  3. Battery percentage on door contact sensor erratic (sent on interrupt)
20 Posts 5 Posters 4.0k Views 4 Watching
  • G Offline
    G Offline
    GreyLinux
    Ok so I have 3 Temp sensors that display battery percentage pretty well and sleep for 5 minutes between reads.
    Now through research on the forum I have put together a sketch for a door sensor that sleeps until interrupted and sends the battery percentage .
    The problem I have is that the battery percentage varies with every read this is the serial monitor read:
    3430 TSF:TDI:TSL
    3432 MCO:SLP:WUP=-1
    3436 TSF:TRI:TSB
    3436 MCO:SLP:MS=0,SMS=0,I1=1,M1=1,I2=255,M2=255
    3442 TSF:TDI:TSL
    3444 MCO:SLP:WUP=1
    3446 TSF:TRI:TSB
    Sensor value: 832
    Battery Voltage: 2.68 V
    Battery percent: -2 %
    3452 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:254
    3463 TSF:MSG:SEND,4-4-0-0,s=3,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:1
    Tripped3471 MCO:SLP:MS=5,SMS=0,I1=255,M1=255,I2=255,M2=255
    3475 TSF:TDI:TSL
    3477 MCO:SLP:WUP=-1
    3479 TSF:TRI:TSB
    3481 MCO:SLP:MS=0,SMS=0,I1=1,M1=1,I2=255,M2=255
    3487 TSF:TDI:TSL
    3489 MCO:SLP:WUP=1
    3491 TSF:TRI:TSB
    Sensor value: 953
    Battery Voltage: 3.07 V
    Battery percent: 62 %
    3497 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:62
    3508 TSF:MSG:SEND,4-4-0-0,s=3,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:0
    Tripped3514 MCO:SLP:MS=5,SMS=0,I1=255,M1=255,I2=255,M2=255
    3520 TSF:TDI:TSL
    3522 MCO:SLP:WUP=-1
    3524 TSF:TRI:TSB
    3526 MCO:SLP:MS=0,SMS=0,I1=1,M1=1,I2=255,M2=255
    3532 TSF:TDI:TSL
    3534 MCO:SLP:WUP=1
    3536 TSF:TRI:TSB
    Sensor value: 930
    Battery Voltage: 3.00 V
    Battery percent: 50 %
    3543 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:50
    3553 TSF:MSG:SEND,4-4-0-0,s=3,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:1
    Tripped3559 MCO:SLP:MS=5,SMS=0,I1=255,M1=255,I2=255,M2=255
    3565 TSF:TDI:TSL
    3567 MCO:SLP:WUP=-1
    3569 TSF:TRI:TSB
    3571 MCO:SLP:MS=0,SMS=0,I1=1,M1=1,I2=255,M2=255
    3575 TSF:TDI:TSL
    3577 MCO:SLP:WUP=1
    3579 TSF:TRI:TSB
    Sensor value: 854
    Battery Voltage: 2.75 V
    Battery percent: 9 %
    3586 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:9
    3596 TSF:MSG:SEND,4-4-0-0,s=3,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:0
    Tripped3604 MCO:SLP:MS=5,SMS=0,I1=255,M1=255,I2=255,M2=255```
    and this is the sketch;
     * Simple binary switch example
     * Connect button or door/window reed switch between
     * digitial I/O pin 3 (BUTTON_PIN below) and GND.
