  2. Bug Reports
  3. Possible Bug version 2.2.0
38 Posts 4 Posters 8.1k Views 3 Watching
  • AnticimexA Anticimex
    @sindrome73 you use signing? Have you followed the signing migration guide for 2.1 to 2.2?
    https://forum.mysensors.org/topic/7843/security-migrating-from-library-version-2-1-to-2-2
    alexsh1A
    alexsh1A
    alexsh1
    @anticimex Just out of curiosity - what happens if re-personalisation is not done after moving to 2.2.0? Signing fails?
    AnticimexA 1 Reply Last reply
    • alexsh1A alexsh1
      AnticimexA
      AnticimexA
      Anticimex
      @alexsh1 checksum verification for the signing backend will fail and signing will not operate
      alexsh1A 1 Reply Last reply
        alexsh1A
        alexsh1A
        alexsh1
        @anticimex OK, but if the GW is still on 2.1.1 and nodes are 2.2.0 it should be fine, right?
        • alexsh1A alexsh1
          AnticimexA
          AnticimexA
          Anticimex
          @alexsh1 if the 2.2 node has correct checksum yes. And this is shown in the debug log.
            sindrome73
            @anticimex
            532/5000
            I made the customization from the beginning, with MySensors 2.2.0
            I followed these steps:
            • The EEPROM has been deleted
            • Open SecurityPersonalize.ino inserted the new Key
            • loaded the scketch and it does not go
            I redid the same procedure above, then EEprom deleted, SecurityPersonalize file, and loaded the scketch, but this time using Mysensors 2.1.1
            And here it worked ..... The same thing I did on Several Pro Mini at 5V 16Mhz and the result is the same ..... That's why I assume there may be something wrong with 2.2.0
            • S sindrome73
              @anticimex
              532/5000
              AnticimexA
              AnticimexA
              Anticimex
              @sindrome73 2.2 works. At least signing. Log please.
                sindrome73
                I apologize, but I did not understand what you tell me ....
                I would like to add that the script without the signature with the 2.2 version works, while the signature works only with MySensors 2.1
                • S sindrome73
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @sindrome73 log please.
                    sindrome73
                    In the evening ..... Now I'm at work and I can not
                    • S sindrome73
                      AnticimexA
                      AnticimexA
                      Anticimex
                      @sindrome73 no problem
                        sindrome73
                        Here I am at home .... I proceeded to redo the procedure and this sot is the log ....
                        I had to put an image because the last signs that mida I can not copy them as text ....
                        • S sindrome73
                          AnticimexA
                          AnticimexA
                          Anticimex
                          @sindrome73 log looks pretty corrupt, but I can't find any signing related messages so it would seem signing is not enabled on the node. Do you have a log from the GW? Is it also running 2.2.0?
                          • S sindrome73
                            AnticimexA
                            AnticimexA
                            Anticimex
                            @sindrome73 sorry, the capabilities string indicate software signing. But I don't see the backend initialization message. Could you please enable verbose signing debug?
                              sindrome73
                              tell me how to abbilitate the detailed signature debug .....
                              • S sindrome73
                                AnticimexA
                                AnticimexA
                                Anticimex
                                @sindrome73 https://www.mysensors.org/apidocs-beta/group__MySigningTroubleshootinggrp.html
                                  sindrome73
                                  Here is the log with the Debug signed abbreviation.
                                  I specify that I had to disable // # define MY_DEBUG because the scketch is too big
                                  • S sindrome73
                                    AnticimexA
                                    AnticimexA
                                    Anticimex
                                    @sindrome73 signing messages look sane. But the logs look very corrupt. It also looks like the sketch crashed and restarted so I suspect you are running out of stack space. The arduino IDE reports and warns about memory usage and I suspect you get a warning on that.
                                      sindrome73
                                      Yes indeed I have already said this !! So true that to have the DEBUG of the signature I had to disable the DEBUG.
                                      But with this same script, and going to Mysensors 2.1 it works !!
                                      • S sindrome73
                                        AnticimexA
                                        AnticimexA
                                        Anticimex
                                        @sindrome73 you could try to completely disable debug on your node and observe the behavior of your gw or controller.
                                          sindrome73
                                          Ok .... Tomorrow I'll do it ..... But it will be difficult to have the Gateway Log because with the signature enabled, the sketch is very large, and does not allow me to activate the Debug ....
