total,   2 running, 155 sleeping,   0 stopped,   0 zombie
                      %Cpu(s):  2.5 us, 23.0 sy,  0.0 ni, 74.3 id,  0.1 wa,  0.0 hi,  0.0 si,  0.0 st
                      KiB Mem :   949580 total,   448732 free,   146912 used,   353936 buff/cache
                      KiB Swap:   102396 total,   102396 free,        0 used.   737656 avail Mem
                        337 root      20   0   20492   1060    932 R 100.0  0.1  28:54.55 mysgw
                       3947 pi        20   0    8248   3324   2736 R   1.6  0.4   0:00.82 top
                        447 homeass+  20   0  340112  63684   9916 S   1.0  6.7   3:28.71 hass
                          7 root      20   0       0      0      0 S   0.3  0.0   0:04.18 rcu_sched
                        767 root      20   0  126572   8628   6544 S   0.3  0.9   0:00.95 piplight-daemon
                      PRETTY_NAME="Raspbian GNU/Linux 9 (stretch)"
                      NAME="Raspbian GNU/Linux"
                      VERSION_ID="9"
                      VERSION="9 (stretch)"
                      Linux raspberrypi 4.9.59-v7+ #1047 SMP Sun Oct 29 12:19:23 GMT 2017 armv7l GNU/Linux
                      Rebooting the pi sometimes helps, sometimes freezes the pi
                      seeing nothing strange in the mysensors log what so ever
                      running MySensors Version 2.2.0
                      and Home Assistant Version 0.64.0
                      Anyone can point me in the direction where to troubleshoot this further ?
                      its not a high traffic gateway (around 10 sensors connected of which 5 updating every 15 minutes)
                      • Richard van der PlasR Richard van der Plas
                        top:
                        VERSION_ID="9"
                        @richard-van-der-plas the best workaround so far is in the post I linked to.
                        • M mvader
                          @gohan said in 💬 Building a Raspberry Pi Gateway:
                          I'm not using mqtt.
                          marceloaqno
                          Code Contributor
                          @mvader The gateway will respond with an I_VERSION every time a controller connected to port 5003 sends an I_VERSION request.
                            marceloaqno
                            Code Contributor
                            @gohan Sorry to hear that, mysgw doesn't change any system files, a simple reboot and rebuild of the gateway should be enough to resume communication in a case of more serious error.
                            • MasMatM MasMat
                              So is this normal?
                              marceloaqno
                              Code Contributor
                              @masmat This is my mosquitto.log
                              1521680648: mosquitto version 1.4.10 (build date Fri, 22 Dec 2017 08:19:25 +0000) starting
                              1521680648: Config loaded from /etc/mosquitto/mosquitto.conf.
                              1521680648: Opening ipv4 listen socket on port 1883.
                              1521680648: Opening ipv6 listen socket on port 1883.
                              1521762617: Saving in-memory database to /var/lib/mosquitto/mosquitto.db.
                              1521763549: New connection from 127.0.0.1 on port 1883.
                              1521763549: New client connected from 127.0.0.1 as mygateway1 (c1, k15, u'rpi').
                              A socket error message:
                              1521764339: Socket error on client mygateway1, disconnecting.
                              shows only if I stop/exit mysgw.
                              • M marceloaqno
                                MasMatM
                                MasMatM
                                MasMat
                                @marceloaqno OK, I will look into that once I have an extra sensor feeding my gw (the one I built is a little complex and could be buggy).
                                Another question: I configured mysgw without "simple password" to sort out problems.
                                Now to reconfigure mysgw I have to run the "./configure --blah --blahblah..." command and "make", but do I also have to do "make install"? And do I have to re-start & enable the service? Should I stop it first also? Anybody got a step-by-step for this?
                                  You could also make a simple node running mock mysensors sketch that can simulate a working sensor, if you need some data running through the gateway. When I recompile the gateway I usually stop the service, uninstall the mysgw service and do the make and make install. I don't really know if it is actually required but I like to keep things clean
                                  M MasMatM 2 Replies Last reply
                                    marceloaqno
                                    Code Contributor
                                    The two patches to fix ethernet stability have been merger into the development branch, and also some changes to the gateway logging. I updated the build instructions to reflect the changes.
                                      MasMatM
                                      MasMatM
                                      MasMat
                                      #868
                                      @gohan I made a sensor that sends DHT11 temp+hum. This is the output (some of it..) from mosquitto_sub to topic mysensors-out. So I appear to have a something working. OpenHab2 is not finding any items still...
                                      pi@DietPi:~ $ mosquitto_sub  -u XXXXXX -P YYYYYY -v -t 'mysensors-out/#'
                                      mysensors-out/99/1/1/0/0 14.0
                                      mysensors-out/99/0/1/0/1 46.0
                                      mysensors-out/99/1/1/0/0 15.0
                                      mysensors-out/99/0/1/0/1 45.0
                                      mysensors-out/99/0/1/0/1 44.0
                                      Once I changed the config to include simple password, it's not showing anything anymore in mosquitto_sub
                                      It would appear that something is missing from my setup or there's a bug in the configure-line. Can someone tell if there's a bug here somewhere:
                                      sudo ./configure --my-transport=nrf24 --my-rf24-irq-pin=15 --my-signing=password --my-signing-password=ZZZZZZ --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-user=XXXXXX --my-mqtt-password=YYYYYY --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1 --my-leds-err-pin=12 --my-leds-rx-pin=16 --my-leds-tx-pin=18
                                        Look also in node log, that's the first place to look at
                                          MasMatM
                                          MasMatM
                                          MasMat
                                          #870
                                          @gohan I did, I will post it (but it appears to send normally). But the only things I changed was:
                                          1. Rpi configure added: --my-signing=password --my-signing-password=ZZZZZZ
                                          2. In the nodes code: #define MY_SIGNING_SIMPLE_PASSWD = "ZZZZZZ"
                                          AnticimexA 1 Reply Last reply