     * http://www.mysensors.org/build/binary
    #define MY_NODE_ID 4
    #define CHILD_ID 3
    #define BUTTON_PIN  3  // Arduino Digital I/O pin for button/reed switch
    #define SLEEP_TIME 0 // sleep forever
    // ------------------ BATTERY ------------------
    int oldBatteryPcnt = 0;  // remember last measured percentage
    #define V_MIN 2.7  // 0% Battery voltage
    #define V_MAX 3.3  // 100% Battery voltage
    byte oldSwitch_State = HIGH;
      // Setup the button
      pinMode(BUTTON_PIN,INPUT);
      // Activate internal pull-up
      // Setup 1.1 V internal reference for analoge GPIO
      analogReference(INTERNAL);
      present(CHILD_ID, S_DOOR);
      // read analog pin
      // calculate battery voltage
      float vBat  = static_cast<float>(sensorValue * (V_MAX/1023));
      // calculate % left of defined interval
      int batteryPcnt = static_cast<int>(((vBat-V_MIN)/(V_MAX-V_MIN))*100.);
      // debugging
      #ifdef MY_DEBUG
        Serial.print("Sensor value: ");
        Serial.println(sensorValue);
        Serial.print(vBat);
        Serial.println(" V");
        Serial.print(batteryPcnt);
        Serial.println(" %");
      // If battery % has change send to controller
        // Power up radio after sleep
        oldBatteryPcnt = batteryPcnt;
       byte switchState = digitalRead (BUTTON_PIN);
      if (switchState != oldSwitch_State) {
         // Send in the new value
         send(msg.set(switchState==LOW ? 1 : 0));
         oldSwitch_State = switchState;
         sleep(5);
     sleep(digitalPinToInterrupt(BUTTON_PIN), CHANGE, SLEEP_TIME);
    I have the resistors set up as described here
    with the addition of a 0.1uF cap over R2 (470KΩ) resistor
    is there a way to stabilize these readings ?
    Y 1 Reply Last reply
    • G GreyLinux
      3430 TSF:TDI:TSL
      3432 MCO:SLP:WUP=-1
      3436 TSF:TRI:TSB
      3442 TSF:TDI:TSL
      3444 MCO:SLP:WUP=1
      3446 TSF:TRI:TSB
      Sensor value: 832
      3475 TSF:TDI:TSL
      3477 MCO:SLP:WUP=-1
      3479 TSF:TRI:TSB
      3487 TSF:TDI:TSL
      3489 MCO:SLP:WUP=1
      3491 TSF:TRI:TSB
      Sensor value: 953
      3520 TSF:TDI:TSL
      3522 MCO:SLP:WUP=-1
      3524 TSF:TRI:TSB
      3532 TSF:TDI:TSL
      3534 MCO:SLP:WUP=1
      3536 TSF:TRI:TSB
      Sensor value: 930
      3565 TSF:TDI:TSL
      3567 MCO:SLP:WUP=-1
      3569 TSF:TRI:TSB
      3575 TSF:TDI:TSL
      3577 MCO:SLP:WUP=1
      3579 TSF:TRI:TSB
      Sensor value: 854
      #define CHILD_ID 3
        // Setup the button
        // read analog pin
        // debugging
        #ifdef MY_DEBUG
          Serial.print(vBat);
           sleep(5);
      Y Offline
      Y Offline
      @greymarvel what happens if you place a sleep of e.g. 100ms just before reading the analog value?
      Or write the analog reference every time just before the analog read?
      You could also use my Vcc library as a reference: https://github.com/Yveaux/Arduino_Vcc
      G 1 Reply Last reply
      • Y Yveaux
        G Offline
        G Offline
        GreyLinux
        @yveaux
        Ok so I added the analog reference into the loop and a delay(100);
        this has improved things the readings are less erratic but still not close enough .
