  2. Bug Reports
  3. Possible Bug version 2.2.0
38 Posts 4 Posters 7.5k Views 3 Watching
  • S Offline
    sindrome73
    Good morning, for one of my Weather Station (very early stage) I used the code below. Which works perfectly with MySensors 2.1.1
    Yesterday I updated my Arduino IDE to Version 2.2.0 and when I try to compile the code it goes, but once loaded the scketch on my arduino Pro, it does not work, while reloading the code compiled with MySensors 2.1.1 It works !!
    I think there is something wrong with the latest version of Mysensors
    // ---- - Stazione Meteo Francy Ver 1 - ----
    // Enable debug prints
    #define MY_PARENT_NODE_ID 0
    #define   MY_RF24_CHANNEL 84
    #define MY_SIGNING_SOFT
    // Definisco il Nodo
    #define MY_NODE_ID 66
    // Nomino i figli del Nodo
    #define CHILD_ID_TEMP 1
    #define CHILD_ID_aaaa 2
    #define CHILD_ID_HUMI 3
    #define CHILD_ID_bbbb 4
    #define CHILD_ID_BARO 5
    #define CHILD_ID_LIGHT 6
    const float ALTITUDE = 335;
    //----------------------------- Pressione
    //float pressione = 1017;
    //int forecast = 4;
    const char *weather[] = { "stable", "sunny", "cloudy", "unstable", "thunderstorm", "unknown" };
    enum FORECAST
        STABLE = 0,            // "Stable Weather Pattern"
        SUNNY = 1,            // "Slowly rising Good Weather", "Clear/Sunny "
        CLOUDY = 2,            // "Slowly falling L-Pressure ", "Cloudy/Rain "
        UNSTABLE = 3,        // "Quickly rising H-Press",     "Not Stable"
        THUNDERSTORM = 4,    // "Quickly falling L-Press",    "Thunderstorm"
        UNKNOWN = 5            // "Unknown (More Time needed)
    #include <Adafruit_BMP085.h>
    DHT dht;
    Adafruit_BMP085 bmp = Adafruit_BMP085();      // Digital Pressure Sensor
    float lastPressure = -1;
    float lastTemp = -1;
    int lastForecast = -1;
    const int LAST_SAMPLES_COUNT = 5;
    float lastPressureSamples[LAST_SAMPLES_COUNT];
    // this CONVERSION_FACTOR is used to convert from Pa to kPa in forecast algorithm
    // get kPa/h be dividing hPa by 10
    #define CONVERSION_FACTOR (1.0/10.0)
    int minuteCount = 0;
    bool firstRound = true;
    // average value is used in forecast algorithm.
    float pressureAvg;
    // average after 2 hours is used as reference value for the next iteration.
    float pressureAvg2;
    float dP_dt;
    bool metric;
    //Dichiarazioni per pause dei diversi blocchi
    unsigned long int time;
    unsigned long int lettura_Press;
    unsigned long int lettura_Temp;
    unsigned long int letturaluce_time;
    int lastLightLevel; //Dichiarazione Luminosita
    float temperatureDTH2;
      sendSketchInfo("Temp e Umidita", "3");
      present(CHILD_ID_aaaa, S_LIGHT);
      present(CHILD_ID_HUMI, S_HUM);
      present(CHILD_ID_bbbb, S_LIGHT);
      present(CHILD_ID_BARO, S_BARO);
    MyMessage msgaaaa(CHILD_ID_HUMI, V_LIGHT);
    MyMessage msgHumi(CHILD_ID_HUMI, V_HUM);
    MyMessage msgbbbb(CHILD_ID_HUMI, V_LIGHT);
    MyMessage msgPres(CHILD_ID_BARO, V_PRESSURE);
    MyMessage msgForecast(CHILD_ID_BARO, V_FORECAST);
    MyMessage msg4(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
      // Setto il Pin dove e collegato il sensore di Temperatura DHT22
      dht.setup(3);
      //Settaggi del BMP180
          if (!bmp.begin())
            Serial.println("Could not find a valid BMP085 sensor, check wiring!");
            while (1) {}
      //Fine settaggi BMP180
    //-- Setup Variabili MILLIS per sensore di Pressione
    time=millis();
    lettura_Press = millis();
    lettura_Temp = millis();
    letturaluce_time = millis();
    //Attivo Time MILLIS
    time=millis();
    //----------- Inizio DHT22 ------------------------
    if(time>lettura_Temp+12000){
    Serial.println("--- Temperatura ---  ");
    float temperatureDTH;
    float temperatureDHT = dht.getTemperature();
    temperatureDTH2 = temperatureDTH;
     //Invio la lettura della Temperatura
      send(msgTemp.set(temperatureDHT, 1));
      //delay(6000); // Faccio una pausa ed invio altra lettura
     //Invio lettura Umidita
      send(msgHumi.set(humidity, 1));
      //delay(4000);
    lettura_Temp=millis();
    //---------- Inizio Pressione ---------------------------
    if(time>lettura_Press+11000){
    Serial.println("--- Tempo passato lego la Pressione---  ");
    float temperatureDHT2;
    float pressure = bmp.readSealevelPressure(ALTITUDE) / 100.0;
    float temperature = temperatureDHT2;
    if (!metric)
            // Convert to fahrenheit
            temperature = temperature * 9.0 / 5.0 + 32.0;
    int forecast = sample(pressure);
        Serial.print("Pressione = ");
        Serial.print(pressure);
        Serial.println(" hPa");
        Serial.print("Forecast = ");
