  3. Battery percentage on door contact sensor erratic (sent on interrupt)
20 Posts 5 Posters 4.3k Views 4 Watching
    I am using the vcc library and also a voltage divider to read higher voltages than 3.3v and I make the average of the last 4 readings before sending the value and it has been working very well so far.
    • G
      G
      GreyLinux
      @gohan @Yveaux I think this might be the option to send in the average reading .To be fair this was opening the contact every couple of seconds and in reality this would be alot longer between reads . Thanks for your help.
      • rozpruwaczR
        rozpruwaczR
        rozpruwacz
        @greymarvel what kind of battery are You using ? The voltage on the battery may not be constant in short periods, it depends on the load and bettery internal resistance. The higher the internal resistance the bigger are voltage swings in response to load swings. I have two identical boards, differing only in the batery holder, one is for cr2032 (higher internal resistance) and the other is for cr123 (lower internal resistance). These boards have exactyl the same circuit and software, the only difference is the battery type. And the one with cr2032 give me very unstable battery voltage readings while the other very is stable. So for sure it depends on the battery type and the current consumption at the moment of voltage probing.
        G 1 Reply Last reply
        • rozpruwaczR rozpruwacz
          G
          G
          GreyLinux
          wrote on last edited by GreyLinux
          @rozpruwacz I'm using 2 AA batteries . I think it might be worthwhile me using @Yveaux vcc library as a reference and see if that improves things. Also I think I might delay a little longer before the read to allow it to settle more after the contact interrupt .
          • G GreyLinux
            rozpruwaczR
            rozpruwaczR
            rozpruwacz
            @greymarvel AA batteries should have much lower internal resistance, so I guess that voltage reading should be stable. Good luck finding the problem :)
              try adding a little ceramic cap on vcc or near the analog pin you are reading from.
                G
                G
                GreyLinux
                This is how it looks I know it's a little messy but a little cap between the high impedance point and A0 will help ?
                  are you using a voltage divider on pin A0? if so, a small 0.1uF ceramic should do. If you are using a booster is your only option. In addition you can also consider using a single LiFePO4 battery and use the vcc library to get battery voltage
                    G
                    G
                    GreyLinux
                    @gohan yeah it's hard to see but the black wire behind all the radio wires goes to A0 from the divider. I'll put a little cap on this .
                      You may also consider some Easy Pcb you can find on openhardware.io that would make a much cleaner solution for your node
                      G 2 Replies Last reply
                        G
                        G
                        GreyLinux
                        @gohan yeah I have some on order. I'm just learning with what I've got till they come and the sensors I've made won't be seen so not a problem for the moment . Thanks again .
                          G
                          G
                          GreyLinux
                          @gohan well adding a cap from the impedance point to A0 has 100% stabilized my readings
                          4630 MCO:SLP:WUP=-1
                          4632 TSF:TRI:TSB
                          4634 MCO:SLP:MS=0,SMS=0,I1=1,M1=1,I2=255,M2=255
                          4638 TSF:TDI:TSL
                          4640 MCO:SLP:WUP=1
                          4642 TSF:TRI:TSB
                          Sensor value: 862
                          Battery Voltage: 2.78 V
                          Battery percent: 13 %
                          4751 TSF:MSG:SEND,4-4-0-0,s=3,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:0
                          4759 MCO:SLP:MS=5,SMS=0,I1=255,M1=255,I2=255,M2=255
                          4763 TSF:TDI:TSL
                          4765 MCO:SLP:WUP=-1
                          4767 TSF:TRI:TSB
                          4769 MCO:SLP:MS=0,SMS=0,I1=1,M1=1,I2=255,M2=255
                          4775 TSF:TDI:TSL
                          4777 MCO:SLP:WUP=1
                          4780 TSF:TRI:TSB
                          Sensor value: 863
                          4886 TSF:MSG:SEND,4-4-0-0,s=3,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:1
                          4894 MCO:SLP:MS=5,SMS=0,I1=255,M1=255,I2=255,M2=255
                          4898 TSF:TDI:TSL
                          4900 MCO:SLP:WUP=-1