        2328 MCO:SLP:WUP=-1
        2330 TSF:TRI:TSB
        2332 MCO:SLP:MS=0,SMS=0,I1=1,M1=1,I2=255,M2=255
        2336 TSF:TDI:TSL
        2338 MCO:SLP:WUP=1
        2340 TSF:TRI:TSB
        Sensor value: 876
        Battery Voltage: 2.83 V
        Battery percent: 20 %
        2447 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:20
        2457 TSF:MSG:SEND,4-4-0-0,s=3,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:0
        2465 MCO:SLP:MS=5,SMS=0,I1=255,M1=255,I2=255,M2=255
        2469 TSF:TDI:TSL
        2471 MCO:SLP:WUP=-1
        2476 TSF:TRI:TSB
        2476 MCO:SLP:MS=0,SMS=0,I1=1,M1=1,I2=255,M2=255
        2482 TSF:TDI:TSL
        2484 MCO:SLP:WUP=1
        2486 TSF:TRI:TSB
        Sensor value: 874
        Battery Voltage: 2.82 V
        Battery percent: 19 %
        2594 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:19
        2603 TSF:MSG:SEND,4-4-0-0,s=3,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:1
        2611 MCO:SLP:MS=5,SMS=0,I1=255,M1=255,I2=255,M2=255
        2617 TSF:TDI:TSL
        2619 MCO:SLP:WUP=-1
        2621 TSF:TRI:TSB
        2623 MCO:SLP:MS=0,SMS=0,I1=1,M1=1,I2=255,M2=255
        2627 TSF:TDI:TSL
        2629 MCO:SLP:WUP=1
        2631 TSF:TRI:TSB
        Sensor value: 854
        2738 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:9
        2748 TSF:MSG:SEND,4-4-0-0,s=3,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:0
        2754 MCO:SLP:MS=5,SMS=0,I1=255,M1=255,I2=255,M2=255
        2760 TSF:TDI:TSL
        2762 MCO:SLP:WUP=-1
        2764 TSF:TRI:TSB
        2766 MCO:SLP:MS=0,SMS=0,I1=1,M1=1,I2=255,M2=255
        2772 TSF:TDI:TSL
        2775 MCO:SLP:WUP=1
        2777 TSF:TRI:TSB
        Sensor value: 853
        Battery percent: 8 %
        2883 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:8
        2891 TSF:MSG:SEND,4-4-0-0,s=3,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:1
        2899 MCO:SLP:MS=5,SMS=0,I1=255,M1=255,I2=255,M2=255
        2906 TSF:TDI:TSL
        2908 MCO:SLP:WUP=-1
        2910 TSF:TRI:TSB
        2912 MCO:SLP:MS=0,SMS=0,I1=1,M1=1,I2=255,M2=255
        2916 TSF:TDI:TSL
        2918 MCO:SLP:WUP=1
        2920 TSF:TRI:TSB
        Sensor value: 852
        3026 TSF:MSG:SEND,4-4-0-0,s=3,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:0
        3035 MCO:SLP:MS=5,SMS=0,I1=255,M1=255,I2=255,M2=255
        3041 TSF:TDI:TSL
        3043 MCO:SLP:WUP=-1
        3045 TSF:TRI:TSB
        3047 MCO:SLP:MS=0,SMS=0,I1=1,M1=1,I2=255,M2=255
        3051 TSF:TDI:TSL
        3053 MCO:SLP:WUP=1
        3055 TSF:TRI:TSB
        Sensor value: 873
        3162 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:19
        3172 TSF:MSG:SEND,4-4-0-0,s=3,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:1
        3178 MCO:SLP:MS=5,SMS=0,I1=255,M1=255,I2=255,M2=255
        3184 TSF:TDI:TSL
        3186 MCO:SLP:WUP=-1
        3188 TSF:TRI:TSB
        3190 MCO:SLP:MS=0,SMS=0,I1=1,M1=1,I2=255,M2=255
        3196 TSF:TDI:TSL
        3196 MCO:SLP:WUP=1
        3201 TSF:TRI:TSB
        Sensor value: 885
        Battery Voltage: 2.85 V
        Battery percent: 25 %
        3307 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:25
        3315 TSF:MSG:SEND,4-4-0-0,s=3,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:0
        3323 MCO:SLP:MS=5,SMS=0,I1=255,M1=255,I2=255,M2=255
        3330 TSF:TDI:TSL
        3332 MCO:SLP:WUP=-1
        3334 TSF:TRI:TSB
        3336 MCO:SLP:MS=0,SMS=0,I1=1,M1=1,I2=255,M2=255
        3340 TSF:TDI:TSL