     if (pressure != lastPressure)
            send(msgPres.set(pressure, 0));
            lastPressure = pressure;
    if (forecast != lastForecast)
            send(msgForecast.set(weather[forecast]));
            lastForecast = forecast;
    lettura_Press=millis();
    //-------------- Inizio Luminosita --------------------------
    if(time>letturaluce_time+10000){
    Serial.print("Tempo passato lego la Luce: ");
            int16_t lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
        Serial.println(lightLevel);
        //delay(1000);
           if(lightLevel > lastLightLevel + 7 || lightLevel < lastLightLevel - 7){
            send(msg4.set(lightLevel));
            Serial.print("Invio nuova lettura LUX: ");
            lastLightLevel = lightLevel;
    letturaluce_time=millis();
        //Fine Luminosita
    //--------- Eventuale 4 Modulo -------------------------
    // Chiusura Loop
    //------------ Aggiuntivo Previsione del Barometro ---------------------
    float getLastPressureSamplesAverage()
        float lastPressureSamplesAverage = 0;
        for (int i = 0; i < LAST_SAMPLES_COUNT; i++)
            lastPressureSamplesAverage += lastPressureSamples[i];
        lastPressureSamplesAverage /= LAST_SAMPLES_COUNT;
        return lastPressureSamplesAverage;
    // Algorithm found here
    // Pressure in hPa -->  forecast done by calculating kPa/h
    int sample(float pressure)
        // Calculate the average of the last n minutes.
        int index = minuteCount % LAST_SAMPLES_COUNT;
        lastPressureSamples[index] = pressure;
        minuteCount++;
        if (minuteCount > 185)
            minuteCount = 6;
        if (minuteCount == 5)
            pressureAvg = getLastPressureSamplesAverage();
        else if (minuteCount == 35)
            float lastPressureAvg = getLastPressureSamplesAverage();
            float change = (lastPressureAvg - pressureAvg) * CONVERSION_FACTOR;
                dP_dt = change * 2; // note this is for t = 0.5hour
                dP_dt = change / 1.5; // divide by 1.5 as this is the difference in time from 0 value.
        else if (minuteCount == 65)
                dP_dt = change; //note this is for t = 1 hour
                dP_dt = change / 2; //divide by 2 as this is the difference in time from 0 value
        else if (minuteCount == 95)
                dP_dt = change / 1.5; // note this is for t = 1.5 hour
                dP_dt = change / 2.5; // divide by 2.5 as this is the difference in time from 0 value
        else if (minuteCount == 125)
            pressureAvg2 = lastPressureAvg; // store for later use.
                dP_dt = change / 2; // note this is for t = 2 hour
                dP_dt = change / 3; // divide by 3 as this is the difference in time from 0 value
        else if (minuteCount == 155)
                dP_dt = change / 2.5; // note this is for t = 2.5 hour
                dP_dt = change / 3.5; // divide by 3.5 as this is the difference in time from 0 value
        else if (minuteCount == 185)
                dP_dt = change / 3; // note this is for t = 3 hour
                dP_dt = change / 4; // divide by 4 as this is the difference in time from 0 value
            pressureAvg = pressureAvg2; // Equating the pressure at 0 to the pressure at 2 hour after 3 hours have past.
        int forecast = UNKNOWN;
            forecast = UNKNOWN;
        else if (dP_dt < (-0.25))
            forecast = THUNDERSTORM;
        else if (dP_dt > 0.25)
            forecast = UNSTABLE;
            forecast = CLOUDY;
            forecast = SUNNY;
        else if ((dP_dt >(-0.05)) && (dP_dt < 0.05))
            forecast = STABLE;
            forecast = UNKNOWN;
        // uncomment when debugging
        Serial.print(F("Forecast at minute "));
        Serial.print(minuteCount);
        Serial.print(F(" dP/dt = "));
        Serial.print(dP_dt);
        Serial.print(F("kPa/h --> "));
        return forecast;
    alexsh1A A 2 Replies Last reply
    • S sindrome73
      //int forecast = 4;
      enum FORECAST
      DHT dht;
      float pressureAvg;
      float pressureAvg2;
      float dP_dt;
      bool metric;
        dht.setup(3);
            if (!bmp.begin())
              while (1) {}
      time=millis();
      time=millis();
        //delay(4000);
      if (!metric)
          //delay(1000);
          //Fine Luminosita
      // Chiusura Loop
          minuteCount++;
              minuteCount = 6;
              forecast = UNKNOWN;
              forecast = CLOUDY;
              forecast = SUNNY;
              forecast = STABLE;
              forecast = UNKNOWN;
          return forecast;
      alexsh1A Offline
      alexsh1A Offline
      alexsh1
      @sindrome73 it does not work is a large statement. Did you try different Arduino? Logs?