                          4902 TSF:TRI:TSB
                          4904 MCO:SLP:MS=0,SMS=0,I1=1,M1=1,I2=255,M2=255
                          4911 TSF:TDI:TSL
                          4913 MCO:SLP:WUP=1
                          4915 TSF:TRI:TSB
                          Sensor value: 862
                          5021 TSF:MSG:SEND,4-4-0-0,s=3,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:0
                          5029 MCO:SLP:MS=5,SMS=0,I1=255,M1=255,I2=255,M2=255
                          5033 TSF:TDI:TSL
                          5036 MCO:SLP:WUP=-1
                          5038 TSF:TRI:TSB
                          5040 MCO:SLP:MS=0,SMS=0,I1=1,M1=1,I2=255,M2=255
                          5046 TSF:TDI:TSL
                          5048 MCO:SLP:WUP=1
                          5050 TSF:TRI:TSB
                          Sensor value: 862
                          5156 TSF:MSG:SEND,4-4-0-0,s=3,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:1
                          5165 MCO:SLP:MS=5,SMS=0,I1=255,M1=255,I2=255,M2=255
                          5169 TSF:TDI:TSL
                          5171 MCO:SLP:WUP=-1
                          5173 TSF:TRI:TSB
                          5175 MCO:SLP:MS=0,SMS=0,I1=1,M1=1,I2=255,M2=255
                          5181 TSF:TDI:TSL
                          however a multi meter gives me 2.90v and the reading is 2.78v i understand it wont be 100% accurate but this far out is a little weird my other sensors are about 1 or 2 volts if that . any ideas?
                          • G GreyLinux
                            4630 MCO:SLP:WUP=-1
                            4632 TSF:TRI:TSB
                            4638 TSF:TDI:TSL
                            4640 MCO:SLP:WUP=1
                            4642 TSF:TRI:TSB
                            Sensor value: 862
                            4763 TSF:TDI:TSL
                            4765 MCO:SLP:WUP=-1
                            4767 TSF:TRI:TSB
                            4775 TSF:TDI:TSL
                            4777 MCO:SLP:WUP=1
                            4780 TSF:TRI:TSB
                            Sensor value: 863
                            4898 TSF:TDI:TSL
                            4900 MCO:SLP:WUP=-1
                            4902 TSF:TRI:TSB
                            4911 TSF:TDI:TSL
                            4913 MCO:SLP:WUP=1
                            4915 TSF:TRI:TSB
                            Sensor value: 862
                            5033 TSF:TDI:TSL
                            5036 MCO:SLP:WUP=-1
                            5038 TSF:TRI:TSB
                            5046 TSF:TDI:TSL
                            5048 MCO:SLP:WUP=1
                            5050 TSF:TRI:TSB
                            Sensor value: 862
                            5169 TSF:TDI:TSL
                            5171 MCO:SLP:WUP=-1
                            5173 TSF:TRI:TSB
                            5181 TSF:TDI:TSL
                            rozpruwaczR
                            rozpruwaczR
                            rozpruwacz
                            @greymarvel check the actual values of the resistors in voltage divider how far they are from the nominal values. Resistors have some tolerance so they are not exactly 1kOhm or whatever, this makes the division ratio different than You take into account calculating voltage from ADC reading.
                              also the internal reference is not 100% accurate, so you can't have a multimeter precision. There is a battery measurement code that you can add some correction to it, look into the examples
                              • G
                                G
                                GreyLinux
                                @rozpruwacz I've checked the values and they don't seem to be that far from expected but as you say they definitely weren't the stated resistance . I think @gohan is right I will add the correction in the sketch and try and get it reasonably close. Thanks again everyone for your help .
                                • BulldogLowellB
                                  BulldogLowellB
                                  BulldogLowell
                                  As the analog pins share a single A2D, rapid use of it can cause the previous read to impact the next. A common workaround in this situation is to read twice on each input, ignoring the first.
                                  try that:
                                  // read analog pin
                                    (void) analogRead(BATTERY_SENSE_PIN);
                                    // calculate battery voltage
                                    float vBat  = static_cast<float>(sensorValue * (V_MAX/1023));
                                  12.5k