        3342 MCO:SLP:WUP=1
        3344 TSF:TRI:TSB
        Sensor value: 872
        Battery Voltage: 2.81 V
        Battery percent: 18 %
        3450 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:18
        3461 TSF:MSG:SEND,4-4-0-0,s=3,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:1
        3467 MCO:SLP:MS=5,SMS=0,I1=255,M1=255,I2=255,M2=255
        3473 TSF:TDI:TSL
        3475 MCO:SLP:WUP=-1
        3477 TSF:TRI:TSB
        3479 MCO:SLP:MS=0,SMS=0,I1=1,M1=1,I2=255,M2=255
        3485 TSF:TDI:TSL
        3487 MCO:SLP:WUP=1
        3489 TSF:TRI:TSB
        Sensor value: 869
        Battery Voltage: 2.80 V
        Battery percent: 17 %
        3596 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:17
        3604 TSF:MSG:SEND,4-4-0-0,s=3,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:0
        3612 MCO:SLP:MS=5,SMS=0,I1=255,M1=255,I2=255,M2=255
        3618 TSF:TDI:TSL
        3620 MCO:SLP:WUP=-1
        3622 TSF:TRI:TSB
        3624 MCO:SLP:MS=0,SMS=0,I1=1,M1=1,I2=255,M2=255
        3629 TSF:TDI:TSL
        3631 MCO:SLP:WUP=1
        3633 TSF:TRI:TSB```
        • G GreyLinux
          @yveaux
          2328 MCO:SLP:WUP=-1
          2330 TSF:TRI:TSB
          2336 TSF:TDI:TSL
          2338 MCO:SLP:WUP=1
          2340 TSF:TRI:TSB
          Sensor value: 876
          2469 TSF:TDI:TSL
          2471 MCO:SLP:WUP=-1
          2476 TSF:TRI:TSB
          2482 TSF:TDI:TSL
          2484 MCO:SLP:WUP=1
          2486 TSF:TRI:TSB
          Sensor value: 874
          2617 TSF:TDI:TSL
          2619 MCO:SLP:WUP=-1
          2621 TSF:TRI:TSB
          2627 TSF:TDI:TSL
          2629 MCO:SLP:WUP=1
          2631 TSF:TRI:TSB
          Sensor value: 854
          2760 TSF:TDI:TSL
          2762 MCO:SLP:WUP=-1
          2764 TSF:TRI:TSB
          2772 TSF:TDI:TSL
          2775 MCO:SLP:WUP=1
          2777 TSF:TRI:TSB
          Sensor value: 853
          2906 TSF:TDI:TSL
          2908 MCO:SLP:WUP=-1
          2910 TSF:TRI:TSB
          2916 TSF:TDI:TSL
          2918 MCO:SLP:WUP=1
          2920 TSF:TRI:TSB
          Sensor value: 852
          3041 TSF:TDI:TSL
          3043 MCO:SLP:WUP=-1
          3045 TSF:TRI:TSB
          3051 TSF:TDI:TSL
          3053 MCO:SLP:WUP=1
          3055 TSF:TRI:TSB
          Sensor value: 873
          3184 TSF:TDI:TSL
          3186 MCO:SLP:WUP=-1
          3188 TSF:TRI:TSB
          3196 TSF:TDI:TSL
          3196 MCO:SLP:WUP=1
          3201 TSF:TRI:TSB
          Sensor value: 885
          3330 TSF:TDI:TSL
          3332 MCO:SLP:WUP=-1
          3334 TSF:TRI:TSB
          3340 TSF:TDI:TSL
          3342 MCO:SLP:WUP=1
          3344 TSF:TRI:TSB
          Sensor value: 872
          3473 TSF:TDI:TSL
          3475 MCO:SLP:WUP=-1
          3477 TSF:TRI:TSB
          3485 TSF:TDI:TSL
          3487 MCO:SLP:WUP=1
          3489 TSF:TRI:TSB
          Sensor value: 869
          3618 TSF:TDI:TSL
          3620 MCO:SLP:WUP=-1
          3622 TSF:TRI:TSB
          3629 TSF:TDI:TSL
          3631 MCO:SLP:WUP=1
          3633 TSF:TRI:TSB```
          Y Offline
          Y Offline
          @greymarvel well, the internal reference isn't very accurate, so that might be the cause of the variation.
          You could also average a number of readings and only report values going down wrt to the previous readings.
            I am using the vcc library and also a voltage divider to read higher voltages than 3.3v and I make the average of the last 4 readings before sending the value and it has been working very well so far.
