  2. Announcements
  • O
    O
    otto001
    wrote on last edited by otto001
    #840
    @marceloaqno :
    Still the gw stops receiving, but without high cpu usage :-(
    Fortunately I can restart the gw now using a button and this udp-scripts :-)
    cheers,
    Otto
      MasMatM
      MasMatM
      MasMat
      wrote on last edited by MasMat
      #841
      @gohan I had another sd card and tried a ready image of DietPi with Mosquitto pre-installed.
      ..keeps repeating...
      ...and sudo ./bin/mysgw -d:
      mysgw: Starting gateway...
      mysgw: Protocol version - 2.2.0
      mysgw: MCO:BGN:INIT GW,CP=RNNGLSQX,VER=2.2.0
      mysgw: TSF:LRT:OK
      mysgw: TSM:INIT
      mysgw: TSF:WUR:MS=0
      mysgw: TSM:INIT:TSP OK
      mysgw: TSM:INIT:GW MODE
      mysgw: MCO:REG:NOT NEEDED
      mysgw: MCO:BGN:STP
      mysgw: MCO:BGN:INIT OK,TSP=1
      mysgw: GWT:RMQ:MQTT RECONNECT
      mysgw: connected to 127.0.0.1
      gohanG 1 Reply Last reply
        mvader
        1st patch is still working good for me. have had no issues since applying it.
        • MasMatM MasMat
          mysgw: TSF:LRT:OK
          mysgw: TSM:INIT
          mysgw: TSF:WUR:MS=0
          mysgw: MCO:BGN:STP
          MasMatM M 2 Replies Last reply
            MasMatM
            MasMatM
            MasMat
            @gohan How would I interface the rest of my HA without MQTT...that's at the center of my plan really :(
              MasMatM 1 Reply Last reply
                MasMatM
                MasMatM
                MasMat
                @gohan I configured:
                ./bin/mysgw -d:
                mysgw: TSF:LRT:OK
                mysgw: TSM:INIT
                mysgw: TSF:WUR:MS=0
                mysgw: failed to connect
                mysgw: GWT:TIN:ETH OK
                mysgw: GWT:TPS:ETH OK
                  • MasMatM MasMat
                    ./bin/mysgw -d:
                    mysgw: TSF:LRT:OK
                    mysgw: TSM:INIT
                    mysgw: TSF:WUR:MS=0
                    marceloaqno
                    Code Contributor
                    wrote on last edited by marceloaqno
                    #848
                      No LSB modules are available.
                      Distributor ID: Raspbian
                      Release:        9.1
                      Codename:       stretch
                      persistence true
                      allow_anonymous false
                    mysgw: TSF:LRT:OK
                    mysgw: TSM:INIT
                    mysgw: TSF:WUR:MS=0
                    mysgw: MCO:BGN:STP
                    mysgw: GWT:RMQ:MQTT CONNECTED
                    mysgw: GWT:TPS:TOPIC=mysensors-out/0/255/0/0/18,MSG SENT
                      mvader
                      @gohan said in 💬 Building a Raspberry Pi Gateway:
                      I'm not using mqtt.
                      gohanG M 2 Replies Last reply
                      • M mvader
                        I'm not using mqtt.
                        • O
                          O
                          otto001
                          #851
                          Yesterday I cloned the latest version on a recent raspbian (9.3) and I applied the first patch of @marceloaqno .
                          Cheers,
                          Otto
                            • R
                              R
                              romeo01
                              How can I monitor the traffic data between the raspberry and RF module (NRF24L01) on a Ethernet gateway ??
                              • R romeo01
                                @romeo01 see instructions at https://www.mysensors.org/build/raspberry#troubleshooting
                                R 1 Reply Last reply
                                • M marceloaqno
                                    Release:        9.1
                                    Codename:       stretch
                                    persistence true
                                  mysgw: TSF:LRT:OK
                                  mysgw: TSM:INIT
                                  mysgw: TSF:WUR:MS=0
                                  mysgw: MCO:BGN:STP
                                  MasMatM
                                  MasMatM
                                  MasMat
                                  #855
                                  @marceloaqno What does your mosquitto.log show?
                                  So is this normal?
                                  • O
                                    O
                                    otto001
                                    #856
                                    @MasMat : what does your mysgw.log show?
                                      R
                                      R
                                      romeo01
                                      @mfalkvidd Thanks fer info, now I can see the serial protocol as well in the syslog. Next step should be to have a logfile dedicated to mysgw.
                                      • O otto001
                                        MasMatM
                                        MasMatM
                                        MasMat
                                        @otto001
                                        Syslog:
                                        Mar 21 20:06:05 DietPi systemd[1]: Started MySensors Gateway daemon.
                                        Mar 21 20:06:05 DietPi mysgw: Starting gateway...
                                        Mar 21 20:06:05 DietPi mysgw: Protocol version - 2.2.0
                                        Mar 21 20:06:05 DietPi mysgw: MCO:BGN:INIT GW,CP=RNNGL---,VER=2.2.0
                                        Mar 21 20:06:05 DietPi mysgw: TSF:LRT:OK
                                        Mar 21 20:06:05 DietPi mysgw: TSM:INIT
                                        Mar 21 20:06:05 DietPi mysgw: TSF:WUR:MS=0
                                        Mar 21 20:06:05 DietPi mysgw: TSM:INIT:TSP OK
                                        Mar 21 20:06:05 DietPi mysgw: TSM:INIT:GW MODE
                                        Mar 21 20:06:05 DietPi mysgw: TSM:READY:ID=0,PAR=0,DIS=0
                                        Mar 21 20:06:05 DietPi mysgw: MCO:REG:NOT NEEDED
                                        Mar 21 20:06:05 DietPi mysgw: MCO:BGN:STP
                                        Mar 21 20:06:05 DietPi mysgw: MCO:BGN:INIT OK,TSP=1
                                        Mar 21 20:06:05 DietPi mysgw: GWT:RMQ:MQTT RECONNECT
                                        Mar 21 20:06:05 DietPi mysgw: connected to 127.0.0.1
                                        Mar 21 20:06:05 DietPi mysgw: GWT:RMQ:MQTT CONNECTED
                                        Mar 21 20:06:05 DietPi mysgw: GWT:TPS:TOPIC=mysensors-out/0/255/0/0/18,MSG SENT
                                        Where is mysgw.log?
                                        • O
                                          O
                                          otto001
                                          @MasMat : I just forgot, that I reconfigured rsyslogd to log mysgw to a different file. syslog is correct.
                                          I do not use mqtt for mysensors yet, but the syslog seems good?