      • S sindrome73
        //int forecast = 4;
        enum FORECAST
        DHT dht;
        float pressureAvg;
        float pressureAvg2;
        float dP_dt;
        bool metric;
          dht.setup(3);
              if (!bmp.begin())
                while (1) {}
        time=millis();
        time=millis();
          //delay(4000);
        if (!metric)
            //delay(1000);
            //Fine Luminosita
        // Chiusura Loop
            minuteCount++;
                minuteCount = 6;
                forecast = UNKNOWN;
                forecast = CLOUDY;
                forecast = SUNNY;
                forecast = STABLE;
                forecast = UNKNOWN;
            return forecast;
        A Offline
        A Offline
        Anticimex
        @sindrome73 you use signing? Have you followed the signing migration guide for 2.1 to 2.2?
        https://forum.mysensors.org/topic/7843/security-migrating-from-library-version-2-1-to-2-2
        alexsh1A S 2 Replies Last reply
        • A Anticimex
          alexsh1A Offline
          alexsh1A Offline
          alexsh1
          @anticimex Just out of curiosity - what happens if re-personalisation is not done after moving to 2.2.0? Signing fails?
          A 1 Reply Last reply
          • alexsh1A alexsh1
            A Offline
            A Offline
            Anticimex
            @alexsh1 checksum verification for the signing backend will fail and signing will not operate
            alexsh1A 1 Reply Last reply
            • A Anticimex
              alexsh1A Offline
              alexsh1A Offline
              alexsh1
              @anticimex OK, but if the GW is still on 2.1.1 and nodes are 2.2.0 it should be fine, right?
              • alexsh1A alexsh1
                A Offline
                A Offline
                Anticimex
                @alexsh1 if the 2.2 node has correct checksum yes. And this is shown in the debug log.
                • A Anticimex
                  sindrome73
                  @anticimex
                  532/5000
                  I made the customization from the beginning, with MySensors 2.2.0
                  I followed these steps:
                  • The EEPROM has been deleted
                  • Open SecurityPersonalize.ino inserted the new Key
                  • loaded the scketch and it does not go
                  I redid the same procedure above, then EEprom deleted, SecurityPersonalize file, and loaded the scketch, but this time using Mysensors 2.1.1
                  And here it worked ..... The same thing I did on Several Pro Mini at 5V 16Mhz and the result is the same ..... That's why I assume there may be something wrong with 2.2.0
                  • S sindrome73
                    @anticimex
                    532/5000
                    A Offline
                    A Offline
                    Anticimex
                    @sindrome73 2.2 works. At least signing. Log please.
                    • S Offline
                      sindrome73
                      I apologize, but I did not understand what you tell me ....
                      I would like to add that the script without the signature with the 2.2 version works, while the signature works only with MySensors 2.1
                      • S sindrome73
                        A Offline
                        A Offline
                        Anticimex
                        @sindrome73 log please.
                        • S Offline
                          sindrome73
                          In the evening ..... Now I'm at work and I can not
                          • S sindrome73
                            A Offline
                            A Offline
                            Anticimex
                            @sindrome73 no problem
                            • S Offline
                              sindrome73
                              Here I am at home .... I proceeded to redo the procedure and this sot is the log ....
                              I had to put an image because the last signs that mida I can not copy them as text ....
                              • S sindrome73
                                A Offline
                                A Offline
                                Anticimex
                                @sindrome73 log looks pretty corrupt, but I can't find any signing related messages so it would seem signing is not enabled on the node. Do you have a log from the GW? Is it also running 2.2.0?
                                • S sindrome73
                                  A Offline
                                  A Offline
                                  Anticimex
                                  @sindrome73 sorry, the capabilities string indicate software signing. But I don't see the backend initialization message. Could you please enable verbose signing debug?
                                  • S Offline
                                    sindrome73
                                    tell me how to abbilitate the detailed signature debug .....
                                    • S sindrome73
                                      A Offline
                                      A Offline
                                      Anticimex
                                      @sindrome73 https://www.mysensors.org/apidocs-beta/group__MySigningTroubleshootinggrp.html
                                      • S Offline
                                        sindrome73
                                        Here is the log with the Debug signed abbreviation.
                                        I specify that I had to disable // # define MY_DEBUG because the scketch is too big
                                        • S sindrome73
                                          A Offline
                                          A Offline
                                          Anticimex
                                          @sindrome73 signing messages look sane. But the logs look very corrupt. It also looks like the sketch crashed and restarted so I suspect you are running out of stack space. The arduino IDE reports and warns about memory usage and I suspect you get a warning on that.
                                          12.2k