            • G Offline
              G Offline
              GreyLinux
              @gohan @Yveaux I think this might be the option to send in the average reading .To be fair this was opening the contact every couple of seconds and in reality this would be alot longer between reads . Thanks for your help.
              • rozpruwaczR Offline
                rozpruwaczR Offline
                rozpruwacz
                @greymarvel what kind of battery are You using ? The voltage on the battery may not be constant in short periods, it depends on the load and bettery internal resistance. The higher the internal resistance the bigger are voltage swings in response to load swings. I have two identical boards, differing only in the batery holder, one is for cr2032 (higher internal resistance) and the other is for cr123 (lower internal resistance). These boards have exactyl the same circuit and software, the only difference is the battery type. And the one with cr2032 give me very unstable battery voltage readings while the other very is stable. So for sure it depends on the battery type and the current consumption at the moment of voltage probing.
                • rozpruwaczR rozpruwacz
                  G Offline
                  G Offline
                  GreyLinux
                  wrote on last edited by GreyLinux
                  @rozpruwacz I'm using 2 AA batteries . I think it might be worthwhile me using @Yveaux vcc library as a reference and see if that improves things. Also I think I might delay a little longer before the read to allow it to settle more after the contact interrupt .
                  • G GreyLinux
                    rozpruwaczR Offline
                    rozpruwaczR Offline
                    rozpruwacz
                    @greymarvel AA batteries should have much lower internal resistance, so I guess that voltage reading should be stable. Good luck finding the problem :)
                      try adding a little ceramic cap on vcc or near the analog pin you are reading from.
                        G Offline
                        G Offline
                        GreyLinux
                        This is how it looks I know it's a little messy but a little cap between the high impedance point and A0 will help ?
                          are you using a voltage divider on pin A0? if so, a small 0.1uF ceramic should do. If you are using a booster is your only option. In addition you can also consider using a single LiFePO4 battery and use the vcc library to get battery voltage
                            G Offline
                            G Offline
                            GreyLinux
                            @gohan yeah it's hard to see but the black wire behind all the radio wires goes to A0 from the divider. I'll put a little cap on this .
                              You may also consider some Easy Pcb you can find on openhardware.io that would make a much cleaner solution for your node
                              G 2 Replies Last reply
                                G Offline
                                G Offline
                                GreyLinux
                                @gohan yeah I have some on order. I'm just learning with what I've got till they come and the sensors I've made won't be seen so not a problem for the moment . Thanks again .
                                  G Offline
                                  G Offline
                                  GreyLinux
                                  @gohan well adding a cap from the impedance point to A0 has 100% stabilized my readings
                                  4630 MCO:SLP:WUP=-1
                                  4632 TSF:TRI:TSB
                                  4634 MCO:SLP:MS=0,SMS=0,I1=1,M1=1,I2=255,M2=255
                                  4638 TSF:TDI:TSL
                                  4640 MCO:SLP:WUP=1
                                  4642 TSF:TRI:TSB
                                  Sensor value: 862
                                  Battery Voltage: 2.78 V
                                  Battery percent: 13 %
                                  4751 TSF:MSG:SEND,4-4-0-0,s=3,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:0
                                  4759 MCO:SLP:MS=5,SMS=0,I1=255,M1=255,I2=255,M2=255
                                  4763 TSF:TDI:TSL
                                  4765 MCO:SLP:WUP=-1
                                  4767 TSF:TRI:TSB
                                  4769 MCO:SLP:MS=0,SMS=0,I1=1,M1=1,I2=255,M2=255
                                  4775 TSF:TDI:TSL
                                  4777 MCO:SLP:WUP=1
                                  4780 TSF:TRI:TSB
                                  Sensor value: 863
                                  4886 TSF:MSG:SEND,4-4-0-0,s=3,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:1
                                  4894 MCO:SLP:MS=5,SMS=0,I1=255,M1=255,I2=255,M2=255
                                  4898 TSF:TDI:TSL
                                  4900 MCO:SLP:WUP=-1
                                  4902 TSF:TRI:TSB
                                  4904 MCO:SLP:MS=0,SMS=0,I1=1,M1=1,I2=255,M2=255
                                  4911 TSF:TDI:TSL
                                  4913 MCO:SLP:WUP=1
                                  4915 TSF:TRI:TSB
                                  Sensor value: 862
                                  5021 TSF:MSG:SEND,4-4-0-0,s=3,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:0
                                  5029 MCO:SLP:MS=5,SMS=0,I1=255,M1=255,I2=255,M2=255
                                  5033 TSF:TDI:TSL
                                  5036 MCO:SLP:WUP=-1
                                  5038 TSF:TRI:TSB
                                  5040 MCO:SLP:MS=0,SMS=0,I1=1,M1=1,I2=255,M2=255
                                  5046 TSF:TDI:TSL
                                  5048 MCO:SLP:WUP=1
                                  5050 TSF:TRI:TSB
                                  Sensor value: 862
                                  5156 TSF:MSG:SEND,4-4-0-0,s=3,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:1
                                  5165 MCO:SLP:MS=5,SMS=0,I1=255,M1=255,I2=255,M2=255
                                  5169 TSF:TDI:TSL
                                  5171 MCO:SLP:WUP=-1
                                  5173 TSF:TRI:TSB
                                  5175 MCO:SLP:MS=0,SMS=0,I1=1,M1=1,I2=255,M2=255
                                  5181 TSF:TDI:TSL
                                  however a multi meter gives me 2.90v and the reading is 2.78v i understand it wont be 100% accurate but this far out is a little weird my other sensors are about 1 or 2 volts if that . any ideas?
                                  • G GreyLinux
                                    4630 MCO:SLP:WUP=-1
                                    4632 TSF:TRI:TSB
                                    4638 TSF:TDI:TSL
                                    4640 MCO:SLP:WUP=1
                                    4642 TSF:TRI:TSB
                                    Sensor value: 862
                                    4763 TSF:TDI:TSL
                                    4765 MCO:SLP:WUP=-1
                                    4767 TSF:TRI:TSB
                                    4775 TSF:TDI:TSL
                                    4777 MCO:SLP:WUP=1
                                    4780 TSF:TRI:TSB
                                    Sensor value: 863
                                    4898 TSF:TDI:TSL
                                    4900 MCO:SLP:WUP=-1
                                    4902 TSF:TRI:TSB
                                    4911 TSF:TDI:TSL
                                    4913 MCO:SLP:WUP=1
                                    4915 TSF:TRI:TSB
                                    Sensor value: 862
                                    5033 TSF:TDI:TSL
                                    5036 MCO:SLP:WUP=-1
                                    5038 TSF:TRI:TSB
                                    5046 TSF:TDI:TSL
                                    5048 MCO:SLP:WUP=1
                                    5050 TSF:TRI:TSB
                                    Sensor value: 862
                                    5169 TSF:TDI:TSL
                                    5171 MCO:SLP:WUP=-1
                                    5173 TSF:TRI:TSB
                                    5181 TSF:TDI:TSL
                                    rozpruwaczR Offline
                                    rozpruwaczR Offline
                                    rozpruwacz
                                    @greymarvel check the actual values of the resistors in voltage divider how far they are from the nominal values. Resistors have some tolerance so they are not exactly 1kOhm or whatever, this makes the division ratio different than You take into account calculating voltage from ADC reading.
                                      also the internal reference is not 100% accurate, so you can't have a multimeter precision. There is a battery measurement code that you can add some correction to it, look into the examples
                                      • G Offline
                                        G Offline
                                        GreyLinux
                                        @rozpruwacz I've checked the values and they don't seem to be that far from expected but as you say they definitely weren't the stated resistance . I think @gohan is right I will add the correction in the sketch and try and get it reasonably close. Thanks again everyone for your help .
                                        • B Offline
                                          B Offline
                                          BulldogLowell
                                          As the analog pins share a single A2D, rapid use of it can cause the previous read to impact the next. A common workaround in this situation is to read twice on each input, ignoring the first.
                                          try that:
                                          // read analog pin
                                            (void) analogRead(BATTERY_SENSE_PIN);
                                          12.2k
